I connected DM-M10R800 LVDS LCD with AIO-3399J Board.
and powered up. and booting… but LVDS LCD did not work.
No response. what do I check?
thanks.. can I use LCD with Linux ubuntu?
Is the command same with android?
I hope Linux ubuntu Image that supports LVDS LCD display funtion
eschoi@huvitz.c Posted at 8/24/2018 19:11
Linux Image will be released. Be patient .You can do it yourself. Just use the dts rk3399-firefly-aio-3399j-lvds.dts
leung先森 Posted at 8/27/2018 10:55
Linux Image will be released. Be patient .You can do it yourself. Just use the dts rk3399-firefl …
I tried with command below
make rk3399-firefly-aio-linux-lvds.img -j4
but no response, no backlight, no display
what can I do next?
eschoi@huvitz.c Posted at 9/5/2018 10:48
but no response, no backli …
rk3399-firefly-aio-linux-lvds.rar (7.13 KB)
thanks…I found solutiion..
I need to change PWM default-brightness-level from 200 to 100
and then backlight was turned on
No doubt this is an excellent article, I have gained a lot of knowledge after reading Good luck. The topic of the blog is great, there is almost everything to read. thanks! run 3
Your article was so impactful, thank you for sharing it. Downloadable C-BCBDC-2505 PDF helped me get ahead in my career and earn more. Now, I’m offering it to you for free!
Pass4Tes가 제공하는 제품을 사용함으로 여러분은 IT업계하이클래스와 멀지 않았습니다. Pass4Tes 가 제공하는 인증시험덤프는 여러분을SAP인증C_P2WWM_2023시험을 안전하게 통과는 물론 관연전업지식장악에도 많은 도움이 되며 또한 우리는 일년무료 업뎃서비스를 제공합니다.
350-701J認定試験に関連する参考資料を提供できるサイトが多くあります。しかし、資料の品質が保証されることができません。それと同時に、あなたに試験に失敗すれば全額返金という保障を与えることもできません。普通の参考資料と比べて、Pass4Testの350-701J問題集は最も利用に値するツールです。Pass4Testの指導を元にして、あなたは試験の準備を十分にすることができます。しかも、楽に試験に合格することができます。IT領域でより大きな進歩を望むなら、350-701J認定試験を受験する必要があります。IT試験に順調に合格することを望むなら、Pass4Testの350-701J問題集を使用する必要があります。
