I have spent many hours and am extremely frustrated. I installed image “ROC-RK3328-CC_Debian9-Arch64_20180525.img” on a new Renegade board and plugged in a compatible USB Wireless adapter “Ralink Technology, Corp. MT7601U Wireless Adapter” but when I run ‘ifconfig -a’ or ‘iwconfig’ I am only showing lo and eth0.
Everything looks right, can anyone help what I am missing???
apt-get install firmware-misc-nonfree (installed)
lsusb
Bus 001 Device 002: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
The OS’s are experimental at this point. It is possible it is broken. Try updating through wired connection, it may fix things. If that doesn’t do it, try a different OS. I’m using Arrmbian booting off external HD on the USB 3.0 (very fast!). It’s not perfect eg (video choppy, and wont run Kodi yet) Can’t tell you if if wi/fi works thorough. I never use it. Wired is healthier for you and,faster. I’m not connected to this site so, you my get better advice but, I see lots of unanswered posts here though.
Hi!
Sorry for opening this post again, but I still have this problem. I tried with the image perello left there, but no wlan in ifconfig or anything else.
I read in another forum which drivers are already installed in ubuntu images (http://forum.loverpi.com/discuss … 4-114-linux-headers) , and I bought a wifi dongle with a RTL8811AU chip, with no luck at all.
How have you managed to solve it?
I am completely lost…
What’s the kernel message when you plug in the wifi dongle?
This is the message for the RTL8811AU wifi dongle:
dmesg
[ 7919.892530] usb 4-1: new high-speed USB device number 3 using xhci-hcd
[ 7920.005845] usb 4-1: New USB device found, idVendor=0bda, idProduct=c811
[ 7920.005856] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7920.005862] usb 4-1: Product: 802.11ac NIC
[ 7920.005868] usb 4-1: Manufacturer: Realtek
[ 7920.005873] usb 4-1: SerialNumber: 123456
I also installed the package rtl8812au-dkms, but the result it was the same as before:
firefly@firefly:~$ lsmod
Module Size Used by
8812au 1019904 0
firefly@firefly:~$ uname -r
4.4.114
firefly@firefly:~$ lsusb
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 003: ID 0bda:c811 Realtek Semiconductor Corp. <---this is the wifi dongle
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 046d:c062 Logitech, Inc. M-UAS144 [LS1 Laser Mouse]
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 04d9:a088 Holtek Semiconductor, Inc.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
firefly@firefly:~$ iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
firefly@firefly:~$
For the TP-Link WIFI (chipset MT7610u) the message is the following:
[ 8803.151433] usb 4-1: new high-speed USB device number 4 using xhci-hcd
[ 8803.264833] usb 4-1: New USB device found, idVendor=2357, idProduct=011e
[ 8803.264844] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8803.264849] usb 4-1: Product: 802.11ac WLAN Adapter
[ 8803.264855] usb 4-1: Manufacturer: Realtek
[ 8803.264861] usb 4-1: SerialNumber: 00e04c000001
But I am afraid a noob in terms of modifying kernels.
What should I do exactly? Do I have to download a clean ubuntu image and then compile the kernel manually like the instructions of the webpage you have posted? But how can I add the drivers there?
I’m so grateful for your article, it truly grabbed my attention. Upgrade your IT skills with free SecOps-Pro excellect pass rate. Wishing you good luck in your exams!
