LCD Backlight Error => Solved
I am working with AIO-3399J and DM-M10R800
I compiled with rk3399-firefly-aio-linux-lvds.dts
and I checked lcd_pwr_en is high , VDD-CORE is 1.2V , lcd_rst is high, 1.8V
and I checked LCD Board VGH =>5.59V , VGL=>-5.6V
AVDD=>11.2V ,VCC_LCD=>3.2V, LED+ => 4.97V, LED- =>0.0V
But LCD backlight is not working. tured off.
what position should I check?
I want to turn on LCD
1.edit rk3399-firefly-aio-linux-lvds.dts backlight: backlight { status = "okay"; compatible = "pwm-backlight"; pwms = <&pwm0 0 25000 1>; brightness-levels = </* 0 1 2 3 4 5 6 7 248 249 250 251 252 253 254 255>; default-brightness-level = <200>; => default-brightness-level = <100>; 2.check LED+ of LCD Board LED+ voltalge should be higher than 11v when default-brightness-level is 200, 78% duty, LED+ voltage is 4.9v => backlight turned off but if default-brightness-level is 100, 40% duty,LED+ voltage is 11.4v => backlight turned on ![pwm.jpg|697x309](upload://3IFa74mnLgoZ9SUebp870D1z0Q2.jpeg) Success!!!!!!!! ![lcd_on.jpg|159x242](upload://yYrqt0lciOymqQtOm933RR25xMC.jpeg)
Have you fixed it yet? I was playing Chill Guy Clicker and my computer had the same problem as yours. Please help me.
Welcome to Quick Draw ! This is the perfect game for those who are passionate about art and love to challenge their intelligence. With each passing second, you will have to draw images for AI to guess. Can you complete them quickly and accurately to prove your talent?
LCD backlight error, solved! A common issue with a simple fix, often involving replacing the inverter or checking connections. Celebrate the win with a game of Wordle Unlimited to sharpen your deduction skills. Now, enjoy that perfectly illuminated display.
I appreciate your work. Your posts are very interesting and I must say you have done an amazing job. I think this is one of the most positive blogs I have come across. fireboy and watergirl
Make sure the data lines (MIPI, LVDS, etc.) that connect the AIO-3399J to the DM-M10R800 are not broken and are properly linked wordle hint. Look at the connecting pins to see if there are any loose connections or shorts.
Great technical breakdown — you’ve clearly done thorough voltage checks on the AIO-3399J setup. It reminds me of how Remark Construction approaches troubleshooting: methodical and precise. Maybe double-check the backlight enable signal or PWM control line; that’s often the missing piece when all the voltages look right but the LCD stays dark.
요즘같이 시간인즉 금이라는 시대에 시간도 절약하고 빠른 시일 내에 학습할 수 있는 PassTIP의 덤프를 추천합니다. 귀중한 시간절약은 물론이고 한번에SAP C_BCSSS_2502인증시험을 패스함으로 여러분의 발전공간을 넓혀줍니다.
This is an inspiring article, and I’m grateful for your share! Taking the Certification Plat-Admn-201 exam dumps exam soon, hope I’ll do well!
This is top-tier content, I’m liking it immediately. Latest testcollection C-THR88-2505 provides a range of useful materials for free, hoping they help you progress.
