Mutil-Boot is developed for the firefly hardware platform. It can realize online installation and startup of multiple systems. The interface design is simple and easy to operate. It is easy for beginners to get started with multiple operating systems.
----------------------------- Dividing Line ----------------------------
▍System login
Linux system requires a login password (the Armbian system also needs to be initialized)
1. Ubuntu
(default username: firefly, password: firefly)
2. Debian
3. Armbian Stretch
A lightweight Debian for ARM development boards. You need to set the user and password according to the
system prompts to complete the initialization. (Default username: root, password: 1234)
4. OpenMediaVault
A network attached storage (NAS) system that requires remote access via the web
(default username: admin, password: openmediavault)
No possibility to use android or ubuntu in multy boot ?
the system OS where a lot of part are still in chinese (?), even when you configure the language in English ?
Issue (for not say impossibility) for the use of the camera with MIPI sell with the RK3399 under ubuntu (yes apparently somebody succeed to make it work for ONE camera) that still don’t have solution ? ( by the way since the start of the sells of those camera when will we have a tuto or a driver for this?)
(and I don’t speak about the fact that the board reboot continuously when you press shutdown (still under ubuntu) if you don’t unplug the power source)
do you want to kill your product ? because it’s how you do.
PS: people can understand that there aren’t a big dev team and the fact that you can meet a lot of issue but don’t advertise something that doesn’t work.
Hi Yolo19048, this is one of the most thoughtful comments I have ever seen. Thank you very much, we are constantly optimizing the system and trying to give users a better experience.
in the version of the image that I downloaded and that you propose here, there is only OpenMediaVault, Armbian stretch and Station OS. There is NOT Ubuntu nor Android as in the photos you show. So we have only 3 option to install and not 5 as in the photos.
Good time of day. Tell me, is this project still supported? Is there an update? What systems does it currently support? Thank you in advance for the answer.
This article is absolutely amazing, thank you for sharing it with us. Good luck to me on my Certification MuleSoft-Integration-Architect-I dump exam! Hoping for great results!
