Cannot activate Mobile broadband connection
Hello everyone,
I’ve just received a AIO3399 board and I’m not able to activate mobile broadband connection.
After the board is on I’m asked for kerying key wich I provide then I’m asked for a mobile broadband password.
I tried using the information available from ISP concerning APN configuration but with no sccess.
By the way, when using android the sim card works fine.
Any thoughts on this?
AIO-3399J_xubuntu16.04_20180910.7z
Flash this firmware
This is exactly the firmware I’m using.
While checking the network manager debug log I found this error message before connection failure:
“Connection requested IPv4 but IPv4 is not supported by the modem.”
Your article is simply remarkable, thank you for sharing it! I hope the Professional-Cloud-Developer latest exam registration content helps you, and best of all, it’s free!
Your article was so impressive, I’m deeply thankful. Boost your IT skills and enjoy free Reliable FCSS_LED_AR-7.6 test prep. Best of luck to you!
Thank you for sharing this inspiring article with us! Free MB-330 exam introduction test papers—your ticket to promotions and a higher salary!
Thank you for sharing this truly remarkable article! The EX-Con-101 valid mock exam test led to my promotion and salary increase. Today, I’m giving it away for free to help you too!
Thank you for bringing such an extraordinary article! Wishing everyone the best of luck! Free D-VXR-DS-00 reliable test sample questions questions are available!
The article was incredibly valuable to me. The Latest Arch-301 test blueprint content is fantastic and free, and I hope it helps you.
ITDumpsKR Fortinet인증NSE4_FGT_AD-7.6시험덤프 구매전 구매사이트에서 무료샘플을 다운받아 PDF버전 덤프내용을 우선 체험해보실수 있습니다. 무료샘플을 보시면ITDumpsKR Fortinet인증NSE4_FGT_AD-7.6시험대비자료에 믿음이 갈것입니다.고객님의 이익을 보장해드리기 위하여ITDumpsKR는 시험불합격시 덤프비용전액환불을 무조건 약속합니다. ITDumpsKR의 도움으로 더욱 많은 분들이 멋진 IT전문가로 거듭나기를 바라는바입니다.
