Hi,
I’m trying to compile an RK3399 image as described in http://wiki.t-firefly.com/ROC-RK … ompile_firmware.htm and http://opensource.rock-chips.com/wiki_Linux_user_guide. We have created custom hardware using the RK3399 CPU. When starting up a default generated kernel, it will stop when trying to find the serial ports. The last lines it prints is:
[ 0.900624] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.901293] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.903508] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.904188] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.906020] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.908085] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 0.909184] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-debugger; cannot claim for ff1a0000.smria▒▒
0(0.▒̰140],vocml▒ip-pko▒▒l`pyngu▒l▒▒py~-37s▒▒ff1y<63̗▒▒▒yy|-&w▒غ▒▒▒mr:▒`08<>/;▒̳▒▒▒▒▒▒▒sxy|?~o▒▒▒▒▒▒py▒▒▒|_?▒|x~'▒▒▒▒▒▒▒x~/▒▒▒▒▒~▒▒▒▒}??/▒▒▒▒▒?▒▒▒▒▒▒▒▒▒|~??▒▒▒▒▒▒▒▒▒▒|▒▒▒▒▒▒▒▒~~~?▒▒▒▒▒▒▒▒▒▒▒▒~▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒
The characters that aren’t correct (that garbled mess) are never the same. But what follows are always some random ASCII characters.
When I then disable some things of FIQ, the kernel won’t start.
I tried to see what would happen if I told the kernel to limit the amount of ports for the serial 8250 driver to zero, and I get the following result:
[ 0.905219] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.905889] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.908140] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.908821] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.911054] dw-apb-uart: probe of ff180000.serial failed with error -28
[ 0.911728] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-debugger; cannot claim for ff1a0000.serial
[ 0.912680] rockchip-pinctrl pinctrl: pin-147 (ff1a0000.serial) status -22
[ 0.913296] rockchip-pinctrl pinctrl: could not request pin 147 (gpio4-19) from group uart2c-xfer on device rockchip-pinctrl
[ 0.913293] dw-apb-uart ff1a0000.serial: Error applying setting, reverse things back
[!▒▒▒p>=75▒0▒] /c▒▒-▒▒▒t:,vs▒l▒▒▒fv9m6̟8gs▒ض▒▒▒y|}n#▒▒▒▒`uzzo
For some reason, it got further into the kernel without corrupting my serial output.
I then saw what happend if I disabled everything from my serial driver, and now, it will skip the part that corrupted my output (like it should), but it got corrupted a few lines later:
[ 0.900572] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.901242] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.903530] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.904199] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.906253] [drm] Initialized drm 1.1.0 20060810
0.909842] rockchip-▒r}0lmws▒▒y▒▒ubsvg▒▒▒c
y{,dksر▒▒d-▒Р▒▒▒▒yyx8=>]<ooooo▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒|▒▒~|}~~>?????▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒
This is where I’m stuck. At first I thought the FIQ debugger was the problem, but with that last image, I have no idea where to look.
THE FULL LOGS WITH THE DEFAULT IMAGE (FIQ on, UART PORTS 5)
DDR Version 1.08 20170320
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
Boot1: 2017-04-07, version: 1.06
CPUId = 0x0
ChipType = 0x10, 1825
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
FwPartOffset=2000 , 100000
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
FwPartOffset=2000 , 0
StorageInit ok = 311038
LoadTrustBL
No find bl30.bin
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):65aa5ce
NOTICE: BL31: Built : 10:47:37, Jun 19 2018
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1151): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-170-gc4654a6 #16 Wed May 30 08:54:30 UTC 2018 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2017.09-01874-ga60b58c (Aug 16 2018 - 15:49:09 +0200)
Model: Firefly-RK3399 Board
DRAM: 2 GiB
Relocation Offset is: 7fd15000
rk8xx_read: read reg 0x17 failed, ret=-121
MMC: dwmmc@fe320000: 1, sdhci@fe330000: 0
invalid parameter
*** Warning - bad CRC, using default environment
In: serial@ff1a0000
Out: serial@ff1a0000
Err: serial@ff1a0000
switch to partitions #0, OK
mmc1 is current device
do_rkimg_test found IDB in SDcard
Boot from SDcard
get part misc fail -1
Net: eth0: ethernet@fe300000
android_bootloader_boot_flow Could not find misc partition
ANDROID: reboot reason: "(none)"
** Invalid Android Image header **
android_bootloader_boot_flow boot part load fail
=Booting Rockchip format image=
boot_rockchip_image kernel or boot part info error
Scanning mmc 1:4...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
214 bytes read in 3 ms (69.3 KiB/s)
1: kernel-4.4
Retrieving file: /Image
reading /Image
17936392 bytes read in 752 ms (22.7 MiB/s)
append:
earlyprintk console=ttyFIQ0,1500000n8 rw
root=PARTUUID=B921B045-1DF0-41C3-AF44-4C6F280D3FAE rootfstype=ext4
init=/sbin/init rootwait
Retrieving file: /rk3399-firefly-linux.dtb
reading /rk3399-firefly-linux.dtb
75364 bytes read in 7 ms (10.3 MiB/s)
## Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
Loading Device Tree to 00000000081ea000, end 00000000081ff663 ... OK
Adding bank: start=0x00200000, size=0x08200000
Adding bank: start=0x0a200000, size=0x75e00000
Starting kernel ...
0.000000] Linux version 4.4.114 (test@test-VirtualBox) (gcc version
5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.9) ) #37 SMP Wed Sep
19 07:57:22 CEST 2018
[ 0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fef6000 s45800 r8192 d32024 u86016
0.000000] Kernel command line: earlyprintk console=ttyFIQ0,1500000n8
rw root=PARTUUID=B921B045-1DF0-41C3-AF44-4C6F280D3FAE rootfstype=ext4
[ 0.000000] software IO TLB [mem 0x79a00000-0x7da00000] (64MB) mapped at [ffffffc079a00000-ffffffc07d9fffff]
0.000000] Memory: 1943148K/2064384K available (10814K kernel code,
1580K rwdata, 4016K rodata, 1088K init, 729K bss, 121236K reserved, 0K
cma-reserved)
[ 0.000000] .init : 0xffffff8008f00000 - 0xffffff8009010000 ( 1088 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b10000 ( 10816 KB)
[ 0.000000] .rodata : 0xffffff8008b10000 - 0xffffff8008f00000 ( 4032 KB)
[ 0.000000] .data : 0xffffff8009010000 - 0xffffff800919b008 ( 1581 KB)
[ 0.000000] ITS: allocated 65536 Devices @a300000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000000a290000
[ 0.000000] CPU0: using LPI pending table @0x000000000a2a0000
0.000000] rockchip_clk_register_frac_branch: could not find
dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[ 0.001270] Console: colour dummy device 80x25
[ 0.001294] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.001306] pid_max: default: 32768 minimum: 301
[ 0.001454] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.001465] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.002147] Initializing cgroup subsys devices
[ 0.002164] Initializing cgroup subsys freezer
[ 0.002189] ftrace: allocating 39257 entries in 154 pages
[ 0.098517] sched-energy: Sched-energy-costs installed from DT
[ 0.098533] CPU0: update cpu_capacity 401
[ 0.098588] ASID allocator initialised with 32768 entries
[ 0.101445] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.101929] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.103146] Detected VIPT I-cache on CPU1
[ 0.103178] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.103206] CPU1: using LPI pending table @0x0000000000310000
[ 0.103247] CPU1: update cpu_capacity 401
[ 0.103251] CPU1: Booted secondary processor [410fd034]
[ 0.103781] Detected VIPT I-cache on CPU2
[ 0.103802] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.103829] CPU2: using LPI pending table @0x0000000000340000
[ 0.103856] CPU2: update cpu_capacity 401
[ 0.103859] CPU2: Booted secondary processor [410fd034]
[ 0.104374] Detected VIPT I-cache on CPU3
[ 0.104394] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.104421] CPU3: using LPI pending table @0x0000000000390000
[ 0.104446] CPU3: update cpu_capacity 401
[ 0.104450] CPU3: Booted secondary processor [410fd034]
[ 0.104957] Detected PIPT I-cache on CPU4
[ 0.104984] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.105023] CPU4: using LPI pending table @0x00000000003c0000
[ 0.105062] CPU4: update cpu_capacity 1024
[ 0.105066] CPU4: Booted secondary processor [410fd082]
[ 0.105597] Detected PIPT I-cache on CPU5
[ 0.105616] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.105652] CPU5: using LPI pending table @0x00000000003f0000
[ 0.105680] CPU5: update cpu_capacity 1024
[ 0.105683] CPU5: Booted secondary processor [410fd082]
[ 0.105769] Brought up 6 CPUs
[ 0.105848] SMP: Total of 6 processors activated.
[ 0.105857] CPU features: detected feature: GIC system register CPU interface
[ 0.105870] CPU: All CPU(s) started at EL2
[ 0.105916] alternatives: patching kernel code
[ 0.107281] devtmpfs: initialized
[ 0.121525] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.121549] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.122001] pinctrl core: initialized pinctrl subsystem
[ 0.122731] NET: Registered protocol family 16
[ 0.126841] cpuidle: using governor ladder
[ 0.130861] cpuidle: using governor menu
[ 0.130879] Registered FIQ tty driver
[ 0.131072] vdso: 2 pages (1 code @ ffffff8008b16000, 1 data @ ffffff8009014000)
[ 0.131100] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.131262] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.213709] console [ttyFIQ0] enabled
[ 0.214243] Registered fiq debugger ttyFIQ0
[ 0.243853] iommu: Adding device ff650000.vpu_service to group 0
[ 0.244467] iommu: Adding device ff660000.rkvdec to group 1
[ 0.245057] iommu: Adding device ff8f0000.vop to group 2
[ 0.245608] iommu: Adding device ff900000.vop to group 3
[ 0.247377] SCSI subsystem initialized
[ 0.247895] usbcore: registered new interface driver usbfs
[ 0.248417] usbcore: registered new interface driver hub
[ 0.248974] usbcore: registered new device driver usb
[ 0.303948] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.304869] NET: Registered protocol family 2
[ 0.305703] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.306421] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.307379] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.308047] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.308671] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.309507] NET: Registered protocol family 1
[ 0.310195] RPC: Registered named UNIX socket transport module.
[ 0.310735] RPC: Registered udp transport module.
[ 0.311151] RPC: Registered tcp transport module.
[ 0.311567] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.312678] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.313473] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.317447] Initialise system trusted keyring
[ 0.326210] NFS: Registering the id_resolver key type
[ 0.326696] Key type id_resolver registered
[ 0.327067] Key type id_legacy registered
[ 0.327484] fuse init (API version 7.23)
[ 0.328219] SGI XFS with security attributes, no debug enabled
[ 0.333387] NET: Registered protocol family 38
[ 0.333816] Key type asymmetric registered
[ 0.334193] Asymmetric key parser 'x509' registered
[ 0.334786] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.335447] io scheduler noop registered
[ 0.335810] io scheduler deadline registered
[ 0.336312] io scheduler cfq registered (default)
[ 0.338099] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 0.343254] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.343847] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.344424] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.886654] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.887378] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.889094] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.890017] rk-vcodec ff650000.vpu_service: probe device
[ 0.890540] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07923a410
[ 0.891390] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.891972] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 0.893139] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.893773] rk-vcodec ff650000.vpu_service: init success
[ 0.894646] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.895632] rk-vcodec ff660000.rkvdec: probe device
[ 0.896101] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07923ac10
[ 0.896834] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.897347] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 0.898190] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.898787] rk-vcodec ff660000.rkvdec: init success
[ 0(0.▒̰140],vocml▒ip-pko▒▒l`pyngu▒l▒▒py~-37s▒▒ff1y<63̗▒▒▒yy|-&w▒غ▒▒▒mr:▒`08<>/;▒̳▒▒▒▒▒▒▒sxy|?~o▒▒▒▒▒▒py▒▒▒|_?▒|x~'▒▒▒▒▒▒▒x~/▒▒▒▒▒~▒▒▒▒}??/▒▒▒▒▒?▒▒▒▒▒▒▒▒▒|~??▒▒▒▒▒▒▒▒▒▒|▒▒▒▒▒▒▒▒~~~?▒▒▒▒▒▒▒▒▒▒▒▒~▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒
THE FULL LOGS OF THE IMAGE W/O SERIAL DRIVERS (FIQ on, SERIAL_8250 off)
256B stride
CPUId = 0x0
ChipType = 0x10, 1839
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
StorageInit ok = 307676
LoadTrustBL
No find bl30.bin
RunBL31 0x10000
INF
INFO: SPSR = 0x3c9
DRAM: 2 GiB
invalid parameter
In: serial@ff1a0000
Boot from SDcard
Scanning mmc 1:4...
214 bytes read in 4 ms (51.8 KiB/s)
1: kernel-4.4
reading /Image
17911816 bytes read in 751 ms (22.7 MiB/s)
append:
Starting kernel ...
0.000000] Linux version 4.4.114 (marijn@marijn-VirtualBox) (gcc
version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.9) ) #38 SMP
Wed Sep 19 08:15:31 CEST 2018
0.000000] Memory: 1943176K/2064384K available (10814K kernel code,
1556K rwdata, 4000K rodata, 1088K init, 726K bss, 121208K reserved, 0K
cma-reserved)
[ 0.000000] .data : 0xffffff8009010000 - 0xffffff8009195008 ( 1557 KB)
[ 0.001255] Console: colour dummy device 80x25
[ 0.001273] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.001286] pid_max: default: 32768 minimum: 301
[ 0.001433] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.001444] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.002128] Initializing cgroup subsys devices
[ 0.002146] Initializing cgroup subsys freezer
[ 0.002172] ftrace: allocating 39001 entries in 153 pages
[ 0.097982] sched-energy: Sched-energy-costs installed from DT
[ 0.097999] CPU0: update cpu_capacity 401
[ 0.098055] ASID allocator initialised with 32768 entries
[ 0.100876] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.101332] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.102548] Detected VIPT I-cache on CPU1
[ 0.102580] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.102609] CPU1: using LPI pending table @0x0000000000310000
[ 0.102650] CPU1: update cpu_capacity 401
[ 0.102654] CPU1: Booted secondary processor [410fd034]
[ 0.103173] Detected VIPT I-cache on CPU2
[ 0.103194] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.103222] CPU2: using LPI pending table @0x0000000000330000
[ 0.103248] CPU2: update cpu_capacity 401
[ 0.103252] CPU2: Booted secondary processor [410fd034]
[ 0.103772] Detected VIPT I-cache on CPU3
[ 0.103792] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.103819] CPU3: using LPI pending table @0x0000000000380000
[ 0.103845] CPU3: update cpu_capacity 401
[ 0.103849] CPU3: Booted secondary processor [410fd034]
[ 0.104352] Detected PIPT I-cache on CPU4
[ 0.104379] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.104419] CPU4: using LPI pending table @0x00000000003c0000
[ 0.104458] CPU4: update cpu_capacity 1024
[ 0.104462] CPU4: Booted secondary processor [410fd082]
[ 0.104992] Detected PIPT I-cache on CPU5
[ 0.105010] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.105047] CPU5: using LPI pending table @0x00000000003f0000
[ 0.105073] CPU5: update cpu_capacity 1024
[ 0.105076] CPU5: Booted secondary processor [410fd082]
[ 0.105163] Brought up 6 CPUs
[ 0.105241] SMP: Total of 6 processors activated.
[ 0.105250] CPU features: detected feature: GIC system register CPU interface
[ 0.105263] CPU: All CPU(s) started at EL2
[ 0.105308] alternatives: patching kernel code
[ 0.106676] devtmpfs: initialized
[ 0.120968] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.120993] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.121447] pinctrl core: initialized pinctrl subsystem
[ 0.122186] NET: Registered protocol family 16
[ 0.126628] cpuidle: using governor ladder
[ 0.130638] cpuidle: using governor menu
[ 0.130656] Registered FIQ tty driver
[ 0.130844] vdso: 2 pages (1 code @ ffffff8008b16000, 1 data @ ffffff8009014000)
[ 0.130872] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.131032] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.213589] console [ttyFIQ0] enabled
[ 0.214122] Registered fiq debugger ttyFIQ0
[ 0.243712] iommu: Adding device ff650000.vpu_service to group 0
[ 0.244325] iommu: Adding device ff660000.rkvdec to group 1
[ 0.244910] iommu: Adding device ff8f0000.vop to group 2
[ 0.245469] iommu: Adding device ff900000.vop to group 3
[ 0.247225] SCSI subsystem initialized
[ 0.247740] usbcore: registered new interface driver usbfs
[ 0.248262] usbcore: registered new interface driver hub
[ 0.248821] usbcore: registered new device driver usb
[ 0.886500] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.887223] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.888943] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.889860] rk-vcodec ff650000.vpu_service: probe device
[ 0.890383] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07923a410
[ 0.891232] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.891812] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 0.892996] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.893630] rk-vcodec ff650000.vpu_service: init success
[ 0.894506] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.895470] rk-vcodec ff660000.rkvdec: probe device
[ 0.895945] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07923ac10
[ 0.896692] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.897207] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 0.898060] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.898659] rk-vcodec ff660000.rkvdec: init success
THE FULL LOGS W/O UART PORTS CONFIGURED (FIQ on, UART_PORTS 0)
256B stride
CPUId = 0x0
ChipType = 0x10, 1830
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
StorageInit ok = 312104
LoadTrustBL
No find bl30.bin
RunBL31 0x10000
INFO: SPSR = 0x3c9
DRAM: 2 GiB
invalid parameter
In: serial@ff1a0000
Boot from SDcard
Error: Bad gzipped data
FDT load addr 0x10f00000 size 262 KiB
Booting kernel at 0x207f800 with fdt at 32d8800...
## Booting Android Image at 0x0207f800 ...
Kernel load addr 0x02080000 size 18783 KiB
## Flattened Device Tree blob at 032d8800
Booting using the fdt blob at 0x32d8800
XIP Kernel Image ... OK
Loading Device Tree to 00000000081ea000, end 00000000081ff933 ... OK
Starting kernel ...
0.000000] Linux version 4.4.143 (marijn@marijn-VirtualBox) (gcc
version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #4 SMP Fri Aug 17
08:52:06 CEST 2018
[ 0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fef9000 s45800 r8192 d32024 u86016
0.000000] Kernel command line: sdfwupdate storagemedia=sd
androidboot.mode=sd androidboot.slot_suffix=
androidboot.serialno=e251fb7457dd2c0d rw rootwait
earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0
root=PARTUUID=614e0000-0000 rootfstype=ext4
[ 0.000000] software IO TLB [mem 0x7feb1000-0x7fef1000] (0MB) mapped at [ffffffc07feb1000-ffffffc07fef0fff]
0.000000] Memory: 2007524K/2064384K available (11518K kernel code,
1694K rwdata, 4400K rodata, 1088K init, 754K bss, 56860K reserved, 0K
cma-reserved)
[ 0.000000] .init : 0xffffff8008f80000 - 0xffffff80090a0000 ( 1152 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b60000 ( 11136 KB)
[ 0.000000] .rodata : 0xffffff8008b60000 - 0xffffff8008f80000 ( 4224 KB)
[ 0.000000] .data : 0xffffff80090a0000 - 0xffffff8009229808 ( 1575 KB)
[ 0.001257] Console: colour dummy device 80x25
[ 0.001276] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.001289] pid_max: default: 32768 minimum: 301
[ 0.001434] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.001445] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.002121] Initializing cgroup subsys devices
[ 0.002138] Initializing cgroup subsys freezer
[ 0.002163] ftrace: allocating 40726 entries in 160 pages
[ 0.102127] sched-energy: Sched-energy-costs installed from DT
[ 0.102143] CPU0: update cpu_capacity 401
[ 0.102198] ASID allocator initialised with 32768 entries
[ 0.105145] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.105615] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.106839] Detected VIPT I-cache on CPU1
[ 0.106872] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.106901] CPU1: using LPI pending table @0x0000000000310000
[ 0.106943] CPU1: update cpu_capacity 401
[ 0.106947] CPU1: Booted secondary processor [410fd034]
[ 0.107504] Detected VIPT I-cache on CPU2
[ 0.107525] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.107552] CPU2: using LPI pending table @0x0000000000340000
[ 0.107581] CPU2: update cpu_capacity 401
[ 0.107584] CPU2: Booted secondary processor [410fd034]
[ 0.108082] Detected VIPT I-cache on CPU3
[ 0.108102] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.108128] CPU3: using LPI pending table @0x0000000000390000
[ 0.108156] CPU3: update cpu_capacity 401
[ 0.108159] CPU3: Booted secondary processor [410fd034]
[ 0.108674] Detected PIPT I-cache on CPU4
[ 0.108701] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.108740] CPU4: using LPI pending table @0x00000000003c0000
[ 0.108779] CPU4: update cpu_capacity 1024
[ 0.108783] CPU4: Booted secondary processor [410fd082]
[ 0.109329] Detected PIPT I-cache on CPU5
[ 0.109347] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.109384] CPU5: using LPI pending table @0x00000000003f0000
[ 0.109411] CPU5: update cpu_capacity 1024
[ 0.109414] CPU5: Booted secondary processor [410fd082]
[ 0.109500] Brought up 6 CPUs
[ 0.109578] SMP: Total of 6 processors activated.
[ 0.109587] CPU features: detected feature: GIC system register CPU interface
[ 0.109600] CPU: All CPU(s) started at EL2
[ 0.109646] alternatives: patching kernel code
[ 0.111026] devtmpfs: initialized
[ 0.125367] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.125391] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.125848] pinctrl core: initialized pinctrl subsystem
[ 0.126587] NET: Registered protocol family 16
[ 0.131574] cpuidle: using governor ladder
[ 0.135583] cpuidle: using governor menu
[ 0.135599] Registered FIQ tty driver
[ 0.135788] vdso: 2 pages (1 code @ ffffff8008b66000, 1 data @ ffffff80090a4000)
[ 0.135815] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.135978] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.218372] console [ttyFIQ0] enabled
[ 0.218907] Registered fiq debugger ttyFIQ0
[ 0.248459] iommu: Adding device ff650000.vpu_service to group 0
[ 0.249074] iommu: Adding device ff660000.rkvdec to group 1
[ 0.249661] iommu: Adding device ff8f0000.vop to group 2
[ 0.250214] iommu: Adding device ff900000.vop to group 3
[ 0.251969] SCSI subsystem initialized
[ 0.252482] usbcore: registered new interface driver usbfs
[ 0.253005] usbcore: registered new interface driver hub
[ 0.253565] usbcore: registered new device driver usb
[ 0.308793] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.309717] NET: Registered protocol family 2
[ 0.310549] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.311283] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.312274] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.312934] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.313563] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.314401] NET: Registered protocol family 1
[ 0.315074] RPC: Registered named UNIX socket transport module.
[ 0.315615] RPC: Registered udp transport module.
[ 0.316032] RPC: Registered tcp transport module.
[ 0.316456] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.317564] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.318386] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.322189] Initialise system trusted keyring
[ 0.330861] NFS: Registering the id_resolver key type
[ 0.331347] Key type id_resolver registered
[ 0.331717] Key type id_legacy registered
[ 0.332130] fuse init (API version 7.23)
[ 0.332862] SGI XFS with security attributes, no debug enabled
[ 0.338091] NET: Registered protocol family 38
[ 0.338518] Key type asymmetric registered
[ 0.338893] Asymmetric key parser 'x509' registered
[ 0.339486] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.340156] io scheduler noop registered
[ 0.340509] io scheduler deadline registered
[ 0.341014] io scheduler cfq registered (default)
[ 0.342788] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 0.347993] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.348587] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.349174] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.891221] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.891942] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.893659] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.894577] rk-vcodec ff650000.vpu_service: probe device
[ 0.895099] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc079242410
[ 0.895948] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.896528] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 0.897689] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.898323] rk-vcodec ff650000.vpu_service: init success
[ 0.899196] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.900125] rk-vcodec ff660000.rkvdec: probe device
[ 0.900625] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc079242c10
[ 0.901369] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.901885] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 0.902736] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.903325] rk-vcodec ff660000.rkvdec: init success
THE FULL LOGS OF THE IMAGE WITHOUT FIQ (FIQ off)
256B stride
CPUId = 0x0
ChipType = 0x10, 1842
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
StorageInit ok = 316769
LoadTrustBL
No find bl30.bin
RunBL31 0x10000
INFO: SPSR = 0x3c9
DRAM: 2 GiB
invalid parameter
In: serial@ff1a0000
Boot from SDcard
Scanning mmc 1:4...
1: kernel-4.4
reading /Image
17846280 bytes read in 749 ms (22.7 MiB/s)
append: earlyprintk console=ttyFIQ0,1500000n8 rw root=PARTUUID=B921B045-1DF0-41C3-AF44-4C6F280D3FAE rootfstype=ext4 init=/sbin/init rootwait
Starting kernel ...
