hello,
I am starting to test target board(FireFly-RK3128) by the instructions.test environment: prebuilt-ubuntu-image
- kernel version:3.10.0
- prebuilt filesystem
I downloaded prebuilt-ubuntu-image, and the target board loaded firmware in successfully.
But I could not find any other resources or examples related to MPP(video codec) on the system (ubuntu image, kernel version:3.10.0).
Is there any available MPP examples on this target(FireFly-RK3128, kernel 3.10.0) ?
Next, I read MPP wiki from rockchip to test codec functionality, and I tested as following steps :
- build mpp by buildroot
- run mpp test applications on target board(ubuntu) :
Is the following log normal ? If not, what can I check ?
$ mpi_dec_test -i ~/Downloads/dragon2-1280x720.h264 -w 1280 -h 720 -t 7 -o~/decoded.yuv -n 100 -d 255
mpi_dec_test:cmd parse result:
mpi_dec_test:input file name: /home/firefly/Downloads/dragon2-1280x720.h264
mpi_dec_test:output file name: /home/firefly/decoded.yuv
mpi_dec_test:width : 1280
mpi_dec_test:height : 720
mpi_dec_test:type : 7
mpi_dec_test:debug flag : ff
mpi_dec_test:max frames : 100
mpi_dec_test:mpi_dec_test start
mpi_dec_test:input file size 16236245
mpi_dec_test:mpi_dec_test decoder test start w 1280 h 720 type 7
mpi:mpp_create enter ctx 0xbebb8cf0 mpi 0xbebb8cf4
mpi:mpp version: Without VCS info
mpi:mpp_create leave ret 0 ctx 0x2c3e0 mpi 0xb6ef660c
mpi:mpi_control enter ctx 0x2c3e0 cmd 310005 parm 0xbebb8d00
mpi:mpi_control leave ret 0
mpi:mpp_init enter ctx 0x2c3e0 type 0 coding 7
mpp_log:open /proc/device-tree/compatible error.
mpp_rt:found ion allocator
mpp_rt:NOT found drm allocator
mpp_ion:scan /proc/device-tree for vpu_service return -1
mpp_ion:scan /proc/device-tree for hevc_service return -1
mpp_ion:scan /proc/device-tree for rkvdec return -1
mpp_ion:scan /proc/device-tree for rkvenc return -1
mpp_ion:scan /proc/device-tree for vpu_combo return -1
mpp_ion:scan /sys/kernel/debug/ion/heaps for vmalloc return -1
mpp_ion:scan /sys/kernel/debug/ion/heaps for system-heap return -1
mpp_ion:can not find any hint from all possible devices
mpp_ion:using ion heap ION_HEAP_TYPE_CARVEOUT
mpp_ion:ion_ioctl c0144900 failed with code -1: No such device
mpp_ion:allocator_ion_alloc ion_alloc failed ret -19
mpp_buffer:mpp_buffer_create failed to create buffer with size 3680
mpp_buffer:mpp_buffer_put invalid input: buffer (nil)
mpp_hal:mpp_hal_init hal h264d_rkdec init failed ret -1
mpp_hal:mpp_hal_init could not found coding type 7
mpp_dec:mpp_dec_init could not init hal
mpp_time:mpp_timer_put invalid timer (nil)
mpp:error found on mpp initialization
mpi:mpp_init leave ret 0
mpi:mpi_decode_put_packet enter ctx 0x2c3e0 packet 0x2c360
mpi:mpi_decode_put_packet leave ret -1002
mpi:mpi_decode_get_frame enter ctx 0x2c3e0 frame 0xbebb8d14
mpi:mpi_decode_get_frame leave ret -1002
mpi_dec_test:decode_get_frame failed ret -1002
