I was playing with different images and finally after I flashed FlintOS I was not able to return to Ubuntu - upgrade_tool hangs on Check Chip Start and AndriodTool in Windows gives a red Check Chip Fail (first tab shows only one green string with Loader), it can read FlashID, FlashInfo, ChipInfo and pass the TestDevice. ReadCapability also fail. Rockchip Batch Tool also does not pass Check Chip.
Then I noticed that FlintOS was flashed using wl key, that is direct write.
So I tried to do it same way with unpacked Ubuntu image according to parameter file, started from
wl 0 parameter
followed with the rest of uboot, trust, resources, kernel and boot.
Unfortunately this didn’t help and even pl key gave me Reading partition info from device failes!
I would appreciate if someone guide me how to flash Ubuntu image or simply give a full dump of clear Ubuntu system to make
and with ef key:
List of rockusb connected
DevNo=1 Vid=0x2207,Pid=0x330c,LocationID=102 Mode=Maskrom
Found 1 rockusb,Select input DevNo,Rescan press ,Quit press :1
Rockusb>ef
No found loader item from config!
lower format passed in loader mode, but erase flash results in Wait for Maskrom Fail! both in loader and maskrom modes
tried upgrade_tool v 1.20 and 1.38
also went RockChip way with compiling and using rkdeveloptool - didn’ work
used two laptops with USB2 and USB3 and two USB-C cables
UPD: decided to erase flash in Windows AndroidTool - didn’t pass fully but then successfuly flashed StationOS
miracle
now revert back to Linux
thanks a lot for pushing me deeper into RockChip world
UPD2: during this manipulations I disconnected heatink with a 3pin fan just to make it less noisy further (adding 50 Omh resistor for example)
under inspection I revealed that yellow wire is simply soldered to red - looks like no tachometer Hall sensor at all in this fan, and its “supposed” line was pulled directly to FAN_12V
so according to pages 11 and 28 of Firefly-RK3399_V10_SCH_(2017-2-8).pdf pin1 of J19 - and now FAN_12V line - over Schottky diode D24 1N5819 connects to ADC_IN3 - please explain this schematics
Your article has left me speechless, thank you for sharing it! The PCET-30-01 exam questions and answers fee content is excellent, and you can access it for free.
Your article was incredibly impactful, thank you for this insight. Free 3V0-32.23 test dumps demo materials available—wishing you all success in your exams!
HP인증 HPE0-G04시험이 너무 어려워 보여서 오르지못할 산처럼 보이시나요? 그건DumpTOP의 HP인증 HPE0-G04시험문제에 대비하여 제작한HP인증 HPE0-G04덤프가 있다는 것을 모르고 있기때문입니다. HP인증 HPE0-G04시험에 도전하고 싶으시다면 최강 시험패스율로 유명한DumpTOP의 HP인증 HPE0-G04덤프로 시험공부를 해보세요.시간절약은 물론이고 가격도 착해서 간단한 시험패스에 딱 좋은 선택입니다.
I really appreciate your article, it was so enlightening and refreshing. Here are the free L4M4 new exam bootcamp materials resources—good luck, everyone!
