ANDROID 8.1 AIO-3399J no audio on 3.5mm
Hi,
I have tested Android 8.1 on AIO-3399J board. Sound DOES NOT WORK on 3.5mm Jack socket.
Sound works on HDMI only?
How can i fix this.
Rakie
Try firmware from firefly website.
Hi Leung,
I have tried both images from your website:
AIO-3399J_Android8.1.0_HDMI_180901.img
AIO-3399J_Android8.1.0_HDMI_181025.img
But both donot play audio from 3.5mm Jack?
Please advise on a fix for this
Hi Leung,
Pls see debug log :
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.11.07 10:06:08 =~=~=~=~=~=~=~=~=~=~=~=
DDR Version 1.12 20180518
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
Boot1: 2018-04-08, version: 1.12
CPUId = 0x0
ChipType = 0x10, 215
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
SdmmcInit=0 1
StorageInit ok = 67734
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xa912c
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):65aa5ce
NOTICE: BL31: Built : 10:47:37, Jun 19 2018
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1151): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-170-gc4654a6 #16 Wed May 30 08:54:30 UTC 2018 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Oct 25 2018 - 16:01:51)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
can’t find dts node for fixed
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
invalide header tag
ca head not found
#Boot ver: 2018-10-25#1.12
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
Rockchip UBOOT DRM driver version: develop-v1.0.0
failed to find phy node
failed to find panel driver
no fuel gauge found
Monitor has basic audio support
drm_rk_selete_output; fail get baseparameter
rk lcdc - 0 dclk set: dclk = 148500000HZ, pll select = 0, div = 1
rockchip_panel_prepare: failed to find panel prepare funcs
CEA mode used vic=31
dw_hdmi_setup HDMI mode
rockchip_panel_enable: failed to find panel prepare funcs
load fdt from resouce.
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel @ 0x00280000 (0x0127d808)
ramdisk @ 0x04bf0000 (0x00178918)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000004600000, end 00000000046164f1 … OK
Add bank:000000000a200000, 0000000075e00000
[ 0.000000] Linux version 4.4.126 (liangkd@tchip-server) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #203 SMP PREEMPT Tue Oct 23 15:54:13 CST 2018
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eefb000 s45528 r8192 d32296 u86016
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.veritymode=/dev/block/platform/ff0f0000.dwmmc/by-name/metadata androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x00010000@0x00010000(kernel),0x00010000@0x00020000(boot),0x00020000@0x00030000(recovery),0x00038000@0x00050000(backup),0x00002000@0x00088000(security),0x00100000@0x0008a000(cache),0x00500000@0x0018a000(system),0x00008000@0x0068a000(metadata),0x00100000@0x00692000(vendor),0x00100000@0x00794000(oem),0x00000400@0x00894000(frp),-@0x00894400(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2018-10-25_16:01:51 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0x7eeb3000-0x7eef3000] (0MB) mapped at [ffffffc07eeb3000-ffffffc07eef2fff]
[ 0.000000] Memory: 1988276K/2064384K available (11006K kernel code, 1654K rwdata, 5372K rodata, 832K init, 1133K bss, 59724K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009090000 - 0xffffff8009160000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b40000 ( 11008 KB)
[ 0.000000] .rodata : 0xffffff8008b40000 - 0xffffff8009090000 ( 5440 KB)
[ 0.000000] .data : 0xffffff8009160000 - 0xffffff80092fd808 ( 1655 KB)
[ 0.001924] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002911] pid_max: default: 32768 minimum: 301
[ 0.003413] Security Framework initialized
[ 0.003812] SELinux: Initializing.
[ 0.004252] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004897] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006347] Initializing cgroup subsys memory
[ 0.006789] Initializing cgroup subsys freezer
[ 0.008099] sched-energy: Sched-energy-costs installed from DT
[ 0.008663] CPU0: update cpu_capacity 401
[ 0.009124] ASID allocator initialised with 32768 entries
[ 0.025948] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.027240] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039356] Detected VIPT I-cache on CPU1
[ 0.039387] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039421] CPU1: using LPI pending table @0x000000000a3f0000
[ 0.039464] CPU1: update cpu_capacity 401
[ 0.039468] CPU1: Booted secondary processor [410fd034]
[ 0.049341] Detected VIPT I-cache on CPU2
[ 0.049361] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049394] CPU2: using LPI pending table @0x000000007c020000
[ 0.049423] CPU2: update cpu_capacity 401
[ 0.049426] CPU2: Booted secondary processor [410fd034]
[ 0.059372] Detected VIPT I-cache on CPU3
[ 0.059391] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059423] CPU3: using LPI pending table @0x000000007c060000
[ 0.059449] CPU3: update cpu_capacity 401
[ 0.059453] CPU3: Booted secondary processor [410fd034]
[ 0.069421] Detected PIPT I-cache on CPU4
[ 0.069449] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069488] CPU4: using LPI pending table @0x000000007c0b0000
[ 0.069528] CPU4: update cpu_capacity 1024
[ 0.069531] CPU4: Booted secondary processor [410fd082]
[ 0.079447] Detected PIPT I-cache on CPU5
[ 0.079465] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079501] CPU5: using LPI pending table @0x000000007c0e0000
[ 0.079528] CPU5: update cpu_capacity 1024
[ 0.079531] CPU5: Booted secondary processor [410fd082]
[ 0.079614] Brought up 6 CPUs
[ 0.092032] SMP: Total of 6 processors activated.
[ 0.092486] CPU features: detected feature: GIC system register CPU interface
[ 0.093174] CPU: All CPU(s) started at EL2
[ 0.093608] alternatives: patching kernel code
[ 0.095943] devtmpfs: initialized
[ 0.116343] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.117308] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.123368] pinctrl core: initialized pinctrl subsystem
[ 0.125388] Failed to find legacy iommu devices
[ 0.126195] NET: Registered protocol family 16
[ 0.127046] schedtune: init normalization constants…
[ 0.127552] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.128191] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.128827] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.129463] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.130107] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.130744] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.131379] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.132014] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.132648] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.133284] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.134054] schedtune: verify normalization constants…
[ 0.134573] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.135116] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.135658] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.136200] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.136742] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.137284] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.137834] schedtune: configured to support 5 boost groups
[ 0.147868] cpuidle: using governor ladder
[ 0.157874] cpuidle: using governor menu
[ 0.158271] Registered FIQ tty driver
[ 0.158980] vdso: 2 pages (1 code @ ffffff8008b46000, 1 data @ ffffff8009164000)
[ 0.159718] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.161743] DMA: preallocated 2048 KiB pool for atomic allocations
[ 0.184881] console [pstore-1] enabled
[ 0.185487] pstore: Registered ramoops as persistent store backend
[ 0.186092] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.189023] fiq debugger fiq mode enabled
[ [ 0.189675] console [ttyFIQ0] enabled
[ 0.190361] bootconsole [uart0] disabled
[ 0.190925] Registered fiq debugger ttyFIQ0
[ 0.225110] iommu: Adding device ff650000.vpu_service to group 0
[ 0.225204] iommu: Adding device ff660000.rkvdec to group 1
[ 0.225301] iommu: Adding device ff670000.iep to group 2
[ 0.225392] iommu: Adding device ff8f0000.vop to group 3
[ 0.225462] iommu: Adding device ff900000.vop to group 4
[ 0.225562] iommu: Adding device ff910000.isp to group 5
[ 0.225634] iommu: Adding device ff920000.isp to group 6
[ 0.227629] rk_iommu ff670800.iommu: can’t get aclk
[ 0.227645] rk_iommu ff670800.iommu: can’t get hclk
[ 0.228498] SCSI subsystem initialized
[ 0.228811] usbcore: registered new interface driver usbfs
[ 0.228860] usbcore: registered new interface driver hub
[ 0.228936] usbcore: registered new device driver usb
[ 0.229298] media: Linux media interface: v0.10
[ 0.229332] Linux video capture interface: v2.00
[ 0.229508] pps_core: LinuxPPS API ver. 1 registered
[ 0.229518] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.229538] PTP clock support registered
[ 0.232376] Advanced Linux Sound Architecture Driver Initialized.
[ 0.232835] Bluetooth: Core ver 2.21
[ 0.232866] NET: Registered protocol family 31
[ 0.232875] Bluetooth: HCI device and connection manager initialized
[ 0.232888] Bluetooth: HCI socket layer initialized
[ 0.232900] Bluetooth: L2CAP socket layer initialized
[ 0.232925] Bluetooth: SCO socket layer initialized
[ 0.233562] rockchip-cpuinfo cpuinfo: Serial : 3a809135da364fc1
[ 0.234038] clocksource: Switched to clocksource arch_sys_counter
[ 0.275474] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.275713] NET: Registered protocol family 2
[ 0.276140] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.276261] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.276389] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.276462] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.276488] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.276644] NET: Registered protocol family 1
[ 0.277514] Trying to unpack rootfs image as initramfs…
[ 0.344420] Freeing initrd memory: 1504K
[ 0.344969] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.345056] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.347715] audit: initializing netlink subsys (disabled)
[ 0.347806] audit: type=2000 audit(0.343:1): initialized
[ 0.356250] VFS: Disk quotas dquot_6.6.0
[ 0.356381] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.357393] Registering sdcardfs 0.1
[ 0.357959] fuse init (API version 7.23)
[ 0.359006]
[ 0.359006] TEE Core Framework initialization (ver 1:0.1)
[ 0.359031] TEE armv7 Driver initialization
[ 0.359365] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.359380] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.359563] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.363340] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.363364] io scheduler noop registered
[ 0.363522] io scheduler cfq registered (default)
[ 0.364737] phy phy-ff770000.syscon:usb2-phy@e450.0: Failed to get VBUS supply regulator
[ 0.365652] phy phy-ff770000.syscon:usb2-phy@e460.2: Failed to get VBUS supply regulator
[ 0.370817] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.370839] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.370853] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.894100] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.894275] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.895217] iep: failed to find iep power down clock source.
[ 0.895834] IEP Power ON
[ 0.896095] IEP Power OFF
[ 0.896234] IEP Driver loaded succesfully
[ 0.896529] Module initialized.
[ 0.896932] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.897190] rk-vcodec ff650000.vpu_service: probe device
[ 0.897240] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07c25d410
[ 0.897444] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.897512] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 0.898073] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.898093] rk-vcodec ff650000.vpu_service: init success
[ 0.898325] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.902108] rk-vcodec ff660000.rkvdec: probe device
[ 0.902162] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07c25dc10
[ 0.902327] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.902391] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 0.902837] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.902853] rk-vcodec ff660000.rkvdec: init success
[ 0.904668] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.904690] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.906002] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.906020] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.907788] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.909530] ff180000.serial: ttyS0 at MMIO 0xff16†–“‹Ö6vÆ& ›+û «#ÖV––›fVVk
[ 0.909827] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-debugger; cannot claim for ff1a0000.serial
[ 0.909841] rockchip-pinctrl pinctrl: pin-147 (ff1a0000.serial) status -22
[ 0.909854] rockchip-pinctrl pinctrl: could not request pin 147 (gpio4-19) from group uart2c-xfer on device rockchip-pinctrl
[ 0.909864] dw-apb-uart ff1a0000.serial: Error applying setting, reverse things back
[ 0.910156] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 38, base_baud = 1500000) is a 16550A
[ 0.910562] [drm] Initialized drm 1.1.0 20060810
[ 0.913889] [drm] Rockchip DRM driver version: v1.0.1
[ 0.914231] rockchip-drm display-subsystem: dmc is disabled
[ 0.914501] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 0.914766] rockchip-vop ff900000.vop: unable to request PWM
[ 0.914793] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 0.914832] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 0.914999] rockchip-vop ff8f0000.vop: unable to request PWM
[ 0.915018] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 0.915242] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 0.915260] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.915362] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.916063] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 0.916080] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.916088] [drm] No driver support for vblank timestamp query.
[ 1.581680] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.597679] Unable to detect cache hierarchy for CPU 0
[ 1.608915] brd: module loaded
[ 1.623586] loop: module loaded
[ 1.624145] zram: Added device: zram0
[ 1.624974] SCSI Media Changer driver v0.25
[ 1.626261] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 1.626283] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 1.627074] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 1.797397] wk2xxx_serial_init()
[ 1.797412] wk2xxx_request_port
[ 1.797424] ttysWK0 at I/O 0x1 (irq = 104, base_baud = 460800) is a wk2xxx
[ 1.797626] uart_add_one_port success for line i:= 0 with right 0
[ 1.797638] wk2xxx_request_port
[ 1.797649] ttysWK1 at I/O 0x2 (irq = 104, base_baud = 460800) is a wk2xxx
[ 1.797834] uart_add_one_port success for line i:= 1 with right 0
[ 1.797845] wk2xxx_request_port
[ 1.797855] ttysWK2 at I/O 0x3 (irq = 104, base_baud = 460800) is a wk2xxx
[ 1.798034] uart_add_one_port success for line i:= 2 with right 0
[ 1.798046] wk2xxx_request_port
[ 1.798055] ttysWK3 at I/O 0x4 (irq = 104, base_baud = 460800) is a wk2xxx
[ 1.798253] uart_add_one_port success for line i:= 3 with right 0
[ 1.798264] uart_add_one_port = 0x0
[ 1.798288] register spi return v = :0
[ 1.798331] register firefly_spi_init spi return v = :0
[ 1.798385] tun: Universal TUN/TAP device driver, 1.6
[ 1.798396] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.799272] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.799382] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.799401] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.799412] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.799436] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.799595] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.799607] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.804623] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.804737] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.804745] Ring mode enabled
[ 1.804752] DMA HW capability register supported
[ 1.804758] Normal descriptors
[ 1.804767] RX Checksum Offload Engine supported (type 2)
[ 1.804782] Wake-Up On Lan supported
[ 1.804824] Enable RX Mitigation via HW Watchdog Timer
[ 1.878608] libphy: stmmac: probed
[ 1.878648] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.878659] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.878668] eth%d: PHY ID 0000ffff at 2 IRQ POLL (stmmac-0:02)
[ 1.878676] eth%d: PHY ID 0000ffff at 3 IRQ POLL (stmmac-0:03)
[ 1.878684] eth%d: PHY ID 0000ffff at 4 IRQ POLL (stmmac-0:04)
[ 1.878692] eth%d: PHY ID 0000ffff at 5 IRQ POLL (stmmac-0:05)
[ 1.878700] eth%d: PHY ID 0000ffff at 6 IRQ POLL (stmmac-0:06)
[ 1.878708] eth%d: PHY ID 0000ffff at 7 IRQ POLL (stmmac-0:07)
[ 1.878717] eth%d: PHY ID 0000ffff at 8 IRQ POLL (stmmac-0:08)
[ 1.878725] eth%d: PHY ID 0000ffff at 9 IRQ POLL (stmmac-0:09)
[ 1.878733] eth%d: PHY ID 0000ffff at 10 IRQ POLL (stmmac-0:0a)
[ 1.878741] eth%d: PHY ID 0000ffff at 11 IRQ POLL (stmmac-0:0b)
[ 1.878749] eth%d: PHY ID 0000ffff at 12 IRQ POLL (stmmac-0:0c)
[ 1.878757] eth%d: PHY ID 0000ffff at 13 IRQ POLL (stmmac-0:0d)
[ 1.878765] eth%d: PHY ID 0000ffff at 14 IRQ POLL (stmmac-0:0e)
[ 1.878773] eth%d: PHY ID 0000ffff at 15 IRQ POLL (stmmac-0:0f)
[ 1.878781] eth%d: PHY ID 0000ffff at 16 IRQ POLL (stmmac-0:10)
[ 1.878788] eth%d: PHY ID 0000ffff at 17 IRQ POLL (stmmac-0:11)
[ 1.878796] eth%d: PHY ID 0000ffff at 18 IRQ POLL (stmmac-0:12)
[ 1.878804] eth%d: PHY ID 0000ffff at 19 IRQ POLL (stmmac-0:13)
[ 1.878812] eth%d: PHY ID 0000ffff at 20 IRQ POLL (stmmac-0:14)
[ 1.878820] eth%d: PHY ID 0000ffff at 21 IRQ POLL (stmmac-0:15)
[ 1.878827] eth%d: PHY ID 0000ffff at 22 IRQ POLL (stmmac-0:16)
[ 1.878835] eth%d: PHY ID 0000ffff at 23 IRQ POLL (stmmac-0:17)
[ 1.878843] eth%d: PHY ID 0000ffff at 24 IRQ POLL (stmmac-0:18)
[ 1.878851] eth%d: PHY ID 0000ffff at 25 IRQ POLL (stmmac-0:19)
[ 1.878858] eth%d: PHY ID 0000ffff at 26 IRQ POLL (stmmac-0:1a)
[ 1.878866] eth%d: PHY ID 0000ffff at 27 IRQ POLL (stmmac-0:1b)
[ 1.878874] eth%d: PHY ID 0000ffff at 28 IRQ POLL (stmmac-0:1c)
[ 1.878882] eth%d: PHY ID 0000ffff at 29 IRQ POLL (stmmac-0:1d)
[ 1.878889] eth%d: PHY ID 0000ffff at 30 IRQ POLL (stmmac-0:1e)
[ 1.878897] eth%d: PHY ID 0000ffff at 31 IRQ POLL (stmmac-0:1f)
[ 1.879785] PPP generic driver version 2.4.2
[ 1.879967] PPP BSD Compression module registered
[ 1.879981] PPP Deflate Compression module registered
[ 1.880010] PPP MPPE Compression module registered
[ 1.880027] NET: Registered protocol family 24
[ 1.880090] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.880097] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.880114] Rockchip WiFi SYS interface (V1.00) …
[ 1.880195] usbcore: registered new interface driver catc
[ 1.880235] usbcore: registered new interface driver kaweth
[ 1.880251] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.880291] usbcore: registered new interface driver pegasus
[ 1.880331] usbcore: registered new interface driver rtl8150
[ 1.880371] usbcore: registered new interface driver r8152
[ 1.880384] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.880440] usbcore: registered new interface driver hso
[ 1.880488] usbcore: registered new interface driver asix
[ 1.880550] usbcore: registered new interface driver ax88179_178a
[ 1.880589] usbcore: registered new interface driver cdc_ether
[ 1.880629] usbcore: registered new interface driver cdc_eem
[ 1.880668] usbcore: registered new interface driver dm9601
[ 1.880748] usbcore: registered new interface driver smsc75xx
[ 1.880819] usbcore: registered new interface driver smsc95xx
[ 1.880859] usbcore: registered new interface driver gl620a
[ 1.880902] usbcore: registered new interface driver net1080
[ 1.880941] usbcore: registered new interface driver plusb
[ 1.881000] usbcore: registered new interface driver rndis_host
[ 1.881043] usbcore: registered new interface driver cdc_subset
[ 1.881083] usbcore: registered new interface driver zaurus
[ 1.881124] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.881180] usbcore: registered new interface driver int51x1
[ 1.881238] usbcore: registered new interface driver kalmia
[ 1.881282] usbcore: registered new interface driver ipheth
[ 1.881324] usbcore: registered new interface driver sierra_net
[ 1.881364] usbcore: registered new interface driver cx82310_eth
[ 1.881412] usbcore: registered new interface driver cdc_ncm
[ 1.881470] usbcore: registered new interface driver qmi_wwan
[ 1.881514] usbcore: registered new interface driver cdc_mbim
[ 1.985077] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 1.986203] rockchip-typec-phy ff7c0000.phy: Needed 1 loops to turn on
[ 1.987444] rockchip-dwc3 usb@fe800000: fail to get drvdata hcd
[ 1.992622] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.993770] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.993807] ehci-pci: EHCI PCI platform driver
[ 1.993869] ehci-platform: EHCI generic platform driver
[ 1.997405] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.997602] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 1.997793] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 2.007403] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 2.007559] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.007591] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.007602] usb usb1: Product: EHCI Host Controller
[ 2.007611] usb usb1: Manufacturer: Linux 4.4.126 ehci_hcd
[ 2.007620] usb usb1: SerialNumber: fe380000.usb
[ 2.008091] hub 1-0:1.0: USB hub found
[ 2.008142] hub 1-0:1.0: 1 port detected
[ 2.012014] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 2.012261] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 2.012574] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 2.020754] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.021003] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.021051] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.021103] usb usb2: Product: EHCI Host Controller
[ 2.021116] usb usb2: Manufacturer: Linux 4.4.126 ehci_hcd
[ 2.021127] usb usb2: SerialNumber: fe3c0000.usb
[ 2.021747] hub 2-0:1.0: USB hub found
[ 2.021828] hub 2-0:1.0: 1 port detected
[ 2.022752] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.022873] ohci-platform: OHCI generic platform driver
[ 2.023366] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 2.023650] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 2.023910] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 2.078246] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.078295] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.078309] usb usb3: Product: Generic Platform OHCI controller
[ 2.078323] usb usb3: Manufacturer: Linux 4.4.126 ohci_hcd
[ 2.078335] usb usb3: SerialNumber: fe3a0000.usb
[ 2.078934] hub 3-0:1.0: USB hub found
[ 2.079006] hub 3-0:1.0: 1 port detected
[ 2.079698] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 2.079958] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 2.080163] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 2.134903] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.134952] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.134967] usb usb4: Product: Generic Platform OHCI controller
[ 2.134980] usb usb4: Manufacturer: Linux 4.4.126 ohci_hcd
[ 2.134993] usb usb4: SerialNumber: fe3e0000.usb
[ 2.135582] hub 4-0:1.0: USB hub found
[ 2.135665] hub 4-0:1.0: 1 port detected
[ 2.137117] usbcore: registered new interface driver cdc_acm
[ 2.137132] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.137216] usbcore: registered new interface driver usblp
[ 2.137315] usbcore: registered new interface driver cdc_wdm
[ 2.137405] usbcore: registered new interface driver uas
[ 2.137590] usbcore: registered new interface driver usb-storage
[ 2.137654] usbcore: registered new interface driver ums-alauda
[ 2.137744] usbcore: registered new interface driver ums-cypress
[ 2.137802] usbcore: registered new interface driver ums-datafab
[ 2.137862] usbcore: registered new interface driver ums_eneub6250
[ 2.137951] usbcore: registered new interface driver ums-freecom
[ 2.138009] usbcore: registered new interface driver ums-isd200
[ 2.138067] usbcore: registered new interface driver ums-jumpshot
[ 2.138130] usbcore: registered new interface driver ums-karma
[ 2.138220] usbcore: registered new interface driver ums-onetouch
[ 2.138278] usbcore: registered new interface driver ums-sddr09
[ 2.138343] usbcore: registered new interface driver ums-sddr55
[ 2.138432] usbcore: registered new interface driver ums-usbat
[ 2.138548] usbcore: registered new interface driver usbserial
[ 2.138630] usbcore: registered new interface driver usbserial_generic
[ 2.138674] usbserial: USB Serial support registered for generic
[ 2.138735] usbcore: registered new interface driver option
[ 2.138778] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.139070] usbcore: registered new interface driver trancevibrator
[ 2.139120] usb20_otg: version 3.10a 21-DEC-2012
[ 2.139426] usb20_host: version 3.10a 21-DEC-2012
[ 2.140266] usbcore: registered new interface driver xpad
[ 2.140356] usbcore: registered new interface driver usb_acecad
[ 2.140456] usbcore: registered new interface driver aiptek
[ 2.140521] usbcore: registered new interface driver gtco
[ 2.140593] usbcore: registered new interface driver hanwang
[ 2.140690] usbcore: registered new interface driver kbtab
[ 2.140728] ==gsl_ts_init==
[ 2.140778] ret=0
[ 2.141533] .. rk pwm remotectl v1.1 init
[ 2.141862] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 2.142475] sensor_register_slave:kxtj9,id=11
[ 2.142530] sensor_register_slave:mma8452,id=17
[ 2.142551] sensor_register_slave:lis3dh,id=7
[ 2.142570] sensor_register_slave:mma7660,id=18
[ 2.142619] sensor_register_slave:lsm303d,id=22
[ 2.142637] sensor_register_slave:gs_mc3230,id=23
[ 2.142646] [Gsensor] gsensor_init
[ 2.142664] sensor_register_slave:mpu6880_acc,id=24
[ 2.142682] sensor_register_slave:mpu6500_acc,id=25
[ 2.142700] sensor_register_slave:lsm330_acc,id=26
[ 2.142718] sensor_register_slave:bma2xx_acc,id=27
[ 2.142735] sensor_register_slave:akm8975,id=30
[ 2.142754] sensor_register_slave:akm8963,id=31
[ 2.142772] sensor_register_slave:l3g4200d,id=45
[ 2.142791] sensor_register_slave:l3g20d,id=46
[ 2.142840] sensor_register_slave:ewtsa,id=47
[ 2.142854] sensor_register_slave:lsm330_gyro,id=51
[ 2.142868] sensor_register_slave:cm3217,id=53
[ 2.142881] sensor_register_slave:cm3218,id=54
[ 2.142895] sensor_register_slave:ls_stk3410,id=62
[ 2.142909] sensor_register_slave:ps_stk3410,id=67
[ 2.143915] i2c /dev entries driver
[ 2.144963] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80099ca000
[ 2.146196] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 2.146306] fan53555-reg: supplied by vcc5v0_sys
[ 2.148366] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 2.148475] fan53555-reg: supplied by vcc5v0_sys
[ 2.150617] rk808 0-001b: Pmic Chip id: 0x0
[ 2.153703] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 2.153824] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 2.153951] DCDC_REG1: supplied by vcc3v3_sys
[ 2.154884] DCDC_REG2: supplied by vcc3v3_sys
[ 2.155570] DCDC_REG3: supplied by vcc3v3_sys
[ 2.155958] DCDC_REG4: supplied by vcc3v3_sys
[ 2.156498] LDO_REG1: supplied by vcc3v3_sys
[ 2.157698] LDO_REG2: supplied by vcc3v3_sys
[ 2.158793] LDO_REG3: supplied by vcc3v3_sys
[ 2.159901] LDO_REG4: supplied by vcc3v3_sys
[ 2.161014] LDO_REG5: supplied by vcc3v3_sys
[ 2.162059] LDO_REG6: supplied by vcc3v3_sys
[ 2.163170] LDO_REG7: supplied by vcc3v3_sys
[ 2.164297] LDO_REG8: supplied by vcc3v3_sys
[ 2.165435] SWITCH_REG1: supplied by vcc3v3_sys
[ 2.165858] SWITCH_REG2: supplied by vcc3v3_sys
[ 2.169728] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 2.170400] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80099cc000
[ 2.171372] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80099ce000
[ 2.171512] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 2.171560] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 2.171575] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 2.171588] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 2.172065] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80099d0000
[ 2.173396] IR NEC protocol handler initialized
[ 2.173447] IR RC5(x/sz) protocol handler initialized
[ 2.173466] IR RC6 protocol handler initialized
[ 2.173517] IR JVC protocol handler initialized
[ 2.173533] IR Sony protocol handler initialized
[ 2.173548] IR SANYO protocol handler initialized
[ 2.173564] IR Sharp protocol handler initialized
[ 2.173579] IR MCE Keyboard/mouse protocol handler initialized
[ 2.173594] IR XMP protocol handler initialized
[ 2.173897] usbcore: registered new interface driver uvcvideo
[ 2.173939] USB Video Class driver (1.1.1)
[ 2.173962] CamSys driver version: v0.41.0, CamSys head file version: v1.0.0
[ 2.179746] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 2.179924] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 2.180289] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 2.180455] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 2.184010] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 2.185024] device-mapper: uevent: version 1.0.3
[ 2.185488] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.185745] Bluetooth: HCI UART driver ver 2.3
[ 2.185791] Bluetooth: HCI UART protocol H4 registered
[ 2.185801] Bluetooth: HCI UART protocol LL registered
[ 2.185817] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 2.185826] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 2.185834] rtk_btusb: Register usb char device interface for BT driver
[ 2.186102] usbcore: registered new interface driver rtk_btusb
[ 2.186739] cpu cpu0: cpu_leakage=17
[ 2.186840] cpu cpu0: cpu_leakage=17
[ 2.200395] cpu cpu0: temp=43888, pvtm=148956 (148824 + 132)
[ 2.201344] cpu cpu4: cpu_leakage=32
[ 2.201457] cpu cpu4: cpu_leakage=32
[ 2.214554] cpu cpu4: temp=43888, pvtm=153670 (153600 + 70)
[ 2.221248] sdhci: Secure Digital Host Controller Interface driver
[ 2.221303] sdhci: Copyright(c) Pierre Ossman
[ 2.221325] Synopsys Designware Multimedia Card Interface Driver
[ 2.222559] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.222735] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.222789] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.222854] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.222888] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.222974] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.222986] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.224105] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.224200] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.224253] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.224305] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.224329] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.224453] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 2.225410] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.227439] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 2.227456] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 2.254171] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 2.256313] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.258914] usbcore: registered new interface driver usbhid
[ 2.258928] usbhid: USB HID core driver
[ 2.259058] inv_mpu_iio: inv_mpu_init:746
[ 2.259717] ashmem: initialized
[ 2.263319] ff100000.saradc supply vref not found, using dummy regulator
[ 2.265556] rknandbase v1.2 2018-05-08
[ 2.266649] usbcore: registered new interface driver snd-usb-audio
[ 2.281304] gpiod_direction_output: invalid GPIO
[ 2.281352] gpiod_direction_output: invalid GPIO
[ 2.281369] gpiod_direction_output: invalid GPIO
[ 2.292540] tc358749x 1-000f: tc358749x_i2c_probe success
[ 2.295597] mmc0: MAN_BKOPS_EN bit is not set
[ 2.299140] rk-hdmi-dp-sound hdmi-dp-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 2.301922] u32 classifier
[ 2.301952] Actions configured
[ 2.302010] Netfilter messages via NETLINK v0.30.
[ 2.302108] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.302593] ctnetlink v0.93: registering with nfnetlink.
[ 2.303597] xt_time: kernel timezone is -0000
[ 2.304540] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.304896] arp_tables: (C) 2002 David S. Miller
[ 2.305529] Initializing XFRM netlink socket
[ 2.306128] NET: Registered protocol family 10
[ 2.307419] mip6: Mobile IPv6
[ 2.307491] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.308608] sit: IPv6 over IPv4 tunneling driver
[ 2.309253] NET: Registered protocol family 17
[ 2.309323] NET: Registered protocol family 15
[ 2.309374] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.309406] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 2.310002] Bridge firewalling registered
[ 2.310054] Ebtables v2.0 registered
[ 2.310147] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[ 2.310309] Bluetooth: RFCOMM TTY layer initialized
[ 2.310335] Bluetooth: RFCOMM socket layer initialized
[ 2.310358] Bluetooth: RFCOMM ver 1.11
[ 2.310384] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.310392] Bluetooth: BNEP filters: protocol multicast
[ 2.310405] Bluetooth: BNEP socket layer initialized
[ 2.310418] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.310429] Bluetooth: HIDP socket layer initialized
[ 2.310433] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[ 2.310474] l2tp_core: L2TP core driver, V2.0
[ 2.310512] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 2.310525] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.310685] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[ 2.310893] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.310946] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 2.310958] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.310966] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.311042] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 2.311050] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.311060] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.311121] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.311151] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[ 2.311494] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 2.311543] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 2.311575] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 2.311607] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 2.311634] rkpart: partition size too small (1)
[ 2.311653] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 2.311663] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 2.311673] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 2.311682] resource: 0x001000000 – 0x002000000 (16 MB)
[ 2.311690] kernel: 0x002000000 – 0x004000000 (32 MB)
[ 2.311698] boot: 0x004000000 – 0x006000000 (32 MB)
[ 2.311706] recovery: 0x006000000 – 0x00a000000 (64 MB)
[ 2.311715] backup: 0x00a000000 – 0x011000000 (112 MB)
[ 2.311723] security: 0x011000000 – 0x011400000 (4 MB)
[ 2.311731] cache: 0x011400000 – 0x031400000 (512 MB)
[ 2.311740] system: 0x031400000 – 0x0d1400000 (2560 MB)
[ 2.311748] metadata: 0x0d1400000 – 0x0d2400000 (16 MB)
[ 2.311757] vendor: 0x0d2400000 – 0x0f2400000 (512 MB)
[ 2.311765] oem: 0x0f2800000 – 0x112800000 (512 MB)
[ 2.311773] frp: 0x112800000 – 0x112880000 (0 MB)
[ 2.311781] userdata: 0x112880000 – 0x3a3a00000 (10513 MB)
[ 2.311858] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
[ 2.311914] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.311953] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[ 2.311971] [BT_RFKILL]: ** disable irq
[ 2.312101] [BT_RFKILL]: bt_default device registered.
[ 2.312242] sensor_register_slave:mpu6500_gyro,id=49
[ 2.312259] sensor_register_slave:mpu6880_gyro,id=50
[ 2.313619] Registered cp15_barrier emulation handler
[ 2.313718] Registered setend emulation handler
[ 2.314391] registered taskstats version 1
[ 2.315096] rockchip ion idev is NULL
[ 2.315115] rga2 ff680000.rga: rga ion client create success!
[ 2.315318] rga: Driver loaded successfully ver:3.02
[ 2.320013] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.320204] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 5
[ 2.320516] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 2.320565] xhci-hcd xhci-hcd.10.auto: irq 235, io mem 0xfe800000
[ 2.320773] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.320791] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.320802] usb usb5: Product: xHCI Host Controller
[ 2.320811] usb usb5: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.320820] usb usb5: SerialNumber: xhci-hcd.10.auto
[ 2.321286] hub 5-0:1.0: USB hub found
[ 2.321325] hub 5-0:1.0: 1 port detected
[ 2.321596] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.321869] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 6
[ 2.322018] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.322237] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.322259] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.322272] usb usb6: Product: xHCI Host Controller
[ 2.322301] usb usb6: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.322329] usb usb6: SerialNumber: xhci-hcd.10.auto
[ 2.323282] hub 6-0:1.0: USB hub found
[ 2.323334] hub 6-0:1.0: 1 port detected
[ 2.326402] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 2.326451] usb usb6: USB disconnect, device number 1
[ 2.334063] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 2.350562] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
[ 2.350576] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
[ 2.350719] xhci-hcd xhci-hcd.10.auto: USB bus 6 deregistered
[ 2.350899] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 2.350919] usb usb5: USB disconnect, device number 1
[ 2.351340] xhci-hcd xhci-hcd.10.auto: USB bus 5 deregistered
[ 2.354285] vendor storage:20160801 ret = 0
[ 2.355970] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.356176] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 5
[ 2.356487] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 2.356534] xhci-hcd xhci-hcd.11.auto: irq 236, io mem 0xfe900000
[ 2.356723] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.356740] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.356750] usb usb5: Product: xHCI Host Controller
[ 2.356759] usb usb5: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.356768] usb usb5: SerialNumber: xhci-hcd.11.auto
[ 2.357242] hub 5-0:1.0: USB hub found
[ 2.357317] hub 5-0:1.0: 1 port detected
[ 2.357796] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.358021] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 6
[ 2.358203] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.358467] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.358482] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.358492] usb usb6: Product: xHCI Host Controller
[ 2.358501] usb usb6: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.358510] usb usb6: SerialNumber: xhci-hcd.11.auto
[ 2.358935] hub 6-0:1.0: USB hub found
[ 2.359008] hub 6-0:1.0: 1 port detected
[ 2.360426] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.360535] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.360553] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.360589] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.360615] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.360656] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.360665] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.360997] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 2.377585] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.391197] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 2.394555] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.394785] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.394835] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.394903] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.394964] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.395165] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 2.396062] dwmmc_rockchip fe320000.dwmmc: allocated mmc-pwrseq
[ 2.396377] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.396413] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.407470] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.422316] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 2.436221] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.437485] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[ 2.438092] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.439808] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.440679] asoc-simple-card rt5640-sound: rt5640-aif2 ↔ ff890000.i2s mapping ok
[ 2.442362] asoc-simple-card rt5640-sound: tc358749x-audio ↔ ff890000.i2s mapping ok
[ 2.442794] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.454909] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input1
[ 2.455408] usb 2-1: New USB device found, idVendor=1a40, idProduct=0201
[ 2.455532] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.455558] usb 2-1: Product: USB 2.0 Hub [MTT]
[ 2.457140] hub 2-1:1.0: USB hub found
[ 2.457526] hub 2-1:1.0: 7 ports detected
[ 2.460040] asoc-simple-card spdif-sound: dit-hifi ↔ ff870000.spdif mapping ok
[ 2.464493] rk808-rtc rk808-rtc: setting system clock to 2018-10-25 08:24:20 UTC (1540455860)
[ 2.465827] It doesn’t contain Rogue gpu
[ 2.495454] 80 ret 1024
[ 2.498185] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 415; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-14a50f9’, rk_ko_ver is ‘5’, built at ‘15:53:51’, on ‘Oct 23 2018’.
[ 2.498562] Mali: Mali device driver loaded
[ 2.499016] input: rk29-keypad as /devices/platform/rockchip-key/input/input2
[ 2.499918] ALSA device list:
[ 2.499949] #0: rk-hdmi-dp-sound
[ 2.499957] #1: rockchip,rt5640-codec
[ 2.499965] #2: ROCKCHIP,SPDIF
[ 2.500499] Freeing unused kernel memory: 832K
[ 2.502310] mmc_host mmc1: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 2.514305] init: init first stage started!
[ 2.515573] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 2.610493] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: barrier=1,inode_readahead_blks=8
[ 2.610808] init: [libfs_mgr]__mount(source=/dev/block/by-name/system,target=/system,type=ext4)=0: Success
[ 2.619533] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: barrier=1,inode_readahead_blks=8
[ 2.619652] init: [libfs_mgr]__mount(source=/dev/block/by-name/vendor,target=/vendor,type=ext4)=0: Success
[ 2.619875] init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
[ 2.619923] init: Loading SELinux policy
[ 2.664112] usb 5-1: new low-speed USB device number 2 using xhci-hcd
[ 2.718845] audit: type=1403 audit(1540455860.750:2): policy loaded auid=4294967295 ses=4294967295
[ 2.719108] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
[ 2.719108]
[ 2.722761] selinux: SELinux: Loaded file_contexts
[ 2.722761]
[ 2.723871] random: init: uninitialized urandom read (40 bytes read, 41 bits of entropy available)
[ 2.724890] init: init second stage started!
[ 2.727489] usb 2-1.7: new high-speed USB device number 3 using ehci-platform
[ 2.730847] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 2.731291] init: Set boot.mode to emmc
[ 2.731380] init: property_set(“ro.boot.mode”, “emmc”) failed: property already set
[ 2.733426] selinux: SELinux: Loaded file_contexts
[ 2.733426]
[ 2.733917] selinux: SELinux: Loaded property_contexts from /system/etc/selinux/plat_property_contexts & /vendor/etc/selinux/nonplat_property_contexts.
[ 2.733917]
[ 2.733950] init: Running restorecon…
[ 2.738394] init: waitid failed: No child processes
[ 2.739436] init: Couldn’t load property file: Unable to open ‘/odm/default.prop’: No such file or directory: No such file or directory
[ 2.741355] init: Created socket ‘/dev/socket/property_service’, mode 666, user 0, group 0
[ 2.741565] init: Parsing file /init.rc…
[ 2.741992] init: Added ‘/init.environ.rc’ to import list
[ 2.742153] init: Added ‘/init.usb.rc’ to import list
[ 2.742380] init: Added ‘/init.rk30board.rc’ to import list
[ 2.742602] init: Added ‘/vendor/etc/init/hw/init.rk30board.rc’ to import list
[ 2.742822] init: Added ‘/init.usb.configfs.rc’ to import list
[ 2.743047] init: Added ‘/init.zygote64_32.rc’ to import list
[ 2.744390] init: Parsing file /init.environ.rc…
[ 2.744544] init: Parsing file /init.usb.rc…
[ 2.745047] init: Parsing file /init.rk30board.rc…
[ 2.745308] init: Added ‘init.rk30board.bootmode.emmc.rc’ to import list
[ 2.745384] init: Added ‘init.rockchip.rc’ to import list
[ 2.745605] init: Added ‘init.connectivity.rc’ to import list
[ 2.745828] init: Added ‘init.box.samba.rc’ to import list
[ 2.746054] init: Added ‘init.rk3399.rc’ to import list
[ 2.746279] init: Added ‘init.tablet.rc’ to import list
[ 2.746498] init: Added ‘init.car.rc’ to import list
[ 2.746721] init: Added ‘init.optee.rc’ to import list
[ 2.747540] init: Parsing file init.rk30board.bootmode.emmc.rc…
[ 2.747607] init: Parsing file init.rockchip.rc…
[ 2.747684] init: Added ‘init.rk30board.usb.rc’ to import list
[ 2.747723] init: Added ‘init.rk30board.environment.rc’ to import list
[ 2.747737] init: Added ‘/init.debug.rc’ to import list
[ 2.748003] init: Parsing file init.rk30board.usb.rc…
[ 2.748227] init: Parsing file init.rk30board.environment.rc…
[ 2.748296] init: Parsing file /init.debug.rc…
[ 2.748326] init: Unable to open ‘/init.debug.rc’: No such file or directory
[ 2.748346] init: /init.rc: 3: Could not import file ‘/init.debug.rc’: No such file or directory
[ 2.748391] init: Parsing file init.connectivity.rc…
[ 2.748572] init: Parsing file init.box.samba.rc…
[ 2.748626] init: Unable to open ‘init.box.samba.rc’: No such file or directory
[ 2.748642] init: /init.rc: 4: Could not import file ‘init.box.samba.rc’: No such file or directory
[ 2.748663] init: Parsing file init.rk3399.rc…
[ 2.748766] init: init.rk3399.rc: 25: invalid keyword ‘ioprio’
[ 2.748876] init: Parsing file init.tablet.rc…
[ 2.748916] init: Unable to open ‘init.tablet.rc’: No such file or directory
[ 2.748932] init: /init.rc: 6: Could not import file ‘init.tablet.rc’: No such file or directory
[ 2.748953] init: Parsing file init.car.rc…
[ 2.748979] init: Unable to open ‘init.car.rc’: No such file or directory
[ 2.748994] init: /init.rc: 7: Could not import file ‘init.car.rc’: No such file or directory
[ 2.749015] init: Parsing file init.optee.rc…
[ 2.749041] init: Unable to open ‘init.optee.rc’: No such file or directory
[ 2.749056] init: /init.rc: 8: Could not import file ‘init.optee.rc’: No such file or directory
[ 2.749598] init: Parsing file /vendor/etc/init/hw/init.rk30board.rc…
[ 2.749648] init: Unable to open ‘/vendor/etc/init/hw/init.rk30board.rc’: No such file or directory
[ 2.749662] init: /init.rc: 10: Could not import file ‘/vendor/etc/init/hw/init.rk30board.rc’: No such file or directory
[ 2.749681] init: Parsing file /init.usb.configfs.rc…
[ 2.750156] init: Parsing file /init.zygote64_32.rc…
[ 2.750323] init: Parsing directory /system/etc/init…
[ 2.751088] init: Parsing file /system/etc/init/android.hidl.allocator@1.0-service.rc…
[ 2.751581] init: Parsing file /system/etc/init/atrace.rc…
[ 2.752313] init: Parsing file /system/etc/init/atrace_userdebug.rc…
[ 2.752843] init: Parsing file /system/etc/init/audioserver.rc…
[ 2.753363] init: Parsing file /system/etc/init/bootanim.rc…
[ 2.753863] init: Parsing file /system/etc/init/bootstat.rc…
[ 2.754346] init: Parsing file /system/etc/init/cameraserver.rc…
[ 2.754786] init: Parsing file /system/etc/init/drmserver.rc…
[ 2.755320] init: Parsing file /system/etc/init/dumpstate.rc…
[ 2.755607] init: Parsing file /system/etc/init/gatekeeperd.rc…
[ 2.755864] init: Parsing file /system/etc/init/hwservicemanager.rc…
[ 2.756150] init: Parsing file /system/etc/init/init-debug.rc…
[ 2.756435] init: Parsing file /system/etc/init/installd.rc…
[ 2.756888] init: Parsing file /system/etc/init/keystore.rc…
[ 2.757177] init: Parsing file /system/etc/init/lmkd.rc…
[ 2.757448] init: Parsing file /system/etc/init/logcatd.rc…
[ 2.757789] init: Parsing file /system/etc/init/logd.rc…
[ 2.758091] init: Parsing file /system/etc/init/logtagd.rc…
[ 2.758386] init: Parsing file /system/etc/init/mdnsd.rc…
[ 2.758664] init: Parsing file /system/etc/init/mediadrmserver.rc…
[ 2.758960] init: Parsing file /system/etc/init/mediaextractor.rc…
[ 2.759236] init: Parsing file /system/etc/init/mediametrics.rc…
[ 2.759504] init: Parsing file /system/etc/init/mediaserver.rc…
[ 2.759803] init: Parsing file /system/etc/init/mtpd.rc…
[ 2.760088] init: Parsing file /system/etc/init/netd.rc…
[ 2.760375] init: Parsing file /system/etc/init/perfprofd.rc…
[ 2.760646] init: Parsing file /system/etc/init/racoon.rc…
[ 2.760939] init: Parsing file /system/etc/init/servicemanager.rc…
[ 2.761229] init: Parsing file /system/etc/init/storaged.rc…
[ 2.761520] init: Parsing file /system/etc/init/surfaceflinger.rc…
[ 2.761833] init: Parsing file /system/etc/init/thermalservice.rc…
[ 2.762095] init: Parsing file /system/etc/init/tombstoned.rc…
[ 2.762373] init: Parsing file /system/etc/init/uncrypt.rc…
[ 2.762675] init: Parsing file /system/etc/init/vdc.rc…
[ 2.762966] init: Parsing file /system/etc/init/vold.rc…
[ 2.763248] init: Parsing file /system/etc/init/webview_zygote32.rc…
[ 2.763538] init: Parsing file /system/etc/init/webview_zygote64.rc…
[ 2.763815] init: Parsing file /system/etc/init/wifi-events.rc…
[ 2.764219] init: Parsing file /system/etc/init/wificond.rc…
[ 2.764529] init: Parsing directory /vendor/etc/init…
[ 2.764688] init: Parsing file /vendor/etc/init/android.hardware.audio@2.0-service.rc…
[ 2.765060] init: Parsing file /vendor/etc/init/android.hardware.bluetooth@1.0-service.rc…
[ 2.765349] init: Parsing file /vendor/etc/init/android.hardware.camera.provider@2.4-service.rc…
[ 2.765626] init: Parsing file /vendor/etc/init/android.hardware.cas@1.0-service.rc…
[ 2.765901] init: Parsing file /vendor/etc/init/android.hardware.configstore@1.0-service.rc…
[ 2.766169] init: Parsing file /vendor/etc/init/android.hardware.drm@1.0-service.rc…
[ 2.766471] init: Parsing file /vendor/etc/init/android.hardware.drm@1.0-service.widevine.rc…
[ 2.766747] init: Parsing file /vendor/etc/init/android.hardware.gnss@1.0-service.rc…
[ 2.767036] init: /vendor/etc/init/android.hardware.gnss@1.0-service.rc: 1: ignored duplicate definition of service ‘gnss_service’
[ 2.767060] init: Parsing file /vendor/etc/init/android.hardware.graphics.allocator@2.0-service.rc…
[ 2.767328] init: Parsing file /vendor/etc/init/android.hardware.graphics.composer@2.1-service.rc…
[ 2.767638] init: Parsing file /vendor/etc/init/android.hardware.keymaster@3.0-service.rc…
[ 2.767921] init: Parsing file /vendor/etc/init/android.hardware.light@2.0-service.rc…
[ 2.768219] init: Parsing file /vendor/etc/init/android.hardware.media.omx@1.0-service.rc…
[ 2.768522] init: Parsing file /vendor/etc/init/android.hardware.neuralnetworks@1.0-service-armnn.rc…
[ 2.768803] init: Parsing file /vendor/etc/init/android.hardware.power@1.0-service.rc…
[ 2.769095] init: Parsing file /vendor/etc/init/android.hardware.sensors@1.0-service.rc…
[ 2.769395] init: Parsing file /vendor/etc/init/android.hardware.wifi@1.0-service.rc…
[ 2.769690] init: Parsing file /vendor/etc/init/drmservice.rc…
[ 2.769973] init: Parsing file /vendor/etc/init/hostapd.android.rc…
[ 2.770241] init: Parsing file /vendor/etc/init/rild.rc…
[ 2.770484] init: /vendor/etc/init/rild.rc: 1: ignored duplicate definition of service ‘ril-daemon’
[ 2.770508] init: Parsing file /vendor/etc/init/vndservicemanager.rc…
[ 2.770803] init: Parsing file /odm/etc/init…
[ 2.770832] init: Unable to open ‘/odm/etc/init’: No such file or directory
[ 2.770900] init: processing action (early-init) from (/init.rc:14)
[ 2.775993] init: starting service ‘ueventd’…
[ 2.776504] cgroup: init (1) created nested cgroup for controller “memory” which has incomplete hierarchy support. Nested cgroups may change behavior in the future.
[ 2.776529] cgroup: “memory” requires setting use_hierarchy to 1 on the root
[ 2.776888] init: processing action (early-init) from (init.rockchip.rc:5)
[ 2.781053] init: processing action (wait_for_coldboot_done) from (:0)
[ 2.783451] random: ueventd: uninitialized urandom read (40 bytes read, 44 bits of entropy available)
[ 2.788385] usb 5-1: New USB device found, idVendor=046d, idProduct=c077
[ 2.788471] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.788496] usb 5-1: Product: USB Optical Mouse
[ 2.788520] usb 5-1: Manufacturer: Logitech
[ 2.790427] usb 5-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 2.791126] ueventd: ueventd started!
[ 2.791311] ueventd: Parsing file /ueventd.rc…
[ 2.793716] ueventd: Parsing file /vendor/ueventd.rc…
[ 2.793819] ueventd: Unable to open ‘/vendor/ueventd.rc’: No such file or directory
[ 2.793900] ueventd: Parsing file /odm/ueventd.rc…
[ 2.794006] ueventd: Unable to open ‘/odm/ueventd.rc’: No such file or directory
[ 2.794292] ueventd: Parsing file /ueventd.rk30board.rc…
[ 2.796036] ueventd: /ueventd.rk30board.rc: 56: invalid gid ‘net_bt_stack’
[ 2.796138] ueventd: /ueventd.rk30board.rc: 57: invalid gid ‘net_bt_stack’
[ 2.796222] ueventd: /ueventd.rk30board.rc: 58: invalid gid ‘net_bt_stack’
[ 2.796316] ueventd: /ueventd.rk30board.rc: 60: invalid gid ‘net_bt_stack’
[ 2.797026] ueventd: /ueventd.rk30board.rc: 114: invalid gid ‘trace’
[ 2.802399] input: Logitech USB Optical Mouse as /devices/platform/usb@fe900000/fe900000.dwc3/xhci-hcd.11.auto/usb5/5-1/5-1:1.0/0003:046D:C077.0001/input/input3
[ 2.811529] selinux: SELinux: Loaded file_contexts
[ 2.811529]
[ 2.826822] usb 2-1.7: New USB device found, idVendor=0781, idProduct=5583
[ 2.826858] usb 2-1.7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.826868] usb 2-1.7: Product: Ultra Fit
[ 2.826877] usb 2-1.7: Manufacturer: SanDisk
[ 2.826884] usb 2-1.7: SerialNumber: 4C531001480520104392
[ 2.827676] usb-storage 2-1.7:1.0: USB Mass Storage device detected
[ 2.828461] scsi host0: usb-storage 2-1.7:1.0
[ 2.854678] hid-generic 0003:046D:C077.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-xhci-hcd.11.auto-1/input0
[ 2.879338] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 110
[ 2.881694] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.881734] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 2.925685] selinux: SELinux: Loaded file_contexts
[ 2.925685]
[ 3.009276] ueventd: Coldboot took 0.197 seconds
[ 3.014384] init: Command ‘wait_for_coldboot_done’ action=wait_for_coldboot_done (:0) returned 0 took 233ms.
[ 3.014455] init: processing action (mix_hwrng_into_linux_rng) from (:0)
[ 3.014503] init: /dev/hw_random not found
[ 3.014533] init: processing action (set_mmap_rnd_bits) from (:0)
[ 3.015121] init: processing action (set_kptr_restrict) from (:0)
[ 3.015308] init: processing action (keychord_init) from (:0)
[ 3.015379] keychord: using input dev ff420030.pwm for fevent
[ 3.015391] keychord: using input dev rk29-keypad for fevent
[ 3.015431] init: processing action (console_init) from (:0)
[ 3.015474] init: processing action (init) from (/init.rc:44)
[ 3.015685] init: Unable to open ‘/default.prop’: Too many symbolic links encountered
[ 3.023622] init: Unable to open ‘/proc/cpu/alignment’: No such file or directory
[ 3.034598] Registered swp emulation handler
[ 3.034784] init: Unable to open ‘/sys/class/leds/vibrator/trigger’: No such file or directory
[ 3.034831] init: processing action (init) from (/init.environ.rc:2)
[ 3.034971] init: processing action (init) from (/init.rk30board.rc:49)
[ 3.035023] init: Unable to open ‘/sys/module/rockchip_pm/parameters/policy’: No such file or directory
[ 3.035133] init: processing action (init) from (init.rockchip.rc:16)
[ 3.035526] init: processing action (init) from (init.rk30board.environment.rc:1)
[ 3.035585] init: processing action (init) from (init.rk3399.rc:30)
[ 3.036547] init: processing action (mix_hwrng_into_linux_rng) from (:0)
[ 3.036598] init: /dev/hw_random not found
[ 3.036632] init: processing action (late-init) from (/init.rc:270)
[ 3.036703] init: processing action (queue_property_triggers) from (:0)
[ 3.036759] init: processing action (fs) from (init.rk30board.bootmode.emmc.rc:1)
[ 3.038638] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/oem
[ 3.040969] EXT4-fs (mmcblk0p14): Ignoring removed nomblk_io_submit option
[ 3.043013] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 3.043253] init: [libfs_mgr]check_fs(): mount(/dev/block/by-name/oem,/oem,ext4)=0: Success
[ 3.066166] init: [libfs_mgr]check_fs(): unmount(/oem) succeeded
[ 3.067979] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/by-name/oem
[ 3.076371] random: e2fsck: uninitialized urandom read (40 bytes read, 52 bits of entropy available)
[ 3.110136] random: e2fsck: uninitialized urandom read (40 bytes read, 54 bits of entropy available)
[ 3.119510] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[ 3.119510]
[ 3.119582] e2fsck: oem: clean, 15/32768 files, 6356/131072 blocks
[ 3.119582]
[ 3.122607] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 3.122809] init: [libfs_mgr]__mount(source=/dev/block/by-name/oem,target=/oem,type=ext4)=0: Success
[ 3.123550] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/cache
[ 3.123645] init: [libfs_mgr]Filesystem on /dev/block/by-name/cache was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x2c6
[ 3.124099] init: [libfs_mgr]check_fs(): mount(/dev/block/by-name/cache,/cache,ext4)=-1: No such file or directory
[ 3.124152] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/by-name/cache
[ 3.126870] random: e2fsck: uninitialized urandom read (40 bytes read, 54 bits of entropy available)
[ 3.151850] random: e2fsck: uninitialized urandom read (40 bytes read, 54 bits of entropy available)
[ 3.205945] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[ 3.205945]
[ 3.206045] e2fsck: /dev/block/by-name/cache: recovering journal
[ 3.206045]
[ 3.206067] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ 3.206067]
[ 3.206091] e2fsck: Pass 2: Checking directory structure
[ 3.206091]
[ 3.206113] e2fsck: Pass 3: Checking directory connectivity
[ 3.206113]
[ 3.206134] e2fsck: Pass 4: Checking reference counts
[ 3.206134]
[ 3.206184] e2fsck: Pass 5: Checking group summary information
[ 3.206184]
[ 3.206206] e2fsck: /dev/block/by-name/cache: 20/32768 files (0.0% non-contiguous), 6398/131072 blocks
[ 3.206206]
[ 3.210650] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.210919] init: [libfs_mgr]__mount(source=/dev/block/by-name/cache,target=/cache,type=ext4)=0: Success
[ 3.211645] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
[ 3.211770] init: [libfs_mgr]Filesystem on /dev/block/by-name/metadata was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x2c6
[ 3.212851] EXT4-fs (mmcblk0p12): Ignoring removed nomblk_io_submit option
[ 3.221831] EXT4-fs (mmcblk0p12): recovery complete
[ 3.222321] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 3.222807] init: [libfs_mgr]check_fs(): mount(/dev/block/by-name/metadata,/metadata,ext4)=0: Success
[ 3.240590] init: [libfs_mgr]check_fs(): unmount(/metadata) succeeded
[ 3.240807] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/by-name/metadata
[ 3.244006] random: e2fsck: uninitialized urandom read (40 bytes read, 57 bits of entropy available)
[ 3.267735] random: e2fsck: uninitialized urandom read (40 bytes read, 59 bits of entropy available)
[ 3.271045] audit: type=1400 audit(1540455861.303:3): avc: denied { read } for pid=239 comm=“e2fsck” name=“mmcblk0p12” dev=“tmpfs” ino=11341 scontext=u:r:fsck:s0 tcontext=u:object_r:metadata_block_device:s0 tclass=blk_file permissive=1
[ 3.271136] audit: type=1400 audit(1540455861.303:4): avc: denied { open } for pid=239 comm=“e2fsck” path=“/dev/block/mmcblk0p12” dev=“tmpfs” ino=11341 scontext=u:r:fsck:s0 tcontext=u:object_r:metadata_block_device:s0 tclass=blk_file permissive=1
[ 3.271256] audit: type=1400 audit(1540455861.303:5): avc: denied { write } for pid=239 comm=“e2fsck” name=“mmcblk0p12” dev=“tmpfs” ino=11341 scontext=u:r:fsck:s0 tcontext=u:object_r:metadata_block_device:s0 tclass=blk_file permissive=1
[ 3.271372] audit: type=1400 audit(1540455861.303:6): avc: denied { ioctl } for pid=239 comm=“e2fsck” path=“/dev/block/mmcblk0p12” dev=“tmpfs” ino=11341 ioctlcmd=127c scontext=u:r:fsck:s0 tcontext=u:object_r:metadata_block_device:s0 tclass=blk_file permissive=1
[ 3.292515] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[ 3.292515]
[ 3.292586] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ 3.292586]
[ 3.292604] e2fsck: Pass 2: Checking directory structure
[ 3.292604]
[ 3.292619] e2fsck: Pass 3: Checking directory connectivity
[ 3.292619]
[ 3.292634] e2fsck: Pass 4: Checking reference counts
[ 3.292634]
[ 3.292649] e2fsck: Pass 5: Checking group summary information
[ 3.292649]
[ 3.292703] e2fsck: /dev/block/by-name/metadata: 13/4096 files (15.4% non-contiguous), 1170/4096 blocks
[ 3.292703]
[ 3.299203] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.299872] init: [libfs_mgr]__mount(source=/dev/block/by-name/metadata,target=/metadata,type=ext4)=0: Success
[ 3.300182] init: [libfs_mgr]Running /system/bin/fsck.f2fs -a /dev/block/by-name/userdata
[ 3.304386] random: fsck.f2fs: uninitialized urandom read (40 bytes read, 60 bits of entropy available)
[ 3.313801] random: fsck.f2fs: uninitialized urandom read (40 bytes read, 60 bits of entropy available)
[ 3.318584] fsck.f2fs: Info: Fix the reported corruption.
[ 3.318584]
[ 3.318657] fsck.f2fs: Info: Segments per section = 1
[ 3.318657]
[ 3.318674] fsck.f2fs: Info: Sections per zone = 1
[ 3.318674]
[ 3.318690] fsck.f2fs: Info: sector size = 512
[ 3.318690]
[ 3.318705] fsck.f2fs: Info: total sectors = 21531648 (10513 MB)
[ 3.318705]
[ 3.318720] fsck.f2fs: Can’t find a valid F2FS superblock at 0x0
[ 3.318720]
[ 3.318735] fsck.f2fs: Can’t find a valid F2FS superblock at 0x1
[ 3.318735]
[ 3.318753] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 3.318753]
[ 3.322363] F2FS-fs (mmcblk0p16): Magic Mismatch, valid(0xf2f52010) - read(0xc81526db)
[ 3.322401] F2FS-fs (mmcblk0p16): Can’t find valid F2FS filesystem in 1th superblock
[ 3.322700] F2FS-fs (mmcblk0p16): Magic Mismatch, valid(0xf2f52010) - read(0xaca8376e)
[ 3.322742] F2FS-fs (mmcblk0p16): Can’t find valid F2FS filesystem in 2th superblock
[ 3.322819] F2FS-fs (mmcblk0p16): Magic Mismatch, valid(0xf2f52010) - read(0xc81526db)
[ 3.322841] F2FS-fs (mmcblk0p16): Can’t find valid F2FS filesystem in 1th superblock
[ 3.322862] F2FS-fs (mmcblk0p16): Magic Mismatch, valid(0xf2f52010) - read(0xaca8376e)
[ 3.322881] F2FS-fs (mmcblk0p16): Can’t find valid F2FS filesystem in 2th superblock
[ 3.323173] init: [libfs_mgr]__mount(source=/dev/block/by-name/userdata,target=/data,type=f2fs)=-1: Invalid argument
[ 3.323245] init: [libfs_mgr]Running /system/bin/fsck.f2fs -a /dev/block/by-name/userdata
[ 3.340328] fsck.f2fs: Info: Fix the reported corruption.
[ 3.340328]
[ 3.340455] fsck.f2fs: Info: Segments per section = 1
[ 3.340455]
[ 3.340497] fsck.f2fs: Info: Sections per zone = 1
[ 3.340497]
[ 3.340536] fsck.f2fs: Info: sector size = 512
[ 3.340536]
[ 3.340574] fsck.f2fs: Info: total sectors = 21531648 (10513 MB)
[ 3.340574]
[ 3.340612] fsck.f2fs: Can’t find a valid F2FS superblock at 0x0
[ 3.340612]
[ 3.340650] fsck.f2fs: Can’t find a valid F2FS superblock at 0x1
[ 3.340650]
[ 3.340751] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 3.340751]
[ 3.343141] F2FS-fs (mmcblk0p16): Magic Mismatch, valid(0xf2f52010) - read(0xc81526db)
[ 3.343185] F2FS-fs (mmcblk0p16): Can’t find valid F2FS filesystem in 1th superblock
[ 3.343959] init: [libfs_mgr]__mount(source=/dev/block/by-name/userdata,target=/data,type=f2fs)=-1: Invalid argument
[ 3.344699] init: [libfs_mgr]fs_mgr_mount_all(): possibly an encryptable blkdev /dev/block/by-name/userdata for mount /data type f2fs
[ 3.347501] init: Parsing file /odm/etc/init…
[ 3.347595] init: Unable to open ‘/odm/etc/init’: No such file or directory
[ 3.347714] init: Command ‘mount_all fstab.rk30board’ action=fs (init.rk30board.bootmode.emmc.rc:7) returned 2 took 310ms.
[ 3.347824] init: processing action (fs) from (/system/etc/init/logd.rc:18)
[ 3.348331] init: processing action (fs) from (/system/etc/init/wifi-events.rc:17)
[ 3.348408] init: processing action (post-fs) from (/init.rc:303)
[ 3.350246] init: Couldn’t load property file: Unable to open ‘/odm/build.prop’: No such file or directory: No such file or directory
[ 3.352002] init: property_set(“ro.board.platform”, “rk3399”) failed: property already set
[ 3.354371] init: property_set(“ro.target.product”, “tablet”) failed: property already set
[ 3.354604] init: Couldn’t load property file: Unable to open ‘/factory/factory.prop’: No such file or directory: No such file or directory
[ 3.357046] init: /recovery not specified in fstab
[ 3.360663] init: starting service ‘logd’…
[ 3.363659] init: starting service ‘servicemanager’…
[ 3.366369] init: Created socket ‘/dev/socket/logd’, mode 666, user 1036, group 1036
[ 3.366987] init: starting service ‘hwservicemanager’…
[ 3.368030] init: Created socket ‘/dev/socket/logdr’, mode 666, user 1036, group 1036
[ 3.369388] init: Created socket ‘/dev/socket/logdw’, mode 222, user 1036, group 1036
[ 3.369801] init: Opened file ‘/proc/kmsg’, flags 0
[ 3.370003] init: Opened file ‘/dev/kmsg’, flags 1
[ 3.371797] init: starting service ‘vndservicemanager’…
[ 3.377207] selinux: SELinux: Skipping restorecon_recursive(/cache)
[ 3.377207]
[ 3.382319] init: processing action (post-fs) from (/init.rk30board.rc:10)
[ 3.382539] selinux: SELinux: Skipping restorecon_recursive(/metadata)
[ 3.382539]
[ 3.388137] init: insmod: open(“/system/lib/modules/ump.ko”) failed: No such file or directory
[ 3.388299] init: insmod: open(“/system/lib/modules/mali.ko”) failed: No such file or directory
[ 3.468487] mali ff9a0000.gpu: gpu_leakage=22
[ 3.481683] mali ff9a0000.gpu: temp=44444, pvtm=123405 (123369 + 36)
[ 3.484799] logd.auditd: start
[ 3.484872] logd.klogd: 3480833241
[ 3.486096] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 3.486493] mali ff9a0000.gpu: Protected mode not available
[ 3.488632] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 3.489080] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 389; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 3.494364] mali ff9a0000.gpu: Probed as mali0
[ 3.494860] init: Command ‘insmod /vendor/lib/modules/mali_kbase.ko’ action=post-fs (/init.rk30board.rc:14) returned 0 took 106ms.
[ 3.495026] init: insmod: open(“/system/lib/modules/rk30_mirroring.ko”) failed: No such file or directory
[ 3.495846] init: finit_module for “/system/lib/modules/rk29-ipp.ko” failed: Exec format error
[ 3.495990] init: insmod: open(“/system/lib/modules/pvrsrvkm.ko”) failed: No such file or directory
[ 3.501792] zram0: detected capacity change from 0 to 1027579904
[ 3.512278] binder: 246:246 ioctl 620a 0 returned -22
[ 3.537396] mkswap: Swapspace size: 1003492k, UUID=5f9812b2-f7ce-46d8-90dd-06a949687ef9
[ 3.538986] Adding 1003492k swap on /dev/block/zram0. Priority:-1 extents:1 across:1003492k SS
[ 3.539908] init: processing action (post-fs) from (init.rockchip.rc:34)
[ 3.540186] init: processing action (post-fs) from (/system/etc/init/atrace.rc:3)
[ 3.543693] init: Unable to open ‘/sys/kernel/tracing/tracing_on’: No such file or directory
[ 3.543859] init: processing action (post-fs) from (/system/etc/init/atrace_userdebug.rc:6)
[ 3.545103] init: processing action (late-fs) from (/init.rc:363)
[ 3.546004] init: starting service ‘keymaster-3-0’…
[ 3.547029] init: processing action (post-fs-data) from (/init.rc:371)
[ 3.547971] init: starting service ‘vold’…
[ 3.549860] init: Created socket ‘/dev/socket/vold’, mode 660, user 0, group 1009
[ 3.550299] init: Unable to open ‘/data/system/entropy.dat’: No such file or directory
[ 3.550333] init: Created socket ‘/dev/socket/cryptd’, mode 660, user 0, group 1009
[ 3.551150] init: Unable to open ‘/data/misc/recovery/ro.build.fingerprint’: No such file or directory
[ 3.551672] init: Unable to open ‘/data/misc/recovery/proc/version’: No such file or directory
[ 3.566431] init: starting service ‘exec 1 (/system/bin/vdc --wait cryptfs init_user0)’…
[ 3.567407] init: SVC_EXEC pid 263 (uid 0 gid 0+0 context default) started; waiting…
[ 3.634698] init: Service ‘exec 1 (/system/bin/vdc --wait cryptfs init_user0)’ (pid 263) exited with status 0 waiting took 0.068000 seconds
[ 3.643540] init: starting service ‘exec 2 (/system/bin/tzdatacheck /system/usr/share/zoneinfo /data/misc/zoneinfo)’…
[ 3.644639] init: SVC_EXEC pid 267 (uid 1000 gid 1000+0 context default) started; waiting…
[ 3.655332] init: Service ‘exec 2 (/system/bin/tzdatacheck /system/usr/share/zoneinfo /data/misc/zoneinfo)’ (pid 267) exited with status 0 waiting took 0.012000 seconds
[ 3.655561] init: processing action (post-fs-data) from (/init.usb.rc:6)
[ 3.656595] init: processing action (post-fs-data) from (/init.rk30board.rc:25)
[ 3.658249] init: Unable to find GID for ‘system’: getpwnam failed: No such file or directory
[ 3.659164] init: Unable to open ‘/etc/ppp/pap-secrets’: No such file or directory
[ 3.660479] init: processing action (post-fs-data) from (init.rockchip.rc:38)
[ 3.661255] tmpfs: Bad mount option background_gc
[ 3.662291] init: processing action (post-fs-data) from (init.rk3399.rc:37)
[ 3.662480] init: processing action (post-fs-data) from (/system/etc/init/bootstat.rc:3)
[ 3.663476] init: processing action (post-fs-data) from (/system/etc/init/logtagd.rc:4)
[ 3.664411] init: processing action (post-fs-data) from (/vendor/etc/init/hostapd.android.rc:9)
[ 3.664885] init: processing action (load_persist_props_action) from (/init.rc:260)
[ 3.664955] init: Couldn’t load property file: Unable to open ‘/data/local.prop’: No such file or directory: No such file or directory
[ 3.665224] init: starting service ‘logd-reinit’…
[ 3.666279] init: processing action (load_persist_props_action) from (/system/etc/init/logcatd.rc:31)
[ 3.666498] init: processing action (firmware_mounts_complete) from (/init.rc:266)
[ 3.666693] init: processing action (early-boot) from (init.rk3399.rc:9)
[ 3.668645] init: processing action (early-boot) from (/system/etc/init/installd.rc:5)
[ 3.674879] init: processing action (boot) from (/init.rc:554)
[ 3.675412] init: Unable to open ‘/proc/sys/vm/min_free_order_shift’: No such file or directory
[ 3.676637] logd.daemon: reinit
[ 3.677146] init: Service ‘logd-reinit’ (pid 268) exited with status 0
[ 3.677773] init: starting service ‘gnss_service’…
[ 3.679528] init: starting service ‘hidl_memory’…
[ 3.680887] init: starting service ‘audio-hal-2-0’…
[ 3.682319] init: starting service ‘bluetooth-1-0’…
[ 3.683614] init: starting service ‘camera-provider-2-4’…
[ 3.684899] init: starting service ‘cas-hal-1-0’…
[ 3.685218] init: couldn’t write 273 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 3.686539] init: starting service ‘configstore-hal-1-0’…
[ 3.687908] init: starting service ‘drm-hal-1-0’…
[ 3.689766] init: starting service ‘drm-widevine-hal-1-0’…
[ 3.693146] init: starting service ‘gralloc-2-0’…
[ 3.695299] init: starting service ‘hwcomposer-2-1’…
[ 3.697116] init: starting service ‘light-hal-2-0’…
[ 3.699313] init: starting service ‘neuralnetworks_hal_service_armnn’…
[ 3.701254] init: starting service ‘power-hal-1-0’…
[ 3.702851] init: starting service ‘sensors-hal-1-0’…
[ 3.704651] init: starting service ‘wifi_hal_legacy’…
[ 3.706256] init: starting service ‘healthd’…
[ 3.708404] init: cannot find ‘/system/bin/displayd’, disabling ‘displayd’: No such file or directory
[ 3.709015] init: starting service ‘lmkd’…
[ 3.710553] init: starting service ‘surfaceflinger’…
[ 3.712399] init: starting service ‘thermalservice’…
[ 3.714831] init: processing action (boot) from (/init.usb.rc:25)
[ 3.714955] init: processing action (persist.sys.usb.config=* && boot) from (/init.usb.rc:106)
[ 3.715020] init: processing action (boot) from (/init.rk30board.rc:56)
[ 3.720307] init: Unable to open ‘/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold’: No such file or directory
[ 3.720760] init: Failed to bind socket ‘pdx/system/vr/display/client’: No such file or directory
[ 3.721201] init: Failed to bind socket ‘pdx/system/vr/display/manager’: No such file or directory
[ 3.721531] init: Failed to bind socket ‘pdx/system/vr/display/vsync’: No such file or directory
[ 3.721862] init: Created socket ‘/dev/socket/lmkd’, mode 660, user 1000, group 1000
[ 3.753046] selinux: SELinux: Could not stat /metadata/tee: No such file or directory.
[ 3.753046]
[ 3.754549] type=1400 audit(1540455861.786:7): avc: denied { read write } for pid=269 comm=“android.hardwar” name=“vndbinder” dev=“tmpfs” ino=10637 scontext=u:r:hal_gnss_default:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_f
[ 3.754973] init: processing action (boot) from (/init.rk30board.rc:316)
[ 3.755284] init: starting service ‘vm_daemon’…
[ 3.756534] init: processing action (boot) from (init.rockchip.rc:56)
[ 3.756665] init: Unable to find GID for ‘net_bt_stack’: getpwnam failed: No such file or directory
[ 3.756696] init: processing action (boot) from (init.rk30board.usb.rc:1)
[ 3.759657] type=1400 audit(1540455861.786:7): avc: denied { read write } for pid=269 comm=“android.hardwar” name=“vndbinder” dev=“tmpfs” ino=10637 scontext=u:r:hal_gnss_default:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_f
[ 3.759707] type=1400 audit(1540455861.786:8): avc: denied { open } for pid=269 comm=“android.hardwar” path=“/dev/vndbinder” dev=“tmpfs” ino=10637 scontext=u:r:hal_gnss_default:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_f
[ 3.759848] type=1400 audit(1540455861.786:8): avc: denied { open } for pid=269 comm=“android.hardwar” path=“/dev/vndbinder” dev=“tmpfs” ino=10637 scontext=u:r:hal_gnss_default:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_f
[ 3.759869] type=1400 audit(1540455861.786:9): avc: denied { getattr } for pid=1 comm=“init” path=“/vendor/bin/vm” dev=“mmcblk0p13” ino=1077 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 3.760344] type=1400 audit(1540455861.786:9): avc: denied { getattr } for pid=1 comm=“init” path=“/vendor/bin/vm” dev=“mmcblk0p13” ino=1077 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 3.760387] type=1400 audit(1540455861.786:10): avc: denied { ioctl } for pid=269 comm=“android.hardwar” path=“/dev/vndbinder” dev=“tmpfs” ino=10637 ioctlcmd=6209 scontext=u:r:hal_gnss_default:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_f
[ 3.760540] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 3.760574] init: write: cannot expand ‘${ro.serialno}’
[ 3.761899] type=1400 audit(1540455861.786:10): avc: denied { ioctl } for pid=269 comm=“android.hardwar” path=“/dev/vndbinder” dev=“tmpfs” ino=10637 ioctlcmd=6209 scontext=u:r:hal_gnss_default:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_f
[ 3.761932] type=1400 audit(1540455861.793:12): avc: denied { read open } for pid=289 comm=“init” path=“/vendor/bin/vm” dev=“mmcblk0p13” ino=1077 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 3.763151] type=1400 audit(1540455861.793:12): avc: denied { read open } for pid=289 comm=“init” path=“/vendor/bin/vm” dev=“mmcblk0p13” ino=1077 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 3.763184] type=1400 audit(1540455861.793:13): avc: denied { transition } for pid=289 comm=“init” path=“/vendor/bin/vm” dev=“mmcblk0p13” ino=1077 scontext=u:r:init:s0 tcontext=u:r:sudaemon:s0 tclass=proc
[ 3.768297] file system registered
[ 3.779841] using random self ethernet address
[ 3.779859] using random host ethernet address
[ 3.779948] init: Unable to open ‘/config/usb_gadget/g1/functions/rndis.gs4/wceis’: Permission denied
[ 3.782635] init: processing action (boot) from (init.connectivity.rc:2)
[ 3.787160] init: processing action (boot) from (init.rk3399.rc:13)
[ 3.806439] init: processing action (boot) from (/system/etc/init/bootstat.rc:57)
[ 3.814235] init: processing action (boot) from (/system/etc/init/dumpstate.rc:1)
[ 3.814484] init: processing action (enable_property_trigger) from (:0)
[ 3.814702] init: processing action (security.perf_harden=1) from (/init.rc:702)
[ 3.814848] init: processing action (ro.debuggable=1) from (/init.rc:730)
[ 3.815428] init: starting service ‘console’…
[ 3.815894] type=1400 audit(1540455861.793:13): avc: denied { transition } for pid=289 comm=“init” path=“/vendor/bin/vm” dev=“mmcblk0p13” ino=1077 scontext=u:r:init:s0 tcontext=u:r:sudaemon:s0 tclass=proc
[ 3.818531] type=1400 audit(1540455861.846:23): avc: granted { read } for pid=1 comm=“init” name=“ttyFIQ0” dev=“tmpfs” ino=16132 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[ 3.818991] type=1400 audit(1540455861.846:23): avc: granted { read } for pid=1 comm=“init” name=“ttyFIQ0” dev=“tmpfs” ino=16132 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[ 3.819019] type=1400 audit(1540455861.846:24): avc: granted { read open } for pid=1 comm=“init” path=“/dev/ttyFIQ0” dev=“tmpfs” ino=16132 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[ 3.821671] type=1400 audit(1540455861.846:24): avc: granted { read open } for pid=1 comm=“init” path=“/dev/ttyFIQ0” dev=“tmpfs” ino=16132 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[ 3.821682] init: setpgid failed for console: Operation not permitted
[ 3.821717] type=1400 audit(1540455861.853:25): avc: granted { read } for pid=291 comm=“init” name=“ttyFIQ0” dev=“tmpfs” ino=16132 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[ 3.824715] type=1400 audit(1540455861.853:25): avc: granted { read } for pid=291 comm=“init” name=“ttyFIQ0” dev=“tmpfs” ino=16132 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[ 3.824767] type=1400 audit(1540455861.853:26): avc: granted { read open } for pid=291 comm=“init” path=“/dev/ttyFIQ0” dev=“tmpfs” ino=16132 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[ 3.825529] init: processing action (ro.boot.mode=emmc) from (/init.rk30board.rc:256)
[ 3.826182] drmboot: disagrees about version of symbol module_layout
[ 3.826288] init: finit_module for “/drmboot.ko” failed: Exec format error
[ 3.826489] init: processing action (ro.factory.hasUMS=false) from (init.rockchip.rc:130)
[ 3.827002] init: processing action (sys.usb.config=mtp,adb && sys.usb.configfs=1) from (init.rk30board.usb.rc:43)
[ 3.827305] init: processing action (sys.usb.config=mtp,adb && sys.usb.configfs=1) from (/init.usb.configfs.rc:33)
[ 3.827562] init: starting service ‘adbd’…
[ 3.832524] init: Created socket ‘/dev/socket/adbd’, mode 660, user 1000, group 1000
[ 3.834512] init: processing action (defaultcrypto) from (/system/etc/init/vdc.rc:2)
[ 3.835147] init: starting service ‘exec 3 (/system/bin/vdc --wait cryptfs mountdefaultencrypted)’…
[ 3.836545] init: SVC_EXEC pid 296 (uid 0 gid 0+0 context default) started; waiting…
[ 3.838248] scsi 0:0:0:0: Direct-Access SanDisk Ultra Fit 1.00 PQ: 0 ANSI: 6
[ 3.841567] healthd: unable to get HAL interface, using defaults
[ 3.842814] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 3.843570] sd 0:0:0:0: [sda] 60062500 512-byte logical blocks: (30.8 GB/28.6 GiB)
[ 3.844286] healthd: BatteryCurrentNowPath not found
[ 3.844317] healthd: BatteryCycleCountPath not found
[ 3.845015] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 3.845114] sd 0:0:0:0: [sda] Write Protect is off
[ 3.846587] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 3.860649] sda: sda1
[ 3.861684] read descriptors
[ 3.861727] read strings
[ 3.864365] init: Service ‘exec 3 (/system/bin/vdc --wait cryptfs mountdefaultencrypted)’ (pid 296) exited with status 0 waiting took 0.029000 seconds
[ 3.868181] sd 0:0:0:0: [sda] Attached SCSI removable disk
rk3399_firefly_aio_mid:/ $ [ 4.411705] E:camsys_extdev_register(258): Request RK30_PIN2_PD4(92) failed
[ 4.422794] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 4.423028] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 4.434132] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 4.434205] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 4.434427] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 4.434648] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 4.434869] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 4.445944] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 4.446179] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 4.456131] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 4.456214] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 4.456434] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 4.456655] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 4.456876] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 4.467911] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 4.468146] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 4.495048] random: nonblocking pool is initialized
[ 4.500088] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 4.500493] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 4.510658] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 4.510793] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 4.511007] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 4.511227] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 4.511448] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 4.522722] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 4.522983] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 4.533475] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 4.533489] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 4.533496] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 4.533502] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 4.533507] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 4.544487] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 4.544734] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 4.898686] init: starting service ‘bootanim’…
[ 5.211621] fsck.f2fs: Info: Fix the reported corruption.
[ 5.211621]
[ 5.211665] fsck.f2fs: Info: Segments per section = 1
[ 5.211665]
[ 5.211674] fsck.f2fs: Info: Sections per zone = 1
[ 5.211674]
[ 5.211683] fsck.f2fs: Info: sector size = 512
[ 5.211683]
[ 5.211691] fsck.f2fs: Info: total sectors = 21531648 (10513 MB)
[ 5.211691]
[ 5.211700] fsck.f2fs: Info: MKFS version
[ 5.211700]
[ 5.211709] fsck.f2fs: “Linux version 4.4.126 (liangkd@tchip-server) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #203 SMP PREEMPT Tue Oct 23 15:54:13 CST 2018”
[ 5.211709]
[ 5.211717] fsck.f2fs: Info: FSCK version
[ 5.211717]
[ 5.211726] fsck.f2fs: from “Linux version 4.4.126 (liangkd@tchip-server) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #203 SMP PREEMPT Tue Oct 23 15:54:13 CST 2018”
[ 5.211726]
[ 5.211735] fsck.f2fs: to “Linux version 4.4.126 (liangkd@tchip-server) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #203 SMP PREEMPT Tue Oct 23 15:54:13 CST 2018”
[ 5.211735]
[ 5.211744] fsck.f2fs: Info: superblock features = 0 :
[ 5.211744]
[ 5.211753] fsck.f2fs: Info: superblock encrypt level = 0, salt = 00000000000000000000000000000000
[ 5.211753]
[ 5.211761] fsck.f2fs: Info: total FS sectors = 21531648 (10513 MB)
[ 5.211761]
[ 5.211769] fsck.f2fs: Info: CKPT version = 60f65ec6
[ 5.211769]
[ 5.211777] fsck.f2fs: Info: No error was reported
[ 5.211777]
[ 5.268302] init: processing action (vold.decrypt=trigger_post_fs_data) from (/init.rc:668)
[ 5.268532] init: processing action (post-fs-data) from (/init.rc:371)
[ 5.302407] init: starting service ‘exec 4 (/system/bin/vdc --wait cryptfs init_user0)’…
[ 5.303327] init: SVC_EXEC pid 378 (uid 0 gid 0+0 context default) started; waiting…
[ 5.318599] init: Service ‘exec 4 (/system/bin/vdc --wait cryptfs init_user0)’ (pid 378) exited with status 0 waiting took 0.016000 seconds
[ 5.318766] selinux: SELinux: Skipping restorecon_recursive(/data)
[ 5.318766]
[ 5.318990] init: starting service ‘exec 5 (/system/bin/tzdatacheck /system/usr/share/zoneinfo /data/misc/zoneinfo)’…
[ 5.319780] init: SVC_EXEC pid 381 (uid 1000 gid 1000+0 context default) started; waiting…
[ 5.328700] init: Service ‘exec 5 (/system/bin/tzdatacheck /system/usr/share/zoneinfo /data/misc/zoneinfo)’ (pid 381) exited with status 0 waiting took 0.009000 seconds
[ 5.328816] init: processing action (post-fs-data) from (/init.usb.rc:6)
[ 5.330198] init: processing action (post-fs-data) from (/init.rk30board.rc:25)
[ 5.331027] init: Unable to find GID for ‘system’: getpwnam failed: No such file or directory
[ 5.331950] init: Unable to open ‘/etc/ppp/pap-secrets’: No such file or directory
[ 5.333607] init: processing action (post-fs-data) from (init.rockchip.rc:38)
[ 5.337700] init: processing action (post-fs-data) from (init.rk3399.rc:37)
[ 5.337867] init: processing action (post-fs-data) from (/system/etc/init/bootstat.rc:3)
[ 5.342990] init: processing action (init.svc.bootanim=running && ro.crypto.type=block && post-fs-data) from (/system/etc/init/bootstat.rc:44)
[ 5.343431] init: starting service ‘exec 6 (/system/bin/bootstat -r post_decrypt_time_elapsed)’…
[ 5.344832] init: SVC_EXEC pid 384 (uid 1000 gid 1007+0 context default) started; waiting…
[ 5.355699] init: Service ‘exec 6 (/system/bin/bootstat -r post_decrypt_time_elapsed)’ (pid 384) exited with status 0 waiting took 0.012000 seconds
[ 5.355821] init: processing action (post-fs-data) from (/system/etc/init/logtagd.rc:4)
[ 5.357544] init: processing action (post-fs-data) from (/vendor/etc/init/hostapd.android.rc:9)
[ 5.358547] init: processing action (vold.decrypt=trigger_load_persist_props) from (/init.rc:663)
[ 5.358611] init: Couldn’t load property file: Unable to open ‘/data/local.prop’: No such file or directory: No such file or directory
[ 5.394693] init: property_set(“ro.persistent_properties.ready”, “true”) failed: property already set
[ 5.395032] init: starting service ‘logd-reinit’…
[ 5.396112] init: property_set(“ro.boottime.logd-reinit”, “5391583766”) failed: property already set
[ 5.396477] init: processing action (vold.decrypt=trigger_restart_framework) from (/init.rc:676)
[ 5.396685] init: ExecStart(update_verifier): Service not found
[ 5.396985] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’: No such file or directory
[ 5.397164] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’: No such file or directory
[ 5.397596] init: service up_eth0 does not have a SELinux domain defined
[ 5.397846] init: cannot find ‘/vendor/bin/rk_store_keybox’, disabling ‘rk_store_keybox’: No such file or directory
[ 5.398064] init: cannot find ‘/system/bin/akmd’, disabling ‘akmd’: No such file or directory
[ 5.398412] init: starting service ‘ril-daemon’…
[ 5.399824] init: starting service ‘zygote’…
[ 5.401322] init: starting service ‘zygote_secondary’…
[ 5.402741] init: starting service ‘audioserver’…
[ 5.402884] init: Created socket ‘/dev/socket/zygote_secondary’, mode 660, user 0, group 1000
[ 5.403096] init: Created socket ‘/dev/socket/zygote’, mode 660, user 0, group 1000
[ 5.404427] init: starting service ‘cameraserver’…
[ 5.405289] init: couldn’t write 401 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 5.405817] init: starting service ‘drm’…
[ 5.407193] init: starting service ‘installd’…
[ 5.408553] init: starting service ‘keystore’…
[ 5.410284] init: starting service ‘mediadrm’…
[ 5.411641] init: starting service ‘mediaextractor’…
[ 5.412795] init: starting service ‘mediametrics’…
[ 5.414017] init: starting service ‘media’…
[ 5.415884] init: starting service ‘netd’…
[ 5.417299] init: starting service ‘storaged’…
[ 5.420125] init: starting service ‘wificond’…
[ 5.421494] init: starting service ‘mediacodec’…
[ 5.423332] init: starting service ‘drmservice’…
[ 5.425291] init: starting service ‘gatekeeperd’…
[ 5.428412] init: cannot find ‘/system/xbin/perfprofd’, disabling ‘perfprofd’: No such file or directory
[ 5.428888] init: starting service ‘tombstoned’…
[ 5.431155] init: Created socket ‘/dev/socket/netd’, mode 660, user 0, group 1000
[ 5.431625] init: Created socket ‘/dev/socket/dnsproxyd’, mode 660, user 0, group 3003
[ 5.431915] init: Created socket ‘/dev/socket/mdns’, mode 660, user 0, group 1000
[ 5.432160] init: Created socket ‘/dev/socket/fwmarkd’, mode 660, user 0, group 3003
[ 5.436672] init: Opened file ‘/d/mmc0/mmc0:0001/ext_csd’, flags 0
[ 5.437392] init: processing action (persist.sys.usb.config=adb && vold.decrypt=trigger_restart_framework) from (/init.rk30board.rc:22)
[ 5.437910] init: Created socket ‘/dev/socket/tombstoned_crash’, mode 666, user 1000, group 1000
[ 5.438262] init: processing action (persist.sys.usb.config=adb && vold.decrypt=trigger_restart_framework) from (/init.rk30board.rc:22)
[ 5.443963] init: Created socket ‘/dev/socket/tombstoned_intercept’, mode 666, user 1000, group 1000
[ 5.444307] init: Created socket ‘/dev/socket/tombstoned_java_trace’, mode 666, user 1000, group 1000
[ 5.452621] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (init.rk30board.usb.rc:64)
[ 5.452885] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (/init.usb.configfs.rc:18)
[ 5.452956] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/init.usb.configfs.rc:21)
[ 5.461736] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (init.rk30board.usb.rc:64)
[ 5.461836] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (/init.usb.configfs.rc:18)
[ 5.461863] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/init.usb.configfs.rc:21)
[ 5.461983] init: Unable to write to ‘/config/usb_gadget/g1/UDC’: Device or resource busy
[ 5.469313] logd.daemon: reinit
[ 5.471193] init: processing action (sys.serialno=) from (/init.rk30board.rc:271)
[ 5.471520] init: Service ‘logd-reinit’ (pid 396) exited with status 0
[ 5.471809] init: Sending signal 9 to service ‘adbd’ (pid 294) process group…
[ 5.472726] configfs-gadget gadget: unbind function ‘Function FS Gadget’/ffffffc069c57c38
[ 5.472819] android_work: did not send uevent (0 0 (null))
[ 5.484688] init: Successfully killed process cgroup uid 0 pid 294 in 12ms
[ 5.485113] init: Service ‘adbd’ (pid 294) killed by signal 9
[ 5.498394] init: Service ‘drmservice’ (pid 413) exited with status 0
[ 5.619301] Freeing drm_logo memory: 820K
[ 5.678818] selinux: avc: denied { set } for property=telephony.lteOnCdmaDevice pid=397 uid=0 gid=1001 scontext=u:r:rild:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
[ 5.678818]
[ 6.023183] type=1400 audit(1540455861.853:26): avc: granted { read open } for pid=291 comm=“init” path=“/dev/ttyFIQ0” dev=“tmpfs” ino=16132 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[ 6.023224] type=1400 audit(1540455864.053:27): avc: denied { execute_no_trans } for pid=462 comm=“HwBinder:271_1” path=“/vendor/bin/sh” dev=“mmcblk0p13” ino=1031 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:vendor_shell_exec:s0 tclass=f
[ 6.038509] type=1400 audit(1540455864.053:27): avc: denied { execute_no_trans } for pid=462 comm=“HwBinder:271_1” path=“/vendor/bin/sh” dev=“mmcblk0p13” ino=1031 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:vendor_shell_exec:s0 tclass=f
[ 6.038561] type=1400 audit(1540455864.070:28): avc: denied { getattr } for pid=462 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk0p13” ino=1077 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 6.039653] type=1400 audit(1540455864.070:28): avc: denied { getattr } for pid=462 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk0p13” ino=1077 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 6.039680] type=1400 audit(1540455864.070:30): avc: denied { read open } for pid=464 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk0p13” ino=1077 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 6.040165] type=1400 audit(1540455864.070:30): avc: denied { read open } for pid=464 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk0p13” ino=1077 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 6.040189] type=1400 audit(1540455864.070:31): avc: denied { execute_no_trans } for pid=464 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk0p13” ino=1077 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 6.081450] init: Untracked pid 467 exited with status 0
[ 6.138847] init: Untracked pid 478 exited with status 0
[ 6.353998] audit: audit_lost=1 audit_rate_limit=20 audit_backlog_limit=64
[ 6.354022] audit: rate limit exceeded
[ 6.946562] init: Untracked pid 470 killed by signal 1
[ 6.960126] init: Untracked pid 481 killed by signal 1
[ 7.413479] capability: warning: `main’ uses 32-bit capabilities (legacy support in use)
[ 8.578818] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 8.603370] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 8.799044] init: processing action (sys.sysctl.extra_free_kbytes=
) from (/init.rc:692)
[ 8.828581] init: starting service ‘adbd’…
[ 8.829568] init: property_set(“ro.boottime.adbd”, “8824976070”) failed: property already set
[ 8.830798] init: Created socket ‘/dev/socket/adbd’, mode 660, user 1000, group 1000
[ 8.835600] read descriptors
[ 8.835661] read strings
[ 8.836363] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/init.usb.configfs.rc:21)
[ 9.243115] acc_open
[ 9.243176] acc_release
[ 9.373412] rk_gmac-dwmac fe300000.ethernet: rk_get_eth_addr: mac address: c6:ec:52:e3:bb:43
[ 9.373430] eth0: device MAC address c6:ec:52:e3:bb:43
[ 9.536521] type=1400 audit(1540455864.070:31): avc: denied { execute_no_trans } for pid=464 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk0p13” ino=1077 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 9.536589] type=1400 audit(1540455867.566:75): avc: denied { read } for pid=406 comm=“Binder:406_1” name=“u:object_r:ctsgts_prop:s0” dev=“tmpfs” ino=16040 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[ 9.536788] type=1400 audit(1540455867.566:75): avc: denied { read } for pid=406 comm=“Binder:406_1” name=“u:object_r:ctsgts_prop:s0” dev=“tmpfs” ino=16040 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[ 9.536821] type=1400 audit(1540455867.566:76): avc: denied { open } for pid=406 comm=“Binder:406_1” path=“/dev/properties/u:object_r:ctsgts_prop:s0” dev=“tmpfs” ino=16040 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[ 9.536961] type=1400 audit(1540455867.566:76): avc: denied { open } for pid=406 comm=“Binder:406_1” path=“/dev/properties/u:object_r:ctsgts_prop:s0” dev=“tmpfs” ino=16040 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[ 9.536990] type=1400 audit(1540455867.566:77): avc: denied { getattr } for pid=406 comm=“Binder:406_1” path=“/dev/properties/u:object_r:ctsgts_prop:s0” dev=“tmpfs” ino=16040 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[ 9.562663] sdcardfs version 2.0
[ 9.562682] sdcardfs: dev_name → /data/media
[ 9.562687] sdcardfs: options → fsuid=1023,fsgid=1023,multiuser,derive_gid,mask=6,userid=0,gid=1015
[ 9.562693] sdcardfs: mnt → ffffffc04d3aac60
[ 9.562737] sdcardfs: mounted on top of /data/media type f2fs
[ 9.569588] Remount options were mask=23,gid=9997 for vfsmnt ffffffc04b8cc020.
[ 9.569614] sdcardfs : options - debug:1
[ 9.569619] sdcardfs : options - gid:9997
[ 9.569623] sdcardfs : options - mask:23
[ 9.571032] Remount options were mask=7,gid=9997 for vfsmnt ffffffc04b8ccc60.
[ 9.571049] sdcardfs : options - debug:1
[ 9.571053] sdcardfs : options - gid:9997
[ 9.571057] sdcardfs : options - mask:7
[ 9.630632] init: starting service ‘webview_zygote32’…
[ 9.642482] init: Created socket ‘/dev/socket/webview_zygote’, mode 660, user 1053, group 1000
[ 11.193552] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 11.212898] sdcardfs version 2.0
[ 11.212969] sdcardfs: dev_name → /mnt/media_rw/28A4-542D
[ 11.212978] sdcardfs: options → fsuid=1023,fsgid=1023,mask=6,userid=0,gid=1015
[ 11.212983] sdcardfs: mnt → ffffffc064d43520
[ 11.213037] sdcardfs: mounted on top of /mnt/media_rw/28A4-542D type vfat
[ 11.214458] Remount options were mask=18,gid=9997 for vfsmnt ffffffc04b8b8c60.
[ 11.214476] sdcardfs : options - debug:1
[ 11.214480] sdcardfs : options - gid:9997
[ 11.214485] sdcardfs : options - mask:18
[ 11.215893] Remount options were mask=18,gid=9997 for vfsmnt ffffffc04b8b9c20.
[ 11.215907] sdcardfs : options - debug:1
[ 11.215911] sdcardfs : options - gid:9997
[ 11.215914] sdcardfs : options - mask:18
[ 11.531642] init: Service ‘bootanim’ (pid 368) exited with status 0
[ 11.669255] init: processing action (sys.boot_completed=1) from (/init.rc:686)
[ 11.669565] init: processing action (sys.boot_completed=1) from (/init.rk30board.rc:230)
[ 11.671956] init: cannot find ‘/system/bin/glgps’, disabling ‘gpsd’: No such file or directory
[ 11.672153] init: starting service ‘mode_switch’…
[ 11.673533] type=1400 audit(1540455867.566:77): avc: denied { getattr } for pid=406 comm=“Binder:406_1” path=“/dev/properties/u:object_r:ctsgts_prop:s0” dev=“tmpfs” ino=16040 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[ 11.673589] type=1400 audit(1540455869.703:78): avc: denied { entrypoint } for pid=1010 comm=“init” path=“/system/bin/usb_mode_switch.sh” dev=“mmcblk0p11” ino=1551 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[ 11.676957] type=1400 audit(1540455869.703:78): avc: denied { entrypoint } for pid=1010 comm=“init” path=“/system/bin/usb_mode_switch.sh” dev=“mmcblk0p11” ino=1551 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[ 11.677011] type=1400 audit(1540455869.706:79): avc: denied { getattr } for pid=1010 comm=“usb_mode_switch” path=“/system/bin/sh” dev=“mmcblk0p11” ino=1451 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 11.679029] type=1400 audit(1540455869.706:79): avc: denied { getattr } for pid=1010 comm=“usb_mode_switch” path=“/system/bin/sh” dev=“mmcblk0p11” ino=1451 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 11.679066] type=1400 audit(1540455869.710:80): avc: denied { read } for pid=1010 comm=“usb_mode_switch” path=“/system/bin/sh” dev=“mmcblk0p11” ino=1451 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 11.680271] init: processing action (sys.boot_completed=1) from (init.rk3399.rc:1)
[ 11.680754] init: processing action (sys.boot_completed=1 && sys.logbootcomplete=1) from (/system/etc/init/bootstat.rc:66)
[ 11.681012] init: starting service ‘exec 7 (/system/bin/bootstat --record_boot_complete)’…
[ 11.683012] init: SVC_EXEC pid 1011 (uid 1000 gid 1007+0 context default) started; waiting…
[ 11.687346] type=1400 audit(1540455869.710:80): avc: denied { read } for pid=1010 comm=“usb_mode_switch” path=“/system/bin/sh” dev=“mmcblk0p11” ino=1451 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 11.687434] type=1400 audit(1540455869.716:81): avc: denied { read } for pid=1010 comm=“usb_mode_switch” name=“usb_mode_switch.sh” dev=“mmcblk0p11” ino=1551 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[ 11.687641] type=1400 audit(1540455869.716:81): avc: denied { read } for pid=1010 comm=“usb_mode_switch” name=“usb_mode_switch.sh” dev=“mmcblk0p11” ino=1551 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[ 11.687659] type=1400 audit(1540455869.716:82): avc: denied { open } for pid=1010 comm=“usb_mode_switch” path=“/system/bin/usb_mode_switch.sh” dev=“mmcblk0p11” ino=1551 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[ 11.689956] type=1400 audit(1540455869.716:82): avc: denied { open } for pid=1010 comm=“usb_mode_switch” path=“/system/bin/usb_mode_switch.sh” dev=“mmcblk0p11” ino=1551 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[ 11.690026] type=1400 audit(1540455869.720:83): avc: denied { getattr } for pid=1012 comm=“usb_mode_switch” path=“/system/bin/toybox” dev=“mmcblk0p11” ino=1586 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 11.691747] type=1400 audit(1540455869.720:83): avc: denied { getattr } for pid=1012 comm=“usb_mode_switch” path=“/system/bin/toybox” dev=“mmcblk0p11” ino=1586 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 11.691775] type=1400 audit(1540455869.720:84): avc: denied { execute } for pid=1012 comm=“usb_mode_switch” name=“toybox” dev=“mmcblk0p11” ino=1586 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 11.691909] type=1400 audit(1540455869.720:84): avc: denied { execute } for pid=1012 comm=“usb_mode_switch” name=“toybox” dev=“mmcblk0p11” ino=1586 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 11.691924] type=1400 audit(1540455869.720:85): avc: denied { read open } for pid=1012 comm=“usb_mode_switch” path=“/system/bin/toybox” dev=“mmcblk0p11” ino=1586 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 11.692022] type=1400 audit(1540455869.720:85): avc: denied { read open } for pid=1012 comm=“usb_mode_switch” path=“/system/bin/toybox” dev=“mmcblk0p11” ino=1586 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 11.692036] type=1400 audit(1540455869.720:86): avc: denied { execute_no_trans } for pid=1012 comm=“usb_mode_switch” path=“/system/bin/toybox” dev=“mmcblk0p11” ino=1586 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 11.704388] init: Service ‘exec 7 (/system/bin/bootstat --record_boot_complete)’ (pid 1011) exited with status 0 waiting took 0.023000 seconds
[ 11.705244] init: starting service ‘exec 8 (/system/bin/bootstat --record_boot_reason)’…
[ 11.706460] init: SVC_EXEC pid 1013 (uid 1000 gid 1007+0 context default) started; waiting…
[ 11.708443] type=1400 audit(1540455869.720:86): avc: denied { execute_no_trans } for pid=1012 comm=“usb_mode_switch” path=“/system/bin/toybox” dev=“mmcblk0p11” ino=1586 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 11.708491] type=1400 audit(1540455869.740:87): avc: denied { getattr } for pid=1010 comm=“usb_mode_switch” path=“/sys/kernel/debug/usb@fe800000/rk_usb_force_mode” dev=“debugfs” ino=8177 scontext=u:r:mode_switch:s0 tcontext=u:object_r:debugfs:s0 tclass=f
[ 11.708674] type=1400 audit(1540455869.740:87): avc: denied { getattr } for pid=1010 comm=“usb_mode_switch” path=“/sys/kernel/debug/usb@fe800000/rk_usb_force_mode” dev=“debugfs” ino=8177 scontext=u:r:mode_switch:s0 tcontext=u:object_r:debugfs:s0 tclass=f
[ 11.708696] type=1400 audit(1540455869.740:88): avc: denied { write } for pid=1010 comm=“usb_mode_switch” name=“rk_usb_force_mode” dev=“debugfs” ino=8177 scontext=u:r:mode_switch:s0 tcontext=u:object_r:debugfs:s0 tclass=f
[ 11.708793] type=1400 audit(1540455869.740:88): avc: denied { write } for pid=1010 comm=“usb_mode_switch” name=“rk_usb_force_mode” dev=“debugfs” ino=8177 scontext=u:r:mode_switch:s0 tcontext=u:object_r:debugfs:s0 tclass=f
[ 11.708806] type=1400 audit(1540455869.740:89): avc: denied { open } for pid=1010 comm=“usb_mode_switch” path=“/sys/kernel/debug/usb@fe800000/rk_usb_force_mode” dev=“debugfs” ino=8177 scontext=u:r:mode_switch:s0 tcontext=u:object_r:debugfs:s0 tclass=f
[ 11.719272] init: Service ‘exec 8 (/system/bin/bootstat --record_boot_reason)’ (pid 1013) exited with status 0 waiting took 0.014000 seconds
[ 11.720439] init: starting service ‘exec 9 (/system/bin/bootstat --record_time_since_factory_reset)’…
[ 11.722031] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 11.722318] init: SVC_EXEC pid 1016 (uid 1000 gid 1007+0 context default) started; waiting…
[ 11.722697] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 7
[ 11.725594] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 11.725656] xhci-hcd xhci-hcd.10.auto: irq 235, io mem 0xfe800000
[ 11.725845] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 11.725860] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.725869] usb usb7: Product: xHCI Host Controller
[ 11.725878] usb usb7: Manufacturer: Linux 4.4.126 xhci-hcd
[ 11.725885] usb usb7: SerialNumber: xhci-hcd.10.auto
[ 11.728121] hub 7-0:1.0: USB hub found
[ 11.728197] hub 7-0:1.0: 1 port detected
[ 11.728504] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 11.729453] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 8
[ 11.729564] usb usb8: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 11.729660] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[ 11.729673] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.729682] usb usb8: Product: xHCI Host Controller
[ 11.729691] usb usb8: Manufacturer: Linux 4.4.126 xhci-hcd
[ 11.729698] usb usb8: SerialNumber: xhci-hcd.10.auto
[ 11.732011] hub 8-0:1.0: USB hub found
[ 11.732083] hub 8-0:1.0: 1 port detected
[ 11.732394] rockchip-dwc3 usb@fe800000: USB HOST connected
[ 11.732462] init: Service ‘exec 9 (/system/bin/bootstat --record_time_since_factory_reset)’ (pid 1016) exited with status 0 waiting took 0.012000 seconds
[ 11.733648] init: starting service ‘exec 10 (/system/bin/bootstat -l)’…
[ 11.734925] init: SVC_EXEC pid 1017 (uid 1000 gid 1007+0 context default) started; waiting…
[ 11.735157] init: Service ‘mode_switch’ (pid 1010) exited with status 0
[ 11.753214] init: Service ‘exec 10 (/system/bin/bootstat -l)’ (pid 1017) exited with status 0 waiting took 0.020000 seconds
[ 11.753598] init: processing action (sys.boot_completed=1 && sys.wifitracing.started=0) from (/system/etc/init/wifi-events.rc:20)
[ 11.821857] init: processing action (sys.usb.config=none && sys.usb.configfs=1) from (init.rk30board.usb.rc:31)
[ 11.822080] init: processing action (sys.usb.config=none && sys.usb.configfs=1) from (/init.usb.configfs.rc:1)
[ 11.822285] configfs-gadget gadget: unbind function ‘Function FS Gadget’/ffffffc069c57c38
[ 11.822374] android_work: did not send uevent (0 0 (null))
[ 11.822542] init: Sending signal 9 to service ‘adbd’ (pid 586) process group…
[ 11.828030] init: Successfully killed process cgroup uid 0 pid 586 in 5ms
[ 11.828500] init: Service ‘adbd’ (pid 586) killed by signal 9
[ 11.830154] init: processing action (init.svc.adbd=stopped) from (init.rk30board.usb.rc:35)
[ 11.830181] init: processing action (init.svc.adbd=stopped) from (/init.usb.configfs.rc:15)
[ 11.871886] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (init.rk30board.usb.rc:64)
[ 11.872012] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (/init.usb.configfs.rc:18)
[ 11.872095] init: starting service ‘adbd’…
[ 11.873208] init: property_set(“ro.boottime.adbd”, “11868531542”) failed: property already set
[ 11.874705] init: Created socket ‘/dev/socket/adbd’, mode 660, user 1000, group 1000
[ 11.893672] read descriptors
[ 11.893718] read strings
[ 11.896694] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/init.usb.configfs.rc:21)
[ 11.897446] dwc3 fe800000.dwc3: failed to enable ep0out
[ 11.941997] init: processing action (sys.usb.config=none && sys.usb.configfs=1) from (init.rk30board.usb.rc:31)
[ 11.942245] init: processing action (sys.usb.config=none && sys.usb.configfs=1) from (/init.usb.configfs.rc:1)
[ 11.942469] configfs-gadget gadget: unbind function ‘Function FS Gadget’/ffffffc068b26038
[ 11.942803] android_work: did not send uevent (0 0 (null))
[ 11.943270] init: Sending signal 9 to service ‘adbd’ (pid 1080) process group…
[ 11.949175] init: Successfully killed process cgroup uid 0 pid 1080 in 5ms
[ 11.950850] init: Service ‘adbd’ (pid 1080) killed by signal 9
[ 11.953841] init: processing action (init.svc.adbd=stopped) from (init.rk30board.usb.rc:35)
[ 11.954750] init: processing action (init.svc.adbd=stopped) from (/init.usb.configfs.rc:15)
[ 11.992974] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (init.rk30board.usb.rc:64)
[ 11.993072] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (/init.usb.configfs.rc:18)
[ 11.993128] init: starting service ‘adbd’…
[ 11.994872] init: Created socket ‘/dev/socket/adbd’, mode 660, user 1000, group 1000
[ 11.996035] init: property_set(“ro.boottime.adbd”, “11989541721”) failed: property already set
[ 12.001217] read descriptors
[ 12.001461] read strings
[ 12.002027] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/init.usb.configfs.rc:21)
[ 12.002774] dwc3 fe800000.dwc3: failed to enable ep0out
[ 15.302526] type=1400 audit(1540455869.740:89): avc: denied { open } for pid=1010 comm=“usb_mode_switch” path=“/sys/kernel/debug/usb@fe800000/rk_usb_force_mode” dev=“debugfs” ino=8177 scontext=u:r:mode_switch:s0 tcontext=u:object_r:debugfs:s0 tclass=f
[ 15.302602] type=1400 audit(1540455873.330:90): avc: denied { read } for pid=1127 comm=“.update.service” name=“u:object_r:serialno_prop:s0” dev=“tmpfs” ino=16054 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=f
[ 15.303045] type=1400 audit(1540455873.330:90): avc: denied { read } for pid=1127 comm=“.update.service” name=“u:object_r:serialno_prop:s0” dev=“tmpfs” ino=16054 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=f
[ 15.303084] type=1400 audit(1540455873.333:91): avc: denied { open } for pid=1127 comm=“.update.service” path=“/dev/properties/u:object_r:serialno_prop:s0” dev=“tmpfs” ino=16054 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=f
[ 15.303289] type=1400 audit(1540455873.333:91): avc: denied { open } for pid=1127 comm=“.update.service” path=“/dev/properties/u:object_r:serialno_prop:s0” dev=“tmpfs” ino=16054 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=f
[ 15.303321] type=1400 audit(1540455873.333:92): avc: denied { getattr } for pid=1127 comm=“.update.service” path=“/dev/properties/u:object_r:serialno_prop:s0” dev=“tmpfs” ino=16054 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=f
[ 63.845194] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
1500000
RakeshDesai Posted at 11/7/2018 18:12
Hi Leung,
Pls see debug log :
I had found out the problem . It will be fixed later .
The content of the article is thought-provoking, and I’ve learned a lot from it. Free Reliable CAS-005 test pass4sure resources for exam success. Wishing you the best!
The content is excellent, and I’m giving it a like. Get the New JN0-253 learning materials test that contributed to my promotion and salary raise, available for free today. Best wishes for your career!
我々社のSalesforce AP-205問題集を使用して試験に合格しないで全額での返金を承諾するのは弊社の商品に不自信ではなく、行為でもって我々の誠意を示します。Salesforce AP-205問題集の専業化であれば、アフタサービスの細心であれば、我々MogiExamはお客様を安心に購買して利用させます。お客様の満足は我々の進む力です。
I’m grateful for the inspiration this article provides, thanks for sharing! With Latest CHRP-KE cram materials, you get access to valuable content at no cost, designed for your benefit.
