MIPI camera not working with default Android 7.1.2 image
I connected the OV13850 camera board to J22 on my Firefly-RK3399 (that is the RX-only CSI MIPI channel on PHY2). I am using the default Android 7.1.2 image, and the camera is not recognised. Is this expected?
It is not clear to me whether I need to build a custom image or just make some changes to files on the board. The documentation on configuration does not explain anything much, so I would appreciate a complete explanation..
I have been looking at the XML configuration file on your web site at
http://en.t-firefly.com/doc/product/info/id/287.html
under the heading/sub-heading
Configuration Steps/Android Layer Configuration
I wanted to compare it with the file /system/etc/cam_board.xml on my Firefly board. To make it more readable I ran it through this online XML to JSON converter
https://www.browserling.com/tools/xml-to-json
The converter complained of errors when trying to parse this XML,
so I corrected the errors, saving the file (with DOS newlines) as
web-corrected.xml
This file still has a lot of trailing spaces, so I removed them, making file web-corrected-nosp.xml
I have pasted both files below.
File web-corrected.xml
<?xml version="1.0" ?>
<BoardFile>
<BoardXmlVersion version="v0.0xf.0">
</BoardXmlVersion>
<CamDevie>
<HardWareInfo>
<Sensor>
<SensorName name="OV13850" ></SensorName>
<SensorDevID IDname="CAMSYS_DEVID_SENSOR_1A"></SensorDevID>
<SensorHostDevID busnum="CAMSYS_DEVID_MARVIN" ></SensorHostDevID>
<SensorI2cBusNum busnum="1"></SensorI2cBusNum>
<SensorI2cAddrByte byte="2"></SensorI2cAddrByte>
<SensorI2cRate rate="100000"></SensorI2cRate>
<SensorAvdd name="NC" min="28000000" max="28000000" delay="0"></SensorAvdd>
<SensorDvdd name="NC" min="12000000" max="12000000" delay="0"></SensorDvdd>
<SensorDovdd name="NC" min="18000000" max="18000000" delay="5000"></SensorDovdd>
<SensorMclk mclk="24000000" delay="1000"></SensorMclk>
<SensorGpioPwen ioname="RK30_PIN1_PC7" active="1" delay="1000"></SensorGpioPwen>
<SensorGpioRst ioname="RK30_PIN0_PB0" active="1" delay="1000"></SensorGpioRst>
<SensorGpioPwdn ioname="NC" active="0" delay="0"></SensorGpioPwdn>
<SensorFacing facing="back"></SensorFacing>
<SensorInterface interface="MIPI"></SensorInterface>
<SensorMirrorFlip mirror="0"></SensorMirrorFlip>
<SensorOrientation orientation="0"></SensorOrientation>
<SensorPowerupSequence seq="1234"></SensorPowerupSequence>
<SensorFovParemeter h="60.0" v="60.0"></SensorFovParemeter>
<SensorAWB_Frame_Skip fps="15"></SensorAWB_Frame_Skip>
<SensorPhy phyMode="CamSys_Phy_Mipi" lane="2" phyIndex="1" sensorFmt="CamSys_Fmt_Raw_10b"></SensorPhy>
</Sensor>
<VCM>
<VCMDrvName name="BuiltInSensor"></VCMDrvName>
<VCMName name="NC"></VCMName>
<VCMI2cBusNum busnum="3"></VCMI2cBusNum>
<VCMI2cAddrByte byte="0"></VCMI2cAddrByte>
<VCMI2cRate rate="0"></VCMI2cRate>
<VCMVdd name="NC" min="0" max="0"></VCMVdd>
<VCMGpioPwdn ioname="NC" active="0"></VCMGpioPwdn>
<VCMGpioPower ioname="NC" active="0"></VCMGpioPower>
<VCMCurrent start="20" rated="80" vcmmax="100" stepmode="13"  drivermax="100"></VCMCurrent>
</VCM><Flash>
<FlashName name="Internal"></FlashName>
<FlashI2cBusNum busnum="0"></FlashI2cBusNum>
<FlashI2cAddrByte byte="0"></FlashI2cAddrByte>
<FlashI2cRate rate="0"></FlashI2cRate>
<FlashTrigger ioname="NC" active="0"></FlashTrigger>
<FlashEn ioname="NC" active="0"></FlashEn>
<FlashModeType mode="1"></FlashModeType>
<FlashLuminance luminance="0"></FlashLuminance>
<FlashColorTemp colortemp="0"></FlashColorTemp>
</Flash></HardWareInfo> <SoftWareInfo>
<AWB>
<AWB_Auto support="1"></AWB_Auto>
<AWB_Incandescent support="1"></AWB_Incandescent>
<AWB_Fluorescent support="1"></AWB_Fluorescent>
<AWB_Warm_Fluorescent support="1"></AWB_Warm_Fluorescent>
<AWB_Daylight support="1"></AWB_Daylight>
<AWB_Cloudy_Daylight support="1"></AWB_Cloudy_Daylight>
<AWB_Twilight support="1"></AWB_Twilight>
<AWB_Shade support="1"></AWB_Shade>
</AWB>
<Sence>
<Sence_Mode_Auto support="1"></Sence_Mode_Auto>
<Sence_Mode_Action support="1"></Sence_Mode_Action>
<Sence_Mode_Portrait support="1"></Sence_Mode_Portrait>
<Sence_Mode_Landscape support="1"></Sence_Mode_Landscape>
<Sence_Mode_Night support="1"></Sence_Mode_Night>
<Sence_Mode_Night_Portrait support="1"></Sence_Mode_Night_Portrait>
<Sence_Mode_Theatre support="1"></Sence_Mode_Theatre>
<Sence_Mode_Beach support="1"></Sence_Mode_Beach>
<Sence_Mode_Snow support="1"></Sence_Mode_Snow>
<Sence_Mode_Sunset support="1"></Sence_Mode_Sunset>
<Sence_Mode_Steayphoto support="1"></Sence_Mode_Steayphoto>
<Sence_Mode_Pireworks support="1"></Sence_Mode_Pireworks>
<Sence_Mode_Sports support="1"></Sence_Mode_Sports>
<Sence_Mode_Party support="1"></Sence_Mode_Party>
<Sence_Mode_Candlelight support="1"></Sence_Mode_Candlelight>
<Sence_Mode_Barcode support="1"></Sence_Mode_Barcode>
<Sence_Mode_HDR support="1"></Sence_Mode_HDR>
</Sence>
<Effect>
<Effect_None support="1"></Effect_None>
<Effect_Mono support="1"></Effect_Mono>
<Effect_Solarize support="1"></Effect_Solarize>
<Effect_Negative support="1"></Effect_Negative>
<Effect_Sepia support="1"></Effect_Sepia>
<Effect_Posterize support="1"></Effect_Posterize>
<Effect_Whiteboard support="1"></Effect_Whiteboard>
<Effect_Blackboard support="1"></Effect_Blackboard>
<Effect_Aqua support="1"></Effect_Aqua>
</Effect>
<FocusMode>
<Focus_Mode_Auto support="1"></Focus_Mode_Auto>
<Focus_Mode_Infinity support="1"></Focus_Mode_Infinity>
<Focus_Mode_Marco support="1"></Focus_Mode_Marco>
<Focus_Mode_Fixed support="1"></Focus_Mode_Fixed>
<Focus_Mode_Edof support="1"></Focus_Mode_Edof>
<Focus_Mode_Continuous_Video support="0"></Focus_Mode_Continuous_Video>
<Focus_Mode_Continuous_Picture support="1"></Focus_Mode_Continuous_Picture></FocusMode>
<FlashMode>
<Flash_Mode_Off support="1"></Flash_Mode_Off>
<Flash_Mode_On support="1"></Flash_Mode_On>
<Flash_Mode_Torch support="1"></Flash_Mode_Torch>
<Flash_Mode_Auto support="1"></Flash_Mode_Auto>
<Flash_Mode_Red_Eye support="1"></Flash_Mode_Red_Eye>
</FlashMode>
<AntiBanding>
<Anti_Banding_Auto support="1"></Anti_Banding_Auto>
<Anti_Banding_50HZ support="1"></Anti_Banding_50HZ>
<Anti_Banding_60HZ support="1"></Anti_Banding_60HZ>
<Anti_Banding_Off support="1"></Anti_Banding_Off>
</AntiBanding>
<HDR support="1"></HDR>
<ZSL support="1"></ZSL>
<DigitalZoom support="1"></DigitalZoom>
<Continue_SnapShot support="1"></Continue_SnapShot>
<PreviewSize width="800" height="600"></PreviewSize>
<DV>
<DV_QCIF name="qcif" width="176" height="144" fps="10" support="1"></DV_QCIF>
<DV_QVGA name="qvga" width="320" height="240" fps="10" support="1"></DV_QVGA>
<DV_CIF name="cif" width="352" height="288" fps="10" support="1"></DV_CIF>
<DV_VGA name="480p" width="640" height="480" fps="10" support="0"></DV_VGA>
<DV_480P name="480p" width="720" height="480" fps="10" support="0"></DV_480P>
<DV_720P name="720p" width="1280" height="720" fps="10" support="1"></DV_720P>
<DV_1080P name="1080p" width="1920" height="1080" fps="10" support="1"></DV_1080P>
</DV>
</SoftWareInfo>
</CamDevie>
//DVP
<CamDevie>
<HardWareInfo>
<Sensor>
<SensorName name="OV5640" ></SensorName>
<SensorDevID IDname="CAMSYS_DEVID_SENSOR_2"></SensorDevID>
<SensorI2cBusNum busnum="4"></SensorI2cBusNum>
<SensorMclk mclk="24000000"></SensorMclk>
<SensorAvdd name="NC" min="0" max="0"></SensorAvdd>
<SensorDovdd name="NC" min="18000000" max="18000000"></SensorDovdd>
<SensorDvdd name="NC" min="0" max="0"></SensorDvdd>
<SensorGpioPwen ioname="NC" active="1"></SensorGpioPwen>
<SensorGpioRst ioname="NC" active="0"></SensorGpioRst>
<SensorGpioPwdn ioname="RK30_PIN2_PB4" active="1"></SensorGpioPwdn>
<SensorFacing facing="front"></SensorFacing>
<SensorInterface mode="CCIR601"></SensorInterface>
<SensorPhy phyMode="CamSys_Phy_Cif" sensor_d0_to_cif_d="0" cif_num="0" sensorFmt="CamSys_Fmt_Raw_10b"></SensorPhy>
</Sensor>
<VCM><VCMDrvName name="NC"></VCMDrvName>
<VCMI2cBusNum busnum="0"></VCMI2cBusNum>
<VCMI2cAddrByte byte="0"></VCMI2cAddrByte><VCMI2cRate rate="0"></VCMI2cRate>
<VCMCurrent start="20" rated="80" vcmmax="100" stepmode="13"  drivermax="100"></VCMCurrent></VCM>
<Flash>
<FlashName name="NC"></FlashName>
<FlashTrigger ioname="NC" active="1"></FlashTrigger>
<FlashEn ioname="NC" active="1"></FlashEn>
<FlashModeType mode="0"></FlashModeType>
<FlashColorTemp colortemp="0"></FlashColorTemp></Flash>
</HardWareInfo>
<SoftWareInfo>
<AWB>
<AWB_Shade support="1"></AWB_Shade></AWB>
<Sence>
</Sence>
<Effect>
</Effect><FocusMode><Focus_Mode_Auto support="0"></Focus_Mode_Auto>
<Focus_Mode_Infinity support="0"></Focus_Mode_Infinity>
<Focus_Mode_Marco support="0"></Focus_Mode_Marco>
<Focus_Mode_Fixed support="0"></Focus_Mode_Fixed>
<Focus_Mode_Edof support="0"></Focus_Mode_Edof>
<Focus_Mode_Continuous_Picture support="0"></Focus_Mode_Continuous_Picture>
</FocusMode>
<FlashMode>
</FlashMode>
<AntiBanding>
<Anti_Banding_Off support="1"></Anti_Banding_Off></AntiBanding>
<DV>
<DV_VGA name="480p" width="640" height="480" fps="10" support="1"></DV_VGA>
<DV_720P name="720p" width="1280" height="720" fps="10" support="0"></DV_720P>
<DV_1080P name="1080p" width="1920" height="1080" fps="10" support="0"></DV_1080P>
</DV>
</SoftWareInfo>
</CamDevie>
</BoardFile>
File web-corrected-nosp.xml
<BoardFile>
</BoardXmlVersion>
<CamDevie>
<HardWareInfo>
<Sensor>
</Sensor>
<VCM>
</VCM><Flash>
<AWB>
</AWB>
<Sence>
</Sence>
<Effect>
</Effect>
<FocusMode>
<FlashMode>
</FlashMode>
<AntiBanding>
</AntiBanding>
<DV>
</DV>
</SoftWareInfo>
</CamDevie>
//DVP
<CamDevie>
<HardWareInfo>
<Sensor>
</Sensor>
<Flash>
</HardWareInfo>
<SoftWareInfo>
<AWB>
<Sence>
</Sence>
<Effect>
</FocusMode>
<FlashMode>
</FlashMode>
<AntiBanding>
<DV>
</DV>
</SoftWareInfo>
</CamDevie>
</BoardFile>
Officail Firmware is okay with ov13850
Just make sure your board connecting and camera module.
http://en.t-firefly.com/doc/product/info/id/267.html
Clicking the like button immediately—this is brilliant. The Latest study guide JN0-351 files content is highly useful, and it’s offered free of charge.
The article is very empowering, thanks for sharing! The Reliable CT-UT exam bootcamp materials questions are shared for free. Good luck on your exams!
JPTestKingのArch-301試験トレントの合格率は、効果的で有用を証明する唯一の基準であるというのは常識です。 Arch-301試験問題の利点についての一般的な考えは既にお持ちのことと思いますが、Arch-301ガイドトレントの最大の強みである最高の合格率をお見せしたいと思います。 Salesforce統計によると、Arch-301ガイドトレントのガイダンスに従って試験を準備したお客様の合格率は、98〜100%に達し、Arch-301試験トレントを20〜30時間しか練習していません。
우리DumpTOP가 제공하는 최신, 최고의Google Professional-Cloud-DevOps-Engineer시험관련 자료를 선택함으로 여러분은 이미 시험패스성공이라고 보실수 있습니다.
