Dear All,
Just bought your board and tring to compile ubuntu and kernel , install them on board.
- From your web side “http://en.t-firefly.com/index.php/doc/product/info/id/290.html” and for kernel side says "After the compilation is complete , the kernel.img and resource.img should be generated in the kernel folder.
If you need to compile a xxx.dts in the arch/arm64/boot/dts/rockchip/ directory, then
make xxx.img -j4".Which dts file must be used for this rk3399 board?
2.Parameter file:
CMDLINE:console=ttyFIQ0 root=/dev/mmcblk1p6 rw rootwait
mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),
0x00008000@0x00006000(resource),0x0000A000@0x0000E000(kernel),
[0x00002000@0x00018000(backup),-@0x0001A000(boot](mailto:0x00002000@0x00018000(backup),-@0x0001A000(boot))
root=/dev/mmcblk1p6 —> rootfs partition
If the size of the root file partition is abnormal,
resize2fs /dev/mmcblk1p6
0x0000A000@0x0000E000(kernel) —> kernel partition
kernel —> partition name
0x0000E000 —> partition start address
0x0000A000 —> partition size, generally do not need to pay attention
sudo upgrade_tool di kernel kernel.img
sudo upgrade_tool di boot rootfs.img
kernel —> on the parameter partition name
kernel.img —> Compiled production kernel.img partition image
Document says a parameter file but i could find it.Where can i find it?Also I couldnt find rootfs file.
Where can i find any video or pdf document that explains all steps.Could you pls help me about these subjects.
Best regards,
