Unable to use emmc drive
Hi, folks.
I am now unable to boot from emmc drive. Did clean it with blkdiscard /dev/mmcblk1. I am unable to flash all firmware images with upgrade_tool (using debian 18.04 host) through usb-c cable. The error messages are “Test Device Fail” and “Creating Comm Object failed!” when using “upgrade_tool uf Firefly-RK3399_LinuxSDK_xubuntu16.04_20181011.img”. I only able to boot from the Firefly-rk3399_xubuntu1604_SD_201705151725.img. This is getting frustrating. The documentation will not help in this case.
Is it somehow possible to flash the emmc drive with or without upgrade_tool?
Try to dd Firefly-rk3399_xubuntu1604_SD_201705151725.img directly to /dev/mmcblk1 . It might work.
Please try another USB port in your PC for upgrade_tool to work. In my case, I often find the USB 3.0 port
has more luck than the USB 2.0 port. YMMV.
Did you also try to flash the firmware to eMMC in MaskRom mode? (But if you clear the eMMC, it should go
to that mode. In case of something wrong, you can follow the instructions in the Wiki to force into MaskRom
mode. )
Seems you have found the solution: start with sd boot and wipe eMMC
penguin Posted at 12/11/2018 17:36
@penguin That is exactly what i did. Got the firefly SD image from 2017 and did use etcher to put in on SD. Then I could boot firefly rk3399 and wipe out emmc drive and make new ext4 file system. Thanks for your advice.
Your article was incredibly refreshing, thank you. Level up your IT knowledge with free New test BUS105 questions explanations. Wishing you success in all your endeavors!
Sie haben einen großen Traum. Sie können viele Materialien zur Vorbereitung finden. Unsere Fragenkataloge zur Oracle 1Z1-947 Zertifizierungsprüfung können Ihren Traum verwirklichen. Die Fragen und Antworten zur Oracle 1Z1-947 Zertifizierungsprüfung von ExamFragen werden von den erfahrungsreichen IT-Fachleuten bearbeitet. Mit unseren Produkten können Sie alle Probleme versuchen. Wir würden Ihnen versprechen, dass die Kandidaten die realen Antworten 100% bekommen.
Your article really made an impact on me, I’m truly grateful. The C_BCBTP_2502 reliable exam camp sheet exam questions are available for free. Wishing you the best in your exams!
Thank you for your article, it was so insightful and inspiring. Today, I’m giving you the AP-213 latest test study guide questions that helped me secure a promotion and a raise—for free!
That article was nothing less than inspiring. This ITIL-4-CDS reasonable exam price helped me get promoted and enjoy a salary raise. It’s now free to everyone. Best wishes for your career advancements!
