How to use dual mipi-csi camera on Firefly-RK3399?
The content is as shown by the title.
I wanna know about that.
I used the camera using ‘gst-launch-1.0’ and got a green screen.
  • Is the use of gst-launch-1.0 correct?
  • Or is there another way?
I have confirmed that one camera is working, but I don’t know how to use two cameras.
  • How to use dual mipi-camera on Firefly-RK3399 ??
ubuntu cannot support csi-mipi cameraOnly Debian can use one csi-mipi.
leung先森 Posted at 12/11/2018 15:57
okay. thanks for reply.
It’s not generous about the camera.
hmm. one more question.
will there be support for ‘dual MPi-csi’ cameras from Devian OS in the future?
this is very important for me in deciding to use ‘Firefly-RK3399’ as a development board in the future.
There’s no estimated date yet. ‘dual MPi-csi’ cameras have been supported in Android.
We’ll work with the upstream vendor to sort thing out in Linux at our best effort.
penguin Posted at 12/13/2018 10:23
We’ll work wi …
Good.
I don’t know how long it will take, but I wonder what will happen.
Have a great day.
I worked on it last year. Two cameras work simultaneously fine. If you wish. I can share my sources of the kernel with support of two imx219 sensors. You can edit it for work with another sensors.
Hi @alexanib , it would be nice to see your kernel with support of two imx219 sensors in github.
alexanib Posted at 4/5/2019 02:06
I worked on it last year. Two cameras work simultaneously fine. If you wish. I can share my sources …
Can you give me a code link for imx219?
Hi,
I am facing issue to integrate binocular camera module (SV-TAYSH-TQ). We are struggling with support team to fix this from Dec-2020. Still no resolution. We are using firefly-SDK for linux development, not android. Help us to resolve if you have a solution to it.
Thanks
Your article was truly stunning, thank you for sharing! Free TDA-C01 test online exam questions—best of luck to all exam candidates!
Your article took my breath away, thank you for sharing! The Reliable ITIL-4-Transition exam camp sheet exam questions are key to advancing in your career—get them for free!
Wenn Sie sich noch anstrengend um die Salesforce Sales-Con-201 Zertifizierungsprüfung bemühen, dann haben Sie einen großen Fehler gemacht. Durch fleißiges Lernen können Sie sicher die Prüfung bestehen. Aber Sie können vielleicht das erwartete Ziel vielleicht nicht erreichen. Im Zeitalter des Internets gibt es zahlreiche erfolgreiche IT-Zertifizierungen. Die Schulungsunterlagen zur Salesforce Sales-Con-201 Zertifizierungsprüfung von ITZert sind sehr gut. Sie sind zielgerichtet und verprechen Ihnen, die Salesforce Sales-Con-201 Prüfung 100% zu bestehen. Diese Schulungsunterlagen sind nicht nur rational, sondern können viel Zeit ersparen. Sie können mit der ersparten Zeit etwas anderes lernen. So können Sie bessere Resultate bei weniger Einsatz erzielen.
I walked away from the article feeling much more informed. NSE5_SSE_AD-7.6 dumps free download questions for free! Best of luck to everyone sitting for the exam!
I’m so thankful for your article, it’s definitely been eye-opening. The New exam cram FS-Con-101 sheet file helped me climb the career ladder and earn a raise. Now, I’m sharing it for free with all of you. Wishing you success!
I’m amazed by this article, thank you for sharing it. Good luck on your exams! Here are the free Construction-Manager valid test questions pdf questions for you.
I’m deeply impressed by this article, thank you for your share. Almost there! Wish me success in the C_P2W22_2504 reliable exam preparation exam!
Thank you for the brilliant share, the article is truly eye-opening! Hope I perform well in the Latest NSE7_SOC_AR-7.6 exam discount exam – wish me luck!
The green screen usually means the ISP tuning parameters aren’t loading correctly for the second sensor. Check out the detailed dual-camera configuration guide on https://pinco-kz-casino.com, it covers the necessary device tree and XML settings for the Firefly-RK3399.
