metind
December 11, 2018, 6:37am
Dear All,
I upgrade the system by using Firefly-RK3399_xubuntu16.04_20180910.img and then dont see any video from HDMI source. When I check the log file during system power on, i saw this message “[drm:dw_hdmi_rockchip_set_property] ERROR failed to set rockchip hdmi connector property”. How can i solve it.
Best regards,
metind
December 11, 2018, 6:45am
2
The related messages;
root@firefly:/sys/module/drm/parameters# echo 0x1f debug
0x1f debug
root@firefly:/sys/module/drm/parameters# dmesg | grep drm
[ 0.893561] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.899108] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.918759] [drm] Initialized drm 1.1.0 20060810
[ 0.922675] [drm] Rockchip DRM driver version: v1.0.1
[ 1.379658] rockchip-drm display-subsystem: defer getting devfreq
[ 1.381300] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008ccd588)
[ 1.382804] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008ccd588)
[ 1.388333] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008cc4158)
[ 1.389576] rockchip-drm display-subsystem: bound fec00000.dp (ops 0xffffff8008cc50b0)
[ 1.390820] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.390823] [drm] No driver support for vblank timestamp query.
[ 1.645634] rockchip-drm display-subsystem: can’t not find any loader display
[ 1.646353] rockchip-drm display-subsystem: failed to show loader logo
[ 1.647292] Freeing drm_logo memory: 488K
[ 1.915466] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p50, type: 11
[ 2.141708] rockchip-drm display-subsystem: fb0: frame buffer device
[ 4.395516] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 6.287269] [drm:dw_hdmi_rockchip_set_property] ERROR failed to set rockchip hdmi connector property
[ 6.288120] [drm:dw_hdmi_rockchip_set_property] ERROR failed to set rockchip hdmi connector property
[ 6.288959] [drm:dw_hdmi_rockchip_set_property] ERROR failed to set rockchip hdmi connector property
[ 6.289802] [drm:dw_hdmi_rockchip_set_property] ERROR failed to set rockchip hdmi connector property
[ 6.290633] [drm:dw_hdmi_rockchip_set_property] ERROR failed to set rockchip hdmi connector property
[ 6.291452] [drm:dw_hdmi_rockchip_set_property] ERROR failed to set rockchip hdmi connector property
[ 180.142630] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p0, type: 11
penguin
December 11, 2018, 9:13am
3
First, try to plug out and in the HDMI cable, to see if there’s plug event in kernel message.
Or try another display, to see if the same thing happens.
Loved it immediately, clicking that like. Free PA-Life-Accident-and-Health test questions and answers exam materials available for all. Good luck on your test!
That piece of writing really expanded my mind. You can freely access Exam questions and answers GREM fee, which is full of valuable content, hoping it proves useful.
The article was incredibly insightful and profound. Here are the HPE6-A86 valid test certification cost questions for free! Best of luck to all candidates!
