Compile Ubuntu firmware(GPT) kernek compile error
Dear All,
I load and did all steps for GPT compiling and then try to compile kernel I got this error;
met@met:~/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk$ ./build.sh kernel
============Start build kernel============
TARGET_ARCH =arm64
TARGET_KERNEL_CONFIG =firefly_linux_defconfig
TARGET_KERNEL_DTS =rk3399-firefly
TARGET_KERNEL_JOBS =8
/bin/sh: 1: Syntax error: “(” unexpected
scripts/Makefile.build:277: recipe for target ‘scripts/mod/empty.o’ failed
make[2]: *** [scripts/mod/empty.o] Error 2
make[2]: *** Waiting for unfinished jobs…
scripts/Makefile.build:153: recipe for target ‘scripts/mod/devicetable-offsets.s’ failed
make[2]: *** [scripts/mod/devicetable-offsets.s] Error 2
scripts/Makefile.build:484: recipe for target ‘scripts/mod’ failed
make[1]: *** [scripts/mod] Error 2
Makefile:584: recipe for target ‘scripts’ failed
make: *** [scripts] Error 2
====Build kernel failed!====
What is problem?
Best regards,
Metin
Think firstly have to define compiler tool chain so then used export ARCH=arm64
export CROSS_COMPILE=aarch64-linux-gnu- and try again, compiled but now same as for uboot. So for uboot which croos compile tool chain must be used and what must be the ARCH?
The ARCH & CROSS_COMPILE should be taken care of in the build.sh.
What’s your compiling environment? We pass all builds in 64bits Ubuntu 16.04,
using ext4 or xfs filesystem.
By reading this article, I feel that I have experienced a lot of growth. Enhance your IT knowledge with free Reliable study questions Project-Planning-Design book. Good luck and best wishes!
