GBT uboot compile
Dear All,
I have problem when I try to compile boot and getting these messages;
met@met:~/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk$ ./build.sh firefly-rk3399.mk
/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/firefly-rk3399.mk
met@met:~/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk$ ./build.sh uboot
============Start build uboot============
TARGET_UBOOT_CONFIG=firefly-rk3399
…-------PREPARE----------…
make for firefly-rk3399_defconfig by -j2
arch/../configs/firefly-rk3399_defconfig:17:warning: override: reassigning to symbol ANDROID_BOOTLOADER
/bin/sh: 1: Syntax error: word unexpected (expecting “)”)
/bin/sh: 1: Syntax error: “(” unexpected
CHK include/config.h
scripts/Makefile.autoconf:50: recipe for target ‘include/autoconf.mk.dep’ failed
make[1]: *** [include/autoconf.mk.dep] Error 2
make[1]: *** Waiting for unfinished jobs…
scripts/Makefile.autoconf:79: recipe for target ‘u-boot.cfg’ failed
make[1]: *** [u-boot.cfg] Error 2
make: *** No rule to make target ‘include/config/auto.conf’, needed by ‘include/config/uboot.release’. Stop.
====Build uboot failed!====
Could you pls share idea about the problem.How can i solve it?
Best regards,
[u-boot.cfg] Error 2 - some config issues?
I did only what steps say. Is there any body tried it?
is there any person who can help me about this subject. I did all steps explain from your web site and gave this error. Think this error /bin/sh: 1: Syntax error: word unexpected (expecting “)”) related to compiler toolchain not supported. Try to export CROSS_COMPILE=aarch64-linux-gnu- and is same. did you test it and eveything is ok?
Is there anybody who wants to answer this problem. Board is perfect as properties, contains all and ok it is for development but if we saw any problem and try to find a solution where is support? When i check the non english part of this web site, there are much more activity so means this board is not for others?Pls help…
Will you please post your environment and full steps?
Try to use:
bash -x ./build.sh uboot
to get the verbose output of the build script, which will help to locate the problem.
Dear pengeuin,
Pls check the log file;
met@met:~$ ls
Desktop Documents Downloads examples.desktop jd2 Music Pictures Public Templates Videos
met@met:~$ cd Desktop/Compile_Ubuntu_firmware(GPT)/linux/
linux-sdk/ repo/
linux-sdk/ repo/
met@met:~$ cd Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/
met@met:~/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk$ bash -x ./build.sh firefly-rk3399.mk
+++ dirname ./build.sh
++ cd .
++ pwd
  • COMMON_DIR=‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk’
  • ‘[’ -h ./build.sh ‘]’
    ++ readlink ./build.sh
  • CMD=device/rockchip/common/build.sh
    ++ dirname device/rockchip/common/build.sh
  • COMMON_DIR=device/rockchip/common
  • cd device/rockchip/common
  • cd ../../..
    ++ pwd
  • TOP_DIR=‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk’
  • COMMON_DIR=‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/common’
  • BOARD_CONFIG=‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/.BoardConfig.mk’
  • CFG_DIR=‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip’
  • ROCKDEV=‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/rockdev’
  • source ‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/.BoardConfig.mk’
  • PARAMETER=‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/parameter-ubuntu.txt’
  • SD_PARAMETER=‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/parameter-recovery.txt’
  • ‘[’ ‘!’ -n firefly-rk3399.mk ‘]’
  • BUILD_TARGET=firefly-rk3399.mk
    ++ find ‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip’ -name firefly-rk3399.mk
  • NEW_BOARD_CONFIG=‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/firefly-rk3399.mk’
  • ‘[’ firefly-rk3399.mk == uboot ‘]’
  • ‘[’ firefly-rk3399.mk == kernel ‘]’
  • ‘[’ firefly-rk3399.mk == extboot ‘]’
  • ‘[’ firefly-rk3399.mk == rootfs ‘]’
  • ‘[’ firefly-rk3399.mk == buildroot ‘]’
  • ‘[’ firefly-rk3399.mk == recovery ‘]’
  • ‘[’ firefly-rk3399.mk == pcba ‘]’
  • ‘[’ firefly-rk3399.mk == yocto ‘]’
  • ‘[’ firefly-rk3399.mk == ros ‘]’
  • ‘[’ firefly-rk3399.mk == debian ‘]’
  • ‘[’ firefly-rk3399.mk == updateimg ‘]’
  • ‘[’ firefly-rk3399.mk == sdbootimg ‘]’
  • ‘[’ firefly-rk3399.mk == sdupdateimg ‘]’
  • ‘[’ firefly-rk3399.mk == all ‘]’
  • ‘[’ firefly-rk3399.mk == firmware ‘]’
  • ‘[’ firefly-rk3399.mk == save ‘]’
  • ‘[’ firefly-rk3399.mk == cleanall ‘]’
  • ‘[’ firefly-rk3399.mk == --help ‘]’
  • ‘[’ firefly-rk3399.mk == help ‘]’
  • ‘[’ firefly-rk3399.mk == -h ‘]’
  • ‘[’ firefly-rk3399.mk == allsave ‘]’
  • ‘[’ -f ‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/firefly-rk3399.mk’ ‘]’
  • ‘[’ ‘!’ -n ‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/firefly-rk3399.mk’ ‘]’
  • echo ‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/firefly-rk3399.mk’
  • rm -f ‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/.BoardConfig.mk’
  • ln -s ‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/firefly-rk3399.mk’ ‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/.BoardConfig.mk’
  • unset RK_PACKAGE_FILE
  • unset RK_MKUPDATE_FILE
  • source ‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/firefly-rk3399.mk’
    ++ export RK_ARCH=arm64
    ++ RK_ARCH=arm64
    ++ export RK_UBOOT_DEFCONFIG=firefly-rk3399
    ++ RK_UBOOT_DEFCONFIG=firefly-rk3399
    ++ export RK_KERNEL_DEFCONFIG=firefly_linux_defconfig
    ++ RK_KERNEL_DEFCONFIG=firefly_linux_defconfig
    ++ export RK_KERNEL_DTS=rk3399-firefly
    ++ RK_KERNEL_DTS=rk3399-firefly
    ++ export RK_BOOT_IMG=boot.img
    ++ RK_BOOT_IMG=boot.img
    ++ export RK_PARAMETER=parameter-ubuntu.txt
    ++ RK_PARAMETER=parameter-ubuntu.txt
    ++ export RK_SD_PARAMETER=parameter-recovery.txt
    ++ RK_SD_PARAMETER=parameter-recovery.txt
    ++ export RK_PACKAGE_FILE=rk3399-ubuntu-package-file
    ++ RK_PACKAGE_FILE=rk3399-ubuntu-package-file
    ++ export RK_SD_PACKAGE_FILE=rk3399-recovery-package-file
    ++ RK_SD_PACKAGE_FILE=rk3399-recovery-package-file
    ++ export RK_CFG_BUILDROOT=rockchip_rk3399
    ++ RK_CFG_BUILDROOT=rockchip_rk3399
    ++ export RK_CFG_RECOVERY=rockchip_rk3399_recovery
    ++ RK_CFG_RECOVERY=rockchip_rk3399_recovery
    ++ export RK_CFG_PCBA=rockchip_rk3399_pcba
    ++ RK_CFG_PCBA=rockchip_rk3399_pcba
    ++ export RK_JOBS=8
    ++ RK_JOBS=8
    ++ export RK_TARGET_PRODUCT=rk3399
    ++ RK_TARGET_PRODUCT=rk3399
    ++ export RK_ROOTFS_TYPE=ext4
    ++ RK_ROOTFS_TYPE=ext4
    ++ export RK_ROOTFS_IMG=buildroot/output/rockchip_rk3399/images/rootfs.ext4
    ++ RK_ROOTFS_IMG=buildroot/output/rockchip_rk3399/images/rootfs.ext4
    ++ export RK_OEM_FS_TYPE=ext2
    ++ RK_OEM_FS_TYPE=ext2
    ++ export RK_USERDATA_FS_TYPE=ext2
    ++ RK_USERDATA_FS_TYPE=ext2
    ++ export RK_STORAGE_TYPE=emmc
    ++ RK_STORAGE_TYPE=emmc
    ++ export RK_OEM_DIR=oem_normal
    ++ RK_OEM_DIR=oem_normal
    ++ export RK_USERDATA_DIR=userdata_normal
    ++ RK_USERDATA_DIR=userdata_normal
  • [[ xrk3399-ubuntu-package-file != x ]]
  • PACK_TOOL_DIR=‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/tools/linux/Linux_Pack_Firmware/rockdev/’
  • cd ‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/tools/linux/Linux_Pack_Firmware/rockdev/’
  • rm -f package-file
  • ln -sf rk3399-ubuntu-package-file package-file
  • MKUPDATE_FILE=rk3399-mkupdate.sh
  • [[ xrk3399-mkupdate.sh != x-mkupdate.sh ]]
  • rm -f mkupdate.sh
  • ln -sf rk3399-mkupdate.sh mkupdate.sh
  • exit 0
    met@met:~/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk$ bash -x ./build.sh uboot
    ++ cd .
    ++ pwd
  • cd ../../..
    ++ pwd
  • ‘[’ ‘!’ -n uboot ‘]’
  • BUILD_TARGET=uboot
    ++ find ‘/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip’ -name uboot
  • NEW_BOARD_CONFIG=
  • ‘[’ uboot == uboot ‘]’
  • build_uboot
  • echo ‘============Start build uboot============’
  • echo TARGET_UBOOT_CONFIG=firefly-rk3399
  • echo =========================================
  • ‘[’ -f ‘u-boot/loader.bin’ ‘]’
  • cd u-boot
  • ./make.sh firefly-rk3399
    …-------PREPARE cmd=----------…
    …-------PREPARE BOARD=firefly-rk3399----------…
    …-------PREPARE OUTDIR=.----------…
    RKBIN=/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/rkbin
    RKTOOLS=/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/rkbin/tools
    …------- metin after prepare----------…
    …-------select_toolchain----------…
    TOOLCHAIN_GCC=/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
    TOOLCHAIN_OBJDUMP=/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-objdump
    TOOLCHAIN_ADDR2LINE=/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-addr2line
    …------- metin after select_toolchain----------…
    …-------select_chip_info----------…
    …-------RKCHIP_LABEL=RK3399----------…
    …-------RKCHIP_LOADER=RK3399----------…
    …-------RKCHIP_TRUST=RK3399----------…
    …------- metin after select_chip_info----------…
    …-------fixup_platform_configure----------…
    …-------PLATFORM_RSA=----------…
    …-------PLATFORM_SHA=----------…
    …-------PLATFORM_UBOOT_IMG_SIZE=----------…
    …-------PLATFORM_AARCH32=----------…
    …------- metin after fixup_platform_configure----------…
    …-------sub_commands----------…
    …-------sub_commands cmd=firefly----------…
    …------- metin after sub_commands----------…
  • ‘[’ 2 -eq 0 ‘]’
  • echo ‘====Build uboot failed!====’
  • exit 1
And only do the related steps at http://wiki.t-firefly.com/en/Firefly-RK3399/linux_compile_gpt.html
Best regards,
Metin
I include some echo or prints to understand to understand what happend…
@metind what’s your os and filesystem used?
Post result of:
cd u-boot
git log -n2
git status
Compile environment
Dear penguin,
Just compile according to “Compile Ubuntu firmware(GPT)” directives and used ./build.sh. from cat /etc/issue getting “Welcome to RK3399 Buildroot”. I tried 4K and as video there is no problem but there is no sound!!! it is not only for this video also when i test sound part, i coudnt get sound also. Do i have to chnage something? I didnt copy ubuntu18LXDE just used default rootfs for compiling. Do you have any idea.
Please use the rootfs in the official firmware to test.
“official firmware”. Whichone and where can i download it? Also I used ubuntu18LXDE rootfs i saw 4K is so slow and also no sound. Then used debian linaro, couldnt download any package to play video. So which is the best solution for 4K with sound.
I tried all. For debian linaro rootfs there is no network connection. For other ubuntu rootfs images have same problem, sound ok but 4k video so slow. Is there any solution for it or am i doing something wrong?
Is there any person ho tried these rootfs files and saw everything is ok espacialy 4K performance? If yes, could you pls share your way to help us…
I’m amazed by this article, thank you for sharing it. The COH-285 reliable exam duration materials are excellent, and you can access them for free.
I appreciate your article; it was truly eye-catching and unique. Here’s the C_THR85_2505 visual cert exam test I took to earn my promotion and raise, now free for you today. Best of luck in your professional journey!
多くのSnowflakeのDAA-C01認定試験を準備している受験生がいろいろなDAA-C01「SnowPro Advanced: Data Analyst Certification Exam」認証試験についてサービスを提供するサイトオンラインがみつけたがFast2testはIT業界トップの専門家が研究した参考材料で権威性が高く、品質の高い教育資料で、一回に参加する受験者も合格するのを確保いたします。
