Hi
We run Android Oreo 8.1 on our FireFly-RK3399 Boards in our Labs at the University.
Everything runs smooth except the audio part is not working.
There is no sound on the headset HPOx and also on the speaker SPOx output.
It seems that device tree is ok and the audio drivers are installed.
Do you already have a fix for the audio problem.
It would be great if the new firmware works at the beginning of January and we are able to use it at our labs.
We use a touchscreen driver from FocalTech FT5x06 in the kernel.
Your kernel image doesn’t work, because the FT5x06 driver is not enabled in your kernel image.
What changes do I have to make in the kernel source tree for the audio part?
Your article is truly outstanding, thank you for sharing it with us! Free CRT-450 test objectives exam papers are here. Wishing you the best of luck on your exam!
