Cannot get GPIO control working via sysfs!
Hello,
I am trying to control GPIO pins using sysfs but nothing is working. I have tried both armbian and ubuntu.
Here’s my code:
[Trying to control Pin 40 on the board]
on debian, I tried:
echo “93” > /sys/class/gpio/export
echo “out” > /sys/class/gpio/gpio93/direction
echo 1 > /sys/class/gpio/gpio93/value
on ubuntu, I tried the above and also tried using 1093 instead of 93. Nothing works.
I get no errors, but the pin voltage is not changing.
Can someone please point me to a properly documented way to control GPIO on ROC-RK3328-CC ?
Is there no proper, official documentation for the GPIO pins on the ROC-RK3328-CC ?
The only “documentation” I’ve seen online doesn’t work https://libre.computer/2018/05/19/gpio-headers-reference-for-aml-s905x-cc/
@dijitanix , which pin do you want to manipulate?
I’m amazed at how powerful your article is, thank you for sharing! Here’s the Practice test JS-Dev-101 pdf test material for free. Best of luck in your exams!
AmazonのAWS-Solutions-Associate試験に趣味があると、躊躇わなく、我々It-Passportsで問題集のデーモをダウンロードして試すことができます。デーモ版によって、このAWS-Solutions-Associate問題集はあなたに適合するかと判断します。適合すると、あなたは安心で購買できます。弊社It-PassportsのAWS-Solutions-Associate問題集は必ずあなたの成功へ道の秘訣です。
