[ 102.088596] Error getting the SSID
[ 102.596428] _tdata_psh_info_pool_deq 200: Out of tdata_disc_grp
[ 102.596438] dhd_tcpdata_info_get 1092: No more free tdata_psh_info!!
Formally wireless works stable both 2.4 and 5GHz, but I’m sure it should not constantly give this output.
The only mod I added to 4.4.154 kernel was NFSD support.
Any high load to HDD connected over Firefly’s SATA adapter result in system hang with adaper’s blue led on permanently.
Moreover, hdparm -tT /dev/sda1 returns extremely slow timing:
/dev/sda1:
Timing cached reads: 2588 MB in 2.00 seconds = 1293.83 MB/sec
Timing buffered disk reads: 330 MB in 3.00 seconds = 109.87 MB/sec
Suppose no overtemperature occurs - I put a small fin heatsink on ASM1061 chip and maximim that IR thermometer read is 37C. Firefly hangs when Transmission downloading a big file even with speed limitations, and when I read same file over NFS everything is ok. I have no extra hdd to reproduce the problem.
And what about wifi?
firefly@firefly:~$ cat /var/log/syslog
Dec 18 20:43:14 firefly kernel: [ 876.079038] Error getting the SSID
Dec 18 20:43:17 firefly kernel: [ 879.078745] Error getting the SSID
Dec 18 20:43:20 firefly kernel: [ 882.078423] Error getting the SSID
OK I’ve found who was requesting SSID every 3 second - conky, now turned off and this problem elimnated
but still I get messages:
[41058.513959] _tdata_psh_info_pool_deq 200: Out of tdata_disc_grp
[41058.513978] dhd_tcpdata_info_get 1092: No more free tdata_psh_info!!
[41058.541146] _tdata_psh_info_pool_deq 200: Out of tdata_disc_grp
[41058.541165] dhd_tcpdata_info_get 1092: No more free tdata_psh_info!!
This article is brilliant beyond words, thank you for sharing. Get the New 78202T practice test fee questions for free—your career and salary progression start here!
