Hello Penguin,
Thank you for your answer. Here is the full report I got with putty. I set the usb to UART exactly as you explained it to me then I put the SD card in the RK3399. I connected the rk3399 electrically in very last. What putty displays is the full report. Have I done everything right or need to do something else? I made a short video of my hookup and putty display over the last 1.15 minutes as the full load procedure took at least 5 minutes. Thank you for telling me what to do. If my card is broken, how to guarantee. I will not return the card in China from France by DHL which costs $ 30 can pay $ 30 again to receive my repaired card (or new) it’s $ 60 If I have to do that, the Firefly Rk3399 will have cost me over $ 300 since I bought it in December. I hope there will be another solution. Thank you.
[ytube]9_7sH0vkxBg[/ytube]
[ 1.147040] usbcore: registered new interface driver usb-storage
[ 1.147654] usbcore: registered new interface driver usbserial
[ 1.148192] usbcore: registered new interface driver usbserial_generic
[ 1.148796] usbserial: USB Serial support registered for generic
[ 1.149358] usbcore: registered new interface driver cp210x
[ 1.149877] usbserial: USB Serial support registered for cp210x
[ 1.150453] usbcore: registered new interface driver ftdi_sio
[ 1.150985] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.151778] usbcore: registered new interface driver keyspan
[ 1.152293] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.153008] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.153677] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.154333] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.155026] usbcore: registered new interface driver option
[ 1.155545] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.156346] usbcore: registered new interface driver oti6858
[ 1.156871] usbserial: USB Serial support registered for oti6858
[ 1.157434] usbcore: registered new interface driver pl2303
[ 1.157955] usbserial: USB Serial support registered for pl2303
[ 1.158530] usbcore: registered new interface driver qcserial
[ 1.159052] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.159727] usbcore: registered new interface driver sierra
[ 1.160233] usbserial: USB Serial support registered for Sierra USB modem
[ 1.161699] usbcore: registered new interface driver iforce
[ 1.162247] usbcore: registered new interface driver xpad
[ 1.163015] usbcore: registered new interface driver usbtouchscreen
[ 1.163904] i2c /dev entries driver
[ 1.165363] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.168007] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.170897] rk808 0-001b: Pmic Chip id: 0x0
[ 1.174197] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.174798] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.187174] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.188184] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009596000
[ 1.189435] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009598000
[ 1.190519] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff800959a000
[ 1.201154] fusb302 4-0022: port 0 probe success
[ 1.201603] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff800959c000
[ 1.203250] IR NEC protocol handler initialized
[ 1.203666] IR RC5(x/sz) protocol handler initialized
[ 1.204114] IR RC6 protocol handler initialized
[ 1.204526] IR JVC protocol handler initialized
[ 1.204928] IR Sony protocol handler initialized
[ 1.205336] IR SANYO protocol handler initialized
[ 1.205760] IR Sharp protocol handler initialized
[ 1.206177] IR MCE Keyboard/mouse protocol handler initialized
[ 1.206702] IR XMP protocol handler initialized
[ 1.207187] usbcore: registered new interface driver uvcvideo
[ 1.207699] USB Video Class driver (1.1.1)
[ 1.208612] vcc_3v0: supplied by vcc3v3_sys
[ 1.209204] vcc1v8_dvp: supplied by vcc3v3_sys
[ 1.209716] vcca1v8_codec: supplied by vcc3v3_sys
[ 1.210231] vcc_sd: supplied by vcc3v3_sys
[ 1.211136] rockchip_cpu_avs: cluster0 leakage=19 adjust_volt=0
[ 1.211694] rockchip_cpu_avs: cluster1 leakage=33 adjust_volt=0
[ 1.213471] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.215016] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.215904] Bluetooth: Virtual HCI driver ver 1.5
[ 1.216425] Bluetooth: HCI UART driver ver 2.3
[ 1.216830] Bluetooth: HCI UART protocol H4 registered
[ 1.217281] Bluetooth: HCI UART protocol LL registered
[ 1.217738] Bluetooth: HCI UART protocol ATH3K registered
[ 1.218282] usbcore: registered new interface driver bfusb
[ 1.218830] usbcore: registered new interface driver btusb
[ 1.219752] vdd_cpu_l: supplied by vcc3v3_sys
[ 1.221668] vdd_cpu_b: supplied by vcc5v0_sys
[ 1.224458] sdhci: Secure Digital Host Controller Interface driver
[ 1.225014] sdhci: Copyright(c) Pierre Ossman
[ 1.225402] Synopsys Designware Multimedia Card Interface Driver
[ 1.226748] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.227408] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.228019] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.228574] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.229434] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 1.230214] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.230762] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.232091] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.232769] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.233369] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.233922] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.234789] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 1.235606] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.236398] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.237199] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.248640] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.260605] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.261417] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.263754] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.264286] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.276054] fusb302 4-0022: connection has disconnected
[ 1.290516] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.293084] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.294387] usbcore: registered new interface driver usbhid
[ 1.294901] usbhid: USB HID core driver
[ 1.295539] ashmem: initialized
[ 1.295645] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 1.295719] mmc0: new high speed SDHC card at address 0001
[ 1.296165] mmcblk0: mmc0:0001 ASTC 7.44 GiB
[ 1.299460] usbcore: registered new interface driver snd-usb-audio
[ 1.309776] mmcblk0: p1
[ 1.319099] u32 classifier
[ 1.319358] Netfilter messages via NETLINK v0.30.
[ 1.320151] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.321102] ctnetlink v0.93: registering with nfnetlink.
[ 1.321794] ip_set: protocol 6
[ 1.322079] IPVS: Registered protocols ()
[ 1.322643] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 1.323396] IPVS: Creating netns size=1592 id=0
[ 1.323846] IPVS: ipvs loaded.
[ 1.324587] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.325217] Initializing XFRM netlink socket
[ 1.326425] NET: Registered protocol family 10
[ 1.328290] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.328991] sit: IPv6 over IPv4 tunneling driver
[ 1.330044] NET: Registered protocol family 17
[ 1.330461] NET: Registered protocol family 15
[ 1.330911] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.332052] Bridge firewalling registered
[ 1.332893] Bluetooth: RFCOMM socket layer initialized
[ 1.333371] Bluetooth: RFCOMM ver 1.11
[ 1.333741] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.334270] Bluetooth: HIDP socket layer initialized
[ 1.334781] 8021q: 802.1Q VLAN Support v1.8
[ 1.335179] lib80211: common routines for IEEE802.11 drivers
[ 1.335768] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.336524] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.337008] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354
[ 1.337621] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.338244] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.338949] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.339746] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.340205] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.340677] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.341394] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.342145] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 1.342864] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 1.343585] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 1.345235] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.345769] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[ 1.345784] [BT_RFKILL]: ** disable irq
[ 1.346674] [BT_RFKILL]: bt_default device registered.
[ 1.347211] Key type dns_resolver registered
[ 1.348517] Registered cp15_barrier emulation handler
[ 1.349108] Registered setend emulation handler
[ 1.350701] Loading compiled-in X.509 certificates
[ 1.352157] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 1.355023] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008c302d8)
[ 1.355899] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008c302d8)
[ 1.356801] dwhdmi-rockchip ff940000.hdmi: Detected HDMI controller 0x21:0x1a:0xa0:0xc1
[ 1.358186] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008c2c6c8)
[ 1.358926] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.359638] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[ 1.360361] rockchip-drm display-subsystem: failed to parse loader memory
[ 1.360982] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 1.361723] [drm:drm_fb_helper_single_fb_probe] Cannot find any crtc or sizes - going 1024x768
[ 1.374289] Console: switching to colour frame buffer device 128x48
[ 1.374314] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1.382092] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.388376] vdd_gpu: supplied by vcc5v0_sys
[ 1.389948] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 1.391108] I : [File] : drivers/gpu/arm/midgard_for_linux/backend/gpu/mali_kbase_devfreq.c; [Line] : 265; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 1.392952] mali ff9a0000.gpu: Probed as mali0
[ 1.396797] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[ 1.397497] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 5
[ 1.398291] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010
[ 1.399096] xhci-hcd xhci-hcd.6.auto: irq 227, io mem 0xfe800000
[ 1.399733] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.400328] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.400968] usb usb5: Product: xHCI Host Controller
[ 1.401396] usb usb5: Manufacturer: Linux 4.4.52 xhci-hcd
[ 1.401879] usb usb5: SerialNumber: xhci-hcd.6.auto
[ 1.402705] hub 5-0:1.0: USB hub found
[ 1.403059] hub 5-0:1.0: 1 port detected
[ 1.403629] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[ 1.404229] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 6
[ 1.404951] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.405736] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.406330] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.406968] usb usb6: Product: xHCI Host Controller
[ 1.407396] usb usb6: Manufacturer: Linux 4.4.52 xhci-hcd
[ 1.407873] usb usb6: SerialNumber: xhci-hcd.6.auto
[ 1.408648] hub 6-0:1.0: USB hub found
[ 1.408998] hub 6-0:1.0: 1 port detected
[ 1.410290] xhci-hcd xhci-hcd.6.auto: remove, state 1
[ 1.410762] usb usb6: USB disconnect, device number 1
[ 1.434925] xhci-hcd xhci-hcd.6.auto: Host not halted after 16000 microseconds.
[ 1.435564] xhci-hcd xhci-hcd.6.auto: Host controller not halted, aborting reset.
[ 1.436254] xhci-hcd xhci-hcd.6.auto: USB bus 6 deregistered
[ 1.437146] xhci-hcd xhci-hcd.6.auto: remove, state 1
[ 1.437610] usb usb5: USB disconnect, device number 1
[ 1.438418] xhci-hcd xhci-hcd.6.auto: USB bus 5 deregistered
[ 1.440761] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.441365] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 1.442143] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 1.468773] fusb302 4-0022: connection has disconnected
[ 1.493753] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.494612] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.495223] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.495890] usb usb5: Product: EHCI Host Controller
[ 1.496329] usb usb5: Manufacturer: Linux 4.4.52 ehci_hcd
[ 1.496828] usb usb5: SerialNumber: fe380000.usb
[ 1.498393] hub 5-0:1.0: USB hub found
[ 1.498811] hub 5-0:1.0: 1 port detected
[ 1.500478] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.500684] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.500697] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.500707] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 1.501574] hub 1-1:1.0: USB hub found
[ 1.501674] hub 1-1:1.0: 7 ports detected
[ 1.503896] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 1.504822] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 1.560026] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.560666] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.561311] usb usb6: Product: Generic Platform OHCI controller
[ 1.561858] usb usb6: Manufacturer: Linux 4.4.52 ohci_hcd
[ 1.562340] usb usb6: SerialNumber: fe3a0000.usb
[ 1.563946] hub 6-0:1.0: USB hub found
[ 1.564342] hub 6-0:1.0: 1 port detected
[ 1.566628] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.567323] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.567957] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.568525] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.569401] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 1.570249] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.570815] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.571825] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.583784] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.595695] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 1.607397] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mapping ok
[ 1.613852] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card0/input0
[ 1.617240] asoc-simple-card hdmi-codec: i2s-hifi <-> ff8a0000.i2s mapping ok
[ 1.621483] rockchip-spdif ff870000.spdif: Missing dma channel for stream: 0
[ 1.622165] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22
[ 1.622813] asoc-simple-card spdif-sound: ASoC: can't create pcm ff870000.spdif-dit-hifi :-22
[ 1.623583] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -22
[ 1.624575] asoc-simple-card: probe of spdif-sound failed with error -22
[ 1.625837]
[ 1.625981] =======================================================
[ 1.626558] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 1.627111] =======================================================
[ 1.627708] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init.
[ 1.628384] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.628845] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.629263] RTL871X: module init start
[ 1.629622] RTL871X: rtl8188eu v4.3.24_16705.20160509
[ 1.630349] usbcore: registered new interface driver rtl8188eu
[ 1.630910] RTL871X: module init ret=0
[ 1.632590] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 1.633412] dhd_module_init: in
[ 1.633775] ======== bcm_wlan_set_plat_data ========
[ 1.634229] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.634747] host_oob_irq: 68
[ 1.634802] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:04 UTC (1358499004)
[ 1.635769] host_oob_irq_flags=0x4
[ 1.636074] dhd_wifi_platform_load: Enter
[ 1.636561] Power-up adapter 'DHD generic adapter'
[ 1.637101] wifi_platform_set_power = 1
[ 1.637466] ======== PULL WL_REG_ON HIGH! ========
[ 1.637916] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.638335] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.647575] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.649733] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.651918] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.655418] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.666568] fusb302 4-0022: connection has disconnected
[ 1.716702] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 1.738509] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 313
[ 1.747041] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 1.747624] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 1.839568] wifi_platform_bus_enumerate device present 1
[ 1.840049] ======== Card detection to detect SDIO card! ========
[ 1.840616] mmc2:mmc host rescan start!
[ 1.848621] vendor storage:20160801 ret = -1
[ 1.852830] fusb302 4-0022: connection has disconnected
[ 1.856631] bcmsdh_register: register client driver
[ 1.857431] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 1.858246] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 1.858723] bus num (host idx)=2, slot num (rca)=1
[ 1.859150] found adapter info 'DHD generic adapter'
[ 1.859923] sdioh_attach: set sd_f2_blocksize 128
[ 1.865844] F1 signature read @0x18000000=0x17224356
[ 1.880202] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
[ 1.882178] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 1.882976] wifi_platform_get_mac_addr
[ 1.883316] ======== bcm_wlan_get_mac_address ========
[ 1.883800] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 1.884281] [WLAN_RFKILL]: get_wifi_addr_vendor: rk_vendor_read wifi mac address failed (-1)
[ 1.885058] dhd_conf_set_chiprev: chip=0x4354, chiprev=2
[ 1.885680] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 1.887527] wl_create_event_handler(): thread:wl_event_handler:a8 started
[ 1.887545] tsk Enter, tsk = 0xffffffc077de1be8
[ 1.888783] wl_escan_attach: Enter
[ 1.889122] wl_escan_init: Enter
[ 1.889665] wl_create_event_handler(): thread:wl_escan_handler:a9 started
[ 1.889680] tsk Enter, tsk = 0xffffffc077e301b0
[ 1.890948] dhd_attach(): thread:dhd_watchdog_thread:aa started
[ 1.891795] dhd_attach(): thread:dhd_dpc:ab started
[ 1.891830] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 1.893086] dhd_attach(): thread:dhd_rxf:ac started
[ 1.893550] dhd_deferred_work_init: work queue initialized
[ 1.922229] Dongle Host Driver, version 1.363.59.144.1 (r)
[ 1.923704] Register interface [wlan0] MAC: cc:4b:73:1d:1a:78
[ 1.923704]
[ 1.924475] wl_event_handler: was terminated
[ 1.924942] wl_destroy_event_handler(): thread:wl_event_handler:a8 terminated OK
[ 1.925622] dhd_wl_ioctl: returning as busstate=0
[ 1.926120] bcmsdh_oob_intr_unregister: Enter
[ 1.926531] bcmsdh_oob_intr_unregister: irq is not registered
[ 1.927048] dhd_txglom_enable: enable 0
[ 1.927392] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0
[ 1.927936] dhd_conf_set_txglom_params: txglom_bucket_size=0
[ 1.928437] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=0
[ 1.929141] dhd_conf_set_txglom_params: tx_in_rx=1, tx_max_offset=0
[ 1.929707] dhd_bus_devreset: WLAN OFF DONE
[ 1.930200] wifi_platform_set_power = 0
[ 1.930565] ======== PULL WL_REG_ON LOW! ========
[ 1.930983] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 1.931413] [WLAN_RFKILL]: wifi shut off power.
[ 1.931900] dhd_module_init: Exit err=0
[ 2.037817] fusb302 4-0022: connection has disconnected
[ 2.223601] fusb302 4-0022: connection has disconnected
[ 2.412600] fusb302 4-0022: connection has disconnected
[ 2.599722] fusb302 4-0022: connection has disconnected
[ 2.784419] fusb302 4-0022: connection has disconnected
[ 2.973780] fusb302 4-0022: connection has disconnected
[ 3.163376] fusb302 4-0022: connection has disconnected
[ 3.351348] fusb302 4-0022: connection has disconnected
[ 3.539333] fusb302 4-0022: connection has disconnected
[ 3.614814] phy phy-ff770000.syscon:usb2-phy@e450.6: charger = USB_SDP_CHARGER
[ 3.728981] fusb302 4-0022: connection has disconnected
[ 3.916746] fusb302 4-0022: connection has disconnected
[ 4.050833] random: nonblocking pool is initialized
[ 4.105116] fusb302 4-0022: connection has disconnected
[ 4.303187] fusb302 4-0022: connection has disconnected
[ 4.511206] fusb302 4-0022: connection has disconnected
[ 4.717910] fusb302 4-0022: connection has disconnected
[ 4.926030] fusb302 4-0022: connection has disconnected
[ 5.133007] fusb302 4-0022: connection has disconnected
[ 5.339817] fusb302 4-0022: connection has disconnected
[ 5.546523] fusb302 4-0022: connection has disconnected
[ 5.751383] fusb302 4-0022: connection has disconnected
[ 5.957577] fusb302 4-0022: connection has disconnected
[ 6.157551] fusb302 4-0022: connection has disconnected
[ 6.357088] fusb302 4-0022: connection has disconnected
[ 6.556918] fusb302 4-0022: connection has disconnected
[ 6.756373] fusb302 4-0022: connection has disconnected
[ 6.956425] fusb302 4-0022: connection has disconnected
[ 7.150533] fusb302 4-0022: connection has disconnected
[ 7.338922] fusb302 4-0022: connection has disconnected
[ 7.527485] fusb302 4-0022: connection has disconnected
[ 7.715631] fusb302 4-0022: connection has disconnected
[ 7.904643] fusb302 4-0022: connection has disconnected
[ 8.096544] fusb302 4-0022: connection has disconnected
[ 8.294416] fusb302 4-0022: connection has disconnected
[ 8.501481] fusb302 4-0022: connection has disconnected
[ 8.710251] fusb302 4-0022: connection has disconnected
[ 8.916852] fusb302 4-0022: connection has disconnected
[ 9.123891] fusb302 4-0022: connection has disconnected
[ 9.330760] fusb302 4-0022: connection has disconnected
[ 9.538035] fusb302 4-0022: connection has disconnected
[ 9.744077] fusb302 4-0022: connection has disconnected
[ 9.950305] fusb302 4-0022: connection has disconnected
[ 10.150364] fusb302 4-0022: connection has disconnected
[ 10.347469] fusb302 4-0022: connection has disconnected
[ 10.545697] fusb302 4-0022: connection has disconnected
[ 10.745826] fusb302 4-0022: connection has disconnected
[ 10.945533] fusb302 4-0022: connection has disconnected
[ 11.138456] fusb302 4-0022: connection has disconnected
[ 11.327415] fusb302 4-0022: connection has disconnected
[ 11.515953] fusb302 4-0022: connection has disconnected
[ 11.704938] fusb302 4-0022: connection has disconnected
[ 11.892487] fusb302 4-0022: connection has disconnected
[ 12.082972] fusb302 4-0022: connection has disconnected
[ 12.282900] fusb302 4-0022: connection has disconnected
[ 12.489653] fusb302 4-0022: connection has disconnected
[ 12.695709] fusb302 4-0022: connection has disconnected
[ 12.902580] fusb302 4-0022: connection has disconnected
[ 13.111410] fusb302 4-0022: connection has disconnected
[ 13.319022] fusb302 4-0022: connection has disconnected
[ 13.526131] fusb302 4-0022: connection has disconnected
[ 13.732862] fusb302 4-0022: connection has disconnected
[ 13.940379] fusb302 4-0022: connection has disconnected
[ 14.140557] fusb302 4-0022: connection has disconnected
[ 14.341011] fusb302 4-0022: connection has disconnected
[ 14.539342] fusb302 4-0022: connection has disconnected
[ 14.739469] fusb302 4-0022: connection has disconnected
[ 14.939981] fusb302 4-0022: connection has disconnected
[ 15.131941] fusb302 4-0022: connection has disconnected
[ 15.321458] fusb302 4-0022: connection has disconnected
[ 15.509137] fusb302 4-0022: connection has disconnected
[ 15.696313] fusb302 4-0022: connection has disconnected
[ 15.884773] fusb302 4-0022: connection has disconnected
[ 16.076381] fusb302 4-0022: connection has disconnected
[ 16.276051] fusb302 4-0022: connection has disconnected
[ 16.482540] fusb302 4-0022: connection has disconnected
[ 16.688804] fusb302 4-0022: connection has disconnected
[ 16.894782] fusb302 4-0022: connection has disconnected
[ 17.102183] fusb302 4-0022: connection has disconnected
[ 17.311221] fusb302 4-0022: connection has disconnected
[ 17.518797] fusb302 4-0022: connection has disconnected
[ 17.726237] fusb302 4-0022: connection has disconnected
[ 17.931137] fusb302 4-0022: connection has disconnected
[ 18.132138] fusb302 4-0022: connection has disconnected
[ 18.331902] fusb302 4-0022: connection has disconnected
[ 18.532203] fusb302 4-0022: connection has disconnected
[ 18.730690] fusb302 4-0022: connection has disconnected
[ 18.929079] fusb302 4-0022: connection has disconnected
[ 19.123032] fusb302 4-0022: connection has disconnected
[ 19.313062] fusb302 4-0022: connection has disconnected
[ 19.500432] fusb302 4-0022: connection has disconnected
[ 19.688294] fusb302 4-0022: connection has disconnected
[ 19.874390] fusb302 4-0022: connection has disconnected
[ 20.065686] fusb302 4-0022: connection has disconnected
[ 20.254124] fusb302 4-0022: connection has disconnected
[ 20.442136] fusb302 4-0022: connection has disconnected
[ 20.630045] fusb302 4-0022: connection has disconnected
[ 20.818812] fusb302 4-0022: connection has disconnected
[ 21.012190] fusb302 4-0022: connection has disconnected
[ 21.212735] fusb302 4-0022: connection has disconnected
[ 21.413338] fusb302 4-0022: connection has disconnected
[ 21.615570] fusb302 4-0022: connection has disconnected
[ 21.817143] fusb302 4-0022: connection has disconnected
[ 22.018114] fusb302 4-0022: connection has disconnected
[ 22.219693] fusb302 4-0022: connection has disconnected
[ 22.421044] fusb302 4-0022: connection has disconnected
[ 22.624361] fusb302 4-0022: connection has disconnected
[ 22.824686] fusb302 4-0022: connection has disconnected
[ 23.024414] fusb302 4-0022: connection has disconnected
[ 23.217403] fusb302 4-0022: connection has disconnected
[ 23.405847] fusb302 4-0022: connection has disconnected
[ 23.593390] fusb302 4-0022: connection has disconnected
[ 23.780689] fusb302 4-0022: connection has disconnected
[ 23.967668] fusb302 4-0022: connection has disconnected
[ 24.162519] fusb302 4-0022: connection has disconnected
[ 24.349658] fusb302 4-0022: connection has disconnected
[ 24.537654] fusb302 4-0022: connection has disconnected
[ 24.725477] fusb302 4-0022: connection has disconnected
[ 24.912402] fusb302 4-0022: connection has disconnected
[ 25.100468] fusb302 4-0022: connection has disconnected
[ 25.301562] fusb302 4-0022: connection has disconnected
[ 25.500614] fusb302 4-0022: connection has disconnected
[ 25.699068] fusb302 4-0022: connection has disconnected
[ 25.902361] fusb302 4-0022: connection has disconnected
[ 26.103981] fusb302 4-0022: connection has disconnected
[ 26.306428] fusb302 4-0022: connection has disconnected
[ 26.511366] fusb302 4-0022: connection has disconnected
[ 26.715146] fusb302 4-0022: connection has disconnected
[ 26.917687] fusb302 4-0022: connection has disconnected
[ 27.115104] fusb302 4-0022: connection has disconnected
[ 27.304196] fusb302 4-0022: connection has disconnected
[ 27.492205] fusb302 4-0022: connection has disconnected
[ 27.680449] fusb302 4-0022: connection has disconnected
[ 27.868378] fusb302 4-0022: connection has disconnected
[ 28.056786] fusb302 4-0022: connection has disconnected
[ 28.244544] fusb302 4-0022: connection has disconnected
[ 28.432222] fusb302 4-0022: connection has disconnected
[ 28.620937] fusb302 4-0022: connection has disconnected
[ 28.807311] fusb302 4-0022: connection has disconnected
[ 28.998194] fusb302 4-0022: connection has disconnected
[ 29.197776] fusb302 4-0022: connection has disconnected
[ 29.398093] fusb302 4-0022: connection has disconnected
[ 29.599928] fusb302 4-0022: connection has disconnected
[ 29.800838] fusb302 4-0022: connection has disconnected
[ 30.000852] fusb302 4-0022: connection has disconnected
[ 30.204977] fusb302 4-0022: connection has disconnected
[ 30.408995] fusb302 4-0022: connection has disconnected
[ 30.613309] fusb302 4-0022: connection has disconnected
[ 30.817001] fusb302 4-0022: connection has disconnected
[ 31.019787] fusb302 4-0022: connection has disconnected
[ 31.212220] fusb302 4-0022: connection has disconnected
[ 31.400919] fusb302 4-0022: connection has disconnected
[ 31.588395] fusb302 4-0022: connection has disconnected
[ 31.774193] fusb302 4-0022: connection has disconnected
[ 31.959943] fusb302 4-0022: connection has disconnected
[ 32.153245] fusb302 4-0022: connection has disconnected
[ 32.342285] fusb302 4-0022: connection has disconnected
[ 32.530788] fusb302 4-0022: connection has disconnected
[ 32.719667] fusb302 4-0022: connection has disconnected
[ 32.908170] fusb302 4-0022: connection has disconnected
[ 33.092951] fusb302 4-0022: connection has disconnected
[ 33.294706] fusb302 4-0022: connection has disconnected
[ 33.496347] fusb302 4-0022: connection has disconnected
[ 33.698140] fusb302 4-0022: connection has disconnected
[ 33.901726] fusb302 4-0022: connection has disconnected
[ 34.107064] fusb302 4-0022: connection has disconnected
[ 34.309591] fusb302 4-0022: connection has disconnected
[ 34.511918] fusb302 4-0022: connection has disconnected
[ 34.716273] fusb302 4-0022: connection has disconnected
[ 34.918791] fusb302 4-0022: connection has disconnected
[ 35.114481] fusb302 4-0022: connection has disconnected
[ 35.304361] fusb302 4-0022: connection has disconnected
[ 35.492109] fusb302 4-0022: connection has disconnected
[ 35.680444] fusb302 4-0022: connection has disconnected
[ 35.868331] fusb302 4-0022: connection has disconnected
[ 36.058294] fusb302 4-0022: connection has disconnected
[ 36.257769] fusb302 4-0022: connection has disconnected
[ 36.458699] fusb302 4-0022: connection has disconnected
[ 36.658337] fusb302 4-0022: connection has disconnected
[ 36.859325] fusb302 4-0022: connection has disconnected
[ 37.059772] fusb302 4-0022: connection has disconnected
[ 37.259904] fusb302 4-0022: connection has disconnected
[ 37.461351] fusb302 4-0022: connection has disconnected
[ 37.662046] fusb302 4-0022: connection has disconnected
[ 37.863463] fusb302 4-0022: connection has disconnected
[ 38.063040] fusb302 4-0022: connection has disconnected
[ 38.262384] fusb302 4-0022: connection has disconnected
[ 38.460016] fusb302 4-0022: connection has disconnected
[ 38.657472] fusb302 4-0022: connection has disconnected
[ 38.855100] fusb302 4-0022: connection has disconnected
[ 39.049916] fusb302 4-0022: connection has disconnected
[ 39.241859] fusb302 4-0022: connection has disconnected
[ 39.430744] fusb302 4-0022: connection has disconnected
[ 39.619252] fusb302 4-0022: connection has disconnected
[ 39.806330] fusb302 4-0022: connection has disconnected
[ 39.995213] fusb302 4-0022: connection has disconnected
[ 40.188307] fusb302 4-0022: connection has disconnected
[ 40.375655] fusb302 4-0022: connection has disconnected
[ 40.564002] fusb302 4-0022: connection has disconnected
[ 40.751449] fusb302 4-0022: connection has disconnected
[ 40.938522] fusb302 4-0022: connection has disconnected
[ 41.140947] fusb302 4-0022: connection has disconnected
[ 41.342922] fusb302 4-0022: connection has disconnected
[ 41.543445] fusb302 4-0022: connection has disconnected
[ 41.743776] fusb302 4-0022: connection has disconnected
[ 41.942764] fusb302 4-0022: connection has disconnected
[ 42.141592] fusb302 4-0022: connection has disconnected
[ 42.339312] fusb302 4-0022: connection has disconnected
[ 42.537339] fusb302 4-0022: connection has disconnected
[ 42.737954] fusb302 4-0022: connection has disconnected
[ 42.936182] fusb302 4-0022: connection has disconnected
[ 43.128329] fusb302 4-0022: connection has disconnected
[ 43.318009] fusb302 4-0022: connection has disconnected
[ 43.505592] fusb302 4-0022: connection has disconnected
[ 43.692531] fusb302 4-0022: connection has disconnected
[ 43.879667] fusb302 4-0022: connection has disconnected
[ 44.068602] fusb302 4-0022: connection has disconnected
[ 44.257391] fusb302 4-0022: connection has disconnected
[ 44.445446] fusb302 4-0022: connection has disconnected
[ 44.632995] fusb302 4-0022: connection has disconnected
[ 44.821120] fusb302 4-0022: connection has disconnected
[ 45.013900] fusb302 4-0022: connection has disconnected
[ 45.213745] fusb302 4-0022: connection has disconnected
[ 45.416574] fusb302 4-0022: connection has disconnected
[ 45.619082] fusb302 4-0022: connection has disconnected
[ 45.818145] fusb302 4-0022: connection has disconnected
[ 46.019823] fusb302 4-0022: connection has disconnected
[ 46.222797] fusb302 4-0022: connection has disconnected
[ 46.423898] fusb302 4-0022: connection has disconnected
[ 46.624207] fusb302 4-0022: connection has disconnected
[ 46.824821] fusb302 4-0022: connection has disconnected
[ 47.024829] fusb302 4-0022: connection has disconnected
[ 47.217546] fusb302 4-0022: connection has disconnected
[ 47.404828] fusb302 4-0022: connection has disconnected
[ 47.591948] fusb302 4-0022: connection has disconnected
[ 47.778852] fusb302 4-0022: connection has disconnected
[ 47.965863] fusb302 4-0022: connection has disconnected
[ 48.160521] fusb302 4-0022: connection has disconnected
[ 48.348482] fusb302 4-0022: connection has disconnected
[ 48.536317] fusb302 4-0022: connection has disconnected
[ 48.724542] fusb302 4-0022: connection has disconnected
[ 48.910610] fusb302 4-0022: connection has disconnected
[ 49.097003] fusb302 4-0022: connection has disconnected
[ 49.300004] fusb302 4-0022: connection has disconnected
[ 49.502877] fusb302 4-0022: connection has disconnected
[ 49.705931] fusb302 4-0022: connection has disconnected
[ 49.911304] fusb302 4-0022: connection has disconnected
[ 50.113379] fusb302 4-0022: connection has disconnected
[ 50.316375] fusb302 4-0022: connection has disconnected
[ 50.520235] fusb302 4-0022: connection has disconnected
[ 50.720659] fusb302 4-0022: connection has disconnected
[ 50.924173] fusb302 4-0022: connection has disconnected
[ 51.119150] fusb302 4-0022: connection has disconnected
[ 51.308170] fusb302 4-0022: connection has disconnected
[ 51.496393] fusb302 4-0022: connection has disconnected
[ 51.683889] fusb302 4-0022: connection has disconnected
[ 51.870209] fusb302 4-0022: connection has disconnected
[ 52.057786] fusb302 4-0022: connection has disconnected
[ 52.245910] fusb302 4-0022: connection has disconnected
[ 52.434918] fusb302 4-0022: connection has disconnected
[ 52.623581] fusb302 4-0022: connection has disconnected
[ 52.811023] fusb302 4-0022: connection has disconnected
[ 53.002748] fusb302 4-0022: connection has disconnected
[ 53.202545] fusb302 4-0022: connection has disconnected
[ 53.403849] fusb302 4-0022: connection has disconnected
[ 53.607033] fusb302 4-0022: connection has disconnected
[ 53.809407] fusb302 4-0022: connection has disconnected
[ 54.011852] fusb302 4-0022: connection has disconnected
[ 54.214987] fusb302 4-0022: connection has disconnected
[ 54.418393] fusb302 4-0022: connection has disconnected
[ 54.621960] fusb302 4-0022: connection has disconnected
[ 54.822608] fusb302 4-0022: connection has disconnected
[ 55.023901] fusb302 4-0022: connection has disconnected
[ 55.216212] fusb302 4-0022: connection has disconnected
[ 55.403958] fusb302 4-0022: connection has disconnected
[ 55.591472] fusb302 4-0022: connection has disconnected
[ 55.779208] fusb302 4-0022: connection has disconnected
[ 55.966217] fusb302 4-0022: connection has disconnected
[ 56.161434] fusb302 4-0022: connection has disconnected
[ 56.349697] fusb302 4-0022: connection has disconnected
[ 56.537797] fusb302 4-0022: connection has disconnected
[ 56.725721] fusb302 4-0022: connection has disconnected
[ 56.912208] fusb302 4-0022: connection has disconnected
[ 57.099401] fusb302 4-0022: connection has disconnected
[ 57.301758] fusb302 4-0022: connection has disconnected
[ 57.503964] fusb302 4-0022: connection has disconnected
[ 57.707160] fusb302 4-0022: connection has disconnected
[ 57.913814] fusb302 4-0022: connection has disconnected
[ 58.116701] fusb302 4-0022: connection has disconnected
[ 58.320178] fusb302 4-0022: connection has disconnected
[ 58.523011] fusb302 4-0022: connection has disconnected
[ 58.723245] fusb302 4-0022: connection has disconnected
[ 58.923555] fusb302 4-0022: connection has disconnected
[ 59.121064] fusb302 4-0022: connection has disconnected
[ 59.308155] fusb302 4-0022: connection has disconnected
[ 59.494205] fusb302 4-0022: connection has disconnected
[ 59.681583] fusb302 4-0022: connection has disconnected
[ 59.868672] fusb302 4-0022: connection has disconnected
[ 60.057467] fusb302 4-0022: connection has disconnected
[ 60.256213] fusb302 4-0022: connection has disconnected
[ 60.457426] fusb302 4-0022: connection has disconnected
[ 60.657710] fusb302 4-0022: connection has disconnected
[ 60.857541] fusb302 4-0022: connection has disconnected
[ 61.058486] fusb302 4-0022: connection has disconnected
[ 61.258929] fusb302 4-0022: connection has disconnected
[ 61.459541] fusb302 4-0022: connection has disconnected
[ 61.661026] fusb302 4-0022: connection has disconnected
[ 61.862249] fusb302 4-0022: connection has disconnected
[ 62.059906] fusb302 4-0022: connection has disconnected
[ 62.258121] fusb302 4-0022: connection has disconnected
[ 62.455778] fusb302 4-0022: connection has disconnected
[ 62.650987] fusb302 4-0022: connection has disconnected
[ 62.846378] fusb302 4-0022: connection has disconnected
[ 63.043367] fusb302 4-0022: connection has disconnected
[ 63.236147] fusb302 4-0022: connection has disconnected
[ 63.425039] fusb302 4-0022: connection has disconnected
[ 63.613658] fusb302 4-0022: connection has disconnected
[ 63.800711] fusb302 4-0022: connection has disconnected
[ 63.988577] fusb302 4-0022: connection has disconnected
[ 64.181091] fusb302 4-0022: connection has disconnected
[ 64.369263] fusb302 4-0022: connection has disconnected
[ 64.556951] fusb302 4-0022: connection has disconnected
[ 64.744316] fusb302 4-0022: connection has disconnected
[ 64.931541] fusb302 4-0022: connection has disconnected
[ 65.129999] fusb302 4-0022: connection has disconnected
[ 65.330711] fusb302 4-0022: connection has disconnected
[ 65.531437] fusb302 4-0022: connection has disconnected
[ 65.732921] fusb302 4-0022: connection has disconnected
[ 65.934909] fusb302 4-0022: connection has disconnected
[ 66.133776] fusb302 4-0022: connection has disconnected
[ 66.332111] fusb302 4-0022: connection has disconnected
[ 66.532788] fusb302 4-0022: connection has disconnected
[ 66.731857] fusb302 4-0022: connection has disconnected
[ 66.932299] fusb302 4-0022: connection has disconnected
[ 67.123668] fusb302 4-0022: connection has disconnected
[ 67.311641] fusb302 4-0022: connection has disconnected
[ 67.497529] fusb302 4-0022: connection has disconnected
[ 67.685169] fusb302 4-0022: connection has disconnected
[ 67.871481] fusb302 4-0022: connection has disconnected
[ 68.059384] fusb302 4-0022: connection has disconnected
[ 68.257813] fusb302 4-0022: connection has disconnected
[ 68.458559] fusb302 4-0022: connection has disconnected
[ 68.659822] fusb302 4-0022: connection has disconnected
[ 68.860709] fusb302 4-0022: connection has disconnected
[ 69.060049] fusb302 4-0022: connection has disconnected
[ 69.261117] fusb302 4-0022: connection has disconnected
[ 69.461451] fusb302 4-0022: connection has disconnected
[ 69.660882] fusb302 4-0022: connection has disconnected
[ 69.862045] fusb302 4-0022: connection has disconnected
[ 70.057319] fusb302 4-0022: connection has disconnected
[ 70.257403] fusb302 4-0022: connection has disconnected
[ 70.455750] fusb302 4-0022: connection has disconnected
[ 70.650924] fusb302 4-0022: connection has disconnected
[ 70.846331] fusb302 4-0022: connection has disconnected
[ 71.043187] fusb302 4-0022: connection has disconnected
[ 71.234945] fusb302 4-0022: connection has disconnected
[ 71.424540] fusb302 4-0022: connection has disconnected
[ 71.611625] fusb302 4-0022: connection has disconnected
[ 71.798136] fusb302 4-0022: connection has disconnected
[ 71.985398] fusb302 4-0022: connection has disconnected
[ 72.178898] fusb302 4-0022: connection has disconnected
[ 72.367288] fusb302 4-0022: connection has disconnected
[ 72.555795] fusb302 4-0022: connection has disconnected
[ 72.743298] fusb302 4-0022: connection has disconnected
[ 72.930459] fusb302 4-0022: connection has disconnected
[ 73.128433] fusb302 4-0022: connection has disconnected
[ 73.328821] fusb302 4-0022: connection has disconnected
[ 73.530273] fusb302 4-0022: connection has disconnected
[ 73.732020] fusb302 4-0022: connection has disconnected
[ 73.933882] fusb302 4-0022: connection has disconnected
[ 74.132405] fusb302 4-0022: connection has disconnected
[ 74.331823] fusb302 4-0022: connection has disconnected
[ 74.532473] fusb302 4-0022: connection has disconnected
[ 74.731464] fusb302 4-0022: connection has disconnected
[ 74.932175] fusb302 4-0022: connection has disconnected
[ 75.124910] fusb302 4-0022: connection has disconnected
[ 75.314871] fusb302 4-0022: connection has disconnected
[ 75.503323] fusb302 4-0022: connection has disconnected
[ 75.690393] fusb302 4-0022: connection has disconnected
[ 75.877832] fusb302 4-0022: connection has disconnected
[ 76.066119] fusb302 4-0022: connection has disconnected
[ 76.265692] fusb302 4-0022: connection has disconnected
[ 76.464482] fusb302 4-0022: connection has disconnected
[ 76.664336] fusb302 4-0022: connection has disconnected
[ 76.865161] fusb302 4-0022: connection has disconnected
[ 77.064459] fusb302 4-0022: connection has disconnected
[ 77.264306] fusb302 4-0022: connection has disconnected
[ 77.465550] fusb302 4-0022: connection has disconnected
[ 77.666334] fusb302 4-0022: connection has disconnected
[ 77.867037] fusb302 4-0022: connection has disconnected
[ 78.066113] fusb302 4-0022: connection has disconnected
[ 78.266453] fusb302 4-0022: connection has disconnected
[ 78.466815] fusb302 4-0022: connection has disconnected
[ 78.666907] fusb302 4-0022: connection has disconnected
[ 78.866182] fusb302 4-0022: connection has disconnected
[ 79.065265] fusb302 4-0022: connection has disconnected
[ 79.256448] fusb302 4-0022: connection has disconnected
[ 79.444204] fusb302 4-0022: connection has disconnected
[ 79.632303] fusb302 4-0022: connection has disconnected
[ 79.820808] fusb302 4-0022: connection has disconnected
[ 80.008726] fusb302 4-0022: connection has disconnected
[ 80.202752] fusb302 4-0022: connection has disconnected
[ 80.391297] fusb302 4-0022: connection has disconnected
[ 80.579294] fusb302 4-0022: connection has disconnected
[ 80.766352] fusb302 4-0022: connection has disconnected
[ 80.952480] fusb302 4-0022: connection has disconnected
[ 81.161144] fusb302 4-0022: connection has disconnected
[ 81.361338] fusb302 4-0022: connection has disconnected
[ 81.561361] fusb302 4-0022: connection has disconnected
[ 81.761091] fusb302 4-0022: connection has disconnected
[ 81.961984] fusb302 4-0022: connection has disconnected
[ 82.162237] fusb302 4-0022: connection has disconnected
[ 82.360307] fusb302 4-0022: connection has disconnected
[ 82.557270] fusb302 4-0022: connection has disconnected
[ 82.752411] fusb302 4-0022: connection has disconnected
[ 82.950326] fusb302 4-0022: connection has disconnected
[ 83.140629] fusb302 4-0022: connection has disconnected
[ 83.330220] fusb302 4-0022: connection has disconnected
[ 83.519005] fusb302 4-0022: connection has disconnected
[ 83.706559] fusb302 4-0022: connection has disconnected
[ 83.895526] fusb302 4-0022: connection has disconnected
[ 84.084925] fusb302 4-0022: connection has disconnected
[ 84.283812] fusb302 4-0022: connection has disconnected
[ 84.485009] fusb302 4-0022: connection has disconnected
[ 84.685425] fusb302 4-0022: connection has disconnected
[ 84.886348] fusb302 4-0022: connection has disconnected
[ 85.087873] fusb302 4-0022: connection has disconnected
[ 85.288540] fusb302 4-0022: connection has disconnected
[ 85.490714] fusb302 4-0022: connection has disconnected
[ 85.692350] fusb302 4-0022: connection has disconnected
[ 85.893913] fusb302 4-0022: connection has disconnected
[ 86.093833] fusb302 4-0022: connection has disconnected
[ 86.294057] fusb302 4-0022: connection has disconnected
[ 86.492762] fusb302 4-0022: connection has disconnected
[ 86.689112] fusb302 4-0022: connection has disconnected
[ 86.889538] fusb302 4-0022: connection has disconnected
[ 87.090406] fusb302 4-0022: connection has disconnected
[ 87.279093] fusb302 4-0022: connection has disconnected
[ 87.466578] fusb302 4-0022: connection has disconnected
[ 87.655378] fusb302 4-0022: connection has disconnected
[ 87.842314] fusb302 4-0022: connection has disconnected
[ 88.030578] fusb302 4-0022: connection has disconnected
[ 88.219406] fusb302 4-0022: connection has disconnected
[ 88.407305] fusb302 4-0022: connection has disconnected
[ 88.594220] fusb302 4-0022: connection has disconnected
[ 88.780310] fusb302 4-0022: connection has disconnected
[ 88.966658] fusb302 4-0022: connection has disconnected
[ 89.170773] fusb302 4-0022: connection has disconnected
[ 89.373343] fusb302 4-0022: connection has disconnected
[ 89.574359] fusb302 4-0022: connection has disconnected
[ 89.775859] fusb302 4-0022: connection has disconnected
[ 89.979527] fusb302 4-0022: connection has disconnected
[ 90.176204] fusb302 4-0022: connection has disconnected
[ 90.380525] fusb302 4-0022: connection has disconnected
[ 90.572165] fusb302 4-0022: connection has disconnected
[ 90.760902] fusb302 4-0022: connection has disconnected
[ 90.949375] fusb302 4-0022: connection has disconnected
[ 91.136424] fusb302 4-0022: connection has disconnected
[ 91.324440] fusb302 4-0022: connection has disconnected
[ 91.517241] fusb302 4-0022: connection has disconnected
[ 91.703904] fusb302 4-0022: connection has disconnected
[ 91.891693] fusb302 4-0022: connection has disconnected
[ 92.082310] fusb302 4-0022: connection has disconnected
[ 92.281420] fusb302 4-0022: connection has disconnected
[ 92.482088] fusb302 4-0022: connection has disconnected
[ 92.682424] fusb302 4-0022: connection has disconnected
[ 92.882537] fusb302 4-0022: connection has disconnected
[ 93.084751] fusb302 4-0022: connection has disconnected
[ 93.285080] fusb302 4-0022: connection has disconnected
[ 93.485564] fusb302 4-0022: connection has disconnected
[ 93.686423] fusb302 4-0022: connection has disconnected
[ 93.888340] fusb302 4-0022: connection has disconnected
[ 94.089062] fusb302 4-0022: connection has disconnected
[ 94.290696] fusb302 4-0022: connection has disconnected
[ 94.489537] fusb302 4-0022: connection has disconnected
[ 94.691183] fusb302 4-0022: connection has disconnected
[ 94.893012] fusb302 4-0022: connection has disconnected
[ 95.093168] fusb302 4-0022: connection has disconnected
[ 95.281151] fusb302 4-0022: connection has disconnected
[ 95.468412] fusb302 4-0022: connection has disconnected
[ 95.655849] fusb302 4-0022: connection has disconnected
[ 95.842948] fusb302 4-0022: connection has disconnected
[ 96.030485] fusb302 4-0022: connection has disconnected
[ 96.219557] fusb302 4-0022: connection has disconnected
[ 96.408176] fusb302 4-0022: connection has disconnected
[ 96.595313] fusb302 4-0022: connection has disconnected
[ 96.782390] fusb302 4-0022: connection has disconnected
[ 96.970651] fusb302 4-0022: connection has disconnected
[ 97.184989] fusb302 4-0022: connection has disconnected
[ 97.385313] fusb302 4-0022: connection has disconnected
[ 97.586532] fusb302 4-0022: connection has disconnected
[ 97.786546] fusb302 4-0022: connection has disconnected
[ 97.985917] fusb302 4-0022: connection has disconnected
[ 98.186193] fusb302 4-0022: connection has disconnected
[ 98.386310] fusb302 4-0022: connection has disconnected
[ 98.588223] fusb302 4-0022: connection has disconnected
[ 98.790046] fusb302 4-0022: connection has disconnected
[ 98.992187] fusb302 4-0022: connection has disconnected
[ 99.184284] fusb302 4-0022: connection has disconnected
[ 99.373206] fusb302 4-0022: connection has disconnected
[ 99.561673] fusb302 4-0022: connection has disconnected
[ 99.748813] fusb302 4-0022: connection has disconnected
[ 99.935779] fusb302 4-0022: connection has disconnected
[ 100.122574] fusb302 4-0022: connection has disconnected
[ 100.323341] fusb302 4-0022: connection has disconnected
[ 100.524540] fusb302 4-0022: connection has disconnected
[ 100.726265] fusb302 4-0022: connection has disconnected
[ 100.927859] fusb302 4-0022: connection has disconnected
[ 101.129279] fusb302 4-0022: connection has disconnected
[ 101.331046] fusb302 4-0022: connection has disconnected
[ 101.532172] fusb302 4-0022: connection has disconnected
[ 101.733899] fusb302 4-0022: connection has disconnected
[ 101.936194] fusb302 4-0022: connection has disconnected
[ 102.135261] fusb302 4-0022: connection has disconnected
[ 102.332838] fusb302 4-0022: connection has disconnected
[ 102.531360] fusb302 4-0022: connection has disconnected
[ 102.731838] fusb302 4-0022: connection has disconnected
[ 102.929809] fusb302 4-0022: connection has disconnected
[ 103.121533] fusb302 4-0022: connection has disconnected
[ 103.310150] fusb302 4-0022: connection has disconnected
[ 103.498474] fusb302 4-0022: connection has disconnected
[ 103.686084] fusb302 4-0022: connection has disconnected
[ 103.872226] fusb302 4-0022: connection has disconnected
[ 104.059570] fusb302 4-0022: connection has disconnected
[ 104.248140] fusb302 4-0022: connection has disconnected
[ 104.436736] fusb302 4-0022: connection has disconnected
[ 104.625095] fusb302 4-0022: connection has disconnected
[ 104.813259] fusb302 4-0022: connection has disconnected
[ 105.005168] fusb302 4-0022: connection has disconnected
[ 105.203447] fusb302 4-0022: connection has disconnected
[ 105.405996] fusb302 4-0022: connection has disconnected
[ 105.609789] fusb302 4-0022: connection has disconnected
[ 105.810807] fusb302 4-0022: connection has disconnected
[ 106.013095] fusb302 4-0022: connection has disconnected
[ 106.216196] fusb302 4-0022: connection has disconnected
[ 106.419577] fusb302 4-0022: connection has disconnected
[ 106.620188] fusb302 4-0022: connection has disconnected
[ 106.820761] fusb302 4-0022: connection has disconnected
[ 107.022939] fusb302 4-0022: connection has disconnected
[ 107.215690] fusb302 4-0022: connection has disconnected
[ 107.404219] fusb302 4-0022: connection has disconnected
[ 107.591459] fusb302 4-0022: connection has disconnected
[ 107.778787] fusb302 4-0022: connection has disconnected
[ 107.965697] fusb302 4-0022: connection has disconnected
[ 108.160055] fusb302 4-0022: connection has disconnected
[ 108.348578] fusb302 4-0022: connection has disconnected
[ 108.536674] fusb302 4-0022: connection has disconnected
[ 108.724611] fusb302 4-0022: connection has disconnected
[ 108.911739] fusb302 4-0022: connection has disconnected
[ 109.098209] fusb302 4-0022: connection has disconnected
[ 109.299903] fusb302 4-0022: connection has disconnected
[ 109.502555] fusb302 4-0022: connection has disconnected
[ 109.703904] fusb302 4-0022: connection has disconnected
[ 109.910830] fusb302 4-0022: connection has disconnected
[ 110.113461] fusb302 4-0022: connection has disconnected
[ 110.316880] fusb302 4-0022: connection has disconnected
[ 110.520182] fusb302 4-0022: connection has disconnected
[ 110.721014] fusb302 4-0022: connection has disconnected
[ 110.921954] fusb302 4-0022: connection has disconnected
[ 111.117194] fusb302 4-0022: connection has disconnected
[ 111.306537] fusb302 4-0022: connection has disconnected
[ 111.495111] fusb302 4-0022: connection has disconnected
[ 111.682383] fusb302 4-0022: connection has disconnected
[ 111.868675] fusb302 4-0022: connection has disconnected
[ 112.056090] fusb302 4-0022: connection has disconnected
[ 112.255005] fusb302 4-0022: connection has disconnected
[ 112.455142] fusb302 4-0022: connection has disconnected
[ 112.656185] fusb302 4-0022: connection has disconnected
[ 112.856427] fusb302 4-0022: connection has disconnected
[ 113.056430] fusb302 4-0022: connection has disconnected
[ 113.256029] fusb302 4-0022: connection has disconnected
[ 113.457160] fusb302 4-0022: connection has disconnected
[ 113.657042] fusb302 4-0022: connection has disconnected
[ 113.859553] fusb302 4-0022: connection has disconnected
[ 114.057516] fusb302 4-0022: connection has disconnected
[ 114.255745] fusb302 4-0022: connection has disconnected
[ 114.451556] fusb302 4-0022: connection has disconnected
[ 114.646527] fusb302 4-0022: connection has disconnected
[ 114.844376] fusb302 4-0022: connection has disconnected
[ 115.040303] fusb302 4-0022: connection has disconnected
[ 115.231546] fusb302 4-0022: connection has disconnected
[ 115.419850] fusb302 4-0022: connection has disconnected
[ 115.607321] fusb302 4-0022: connection has disconnected
[ 115.795179] fusb302 4-0022: connection has disconnected
[ 115.981667] fusb302 4-0022: connection has disconnected
[ 116.175730] fusb302 4-0022: connection has disconnected
[ 116.364567] fusb302 4-0022: connection has disconnected
[ 116.552126] fusb302 4-0022: connection has disconnected
[ 116.739677] fusb302 4-0022: connection has disconnected
[ 116.926922] fusb302 4-0022: connection has disconnected
[ 117.124455] fusb302 4-0022: connection has disconnected
[ 117.324844] fusb302 4-0022: connection has disconnected
[ 117.526552] fusb302 4-0022: connection has disconnected
[ 117.727886] fusb302 4-0022: connection has disconnected
[ 117.929448] fusb302 4-0022: connection has disconnected
[ 118.131006] fusb302 4-0022: connection has disconnected
[ 118.331965] fusb302 4-0022: connection has disconnected
[ 118.528590] fusb302 4-0022: connection has disconnected
[ 118.727826] fusb302 4-0022: connection has disconnected
[ 118.928891] fusb302 4-0022: connection has disconnected
[ 119.121107] fusb302 4-0022: connection has disconnected
[ 119.310324] fusb302 4-0022: connection has disconnected
[ 119.498270] fusb302 4-0022: connection has disconnected
[ 119.686330] fusb302 4-0022: connection has disconnected
[ 119.872333] fusb302 4-0022: connection has disconnected
[ 120.061193] fusb302 4-0022: connection has disconnected
[ 120.259299] fusb302 4-0022: connection has disconnected
[ 120.460318] fusb302 4-0022: connection has disconnected
[ 120.660775] fusb302 4-0022: connection has disconnected
[ 120.862109] fusb302 4-0022: connection has disconnected
[ 121.062574] fusb302 4-0022: connection has disconnected
[ 121.262888] fusb302 4-0022: connection has disconnected
[ 121.462238] fusb302 4-0022: connection has disconnected
[ 121.663110] fusb302 4-0022: connection has disconnected
[ 121.861623] fusb302 4-0022: connection has disconnected
[ 122.058691] fusb302 4-0022: connection has disconnected
[ 122.256702] fusb302 4-0022: connection has disconnected
[ 122.457355] fusb302 4-0022: connection has disconnected
[ 122.655537] fusb302 4-0022: connection has disconnected
[ 122.850897] fusb302 4-0022: connection has disconnected
[ 123.048619] fusb302 4-0022: connection has disconnected
[ 123.239164] fusb302 4-0022: connection has disconnected
[ 123.427673] fusb302 4-0022: connection has disconnected
[ 123.616844] fusb302 4-0022: connection has disconnected
[ 123.803538] fusb302 4-0022: connection has disconnected
[ 123.991334] fusb302 4-0022: connection has disconnected
[ 124.185391] fusb302 4-0022: connection has disconnected
[ 124.373583] fusb302 4-0022: connection has disconnected
[ 124.561793] fusb302 4-0022: connection has disconnected
[ 124.748777] fusb302 4-0022: connection has disconnected
[ 124.935834] fusb302 4-0022: connection has disconnected
[ 125.137549] fusb302 4-0022: connection has disconnected
[ 125.338682] fusb302 4-0022: connection has disconnected
[ 125.538945] fusb302 4-0022: connection has disconnected
[ 125.739891] fusb302 4-0022: connection has disconnected
[ 125.941461] fusb302 4-0022: connection has disconnected
[ 126.140399] fusb302 4-0022: connection has disconnected
[ 126.338364] fusb302 4-0022: connection has disconnected
[ 126.536579] fusb302 4-0022: connection has disconnected
[ 126.734349] fusb302 4-0022: connection has disconnected
[ 126.933181] fusb302 4-0022: connection has disconnected
[ 127.124174] fusb302 4-0022: connection has disconnected
[ 127.313884] fusb302 4-0022: connection has disconnected
[ 127.500979] fusb302 4-0022: connection has disconnected
[ 127.688297] fusb302 4-0022: connection has disconnected
[ 127.876578] fusb302 4-0022: connection has disconnected
[ 128.065306] fusb302 4-0022: connection has disconnected
[ 128.264000] fusb302 4-0022: connection has disconnected
[ 128.469772] fusb302 4-0022: connection has disconnected
[ 128.675655] fusb302 4-0022: connection has disconnected
[ 128.881994] fusb302 4-0022: connection has disconnected
[ 129.088163] fusb302 4-0022: connection has disconnected
[ 129.293796] fusb302 4-0022: connection has disconnected
[ 129.499918] fusb302 4-0022: connection has disconnected
[ 129.706986] fusb302 4-0022: connection has disconnected
[ 129.916979] fusb302 4-0022: connection has disconnected
[ 130.120801] fusb302 4-0022: connection has disconnected
[ 130.324207] fusb302 4-0022: connection has disconnected
[ 130.527708] fusb302 4-0022: connection has disconnected
[ 130.731721] fusb302 4-0022: connection has disconnected
[ 130.932404] fusb302 4-0022: connection has disconnected
[ 131.125786] fusb302 4-0022: connection has disconnected
[ 131.315409] fusb302 4-0022: connection has disconnected
[ 131.503442] fusb302 4-0022: connection has disconnected
[ 131.691224] fusb302 4-0022: connection has disconnected
[ 131.877526] fusb302 4-0022: connection has disconnected
[ 132.068693] fusb302 4-0022: connection has disconnected
[ 132.257178] fusb302 4-0022: connection has disconnected
[ 132.445086] fusb302 4-0022: connection has disconnected
[ 132.632804] fusb302 4-0022: connection has disconnected
[ 132.821244] fusb302 4-0022: connection has disconnected
[ 133.014303] fusb302 4-0022: connection has disconnected
[ 133.214124] fusb302 4-0022: connection has disconnected
[ 133.417679] fusb302 4-0022: connection has disconnected
[ 133.619807] fusb302 4-0022: connection has disconnected
[ 133.821542] fusb302 4-0022: connection has disconnected
[ 134.020887] fusb302 4-0022: connection has disconnected
[ 134.222015] fusb302 4-0022: connection has disconnected
[ 134.425325] fusb302 4-0022: connection has disconnected
[ 134.627689] fusb302 4-0022: connection has disconnected
[ 134.828340] fusb302 4-0022: connection has disconnected
[ 135.029009] fusb302 4-0022: connection has disconnected
[ 135.221124] fusb302 4-0022: connection has disconnected
[ 135.410141] fusb302 4-0022: connection has disconnected
[ 135.597294] fusb302 4-0022: connection has disconnected
[ 135.783388] fusb302 4-0022: connection has disconnected
[ 135.971855] fusb302 4-0022: connection has disconnected
[ 136.165926] fusb302 4-0022: connection has disconnected
[ 136.354582] fusb302 4-0022: connection has disconnected
[ 136.543296] fusb302 4-0022: connection has disconnected
[ 136.730824] fusb302 4-0022: connection has disconnected
[ 136.918734] fusb302 4-0022: connection has disconnected
[ 137.112338] fusb302 4-0022: connection has disconnected
[ 137.314787] fusb302 4-0022: connection has disconnected
[ 137.517027] fusb302 4-0022: connection has disconnected
[ 137.719654] fusb302 4-0022: connection has disconnected
[ 137.923773] fusb302 4-0022: connection has disconnected
[ 138.127790] fusb302 4-0022: connection has disconnected
[ 138.328419] fusb302 4-0022: connection has disconnected
[ 138.528925] fusb302 4-0022: connection has disconnected
[ 138.729416] fusb302 4-0022: connection has disconnected
[ 138.928237] fusb302 4-0022: connection has disconnected
[ 139.120014] fusb302 4-0022: connection has disconnected
[ 139.306854] fusb302 4-0022: connection has disconnected
[ 139.493786] fusb302 4-0022: connection has disconnected
[ 139.680307] fusb302 4-0022: connection has disconnected
[ 139.867383] fusb302 4-0022: connection has disconnected
[ 140.056547] fusb302 4-0022: connection has disconnected
[ 140.255031] fusb302 4-0022: connection has disconnected
[ 140.454373] fusb302 4-0022: connection has disconnected
[ 140.654421] fusb302 4-0022: connection has disconnected
[ 140.854436] fusb302 4-0022: connection has disconnected
[ 141.054455] fusb302 4-0022: connection has disconnected
[ 141.254365] fusb302 4-0022: connection has disconnected
[ 141.454560] fusb302 4-0022: connection has disconnected
[ 141.654432] fusb302 4-0022: connection has disconnected
[ 141.854683] fusb302 4-0022: connection has disconnected
[ 142.049535] fusb302 4-0022: connection has disconnected
[ 142.245246] fusb302 4-0022: connection has disconnected
[ 142.440777] fusb302 4-0022: connection has disconnected
[ 142.641349] fusb302 4-0022: connection has disconnected
[ 142.839073] fusb302 4-0022: connection has disconnected
[ 143.036422] fusb302 4-0022: connection has disconnected
[ 143.229124] fusb302 4-0022: connection has disconnected
[ 143.418214] fusb302 4-0022: connection has disconnected
[ 143.606160] fusb302 4-0022: connection has disconnected
[ 143.793937] fusb302 4-0022: connection has disconnected
[ 143.981827] fusb302 4-0022: connection has disconnected
[ 144.175546] fusb302 4-0022: connection has disconnected
[ 144.363794] fusb302 4-0022: connection has disconnected
[ 144.551668] fusb302 4-0022: connection has disconnected
[ 144.739900] fusb302 4-0022: connection has disconnected
[ 144.928188] fusb302 4-0022: connection has disconnected
[ 145.125933] fusb302 4-0022: connection has disconnected
[ 145.327909] fusb302 4-0022: connection has disconnected
[ 145.530346] fusb302 4-0022: connection has disconnected
[ 145.731898] fusb302 4-0022: connection has disconnected
[ 145.935059] fusb302 4-0022: connection has disconnected
[ 146.134096] fusb302 4-0022: connection has disconnected
[ 146.334625] fusb302 4-0022: connection has disconnected
[ 146.532123] fusb302 4-0022: connection has disconnected
[ 146.730397] fusb302 4-0022: connection has disconnected
[ 146.929821] fusb302 4-0022: connection has disconnected
[ 147.123676] fusb302 4-0022: connection has disconnected
[ 147.313827] fusb302 4-0022: connection has disconnected
[ 147.501456] fusb302 4-0022: connection has disconnected
[ 147.689211] fusb302 4-0022: connection has disconnected
[ 147.875094] fusb302 4-0022: connection has disconnected
[ 148.063670] fusb302 4-0022: connection has disconnected
[ 148.251936] fusb302 4-0022: connection has disconnected
[ 148.440403] fusb302 4-0022: connection has disconnected
[ 148.628543] fusb302 4-0022: connection has disconnected
[ 148.816031] fusb302 4-0022: connection has disconnected
[ 149.008160] fusb302 4-0022: connection has disconnected
[ 149.208240] fusb302 4-0022: connection has disconnected
[ 149.408240] fusb302 4-0022: connection has disconnected
[ 149.612314] fusb302 4-0022: connection has disconnected
[ 149.811962] fusb302 4-0022: connection has disconnected
[ 150.013925] fusb302 4-0022: connection has disconnected
[ 150.217700] fusb302 4-0022: connection has disconnected
[ 150.421150] fusb302 4-0022: connection has disconnected
[ 150.621950] fusb302 4-0022: connection has disconnected
[ 150.822421] fusb302 4-0022: connection has disconnected
[ 151.024827] fusb302 4-0022: connection has disconnected
[ 151.217337] fusb302 4-0022: connection has disconnected
[ 151.406018] fusb302 4-0022: connection has disconnected
[ 151.592690] fusb302 4-0022: connection has disconnected
[ 151.779858] fusb302 4-0022: connection has disconnected
[ 151.966895] fusb302 4-0022: connection has disconnected
[ 152.161735] fusb302 4-0022: connection has disconnected
[ 152.349687] fusb302 4-0022: connection has disconnected
[ 152.537692] fusb302 4-0022: connection has disconnected
[ 152.726203] fusb302 4-0022: connection has disconnected
[ 152.914179] fusb302 4-0022: connection has disconnected
[ 153.102773] fusb302 4-0022: connection has disconnected
[ 153.305975] fusb302 4-0022: connection has disconnected
[ 153.510059] fusb302 4-0022: connection has disconnected
[ 153.713939] fusb302 4-0022: connection has disconnected
[ 153.918356] fusb302 4-0022: connection has disconnected
[ 154.121154] fusb302 4-0022: connection has disconnected
[ 154.324415] fusb302 4-0022: connection has disconnected
[ 154.527624] fusb302 4-0022: connection has disconnected
[ 154.727551] fusb302 4-0022: connection has disconnected
[ 154.927460] fusb302 4-0022: connection has disconnected
[ 155.121628] fusb302 4-0022: connection has disconnected
[ 155.311639] fusb302 4-0022: connection has disconnected
[ 155.499874] fusb302 4-0022: connection has disconnected
[ 155.687235] fusb302 4-0022: connection has disconnected
[ 155.873393] fusb302 4-0022: connection has disconnected
[ 156.061583] fusb302 4-0022: connection has disconnected
[ 156.260007] fusb302 4-0022: connection has disconnected
[ 156.461126] fusb302 4-0022: connection has disconnected
[ 156.661154] fusb302 4-0022: connection has disconnected
[ 156.861231] fusb302 4-0022: connection has disconnected
[ 157.060443] fusb302 4-0022: connection has disconnected
[ 157.260167] fusb302 4-0022: connection has disconnected
[ 157.460312] fusb302 4-0022: connection has disconnected
[ 157.660854] fusb302 4-0022: connection has disconnected
[ 157.862101] fusb302 4-0022: connection has disconnected
[ 158.059913] fusb302 4-0022: connection has disconnected
[ 158.257778] fusb302 4-0022: connection has disconnected
[ 158.455464] fusb302 4-0022: connection has disconnected
[ 158.653459] fusb302 4-0022: connection has disconnected
[ 158.849260] fusb302 4-0022: connection has disconnected
[ 159.046405] fusb302 4-0022: connection has disconnected
[ 159.236528] fusb302 4-0022: connection has disconnected
[ 159.424605] fusb302 4-0022: connection has disconnected
[ 159.613035] fusb302 4-0022: connection has disconnected
[ 159.800076] fusb302 4-0022: connection has disconnected
[ 159.987937] fusb302 4-0022: connection has disconnected
[ 160.180718] fusb302 4-0022: connection has disconnected
[ 160.368929] fusb302 4-0022: connection has disconnected
[ 160.556811] fusb302 4-0022: connection has disconnected
[ 160.744305] fusb302 4-0022: connection has disconnected
[ 160.931299] fusb302 4-0022: connection has disconnected
[ 161.129258] fusb302 4-0022: connection has disconnected
[ 161.331112] fusb302 4-0022: connection has disconnected
[ 161.531927] fusb302 4-0022: connection has disconnected
[ 161.732616] fusb302 4-0022: connection has disconnected
[ 161.932965] fusb302 4-0022: connection has disconnected
[ 162.133805] fusb302 4-0022: connection has disconnected
[ 162.332406] fusb302 4-0022: connection has disconnected
[ 162.531829] fusb302 4-0022: connection has disconnected
[ 162.732348] fusb302 4-0022: connection has disconnected
[ 162.932912] fusb302 4-0022: connection has disconnected
[ 163.124184] fusb302 4-0022: connection has disconnected
[ 163.314177] fusb302 4-0022: connection has disconnected
[ 163.502306] fusb302 4-0022: connection has disconnected
[ 163.690054] fusb302 4-0022: connection has disconnected
[ 163.876089] fusb302 4-0022: connection has disconnected
[ 164.064671] fusb302 4-0022: connection has disconnected
[ 164.253347] fusb302 4-0022: connection has disconnected
[ 164.441460] fusb302 4-0022: connection has disconnected
[ 164.629406] fusb302 4-0022: connection has disconnected
[ 164.817299] fusb302 4-0022: connection has disconnected
[ 165.010312] fusb302 4-0022: connection has disconnected
[ 165.209758] fusb302 4-0022: connection has disconnected
[ 165.413304] fusb302 4-0022: connection has disconnected
[ 165.616569] fusb302 4-0022: connection has disconnected
[ 165.817658] fusb302 4-0022: connection has disconnected
[ 166.018895] fusb302 4-0022: connection has disconnected
[ 166.220764] fusb302 4-0022: connection has disconnected
[ 166.421942] fusb302 4-0022: connection has disconnected
[ 166.624809] fusb302 4-0022: connection has disconnected
[ 166.827718] fusb302 4-0022: connection has disconnected
[ 167.026749] fusb302 4-0022: connection has disconnected
[ 167.219429] fusb302 4-0022: connection has disconnected
[ 167.408138] fusb302 4-0022: connection has disconnected
[ 167.595925] fusb302 4-0022: connection has disconnected
[ 167.783728] fusb302 4-0022: connection has disconnected
[ 167.969905] fusb302 4-0022: connection has disconnected
[ 168.164539] fusb302 4-0022: connection has disconnected
[ 168.351581] fusb302 4-0022: connection has disconnected
[ 168.539676] fusb302 4-0022: connection has disconnected
[ 168.727317] fusb302 4-0022: connection has disconnected
[ 168.914281] fusb302 4-0022: connection has disconnected
[ 169.102347] fusb302 4-0022: connection has disconnected
[ 169.304113] fusb302 4-0022: connection has disconnected
[ 169.506947] fusb302 4-0022: connection has disconnected
[ 169.711386] fusb302 4-0022: connection has disconnected
[ 169.916197] fusb302 4-0022: connection has disconnected
[ 170.117073] fusb302 4-0022: connection has disconnected
[ 170.319538] fusb302 4-0022: connection has disconnected
[ 170.520649] fusb302 4-0022: connection has disconnected
[ 170.720765] fusb302 4-0022: connection has disconnected
[ 170.921773] fusb302 4-0022: connection has disconnected
[ 171.117217] fusb302 4-0022: connection has disconnected
[ 171.306558] fusb302 4-0022: connection has disconnected
[ 171.495281] fusb302 4-0022: connection has disconnected
[ 171.682687] fusb302 4-0022: connection has disconnected
[ 171.870390] fusb302 4-0022: connection has disconnected
[ 172.058754] fusb302 4-0022: connection has disconnected
[ 172.246789] fusb302 4-0022: connection has disconnected
[ 172.435684] fusb302 4-0022: connection has disconnected
[ 172.624012] fusb302 4-0022: connection has disconnected
[ 172.811174] fusb302 4-0022: connection has disconnected
[ 173.003641] fusb302 4-0022: connection has disconnected
[ 173.203354] fusb302 4-0022: connection has disconnected
[ 173.406063] fusb302 4-0022: connection has disconnected
[ 173.610692] fusb302 4-0022: connection has disconnected
[ 173.811207] fusb302 4-0022: connection has disconnected
[ 174.016005] fusb302 4-0022: connection has disconnected
[ 174.216950] fusb302 4-0022: connection has disconnected
[ 174.421040] fusb302 4-0022: connection has disconnected
[ 174.622036] fusb302 4-0022: connection has disconnected
[ 174.822837] fusb302 4-0022: connection has disconnected
[ 175.022791] fusb302 4-0022: connection has disconnected
[ 175.215157] fusb302 4-0022: connection has disconnected
[ 175.403208] fusb302 4-0022: connection has disconnected
[ 175.590222] fusb302 4-0022: connection has disconnected
[ 175.778407] fusb302 4-0022: connection has disconnected
[ 175.964773] fusb302 4-0022: connection has disconnected
[ 176.158783] fusb302 4-0022: connection has disconnected
[ 176.347278] fusb302 4-0022: connection has disconnected
[ 176.535671] fusb302 4-0022: connection has disconnected
[ 176.723332] fusb302 4-0022: connection has disconnected
[ 176.910135] fusb302 4-0022: connection has disconnected
[ 177.096414] fusb302 4-0022: connection has disconnected
[ 177.299250] fusb302 4-0022: connection has disconnected
[ 177.501588] fusb302 4-0022: connection has disconnected
[ 177.703617] fusb302 4-0022: connection has disconnected
[ 177.905165] fusb302 4-0022: connection has disconnected
[ 178.109711] fusb302 4-0022: connection has disconnected
[ 178.313310] fusb302 4-0022: connection has disconnected
[ 178.516098] fusb302 4-0022: connection has disconnected
[ 178.719483] fusb302 4-0022: connection has disconnected
[ 178.922709] fusb302 4-0022: connection has disconnected
[ 179.118793] fusb302 4-0022: connection has disconnected
[ 179.306560] fusb302 4-0022: connection has disconnected
[ 179.493377] fusb302 4-0022: connection has disconnected
[ 179.680164] fusb302 4-0022: connection has disconnected
[ 179.867199] fusb302 4-0022: connection has disconnected
[ 180.055583] fusb302 4-0022: connection has disconnected
[ 180.243479] fusb302 4-0022: connection has disconnected
[ 180.431279] fusb302 4-0022: connection has disconnected
[ 180.619844] fusb302 4-0022: connection has disconnected
[ 180.806936] fusb302 4-0022: connection has disconnected
[ 180.997932] fusb302 4-0022: connection has disconnected
[ 181.197422] fusb302 4-0022: connection has disconnected
[ 181.400105] fusb302 4-0022: connection has disconnected
[ 181.602343] fusb302 4-0022: connection has disconnected
[ 181.801994] fusb302 4-0022: connection has disconnected
[ 182.003364] fusb302 4-0022: connection has disconnected
[ 182.207074] fusb302 4-0022: connection has disconnected
[ 182.411951] fusb302 4-0022: connection has disconnected
[ 182.615157] fusb302 4-0022: connection has disconnected
[ 182.817665] fusb302 4-0022: connection has disconnected
[ 183.019988] fusb302 4-0022: connection has disconnected
[ 183.212201] fusb302 4-0022: connection has disconnected
[ 183.400555] fusb302 4-0022: connection has disconnected
[ 183.589532] fusb302 4-0022: connection has disconnected
[ 183.775675] fusb302 4-0022: connection has disconnected
[ 183.963100] fusb302 4-0022: connection has disconnected
[ 184.156533] fusb302 4-0022: connection has disconnected
[ 184.345006] fusb302 4-0022: connection has disconnected
[ 184.532768] fusb302 4-0022: connection has disconnected
[ 184.720938] fusb302 4-0022: connection has disconnected
[ 184.907219] fusb302 4-0022: connection has disconnected
[ 185.092240] fusb302 4-0022: connection has disconnected
[ 185.292783] fusb302 4-0022: connection has disconnected
[ 185.493778] fusb302 4-0022: connection has disconnected
[ 185.695787] fusb302 4-0022: connection has disconnected
[ 185.899279] fusb302 4-0022: connection has disconnected
[ 186.101598] fusb302 4-0022: connection has disconnected
[ 186.304824] fusb302 4-0022: connection has disconnected
[ 186.509393] fusb302 4-0022: connection has disconnected
[ 186.713915] fusb302 4-0022: connection has disconnected
[ 186.916585] fusb302 4-0022: connection has disconnected
[ 187.114643] fusb302 4-0022: connection has disconnected
[ 187.301562] fusb302 4-0022: connection has disconnected
[ 187.489484] fusb302 4-0022: connection has disconnected
[ 187.675386] fusb302 4-0022: connection has disconnected
[ 187.862592] fusb302 4-0022: connection has disconnected
[ 188.052525] fusb302 4-0022: connection has disconnected
[ 188.251164] fusb302 4-0022: connection has disconnected
[ 188.451540] fusb302 4-0022: connection has disconnected
[ 188.651535] fusb302 4-0022: connection has disconnected
[ 188.853012] fusb302 4-0022: connection has disconnected
[ 189.053668] fusb302 4-0022: connection has disconnected
[ 189.252365] fusb302 4-0022: connection has disconnected
[ 189.452708] fusb302 4-0022: connection has disconnected
[ 189.652183] fusb302 4-0022: connection has disconnected
[ 189.851755] fusb302 4-0022: connection has disconnected
[ 190.047297] fusb302 4-0022: connection has disconnected
[ 190.243955] fusb302 4-0022: connection has disconnected
[ 190.441977] fusb302 4-0022: connection has disconnected
[ 190.637744] fusb302 4-0022: connection has disconnected
[ 190.836242] fusb302 4-0022: connection has disconnected
[ 191.033984] fusb302 4-0022: connection has disconnected
[ 191.225911] fusb302 4-0022: connection has disconnected
[ 191.415435] fusb302 4-0022: connection has disconnected
[ 191.603887] fusb302 4-0022: connection has disconnected
[ 191.790944] fusb302 4-0022: connection has disconnected
[ 191.978784] fusb302 4-0022: connection has disconnected
[ 192.172794] fusb302 4-0022: connection has disconnected
[ 192.361452] fusb302 4-0022: connection has disconnected
[ 192.549013] fusb302 4-0022: connection has disconnected
[ 192.736783] fusb302 4-0022: connection has disconnected
[ 192.926102] fusb302 4-0022: connection has disconnected
[ 193.123750] fusb302 4-0022: connection has disconnected
[ 193.326140] fusb302 4-0022: connection has disconnected
[ 193.527447] fusb302 4-0022: connection has disconnected
[ 193.727915] fusb302 4-0022: connection has disconnected
[ 193.931767] fusb302 4-0022: connection has disconnected
[ 194.132556] fusb302 4-0022: connection has disconnected
[ 194.333225] fusb302 4-0022: connection has disconnected
[ 194.533406] fusb302 4-0022: connection has disconnected
[ 194.732775] fusb302 4-0022: connection has disconnected
[ 194.929450] fusb302 4-0022: connection has disconnected
[ 195.123973] fusb302 4-0022: connection has disconnected
[ 195.313412] fusb302 4-0022: connection has disconnected
[ 195.502367] fusb302 4-0022: connection has disconnected
[ 195.690094] fusb302 4-0022: connection has disconnected
[ 195.876305] fusb302 4-0022: connection has disconnected
[ 196.065106] fusb302 4-0022: connection has disconnected
[ 196.263184] fusb302 4-0022: connection has disconnected
[ 196.462875] fusb302 4-0022: connection has disconnected
[ 196.663433] fusb302 4-0022: connection has disconnected
[ 196.863427] fusb302 4-0022: connection has disconnected
[ 197.063370] fusb302 4-0022: connection has disconnected
[ 197.263476] fusb302 4-0022: connection has disconnected
[ 197.463311] fusb302 4-0022: connection has disconnected
[ 197.663461] fusb302 4-0022: connection has disconnected
[ 197.863451] fusb302 4-0022: connection has disconnected
[ 198.063106] fusb302 4-0022: connection has disconnected
[ 198.262905] fusb302 4-0022: connection has disconnected
[ 198.462119] fusb302 4-0022: connection has disconnected
[ 198.659908] fusb302 4-0022: connection has disconnected
[ 198.857427] fusb302 4-0022: connection has disconnected
[ 199.055331] fusb302 4-0022: connection has disconnected
[ 199.246300] fusb302 4-0022: connection has disconnected
[ 199.434903] fusb302 4-0022: connection has disconnected
[ 199.623336] fusb302 4-0022: connection has disconnected
[ 199.811038] fusb302 4-0022: connection has disconnected
[ 199.998390] fusb302 4-0022: connection has disconnected
[ 200.192377] fusb302 4-0022: connection has disconnected
[ 200.380309] fusb302 4-0022: connection has disconnected
[ 200.567121] fusb302 4-0022: connection has disconnected
[ 200.753946] fusb302 4-0022: connection has disconnected
[ 200.942791] fusb302 4-0022: connection has disconnected
[ 201.147758] fusb302 4-0022: connection has disconnected
[ 201.349095] fusb302 4-0022: connection has disconnected
[ 201.550038] fusb302 4-0022: connection has disconnected
[ 201.750111] fusb302 4-0022: connection has disconnected
[ 201.946406] fusb302 4-0022: connection has disconnected
[ 202.146263] fusb302 4-0022: connection has disconnected
[ 202.342386] fusb302 4-0022: connection has disconnected
[ 202.540588] fusb302 4-0022: connection has disconnected
[ 202.737174] fusb302 4-0022: connection has disconnected
[ 202.935055] fusb302 4-0022: connection has disconnected
[ 203.126352] fusb302 4-0022: connection has disconnected
[ 203.316848] fusb302 4-0022: connection has disconnected
[ 203.504621] fusb302 4-0022: connection has disconnected
[ 203.691652] fusb302 4-0022: connection has disconnected
[ 203.880773] fusb302 4-0022: connection has disconnected
[ 204.069577] fusb302 4-0022: connection has disconnected
[ 204.258106] fusb302 4-0022: connection has disconnected
[ 204.446122] fusb302 4-0022: connection has disconnected
[ 204.633574] fusb302 4-0022: connection has disconnected
[ 204.821898] fusb302 4-0022: connection has disconnected
[ 205.014303] fusb302 4-0022: connection has disconnected
[ 205.214693] fusb302 4-0022: connection has disconnected
[ 205.416565] fusb302 4-0022: connection has disconnected
[ 205.619034] fusb302 4-0022: connection has disconnected
[ 205.821185] fusb302 4-0022: connection has disconnected
[ 206.021671] fusb302 4-0022: connection has disconnected
[ 206.224213] fusb302 4-0022: connection has disconnected
[ 206.427055] fusb302 4-0022: connection has disconnected
[ 206.625686] fusb302 4-0022: connection has disconnected
[ 206.826304] fusb302 4-0022: connection has disconnected
[ 207.027186] fusb302 4-0022: connection has disconnected
[ 207.219307] fusb302 4-0022: connection has disconnected
[ 207.408158] fusb302 4-0022: connection has disconnected
[ 207.595942] fusb302 4-0022: connection has disconnected
[ 207.783130] fusb302 4-0022: connection has disconnected
[ 207.968897] fusb302 4-0022: connection has disconnected
[ 208.163182] fusb302 4-0022: connection has disconnected
[ 208.350861] fusb302 4-0022: connection has disconnected
[ 208.539401] fusb302 4-0022: connection has disconnected
[ 208.727390] fusb302 4-0022: connection has disconnected
[ 208.913879] fusb302 4-0022: connection has disconnected
[ 209.102225] fusb302 4-0022: connection has disconnected
[ 209.305097] fusb302 4-0022: connection has disconnected
[ 209.512594] fusb302 4-0022: connection has disconnected
[ 209.717340] fusb302 4-0022: connection has disconnected
[ 209.922665] fusb302 4-0022: connection has disconnected
[ 210.127162] fusb302 4-0022: connection has disconnected
[ 210.332241] fusb302 4-0022: connection has disconnected
[ 210.536022] fusb302 4-0022: connection has disconnected
[ 210.735541] fusb302 4-0022: connection has disconnected
[ 210.926438] fusb302 4-0022: connection has disconnected
[ 211.116777] fusb302 4-0022: connection has disconnected
[ 211.304855] fusb302 4-0022: connection has disconnected
[ 211.491921] fusb302 4-0022: connection has disconnected
[ 211.681793] fusb302 4-0022: connection has disconnected
[ 211.868292] fusb302 4-0022: connection has disconnected
[ 212.059289] fusb302 4-0022: connection has disconnected
[ 212.257824] fusb302 4-0022: connection has disconnected
[ 212.458716] fusb302 4-0022: connection has disconnected
[ 212.659351] fusb302 4-0022: connection has disconnected
[ 212.859355] fusb302 4-0022: connection has disconnected
[ 213.059431] fusb302 4-0022: connection has disconnected
[ 213.259164] fusb302 4-0022: connection has disconnected
[ 213.459363] fusb302 4-0022: connection has disconnected
[ 213.659120] fusb302 4-0022: connection has disconnected
[ 213.860965] fusb302 4-0022: connection has disconnected
[ 214.058559] fusb302 4-0022: connection has disconnected
[ 214.255763] fusb302 4-0022: connection has disconnected
[ 214.451577] fusb302 4-0022: connection has disconnected
[ 214.645878] fusb302 4-0022: connection has disconnected
[ 214.843651] fusb302 4-0022: connection has disconnected
[ 215.040174] fusb302 4-0022: connection has disconnected
[ 215.231545] fusb302 4-0022: connection has disconnected
[ 215.420058] fusb302 4-0022: connection has disconnected
[ 215.608158] fusb302 4-0022: connection has disconnected
[ 215.794949] fusb302 4-0022: connection has disconnected
[ 215.983299] fusb302 4-0022: connection has disconnected
[ 216.177895] fusb302 4-0022: connection has disconnected
[ 216.365918] fusb302 4-0022: connection has disconnected
[ 216.553191] fusb302 4-0022: connection has disconnected
[ 216.740863] fusb302 4-0022: connection has disconnected
[ 216.929533] fusb302 4-0022: connection has disconnected
[ 217.128688] fusb302 4-0022: connection has disconnected
[ 217.329093] fusb302 4-0022: connection has disconnected
[ 217.530093] fusb302 4-0022: connection has disconnected
[ 217.730425] fusb302 4-0022: connection has disconnected
[ 217.932978] fusb302 4-0022: connection has disconnected
[ 218.131451] fusb302 4-0022: connection has disconnected
[ 218.332425] fusb302 4-0022: connection has disconnected
[ 218.530694] fusb302 4-0022: connection has disconnected
[ 218.731762] fusb302 4-0022: connection has disconnected
[ 218.932124] fusb302 4-0022: connection has disconnected
[ 219.125682] fusb302 4-0022: connection has disconnected
[ 219.316113] fusb302 4-0022: connection has disconnected
[ 219.503658] fusb302 4-0022: connection has disconnected
[ 219.691218] fusb302 4-0022: connection has disconnected
[ 219.877851] fusb302 4-0022: connection has disconnected
[ 220.065669] fusb302 4-0022: connection has disconnected
[ 220.254383] fusb302 4-0022: connection has disconnected
[ 220.442401] fusb302 4-0022: connection has disconnected
[ 220.630387] fusb302 4-0022: connection has disconnected
[ 220.818241] fusb302 4-0022: connection has disconnected
[ 221.011892] fusb302 4-0022: connection has disconnected
[ 221.212339] fusb302 4-0022: connection has disconnected
[ 221.414779] fusb302 4-0022: connection has disconnected
[ 221.617377] fusb302 4-0022: connection has disconnected
[ 221.821577] fusb302 4-0022: connection has disconnected
[ 222.019882] fusb302 4-0022: connection has disconnected
[ 222.221225] fusb302 4-0022: connection has disconnected
[ 222.422354] fusb302 4-0022: connection has disconnected
[ 222.622708] fusb302 4-0022: connection has disconnected
[ 222.825756] fusb302 4-0022: connection has disconnected
[ 223.024913] fusb302 4-0022: connection has disconnected
[ 223.217530] fusb302 4-0022: connection has disconnected
[ 223.404952] fusb302 4-0022: connection has disconnected
[ 223.592307] fusb302 4-0022: connection has disconnected
[ 223.780584] fusb302 4-0022: connection has disconnected
[ 223.967287] fusb302 4-0022: connection has disconnected
[ 224.161611] fusb302 4-0022: connection has disconnected
[ 224.349804] fusb302 4-0022: connection has disconnected
[ 224.538315] fusb302 4-0022: connection has disconnected
[ 224.726486] fusb302 4-0022: connection has disconnected
[ 224.913855] fusb302 4-0022: connection has disconnected
[ 225.101882] fusb302 4-0022: connection has disconnected
[ 225.304161] fusb302 4-0022: connection has disconnected
[ 225.507026] fusb302 4-0022: connection has disconnected
[ 225.711478] fusb302 4-0022: connection has disconnected
[ 225.916556] fusb302 4-0022: connection has disconnected
[ 226.120372] fusb302 4-0022: connection has disconnected
[ 226.322302] fusb302 4-0022: connection has disconnected
[ 226.524912] fusb302 4-0022: connection has disconnected
[ 226.725355] fusb302 4-0022: connection has disconnected
[ 226.925795] fusb302 4-0022: connection has disconnected
[ 227.120633] fusb302 4-0022: connection has disconnected
[ 227.310560] fusb302 4-0022: connection has disconnected
[ 227.498347] fusb302 4-0022: connection has disconnected
[ 227.685665] fusb302 4-0022: connection has disconnected
[ 227.872589] fusb302 4-0022: connection has disconnected
[ 228.062099] fusb302 4-0022: connection has disconnected
[ 228.249442] fusb302 4-0022: connection has disconnected
[ 228.437136] fusb302 4-0022: connection has disconnected
[ 228.625011] fusb302 4-0022: connection has disconnected
[ 228.813173] fusb302 4-0022: connection has disconnected
[ 229.004938] fusb302 4-0022: connection has disconnected
[ 229.203547] fusb302 4-0022: connection has disconnected
[ 229.405811] fusb302 4-0022: connection has disconnected
[ 229.610089] fusb302 4-0022: connection has disconnected
[ 229.813923] fusb302 4-0022: connection has disconnected
[ 230.015080] fusb302 4-0022: connection has disconnected
[ 230.218591] fusb302 4-0022: connection has disconnected
[ 230.422302] fusb302 4-0022: connection has disconnected
[ 230.622620] fusb302 4-0022: connection has disconnected
[ 230.822038] fusb302 4-0022: connection has disconnected
[ 231.024320] fusb302 4-0022: connection has disconnected
[ 231.216414] fusb302 4-0022: connection has disconnected
[ 231.403956] fusb302 4-0022: connection has disconnected
[ 231.591276] fusb302 4-0022: connection has disconnected
[ 231.779093] fusb302 4-0022: connection has disconnected
[ 231.965726] fusb302 4-0022: connection has disconnected
[ 232.160437] fusb302 4-0022: connection has disconnected
[ 232.348478] fusb302 4-0022: connection has disconnected
[ 232.536786] fusb302 4-0022: connection has disconnected
[ 232.724630] fusb302 4-0022: connection has disconnected
[ 232.914430] fusb302 4-0022: connection has disconnected
[ 233.102928] fusb302 4-0022: connection has disconnected
[ 233.305573] fusb302 4-0022: connection has disconnected
[ 233.508278] fusb302 4-0022: connection has disconnected
[ 233.712383] fusb302 4-0022: connection has disconnected
[ 233.914173] fusb302 4-0022: connection has disconnected
[ 234.115267] fusb302 4-0022: connection has disconnected
[ 234.316968] fusb302 4-0022: connection has disconnected
[ 234.520173] fusb302 4-0022: connection has disconnected
[ 234.722711] fusb302 4-0022: connection has disconnected
[ 234.925759] fusb302 4-0022: connection has disconnected
[ 235.120597] fusb302 4-0022: connection has disconnected
[ 235.310135] fusb302 4-0022: connection has disconnected
[ 235.498479] fusb302 4-0022: connection has disconnected
[ 235.686303] fusb302 4-0022: connection has disconnected
[ 235.872245] fusb302 4-0022: connection has disconnected
[ 236.061217] fusb302 4-0022: connection has disconnected
[ 236.259699] fusb302 4-0022: connection has disconnected
[ 236.460781] fusb302 4-0022: connection has disconnected
[ 236.661468] fusb302 4-0022: connection has disconnected
[ 236.861585] fusb302 4-0022: connection has disconnected
[ 237.061886] fusb302 4-0022: connection has disconnected
[ 237.262113] fusb302 4-0022: connection has disconnected
[ 237.461526] fusb302 4-0022: connection has disconnected
[ 237.663536] fusb302 4-0022: connection has disconnected
[ 237.863716] fusb302 4-0022: connection has disconnected
[ 238.063190] fusb302 4-0022: connection has disconnected
[ 238.260105] fusb302 4-0022: connection has disconnected
[ 238.457714] fusb302 4-0022: connection has disconnected
[ 238.655011] fusb302 4-0022: connection has disconnected
[ 238.850266] fusb302 4-0022: connection has disconnected
[ 239.044757] fusb302 4-0022: connection has disconnected
[ 239.236640] fusb302 4-0022: connection has disconnected
[ 239.425906] fusb302 4-0022: connection has disconnected
[ 239.614263] fusb302 4-0022: connection has disconnected
[ 239.801331] fusb302 4-0022: connection has disconnected
[ 239.989536] fusb302 4-0022: connection has disconnected
[ 240.181899] fusb302 4-0022: connection has disconnected
[ 240.269755] INFO: task swapper/0:1 blocked for more than 120 seconds.
[ 240.270336] Not tainted 4.4.52 #22
[ 240.270716] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this
[ 240.271407] swapper/0 D ffffff8008084e84 0 1 0 0x00000000
[ 240.272065] Call trace:
[ 240.272311] [<ffffff8008084e84>] __switch_to+0xb4/0xc0
[ 240.272794] [<ffffff8008b9c2f8>] __schedule+0x3e4/0x62c
[ 240.273260] [<ffffff8008b9c5c4>] schedule+0x84/0x98
[ 240.273720] [<ffffff8008b9ed88>] schedule_timeout+0x34/0x21c
[ 240.274224] [<ffffff8008b9d024>] wait_for_common+0x12c/0x16c
[ 240.274746] [<ffffff8008b9d08c>] wait_for_completion+0x28/0x34
[ 240.275269] [<ffffff8008481004>] drm_dev_wait+0x1c/0x24
[ 240.275758] [<ffffff8008fcdc8c>] drm_misc_init+0x10/0x84
[ 240.276234] [<ffffff8008082b48>] do_one_initcall+0xfc/0x180
[ 240.276751] [<ffffff8008fa0d74>] kernel_init_freeable+0x1a8/0x248
[ 240.277292] [<ffffff8008b9b130>] kernel_init+0x18/0x100
[ 240.277775] [<ffffff8008082690>] ret_from_fork+0x10/0x40
[ 240.278249] Kernel panic - not syncing: hung_task: blocked tasks
[ 240.278787] CPU: 5 PID: 39 Comm: khungtaskd Not tainted 4.4.52 #22
[ 240.279333] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (
[ 240.279982] Call trace:
[ 240.280211] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
[ 240.280694] [<ffffff8008088368>] show_stack+0x20/0x28
[ 240.281149] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
[ 240.281602] [<ffffff800815de88>] panic+0xf4/0x23c
[ 240.282026] [<ffffff8008127d60>] watchdog+0x2e0/0x30c
[ 240.282478] [<ffffff80080b9284>] kthread+0xe4/0xec
[ 240.282906] [<ffffff8008082690>] ret_from_fork+0x10/0x40
[ 240.283405] CPU0: stopping
[ 240.283679] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.52 #22
[ 240.284214] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (
[ 240.284867] Call trace:
[ 240.285114] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
[ 240.285604] [<ffffff8008088368>] show_stack+0x20/0x28
[ 240.286066] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
[ 240.286526] [<ffffff800808d944>] handle_IPI+0x134/0x240
[ 240.286997] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
[ 240.287497] Exception stack(0xffffffc07ff03000 to 0xffffffc07ff03130)
[ 240.288076] 3000: ffffff80090c3d80 0000008000000000 ffffff80090c3eb0 ffffff80
[ 240.288773] 3020: 0000000060000045 ffffff80091ae1a0 ffffffc07feff060 00000000
[ 240.289471] 3040: ffffff80090c3eb0 ffffff80090c3d80 0000000000000000 00000000
[ 240.290167] 3060: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.290863] 3080: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.291559] 30a0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.292254] 30c0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.292950] 30e0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.293647] 3100: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.294340] 3120: 0000000000000000 0000000000000000
[ 240.294780] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
[ 240.295228] [<ffffff80088742c4>] cpuidle_enter_state+0x1fc/0x2a8
[ 240.295771] [<ffffff80088743e4>] cpuidle_enter+0x34/0x40
[ 240.296254] [<ffffff80080dd108>] cpu_startup_entry+0x26c/0x300
[ 240.296780] [<ffffff8008b9b110>] rest_init+0x78/0x80
[ 240.297231] [<ffffff8008fa0bb8>] start_kernel+0x3d4/0x3e8
[ 240.297720] [<ffffff8008fa01c4>] __primary_switched+0x30/0x6c
[ 240.298235] CPU4: stopping
[ 240.298495] CPU: 4 PID: 0 Comm: swapper/4 Not tainted 4.4.52 #22
[ 240.299027] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (
[ 240.299678] Call trace:
[ 240.299913] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
[ 240.300399] [<ffffff8008088368>] show_stack+0x20/0x28
[ 240.300853] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
[ 240.301306] [<ffffff800808d944>] handle_IPI+0x134/0x240
[ 240.301771] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
[ 240.302266] Exception stack(0xffffffc07ff57000 to 0xffffffc07ff57130)
[ 240.302840] 7000: ffffffc07965bdc0 0000008000000000 ffffffc07965bef0 ffffff80
[ 240.303532] 7020: 0000000060000045 ffffff80091ae1a0 ffffffc07ff53060 00000000
[ 240.304224] 7040: ffffffc07965bef0 ffffffc07965bdc0 0000000000000000 00000000
[ 240.304914] 7060: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.305605] 7080: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.306295] 70a0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.306985] 70c0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.307676] 70e0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.308365] 7100: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.309054] 7120: 0000000000000000 0000000000000000
[ 240.309490] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
[ 240.309933] [<ffffff80088742c4>] cpuidle_enter_state+0x1fc/0x2a8
[ 240.310469] [<ffffff80088743e4>] cpuidle_enter+0x34/0x40
[ 240.310948] [<ffffff80080dd108>] cpu_startup_entry+0x26c/0x300
[ 240.311467] [<ffffff800808d46c>] secondary_start_kernel+0x184/0x190
[ 240.312022] [<0000000000282978>] 0x282978
[ 240.312386] CPU2: stopping
[ 240.312647] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.4.52 #22
[ 240.313181] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (
[ 240.313832] Call trace:
[ 240.314068] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
[ 240.314556] [<ffffff8008088368>] show_stack+0x20/0x28
[ 240.315014] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
[ 240.315470] [<ffffff800808d944>] handle_IPI+0x134/0x240
[ 240.315940] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
[ 240.316439] Exception stack(0xffffffc07ff2d000 to 0xffffffc07ff2d130)
[ 240.317017] d000: ffffffc07964fdc0 0000008000000000 ffffffc07964fef0 ffffff80
[ 240.317715] d020: 0000000060000045 ffffff80091ae1a0 ffffffc07ff29060 00000000
[ 240.318412] d040: ffffffc07964fef0 ffffffc07964fdc0 0000000000000000 00000000
[ 240.319107] d060: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.319803] d080: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.320499] d0a0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.321195] d0c0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.321891] d0e0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.322587] d100: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.323280] d120: 0000000000000000 0000000000000000
[ 240.323720] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
[ 240.324165] [<ffffff80088742c4>] cpuidle_enter_state+0x1fc/0x2a8
[ 240.324706] [<ffffff80088743e4>] cpuidle_enter+0x34/0x40
[ 240.325189] [<ffffff80080dd108>] cpu_startup_entry+0x26c/0x300
[ 240.325714] [<ffffff800808d46c>] secondary_start_kernel+0x184/0x190
[ 240.326273] [<0000000000282978>] 0x282978
[ 240.326637] CPU1: stopping
[ 240.326896] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.4.52 #22
[ 240.327430] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (
[ 240.328081] Call trace:
[ 240.328317] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
[ 240.328806] [<ffffff8008088368>] show_stack+0x20/0x28
[ 240.329263] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
[ 240.329721] [<ffffff800808d944>] handle_IPI+0x134/0x240
[ 240.330191] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
[ 240.330689] Exception stack(0xffffffc07ff18000 to 0xffffffc07ff18130)
[ 240.331268] 8000: ffffffc07964bdc0 0000008000000000 ffffffc07964bef0 ffffff80
[ 240.331965] 8020: 0000000060000045 ffffff80091ae1a0 ffffffc07ff14060 00000000
[ 240.332662] 8040: ffffffc07964bef0 ffffffc07964bdc0 0000000000000000 00000000
[ 240.333358] 8060: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.334054] 8080: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.334751] 80a0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.335447] 80c0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.336142] 80e0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.336838] 8100: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.337531] 8120: 0000000000000000 0000000000000000
[ 240.337972] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
[ 240.338417] [<ffffff80088742c4>] cpuidle_enter_state+0x1fc/0x2a8
[ 240.338958] [<ffffff80088743e4>] cpuidle_enter+0x34/0x40
[ 240.339441] [<ffffff80080dd108>] cpu_startup_entry+0x26c/0x300
[ 240.339966] [<ffffff800808d46c>] secondary_start_kernel+0x184/0x190
[ 240.340523] [<0000000000282978>] 0x282978
[ 240.340886] CPU3: stopping
[ 240.341145] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.4.52 #22
[ 240.341679] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (
[ 240.342330] Call trace:
[ 240.342566] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
[ 240.343054] [<ffffff8008088368>] show_stack+0x20/0x28
[ 240.343512] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
[ 240.343968] [<ffffff800808d944>] handle_IPI+0x134/0x240
[ 240.344439] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
[ 240.344937] Exception stack(0xffffffc07ff42000 to 0xffffffc07ff42130)
[ 240.345515] 2000: ffffffc079657dc0 0000008000000000 ffffffc079657ef0 ffffff80
[ 240.346213] 2020: 0000000060000045 ffffff80091ae1a0 ffffffc07ff3e060 00000000
[ 240.346910] 2040: ffffffc079657ef0 ffffffc079657dc0 0000000000000000 00000000
[ 240.347607] 2060: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.348303] 2080: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.348999] 20a0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.349695] 20c0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.350391] 20e0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.351087] 2100: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 240.351780] 2120: 0000000000000000 0000000000000000
[ 240.352220] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
[ 240.352665] [<ffffff80088742c4>] cpuidle_enter_state+0x1fc/0x2a8
[ 240.353206] [<ffffff80088743e4>] cpuidle_enter+0x34/0x40
[ 240.353688] [<ffffff80080dd108>] cpu_startup_entry+0x26c/0x300
[ 240.354212] [<ffffff800808d46c>] secondary_start_kernel+0x184/0x190
[ 240.354771] [<0000000000282978>] 0x282978
[ 240.355135] CRU:
[ 240.355323] 00000000: 00000044 00002201 80000000 00000108 00000007 00007f00 0
[ 240.356083] 00000020: 00000044 00002201 80000000 00000108 00000007 00007f00 0
[ 240.356843] 00000040: 00000037 00001201 8000031f 00000108 00000007 00007f00 0
[ 240.357601] 00000060: 00000190 00001206 80000000 00000108 00000007 00007f00 0
[ 240.358359] 00000080: 00000032 00001101 80000000 00000108 00000007 00007f00 0
[ 240.359117] 000000a0: 00000190 00001206 80000000 00000108 00000007 00007f00 0
[ 240.359875] 000000c0: 000000c6 00001202 8000031f 00000008 00000007 00007f00 0
[ 240.360632] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.361389] 00000100: 00000100 00000202 00000140 00006202 00000047 00008743 0
[ 240.362148] 00000120: 00000143 00004343 00000142 00000142 00004242 00008545 0
[ 240.362906] 00000140: 0000010b 00000300 00004a87 00000113 00009382 0000838b 0
[ 240.363664] 00000160: 0000834b 0000018b 00001745 0000001f 00000380 00000380 0
[ 240.364422] 00000180: 00006380 00009200 00000200 00000200 00000200 00000200 0
[ 240.365180] 000001a0: 00000000 00000000 00004242 00000421 00008b00 000002dc 0
[ 240.365937] 000001c0: 00000182 00000001 00000003 0000008b 0000008b 00000142 0
[ 240.366694] 000001e0: 0000853f 0000000b 0000971f 00009797 00009797 00008b8b 0
[ 240.367452] 00000200: 000000d7 000000d7 00000000 00000000 00000000 00000000 0
[ 240.368208] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.368964] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.369720] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.370479] 00000280: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0
[ 240.371236] 000002a0: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 00000000 00000000 0
[ 240.371993] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.372749] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.373506] 00000300: 00000000 00000000 00000000 00000000 00000030 00000000 0
[ 240.374263] 00000320: 00008000 00000000 00000001 00000000 0000000a 00000031 0
[ 240.375020] 00000340: 00000505 00000505 00000000 00000000 00000c04 00000000 0
[ 240.375778] 00000360: 00000000 00000020 00000000 00000000 000000cc 00000000 0
[ 240.376534] 00000380: 00002000 00000000 00000008 00000000 00000000 00000000 0
[ 240.377290] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.378046] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.378802] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.379558] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.380315] 00000420: 00000000 00004070 00000000 00000014 00000000 00000000 0
[ 240.381072] 00000440: 00000000 00000000 00000000 00000000 00001000 00000000 0
[ 240.381828] 00000460: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.382585] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.383341] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.384097] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.384853] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.385610] 00000500: 00000000 00000000 00640064 00000000 00000003 00000000 0
[ 240.386366] 00000520: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.387122] 00000540: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.387879] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.388632] 00000580: 00000004 00000000 00000004 00000946 00000004
[ 240.389175] PMU CRU:
[ 240.389387] 00000000: 000000a9 00001203 80000000 00000108 00000007 00007f00 0
[ 240.390145] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.390904] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.391662] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.392422] 00000080: 0000070d 00001986 00000d0d 0000000d 000002dc 00000200 0
[ 240.393181] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.393940] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.394697] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 0
[ 240.395456] 00000100: 00000600 00000180 00000000 00000000 00000024 00000000 0
[ 240.396211] 00000120: 00000000 00000180 00000000 00000000 00000000
[ 240.396757] Kernel Offset: disabled
[ 240.397069] Memory Limit: none
[ 240.397357] rockchip-thermal ff260000.tsadc: channal 0: temperature(22 C)
[ 240.397954] THERMAL REGS:
[ 240.398204] 00000000: 00000200 00030133 00000031 00000002 00000000 00000000 0
[ 240.398961] 00000020: 000001fd 000001fa 00000000 00000000 0000024e 00000000 0
[ 240.399718] 00000040: 00000279 00000279 00000000 00000000 00000000 00000000 0
[ 240.400476] 00000060: 00000004 00000004 00000753 00000753 00000000 00000000 0
[ 240.401226] 00000080: 00000000 00000000
[ 240.401576] ---[ end Kernel panic - not syncing: hung_task: blocked tasks
[ 252.137485] Watchdog detected hard LOCKUP on cpu 0
[ 252.137908] ------------[ cut here ]------------
[ 252.138337] WARNING: at kernel/watchdog.c:352
[ 252.138723] Modules linked in:
[ 252.139003]
[ 252.139148] CPU: 5 PID: 39 Comm: khungtaskd Not tainted 4.4.52 #22
[ 252.139693] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (
[ 252.140345] task: ffffffc0797924c0 ti: ffffffc078e40000 task.ti: ffffffc078e4
[ 252.141011] PC is at watchdog_timer_fn+0x104/0x2f0
[ 252.141440] LR is at watchdog_timer_fn+0x104/0x2f0
[ 252.141867] pc : [<ffffff80081284c0>] lr : [<ffffff80081284c0>] pstate: 60000
[ 252.142517] sp : ffffffc07ff6bde0
[ 252.142814] x29: ffffffc07ff6bde0 x28: ffffff80090cdf70
[ 252.143298] x27: 0000000000000000 x26: ffffff800908f1f8
[ 252.143781] x25: ffffffc07ff6e210 x24: ffffffc078e43b60
[ 252.144263] x23: 0000000000000000 x22: 0000000000000000
[ 252.144744] x21: ffffff80090cc000 x20: ffffff800908f270
[ 252.145226] x19: ffffff800908f000 x18: 0000000030d00800
[ 252.145707] x17: 0000000000000000 x16: 0000000000000000
[ 252.146187] x15: 0000000000000000 x14: 0ffffffffffffffd
[ 252.146668] x13: 0000000000000000 x12: 0101010101010101
[ 252.147149] x11: 7f7f7f7f7f7f7f7f x10: fefefefefefefeff
[ 252.147630] x9 : 7f7f7f7f7f7f7f7f x8 : 4c20647261682064
[ 252.148110] x7 : 6574636574656420 x6 : ffffff800921982d
[ 252.148590] x5 : 0000000000000002 x4 : 0000000000000005
[ 252.149071] x3 : 0000000000000000 x2 : 0000000000000001
[ 252.149551] x1 : 00000000000001c0 x0 : 0000000000000026
[ 252.150033]
[ 252.150033] PC: 0xffffff8008128440:
[ 252.150475] 8440 b9401c00 f90033a3 f90037a4 97fffeb4 2a0003fb 90007d20 b94f0
[ 252.151252] 8460 54000382 d50339bf b0007d3c 91002281 913dc39c f94037a4 f87b5
[ 252.152024] 8480 34000085 f94033a3 38226823 14000011 91020280 f8626b41 f8626
[ 252.152797] 84a0 eb01007f 54000e40 f8226801 f87b5b80 38206a85 14000007 2a1b0
[ 252.153570] 84c0 d4210000 f87b5b80 52800021 38206a81 9107a274 913d62ba d538d
[ 252.154341] 84e0 f8606820 97fe764c f9401b20 f9401f42 f90037a2 f9401000 d63f0
[ 252.155114] 8500 f94037a2 aa1903e0 97ff55b8 b50000f6 91022694 d538d080 38746
[ 252.155886] 8520 38346816 14000019 97fe8afc 90007d21 f947ac21 36080921 b9403
[ 252.156660]
[ 252.156660] LR: 0xffffff8008128440:
[ 252.157101] 8440 b9401c00 f90033a3 f90037a4 97fffeb4 2a0003fb 90007d20 b94f0
[ 252.157874] 8460 54000382 d50339bf b0007d3c 91002281 913dc39c f94037a4 f87b5
[ 252.158646] 8480 34000085 f94033a3 38226823 14000011 91020280 f8626b41 f8626
[ 252.159419] 84a0 eb01007f 54000e40 f8226801 f87b5b80 38206a85 14000007 2a1b0
[ 252.160192] 84c0 d4210000 f87b5b80 52800021 38206a81 9107a274 913d62ba d538d
[ 252.160965] 84e0 f8606820 97fe764c f9401b20 f9401f42 f90037a2 f9401000 d63f0
[ 252.161736] 8500 f94037a2 aa1903e0 97ff55b8 b50000f6 91022694 d538d080 38746
[ 252.162507] 8520 38346816 14000019 97fe8afc 90007d21 f947ac21 36080921 b9403
[ 252.163281]
[ 252.163281] SP: 0xffffffc07ff6bd60:
[ 252.163721] bd60 00000000 00000000 00000000 00000000 78e43b60 ffffffc0 7ff6e
[ 252.164494] bd80 0908f1f8 ffffff80 00000000 00000000 090cdf70 ffffff80 7ff6b
[ 252.165267] bda0 081284c0 ffffff80 7ff6bde0 ffffffc0 081284c0 ffffff80 60000
[ 252.166039] bdc0 090ccf58 ffffff80 00000000 00000000 00000000 00000080 fffff
[ 252.166812] bde0 7ff6be50 ffffffc0 080fe76c ffffff80 7ff6e210 ffffffc0 7ff6d
[ 252.167583] be00 7ff6dc40 ffffffc0 00000001 00000000 0920a24f ffffff80 090cb
[ 252.168356] be20 081283bc ffffff80 af2c09dd 0000003a 0920a000 ffffff80 78e40
[ 252.169127] be40 00000000 00000000 090ccf58 ffffff80 7ff6bec0 ffffffc0 080fe
[ 252.169906]
[ 252.169906] X6: 0xffffff80092197ad:
[ 252.170346] 97ac 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.171120] 97cc 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.171892] 97ec 00000000 00000001 00000000 30303020 32303330 39383130 39205
[ 252.172663] 980c 312e3235 30393936 58205d36 30203a36 66666678 38666666 32393
[ 252.173435] 982c 300a3a64 32313830 30633438 70205d3e 74617473 36203a65 30303
[ 252.174207] 984c 2030300a 30303030 30303030 4830300a 6964205a 203d2076 730a2
[ 252.174978] 986c 275d305b 65730a0a 7665645f 71657266 696e695f 3b292874 63757
[ 252.175749] 988c 696e6920 676e6974 776f7020 6d5f7265 6c65646f 6d69735f 2e656
[ 252.176522] 98ac 66666666 64626666 66666662 30303030 28202020 32202020 47203
[ 252.177303]
[ 252.177303] X19: 0xffffff800908ef80:
[ 252.177750] ef80 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.178522] efa0 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.179293] efc0 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.180065] efe0 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.180837] f000 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.181608] f020 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.182379] f040 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.183151] f060 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.183926]
[ 252.183926] X20: 0xffffff800908f1f0:
[ 252.184373] f1f0 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.185145] f210 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.185915] f230 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.186687] f250 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.187459] f270 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.188231] f290 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.189003] f2b0 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.189774] f2d0 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.190548]
[ 252.190548] X21: 0xffffff80090cbf80:
[ 252.190996] bf80 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.191767] bfa0 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.192538] bfc0 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.193309] bfe0 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.194080] c000 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.194852] c020 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.195623] c040 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.196395] c060 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.197172]
[ 252.197172] X24: 0xffffffc078e43ae0:
[ 252.197619] 3ae0 0000003d 00000000 00000000 00000000 00000000 00000000 00000
[ 252.198391] 3b00 0925c05a ffffff80 00000000 00000000 0003211c 00000000 00000
[ 252.199165] 3b20 78e43b40 ffffffc0 090e5680 ffffff80 08e27177 ffffff80 00000
[ 252.199935] 3b40 78e43be0 ffffffc0 080e9868 ffffff80 08e22f2a ffffff80 09216
[ 252.200707] 3b60 6c64e51b 00000001 000016a4 00000000 000003e8 00000000 00000
[ 252.201478] 3b80 00000005 00000000 00000002 00000000 09219844 ffffff80 6e756
[ 252.202251] 3ba0 203a6b73 636f6c62 7f7f7f7f 7f7f7f7f fefefeff fefefefe 7f7f7
[ 252.203024] 3bc0 01010101 01010101 00000000 00000000 fffffffd 0fffffff 00000
[ 252.203798]
[ 252.203798] X25: 0xffffffc07ff6e190:
[ 252.204246] e190 ffffffff 00000000 ffffffff ffffffff 00000001 00000000 7ff6e
[ 252.205019] e1b0 7ff6e1a8 ffffffc0 7ff6e1b8 ffffffc0 7ff6e1b8 ffffffc0 08126
[ 252.205791] e1d0 79517cf8 ffffffc0 79517c40 ffffffc0 00020002 00000000 00000
[ 252.206563] e1f0 00000001 00000000 0000003f 00000000 0000003c 00000000 796eb
[ 252.207335] e210 7ff6e210 ffffffc0 7ff6e080 ffffffc0 00000000 00000000 af2c0
[ 252.208106] e230 af2c01c0 0000003a 081283bc ffffff80 7ff6dc40 ffffffc0 00000
[ 252.208879] e250 0812838c ffffff80 63746177 676f6468 0000352f 00000000 00000
[ 252.209652] e270 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.210425]
[ 252.210425] X26: 0xffffff800908f178:
[ 252.210872] f178 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.211643] f198 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.212415] f1b8 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.213187] f1d8 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.213958] f1f8 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.214729] f218 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.215501] f238 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.216273] f258 00000000 00000000 00000000 00000000 00000000 00000000 00000
[ 252.217046]
[ 252.217046] X28: 0xffffff80090cdef0:
[ 252.217494] def0 00000001 00000000 00000001 00000000 000003e8 00000000 7ff7d
[ 252.218266] df10 00000015 00000000 7ff7d500 ffffffc0 00000001 00000000 00000
[ 252.219039] df30 00015000 00000000 7ff7d5c0 ffffffc0 7ff7d580 ffffffc0 00000
[ 252.219810] df50 00000006 00000000 00000005 00000010 7ff7d400 ffffffc0 7feff
[ 252.220583] df70 76e76000 00000040 76e8b000 00000040 76ea0000 00000040 76eb5
[ 252.221354] df90 76eca000 00000040 76edf000 00000040 00000000 00000000 00000
[ 252.222125] dfb0 00000002 00000000 00001415 00000000 00010000 00000000 0007f
[ 252.222897] dfd0 0000effd 00000000 00002000 00000000 00000000 0000fffa 00000
[ 252.223669]
[ 252.223669] X29: 0xffffffc07ff6bd60:
[ 252.224117] bd60 00000000 00000000 00000000 00000000 78e43b60 ffffffc0 7ff6e
[ 252.224890] bd80 0908f1f8 ffffff80 00000000 00000000 090cdf70 ffffff80 7ff6b
[ 252.225660] bda0 081284c0 ffffff80 7ff6bde0 ffffffc0 081284c0 ffffff80 60000
[ 252.226432] bdc0 090ccf58 ffffff80 00000000 00000000 00000000 00000080 fffff
[ 252.227204] bde0 7ff6be50 ffffffc0 080fe76c ffffff80 7ff6e210 ffffffc0 7ff6d
[ 252.227976] be00 7ff6dc40 ffffffc0 00000001 00000000 0920a24f ffffff80 090cb
[ 252.228749] be20 081283bc ffffff80 af2c09dd 0000003a 0920a000 ffffff80 78e40
[ 252.229522] be40 00000000 00000000 090ccf58 ffffff80 7ff6bec0 ffffffc0 080fe
[ 252.230294]
[ 252.230434] ---[ end trace c883920977d80508 ]---
[ 252.230843] Call trace:
[ 252.231067] Exception stack(0xffffffc07ff6bc10 to 0xffffffc07ff6bd40)
[ 252.231638] bc00: ffffff800908f000 00000080
[ 252.232330] bc20: ffffffc07ff6bde0 ffffff80081284c0 ffffff80090e5680 00000000
[ 252.233021] bc40: ffffffc07ff6bc60 ffffff80090e5680 ffffff8008e27177 00000000
[ 252.233712] bc60: ffffffc07ff6bd00 ffffff80080e9868 ffffff8008e2a2af ffffff80
[ 252.234403] bc80: ffffff80090cc000 0000000000000000 0000000000000000 ffffffc0
[ 252.235094] bca0: ffffffc07ff6e210 ffffff800908f1f8 0000000000000026 00000000
[ 252.235785] bcc0: 0000000000000001 0000000000000000 0000000000000005 00000000
[ 252.236476] bce0: ffffff800921982d 6574636574656420 4c20647261682064 7f7f7f7f
[ 252.237167] bd00: fefefefefefefeff 7f7f7f7f7f7f7f7f 0101010101010101 00000000
[ 252.237858] bd20: 0ffffffffffffffd 0000000000000000 0000000000000000 00000000
[ 252.238553] [<ffffff80081284c0>] watchdog_timer_fn+0x104/0x2f0
[ 252.239078] [<ffffff80080fe76c>] __hrtimer_run_queues+0x164/0x290
[ 252.239621] [<ffffff80080fea88>] hrtimer_interrupt+0xac/0x1c4
[ 252.240139] [<ffffff800889a9d0>] arch_timer_handler_phys+0x3c/0x48
[ 252.240690] [<ffffff80080eea08>] handle_percpu_devid_irq+0xc4/0x178
[ 252.241252] [<ffffff80080ea394>] generic_handle_irq+0x30/0x44
[ 252.241766] [<ffffff80080ea6fc>] __handle_domain_irq+0x90/0xc0
[ 252.242283] [<ffffff8008080dfc>] gic_handle_irq+0xcc/0x188
[ 252.242768] Exception stack(0xffffffc07ff6c000 to 0xffffffc07ff6c130)
[ 252.243340] c000: ffffffc078e43b60 0000008000000000 ffffffc078e43c90 ffffff80
[ 252.244031] c020: 0000000080000045 ffffff80090cc000 ffffffc07ff68060 00000000
[ 252.244721] c040: ffffffc078e43c90 ffffffc078e43b60 0000000000000000 00000000
[ 252.245412] c060: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 252.246102] c080: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 252.246792] c0a0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 252.247483] c0c0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 252.248173] c0e0: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 252.248864] c100: 0000000000000000 0000000000000000 0000000000000000 00000000
[ 252.249553] c120: 0000000000000000 0000000000000000
[ 252.249988] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
[ 252.250426] [<ffffff80083856a4>] __delay+0x24/0x48
[ 252.250855] [<ffffff80083856ec>] __const_udelay+0x24/0x2c
[ 252.251336] [<ffffff800815dfc4>] panic+0x230/0x23c
[ 252.251766] [<ffffff8008127d60>] watchdog+0x2e0/0x30c
[ 252.252217] [<ffffff80080b9284>] kthread+0xe4/0xec
[ 252.252645] [<ffffff8008082690>] ret_from_fork+0x10/0x40
