Horizontally flipping the IPC-M10R800-A3399C screen
Hello to everyone
I bought it from 1 IPC-M10R800-A3399C. Linux sdk and I use it with lubuntu. The main board is AIO-3399C and the display uses HSX101H40C. Turns on vertically when the device is switched on. On the Linux side, I can turn the device horizontally with the following commands.
xrandr --output LVDS1 --rotate right
xinput set-prop ‘gslX680’ ‘Coordinate Transformation Matrix’ 0 1 0 -1 0 1 0 0 1
But I want to open this way directly without the need to run the script when the device is turned on. How can I do that?
Is there a change in the file arch / arm64 / boot / dts / rockchip / rk3399-firefly-aioc-lvds.dts? Or is it necessary to change the rootfs?
Hello
is there anyone else on the world who wants to use this device horizontally?
Yes I want to , :slight_smile:
I think you can do it in any of the startup scripts
Wir sind der Schnellste, der daa CompTIA N10-009 Zertifikat erhält; wir sind noch der höchste, der Ihre Interessen schützt. Wir sind Zertpruefung. Zertpruefung kann Ihnen versprechen, dass die Testaufgaben von CompTIA N10-009 Zertifizierungsprüfung 100% richtig und ganz umfassend sind. Nachdem Sie die Testfragen zur CompTIA N10-009 Zertifizierung gekauft haben, werden Sie kostenlos die einjährige Aktualisierung genießen.
Thank you for your powerful article, it left a lasting impression. Valid test C_BW4H_2505 bootcamp exam papers are shared for free. Wishing you success in your exam!
This article is exceptional, I truly appreciate you sharing it! We’ve made Reliable Plat-Arch-205 test camp materials freely available, packed with content to help you succeed.
I’m deeply moved by your article, thank you for sharing this insight! Wishing myself all the best for the Latest study guide Introduction-to-Cryptography ebook exam!
