Yes, this happens in Android 7.1.2. I’m using more than 15 pieces of RK3399 devices for different projects.
If I google for “RK3399 network error” or something like that, then I see that NanoPi M4, RockPro64 and OrangePI seem to have an issue which was solved by “ethtool -K eth0 rx off tx off”.
I have already build “ethtool” for Android and used it to disable TCP offloading as described in the forums, but it didn’t solve the issue.
If I knew, that Firefly-RK3399 with Android7/8 is NOT affected, then I would probably switch to Firefly-RK3399.
Description:
All devices (more than 15) are used 24/7. They are downloading small HTTP content every minute, usually below 100KB, but sometimes about 10 MB.
Usually several times a week one of the devices gets OFFLINE suddenly, sometimes for 5 min., sometimes for 30 min, somtimes for longer than 1h. If you sum all devices this happens nearly every day and sometimes several times a day.
In dmesg-Log I see, that the device switches from 100Mbit link speed to 10Mbit, and than back to 100Mbit. It is offline during this time.
Log:
[1487388.081884] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 10Mbps/Half - flow control off
# So, 17. Feb 2019 08:28:51
[1488648.768330] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
# So, 17. Feb 2019 23:14:46
[1541803.160657] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 10Mbps/Full - flow control off
# So, 17. Feb 2019 23:24:46
[1542403.393871] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
At all switch ports these devices are connected to, I/O errors are logged in the port statistics. The error counter increases, when the device is offline. Other clients connected to the same CISCO 100Mbit switch are not affected.
May Firefly-RK3399 have the same issue?
