4K Resolution Issues
Hello,
I’m running Ubuntu 18.04 on the AIO-3399J with a 4k screen (HDMI 2.0), and I’m having problems with the display. Everything flickers, the display turns off and back on again every few seconds, I sometimes get green dots in a regular pattern and video playback has a lot of artifacts (parts of the video shown in the wrong location etc).
Everything works fine at lower resolutions. Is there a way to fix this? I think I also had the same artifacts with the preinstalled Android 7.1.
Hi anlumo,
Does the 4K display work correctly with other boards or PC ?
@anlumo,
If you open the “Screen Setting” application, are there any 4k resolutions listed?
I tried with the 4K LeTV display. No 4k resolution listed there.
The higher resolutions are listed. The screen works fine on other machines with HDMI 2.0.
Which Android firmware do you use?
Better post a video about this, and also the kernel log and android logcat,which help to solve the problem.
This article is truly remarkable, I’m grateful for your sharing. Upgrade your IT knowledge with free L4M7 reliable test simulator fee. Best wishes for success!
This article is truly exceptional, thank you for sharing it with us. The New testcollection 350-701 helped me secure a promotion and raise. It’s now free to all. Wishing you success in your promotion journey!
Your article made such a difference to me, I’m really thankful. About to take the Latest Maryland-Real-Estate-Salesperson exam objectives pdf exam – I need all the luck I can get!
