Hi Firefly team,
I would like to use microphone linein (headset with 3.5mm 4 pin jack) in ubuntu.
I checked the mic is working within Android which is default installation when I got the board first time with change in audio setting in Android.
After the firmware changed to ubuntu 18.04,
I tested the mic device input and checked that is working well which is attached mic sensor device right beside the PWR button.
But I want to use the headset (mic+ spk via 3.5mm jack with 4 pins ).
[b]#01. Is it possible to use headset in Ubuntu 18.04 ?
[/b]
[b]
[/b]
#02. How to disable built-in MIC device in kernel?
I checked that the headset(mic+ spk via 3.5mm jack with 4 pins)
is working within the Android 7.1 firmware.
#02. Is there a way to use headset in Ubuntu 18.04? (by modifying the kernel & some sound related code)
Or where do I change the kernel code?
Roughly I guess that refer to Android code and change the Ubuntu source tree.
Please give me any information, it will be helpful & appreciated.
Hi, @meche95,
According to the driver code at:
https://github.com/FireflyTeam/k … soc/codecs/rt5640.c
add “linein-mute = 1” to the rt5640 node in dts.
Then a “/sys/linein/linein” file will be created.
echo 1 > /sys/linein/linein
should be sufficient to turn on Line In support.
Hi thank you for reply.
I added the “linein-mute=1” and I found the /sys/linein/linein after compile & flasing the firmware.
But when I install ubuntu using the following guideline, mic input DOES NOT work.
And also linein input does not work.
I’m using the rootfs image named in ‘rk3399_ubuntu18.04_LXDE.img’.
http://wiki.t-firefly.com/en/Fir … ux_compile_gpt.html
When I flash the image (FIREFLY-RK3399-UBUNTU18.04-GPT-20190216-1136.img), then MIC input works well.
But when I compiled the kernel, uboot, etc and using rk3399_ubuntu18.04_LXDE.img rootfs then MIC input did NOT work.
How can I enable Mic input with kernel compile with latest source ?
Hi @meche95,
You can use some tools to extract FIREFLY-RK3399-UBUNTU18.04-GPT-20190216-1136.img,
splitting into individual kernel, uboot and rootfs image etc.
http://wiki.t-firefly.com/en/Firefly-RK3399/customize_android_firmware.html
Then you can take the right rootfs to move on.
I’m in awe of this article, thank you for sharing it with us! Strengthen your IT abilities with free Real 1Z0-1081-24 braindumps. Good luck with your exams!
Your article was absolutely enlightening, thank you! Here comes the 100% 312-50v13 exam coverage exam! Wish me luck and success!
やってみて購入します。我々ShikenPASSはすべてのお客様に責任を持っています。我々はあなたにCiscoの300-430試験ソフトのデモを無料で提供しています。あなたは体験してから安心で購入できます。われわれはあなたが弊社のCiscoの300-430試験ソフトを購入して満足することに自信を持っています。利用してからあなたも弊社のCiscoの300-430試験ソフトに自信を持っています。あなたは自信満々にCiscoの300-430試験に参加することができます。
他の人はあちこちでCIPS L5M1試験資料を探しているとき、あなたはすでに勉強中で、準備階段でライバルに先立ちます。また、我々ShikenPASSは量豊かのCIPS L5M1試験資料を提供しますし、ソフト版であなたにCIPS L5M1試験の最も現実的な環境をシミュレートさせます。勉強中で、何の質問があると、メールで我々はあなたのためにすぐ解決します。心配はありませんし、一心不乱に試験復習に取り組んでいます。
