I dug out my old RC iMax b6 lipo charger to try and charge the battery.
It can balance charge a 2 cell lipo.
On the charger there is a 3 pin balance charging socket which measures and controls the charging.
On the ROC - RK3399 - MEZZ - M2 - POE there is a 3 pin port marked BAT2+ BAT1+ BAT1-.
Do I connect my chargers balance charging socket to the 3 pin port on the POE board?
This is the only document I can find on the battery:
3) Onboard battery (dual 7.4V lithium battery)
4) Onboard balanced charging circuit to charge the onboard battery
Thank You
