I need to transmit/receive data via rs232. AFAIK, AIO-3399C has 4 serial ports. I try to use /dev/ttyS0. It doesn’t work. On other end of serial channel sent data aren’t received and data sent from other end aren’t received at AIO-3399C. ‘setserial’ shows only one working serial port of four. I use standard kernel and rootfile from linux-SDK. What should I do to solve the problem? ‘setserial’ output is below:
$ setserial -g /dev/ttyS[0123]
/dev/ttyS0, UART: 16550A, Port: 0x0000, IRQ: 37
/dev/ttyS1, UART: unknown, Port: 0x0000, IRQ: 0
/dev/ttyS2: Device or resource busy
/dev/ttyS3, UART: unknown, Port: 0x0000, IRQ: 0
I see the below for teh AIO-3399C but the RS232 didn’t work for me on /dev/ttysWK1, I connected a USB to RS232 and it worked on /dev/ttyUSB0.
Using the image AIO-3399C-LVDS-UBUNTU18.04-GPT-20190304-1222.img
Plz post the hardware connection picture, the kernel device tree setting (related to the series ports) and the test commands so that others can help you.
The article is absolutely magnificent, thank you for sharing it with us. Wishing you success! Here are the free Pdf NCP-US-6.10 version resources for you!
I’m left in awe by your article, thank you for sharing this treasure! Sharing with you the Valid CHFM exam duration test that helped me get my promotion and raise. It’s free for all today—good luck with your career!
