Hello, does anyone know how to enable the interface of I2c of RK3328CC ?
The firmware I used is Raw Firmware ubuntu16.04 provided by Firefly official. I have seen the solution in the site following: https://forum.armbian.com/topic/8856-solved-how-to-add-an-external-rtc-module-to-rock64-board/, while it doesn’t work. It always tell me “Your kernel does not support CONFIG OF OVERLAY”, and my folder /sys/kernel/config is vide.
Need I compile linux firmware by myself ? Thanks a lot ![]()
I’m deeply impressed by your article, thank you for sharing it! The AANP-FNP new learning materials questions are shared for free. Good luck on your exams!
Your article really made an impact on me, I’m truly grateful. Sharing the Reliable study questions H13-511_V5.5 free download test that was a key factor in my promotion and salary increase. It’s free for you today—hope you achieve your professional dreams!
Your article is truly amazing, thank you for sharing! Free F5CAB5 reliable exam dumps pdf resources—good luck with your exam!
Your article truly left me in awe, thank you for sharing! Free Valid test 350-401 discount voucher study resources are available for all. Wishing you the best!
Your article is mind-blowing, thank you for sharing! Reliable test CIPP-E dumps free test questions are now free. Good luck with your exams!
Your article is absolutely mind-blowing, thank you for sharing! Free KCNA latest study notes resources are shared—good luck to all!
