Hi all,
after sw reset from Linux u-boot can’t read SD card partition.
root@linaro-alip:~# reboot
Stopping User Manager for UID 0...
[ OK ] Stopped target Alcoma RRL.
[ OK ] Stopped target Timers.
Stopping Session c1 of user root.
[ OK ] Stopped target Sound Card.
[ OK ] Stopped target Multi-User System.
Stopping Network Name Resolution...
Stopping LSB: Advanced IEEE 802.11 management daemon...
Stopping ACPI event daemon...
Stopping LSB: set CPUFreq kernel parameters...
[ OK ] Stopped target Login Prompts.
Stopping Getty on tty1...
Stopping Serial Getty on ttyFIQ0...
[ OK ] Stopped Daily apt upgrade and clean activities.
[ OK ] Stopped Trigger anacron every hour.
[ OK ] Stopped Daily Cleanup of Temporary Directories.
[ OK ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Stopping Save/Restore Sound Card State...
[ OK ] Stopped Daily apt download activities.
[ OK ] Stopped target System Time Synchronized.
Stopping System Logging Service...
[ OK ] Stopped ACPI event daemon.
[ OK ] Stopped System Logging Service.
[ OK ] Stopped Network Name Resolution.
[ OK ] Stopped Getty on tty1.
[ 680.438935] tty_port_close_start: tty->count = 1 port count = 2.
[ OK ] Stopped Serial Getty on ttyFIQ0.
[ OK ] Stopped LSB: Advanced IEEE 802.11 management daemon.
[ OK ] Stopped Session c1 of user root.
[ OK ] Stopped User Manager for UID 0.
[ OK ] Stopped Save/Restore Sound Card State.
[ OK ] Stopped LSB: set CPUFreq kernel parameters.
Stopping LSB: Load kernel modules needed to enable cpufreq scaling...
[ OK ] Removed slice User Slice of root.
Stopping Login Service...
[ OK ] Removed slice system-serial\x2dgetty.slice.
[ OK ] Removed slice system-getty.slice.
Stopping Permit User Sessions...
[ OK ] Stopped /etc/rc.local Compatibility.
[ OK ] Stopped target Network is Online.
[ OK ] Stopped Login Service.
[ OK ] Stopped Permit User Sessions.
[ OK ] Stopped target Network.
Stopping WPA supplicant...
Stopping Network Service...
Stopping Raise network interfaces...
[ OK ] Stopped WPA supplicant.
[ OK ] Stopped LSB: Load kernel modules needed to enable cpufreq scaling.
[ OK ] Stopped target Remote File Systems.
Stopping D-Bus System Message Bus...
[ OK ] Stopped Network Service.
[ OK ] Stopped D-Bus System Message Bus.
[ OK ] Stopped target Basic System.
[ OK ] Stopped target Slices.
[ OK ] Removed slice User and Session Slice.
[ OK ] Stopped target Paths.
[ OK ] Stopped ACPI Events Check.
[ OK ] Stopped target Sockets.
[ OK ] Closed Syslog Socket.
[ OK ] Closed ACPID Listen Socket.
[ OK ] Closed OpenBSD Secure Shell server socket.
[ OK ] Closed D-Bus System Message Bus Socket.
[ OK ] Stopped target System Initialization.
Stopping Update UTMP about System Boot/Shutdown...
Stopping Load/Save Random Seed...
Stopping Network Time Synchronization...
[ OK ] Stopped target Swap.
[ OK ] Stopped target Encrypted Volumes.
[ OK ] Stopped Dispatch Password Requests to Console Directory Watch.
[ OK ] Stopped Forward Password Requests to Wall Directory Watch.
Stopping Load/Save Screen Backlight…ightness of backlight:backlight...
[ OK ] Stopped Network Time Synchronization.
[ OK ] Stopped Load/Save Screen Backlight Brightness of backlight:backlight.
[ OK ] Stopped Update UTMP about System Boot/Shutdown.
[ OK ] Stopped Load/Save Random Seed.
[ OK ] Stopped Create Volatile Files and Directories.
[ OK ] Removed slice system-systemd\x2dbacklight.slice.
[ OK ] Stopped Raise network interfaces.
[ OK ] Stopped Apply Kernel Variables.
[ OK ] Stopped Load Kernel Modules.
[ OK ] Stopped target Local File Systems.
Unmounting /run/user/0...
Unmounting /var/ram...
Unmounting /boot...
[ OK ] Unmounted /var/ram.
[ OK ] Unmounted /run/user/0.
[ OK ] Unmounted /boot.
[ OK ] Reached target Unmount All Filesystems.
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Stopped Create Static Device Nodes in /dev.
[ OK ] Stopped Remount Root and Kernel File Systems.
[ OK ] Reached target Shutdown.
[ 680.819156] dw_wdt: unexpected close, system will reboot soon
[ 680.898628] systemd-journald[172]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 680.951241] EXT4-fs (mmcblk0p5): re-mounted. Opts: data=ordered
[ 680.956409] EXT4-fs (mmcblk0p5): re-mounted. Opts: data=ordered
Failed to read reboot parameter file: No such file or directory
[ 680.967925] cpu4 limit freq=816000 min=816000 max=816000
[ 680.971211] cpu0 limit freq=816000 min=816000 max=816000
[ 680.974836] I : [File] : drivers/gpu/arm/midgard/platform/rk/mali_kbase_config_rk.c; [Line] : 273; [Func] : kbase_platform_rk_shutdown(); to make vdd_gpu enabled for turning off pd_gpu in pm_framework.
[ 680.976614] rk-vcodec ff660000.rkvdec: shutdown
[ 680.977099] rk-vcodec ff650000.vpu_service: shutdown
[ 680.978071] reboot: Restarting system
DDR Version 1.22 20190506
soft reset
SRX
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFC
CS = 1
MR0=0x18
MR4=0x2
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFC
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFC
CS = 1
MR0=0x18
MR4=0x2
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFC
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFC
CS = 1
MR0=0x18
MR4=0x2
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFC
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFC
CS = 1
MR0=0x18
MR4=0x2
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFC
channel 0, cs 0, advanced training done
channel 0, cs 1, advanced training done
channel 1, cs 0, advanced training done
channel 1, cs 1, advanced training done
change freq to 856MHz 1,0
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 325
mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
mmc: ERROR: Card did not respond to voltage select!
emmc reinit
emmc reinit
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=15193MB
FwPartOffset=2000 , 0
StorageInit ok = 58566
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 0, name: loader1, start:0x40, size:0x1f40
GPT part: 1, name: loader2, start:0x4000, size:0x2000
GPT part: 2, name: trust, start:0x6000, size:0x2000
GPT part: 3, name: boot, start:0x8000, size:0x38000
GPT part: 4, name: rootfs, start:0x40000, size:0x4e9fdf
no find partition:uboot.
LoadTrust Addr:0x4000
No find bl30.bin
Load uboot, ReadLba = 2000
hdr 0000000003380880 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Load OK, addr=0x200000, size=0x9c558
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):d98d16e
NOTICE: BL31: Built : 15:03:07, May 10 2018
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1151): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-96-g3fbe315-dev #4 Fri Jun 30 00:35:17 UTC 2017 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.1
INFO: SPSR = 0x3c9
U-Boot 2017.09-gc58a8168bd-dirty (May 15 2019 - 10:28:42 +0200)
Model: Firefly-RK3399 Board
DRAM: 3.9 GiB
MMC: dwmmc@fe320000: 1, sdhci@fe330000: 0
mmc_init: -95, time 20
*** Warning - No block device, using default environment
In: serial@ff1a0000
Out: serial@ff1a0000
Err: serial@ff1a0000
normal boot
Net: eth0: ethernet@fe300000
mmc_init: -95, time 19
switch to partitions #0, OK
mmc1 is current device
*** ERROR: Can't read GPT Entries ***
GPT: Failed to allocate memory for PTE
part_get_info_efi: *** ERROR: Invalid GPT ***
*** ERROR: Can't read GPT header ***
part_get_info_efi: *** ERROR: Invalid Backup GPT ***
** Invalid partition 4 **
starting USB...
USB0: ERROR: failed to enable clock 0
at drivers/usb/host/ehci-generic.c:54/ehci_usb_probe()
probe failed, error -38
USB1: ERROR: failed to enable clock 0
USB error: all controllers failed lowlevel init
USB is stopped. Please issue 'usb start' first.
starting USB...
ethernet@fe300000 Waiting for PHY auto negotiation to complete... done
Speed: 1000, full duplex
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded; starting again
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-92-10-db-6a-67-ee
*** ERROR: `serverip' not set
Retrieving file: pxelinux.cfg/00000000
Retrieving file: pxelinux.cfg/default-arm-rockchip
Config file not found
starting USB...
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
=> mmc part
Partition Map for MMC device 1 -- Partition Type: EFI
part_print_efi: *** ERROR: Invalid GPT ***
part_print_efi: *** ERROR: Invalid Backup GPT ***
Any idea?
Thanks.
