Firefly-RK3399 MPU6050
Hi,
MPU6050 sensor to Firefly-RK3399 board on J21 connector
7 pin - VCC3V3_SYS (MPU6050-VDD),
8 pin - GND (MPU6050-GND),
25 pins - I2C4_SDA (MPU6050_SDA),
26 pins - I2C4_SCL (MPU6050_SCL),
29 pin - SPI1_RXD (MPU6050-INT) is connected.
Attach photos and files.
  2. SensorFind.apk
    SensorFind.apk (1.48 MB)
And I installed the application (SensorFind.apk) to find the Android sensor, but it did not recognize the sensor.
I want to rotate the HDMI output screen every time the MPU6050 sensor moves.
Waiting for your help.
You need to add MPU6050 kernel driver and Android HAL support to get it working.
It is already applied to rk3399-firefly-port.dtsi file, and Android HAL support is already applied.
&i2c4 {
gsl3680: gsl3680@41 {
status = “disabled”;
compatible = “gslX680”;
reg = <0x41>;
screen_max_x = <1536>;
screen_max_y = <2048>;
touch-gpio = <&gpio1 20 IRQ_TYPE_LEVEL_LOW>;
reset-gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>;
mpu6050:mpu@68{
status = “okay”;
compatible = “invensense,mpu6050”;
reg = <0x68>;
mpu-int_config = <0x10>;
mpu-level_shifter = <0>;
mpu-orientation = <0 1 0 1 0 0 0 0 1>;
orientation-x= <1>;
orientation-y= <1>;
orientation-z= <1>;
irq-gpio = <&gpio1 7 IRQ_TYPE_LEVEL_LOW>; /gpio1 A7/
mpu-debug = <1>;
Where do I find out where Android HAL support is applied?
penguin Posted at 5/30/2019 09:58
Hi penguin,
Thank you for the reply.
Hi james,
Please check to make sure that the sensor is probed and initialized correctly by inspecting the kernel log first.
penguin Posted at 6/5/2019 09:06
Hi james,
Please check to make sure that the sensor is probed and initialized correctly by inspec …
Hi penguin,
kernel build error
Error: arch/arm64/boot/dts/rockchip/rk3399-firefly-port.dtsi:200.11-12 syntax error
FATAL ERROR: Unable to parse input tree
&i2c4 {
mpu6500_acc@68 {
status = “okay”;
compatible = “mpu6500_acc”;
reg = <0x68>;
type = <SENSOR_TYPE_ACCEL>; // There was an error in this part. //
irq-gpio = <&gpio1 7 IRQ_TYPE_EDGE_RISING>;
orientation-x= <1>;
orientation-y= <0>;
orientation-z= <0>;
mpu-debug = <1>;
I need your help.
Thank you.
