RK3288 DDR3 Write Leveling
From what I can tell by reading the TRM, the RK3288 supports DDR3 write leveling.
For some reason I can’t seem to get the write leveling routine to run to compensate for the individual byte lane skews. According to the DDR_PCTL_DFITRSTAT0 register, the PHY is configured for PHY Independent mode. In PHY Independent mode, the PHY is responsible for executing data eye training, gate training or write leveling independent of the MC. In this mode, the associated training interface is not used other than the mode signal to the MC. The MC should be capable of generating the required MRS commands to enter or exit the test modes of the memory devices. These operations are not automatically generated. All training sequences, regardless of mode, are expected to be executed after memory initialization. For PHY Independent mode, the update interface may be used to suspend memory commands while the training sequences are executed.
I am able to configure the DRAMs for write leveling using the appropriate MRS commands, but it doesn’t seem to trigger anything. Does anyone know what I need to do to trigger a write leveling routine?
Thanks!
AFAIK, Kever from RK has answered your question in the U-Boot mail list that RK3288 does not support DDR3 Write Leveling.
This article is very motivating, thanks for sharing! Free Project-Management reliable exam cram pdf exam questions to help you prepare. Best wishes for success!
現在の状況に満足することは決してなく、CGSS試験実践ガイドを必ず拡張および更新してください。イノベーションに焦点を当て、専門チームを編成して新しい知識ポイントをまとめ、テストバンクを更新します。私たちはクライアントを神として扱い、CGSS学習教材へのサポートを前進の原動力として扱います。そのため、クライアントはCGSS試験問題に関する最新のイノベーションの結果を楽しんで、より多くの学習リソースを獲得できます。クレジットは、私たちの勤勉で献身的な専門技術革新チームと専門家に帰属します。
Great content, without a doubt, I’m clicking that like button. The Valid dumps C_P2W81_2505 book test questions are key to your promotion and salary boost—free for all!
I’m sincerely grateful for your article, it really stood out to me. Free access to Reliable exam CLF-C02 discount voucher materials for all—good luck!
Your article is brilliant beyond words, I’m thankful for your share! I used the Exam 300-835 pattern to get a promotion and raise. Now it’s free to all. Best wishes for your professional growth!
I appreciate you sharing this brilliant article, it’s really fantastic! Latest test AP-212 cram pdf offers great value, and the content is completely free.
