Unable to Compile Ubuntu Firmware into ROC-RK3399-PC
I have recently bought RK3399-PC and tring to boot ubuntu. But after flashing the ubuntu into the SD card, I am not able to follow the steps given in the link http://wiki.t-firefly.com/en/ROC-RK3399-PC/linux_sdk.html#. When I try to compile Environment from the following link http://wiki.t-firefly.com/en/ROC … compile-environment it diplays error “aarch64 file is obsoelte or command not found”.
I have included Expansion board to the development board and has flashed ubuntu from the following link https://drive.google.com/drive/f … LY0DG_BLx94eAeArvwI Are there any additional libraries that I need to install before compiling ubuntu firmware? Could you guide me in completing the bootup?
Hi, welcome to the forum.
The “sudo apt-get …” command is meant to run as a big long line.
But copy and paste will result in multiple lines.
We’ll fix the doc.
Doc fixed at http://wiki.t-firefly.com/en/ROC … compile-environment
Thanks for reporting this to us.
This is a truly exceptional piece of writing, thank you for sharing. Exam NetSec-Pro fees contains comprehensive material, available at no cost to support your learning.
I was really impressed by the depth of the article. Free Exam C_TS4FI_2023 exercise exam questions to help you prepare. Best wishes for success!
Your article was a breath of fresh air, thank you for sharing it. Free New C-P2WAB-2507 study plan test papers for everyone—good luck!
Thank you for sharing this motivational and inspiring article! The New exam Project-Management guide files exam helped me climb the career ladder and increase my salary, and today, I’m offering it to you for free!
