I just received the ROC-RK3399-PC, mounted the extension board and flashed the latest Ubuntu image (tried both already, with MEZZ and without) from https://drive.google.com/drive/folders/1TF6xJpp5ItZ8yLY0DG_BLx94eAeArvwI and inserted the SD card into the device. Connected it via HDMI to my screen and plugged into a 2019 MBP 15" 85W USB-C Power Supply that does 20.2V@4.3A PD, 9V@3A PD or 5.2V@2.4A.
I see the Firefly logo on the screen for a second, then the device restarts. This happens over and over and over. Any idea what could be wrong?
Seem to have solved it myself. It was because of the power supply, apparently this device needs a very specific power input. It works using a Satechi 75W dual USB-C travel charger, on the upper most USB-C port that says PD.
Your article is absolutely brilliant, thank you for sharing! Sharing the free New CCDM exam topics test questions—your key to career advancement and higher earnings!
Your article is really impressive, thank you for sharing! Free Latest C_THR85_2505 exam braindumps exam papers to help you prepare. Best of luck to all!
Your article is absolutely mind-blowing, thank you for sharing! Thanks to the AZ-140 Real Exams, I moved up in my career and got a raise. Now, it’s free for you all. Wishing you promotions ahead!
