How to install Kernel development packages?
I am trying to install PCIe drivers which needs kernel development packages. Can anyone help me with in installing the kernel package for an Ubuntu RK3399-PC?
1.Put kernel source code under this directory:/usr/src/kernel
2.Install kernel package tool on the board:
apt-get install kernel-package
3.Make package deb on the board:
For example with firefly-rk3288:
make firefly-rk3288-linux_defconfig
make-kpkg kernel_headers --config menuconfigExecute second command will display the dialog of menuconfig, pls load .config then save .config , exit for auto complie . finally create: /usr/src/kernel/debian/linux-headers-3.10.0/ and /usr/src/linux-headers-3.10.0_3.10.0-10.00.Custom_armhf.deb
4.Install head-file:
dpkg -i /usr/src/linux-headers-3.10.0_3.10.0-10.00.Custom_armhf.deb
Will create file after install :/usr/src/linux-headers-3.10.0
Then, if you want to complie kernel source code on the board , pls add patch below on Makefile:
KERNELDR := /usr/src/linux-headers-3.10.0/
I’m truly thankful for your article, it really stood out. I’m sharing the Valid braindumps PL-400 pdf test that helped me achieve a promotion and raise. It’s free for you today—best of luck in reaching your career goals!
Truly a magnificent read, thank you for this wonderful share. Here’s the CGEIT latest exam camp sheet test I took to earn my promotion and raise, now free for you today. Best of luck in your professional journey!
Your article is brilliant, thank you for sharing! The Valid dumps 010-160 free download questions are now free! Wishing you all the best for your exams!
Nun gibt es viele IT-Profis in der ganzen Welt und die Konkurrenz der IT-Branche ist sehr hart. So viele IT-Profis entscheiden sich dafür, an der IT-Zertifizierungsprüfung teilzunehmen, um ihre Position in der IT-Branche zu verstärken. Die MSP-Foundation Prüfung ist eine sehr wichtige Peoplecert-Zertifizierungsprüfung. Aber wenn Sie eine Peoplecert-Zertifizierung erhalten wollen, müssen Sie die Prüfung bestehen.
