I have now successfully installed PCIe drivers but display goes blank after reboot. When I uninstall the driver the display shows up. I am able to use the console mode but not the display mode. Here is the log:
[ 0.000000] Linux version 4.4.167 (daijh@tchip14) (firefly-merged-20190124-oldrkbin: 2f18cc87774957059d9f1d6282ca47f6d6f3ce40) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #152 SMP Tue Jun 25 15:15:26 CST 2019
[ 0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[ 0.000000] On node 0 totalpages: 1007616
[ 0.000000] DMA zone: 15864 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 1007616 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ec9000 s46120 r8192 d31704 u86016
[ 0.000000] pcpu-alloc: s46120 r8192 d31704 u86016 alloc=21*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 991752
[ 0.000000] Kernel command line: storagemedia=sd androidboot.mode=sd androidboot.slot_suffix= androidboot.serialno=db88e99c900a6478 rw rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 systemd.gpt_auto=0
[ 0.000000] software IO TLB [mem 0xf7e81000-0xf7ec1000] (0MB) mapped at [ffffffc0f7e81000-ffffffc0f7ec0fff]
[ 0.000000] Memory: 3937416K/4030464K available (10238K kernel code, 1542K rwdata, 4164K rodata, 1088K init, 1953K bss, 93048K reserved, 0K cma-reserved)
modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB)
.init : 0xffffff8008ea0000 - 0xffffff8008fb0000 ( 1088 KB)
.text : 0xffffff8008080000 - 0xffffff8008a80000 ( 10240 KB)
.rodata : 0xffffff8008a80000 - 0xffffff8008ea0000 ( 4224 KB)
.data : 0xffffff8008fb0000 - 0xffffff8009131808 ( 1543 KB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
fixed : 0xffffffbffe7fb000 - 0xffffffbffec00000 ( 4116 KB)
PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB)
memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.000000] ITS: allocated 65536 Devices @a280000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000000a210000
[ 0.000000] CPU0: using LPI pending table @0x000000000a220000
[ 0.000000] rockchip_mmc_get_phase: invalid clk rate
[ 0.002293] Console: colour dummy device 80x25
[ 0.002736] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003724] pid_max: default: 32768 minimum: 301
[ 0.004253] Security Framework initialized
[ 0.004719] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.005360] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006829] Initializing cgroup subsys devices
[ 0.007278] Initializing cgroup subsys freezer
[ 0.007727] ftrace: allocating 39061 entries in 153 pages
[ 0.108878] sched-energy: Sched-energy-costs installed from DT
[ 0.109448] CPU0: update cpu_capacity 401
[ 0.109895] ASID allocator initialised with 32768 entries
[ 0.113603] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.115008] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.117317] Detected VIPT I-cache on CPU1
[ 0.117351] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.117381] CPU1: using LPI pending table @0x00000000f2ca0000
[ 0.117424] CPU1: update cpu_capacity 401
[ 0.117428] CPU1: Booted secondary processor [410fd034]
[ 0.117981] Detected VIPT I-cache on CPU2
[ 0.118002] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.118029] CPU2: using LPI pending table @0x00000000f2cd0000
[ 0.118055] CPU2: update cpu_capacity 401
[ 0.118058] CPU2: Booted secondary processor [410fd034]
[ 0.118589] Detected VIPT I-cache on CPU3
[ 0.118608] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.118636] CPU3: using LPI pending table @0x00000000f2d20000
[ 0.118662] CPU3: update cpu_capacity 401
[ 0.118665] CPU3: Booted secondary processor [410fd034]
[ 0.119219] Detected PIPT I-cache on CPU4
[ 0.119245] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.119283] CPU4: using LPI pending table @0x00000000f2d50000
[ 0.119321] CPU4: update cpu_capacity 1024
[ 0.119325] CPU4: Booted secondary processor [410fd082]
[ 0.119880] Detected PIPT I-cache on CPU5
[ 0.119898] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.119934] CPU5: using LPI pending table @0x00000000f2d80000
[ 0.119962] CPU5: update cpu_capacity 1024
[ 0.119965] CPU5: Booted secondary processor [410fd082]
[ 0.120052] Brought up 6 CPUs
[ 0.132419] SMP: Total of 6 processors activated.
[ 0.132870] CPU features: detected feature: GIC system register CPU interface
[ 0.133559] CPU features: detected feature: 32-bit EL0 Support
[ 0.134119] CPU: All CPU(s) started at EL2
[ 0.134550] alternatives: patching kernel code
[ 0.136382] devtmpfs: initialized
[ 0.154604] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.155531] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.156591] pinctrl core: initialized pinctrl subsystem
[ 0.157301] regulator-dummy: no parameters
[ 0.157854] NET: Registered protocol family 16
[ 0.163583] cpuidle: using governor ladder
[ 0.167591] cpuidle: using governor menu
[ 0.167976] Registered FIQ tty driver
[ 0.168563] vdso: 2 pages (1 code @ ffffff8008a86000, 1 data @ ffffff8008fb4000)
[ 0.169310] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.170100] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.187186] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[ 0.187268] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[ 0.187339] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[ 0.187410] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[ 0.187479] gpiochip_add_data: registered GPIOs 128 to 159 on device: gpio4
[ 0.197333] console [ttyFIQ0] enabled
[ 0.198016] bootconsole [uart0] disabled
[ 0.198912] Registered fiq debugger ttyFIQ0
[ 0.213521] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vccadc-ref[0]'
[ 0.213546] vcc1v8_sys: 1800 mV
[ 0.213712] reg-fixed-voltage vccadc-ref: vcc1v8_sys supplying 1800000uV
[ 0.213766] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc3v3-sys[0]'
[ 0.213782] vcc3v3_sys: 3300 mV
[ 0.213938] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[ 0.214171] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc5v0-host-regulator[0]' - status (0)
[ 0.214223] vcc5v0_host: no parameters
[ 0.214369] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[ 0.214518] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc_hub_en-regulator[0]' - status (0)
[ 0.214556] vcc_hub_en: no parameters
[ 0.214718] reg-fixed-voltage vcc_hub_en-regulator: vcc_hub_en supplying 0uV
[ 0.214862] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-wifi[0]' - status (0)
[ 0.214905] vcc_wifi: 5000 mV
[ 0.215059] reg-fixed-voltage vcc-wifi: vcc_wifi supplying 5000000uV
[ 0.215187] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-pcie[0]' - status (0)
[ 0.215227] vcc_pcie: 5000 mV
[ 0.215387] reg-fixed-voltage vcc-pcie: vcc_pcie supplying 5000000uV
[ 0.215533] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-sd[0]' - status (0)
[ 0.215571] vcc_sd: 3300 mV
[ 0.215723] reg-fixed-voltage vcc-sd: vcc_sd supplying 3300000uV
[ 0.215779] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc5v0-sys[0]'
[ 0.215795] vcc5v0_sys: 5000 mV
[ 0.215952] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[ 0.216002] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[ 0.216017] vcc_phy: no parameters
[ 0.216163] reg-fixed-voltage vcc-phy-regulator: vcc_phy supplying 0uV
[ 0.216293] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-lcd-regulator[0]' - status (0)
[ 0.216332] vcc_lcd: no parameters
[ 0.216497] reg-fixed-voltage vcc-lcd-regulator: vcc_lcd supplying 0uV
[ 0.216640] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc_mipi[0]' - status (0)
[ 0.216676] vcc_mipi: no parameters
[ 0.216834] reg-fixed-voltage vcc_mipi: vcc_mipi supplying 0uV
[ 0.216902] rockchip-pinctrl pinctrl: pin gpio1-17 already requested by vcc-pcie; cannot claim for dvdd-1v2
[ 0.217769] rockchip-pinctrl pinctrl: pin-49 (dvdd-1v2) status -22
[ 0.218321] rockchip-pinctrl pinctrl: could not request pin 49 (gpio1-17) from group cif-pwr on device rockchip-pinctrl
[ 0.219284] reg-fixed-voltage dvdd-1v2: Error applying setting, reverse things back
[ 0.220010] of_get_named_gpiod_flags: parsed 'gpio' property of node '/dvdd-1v2[0]' - status (0)
[ 0.220046] dvdd_1v2: no parameters
[ 0.220201] reg-fixed-voltage dvdd-1v2: dvdd_1v2 supplying 0uV
[ 0.220883] iommu: Adding device ff650000.vpu_service to group 0
[ 0.221508] iommu: Adding device ff660000.rkvdec to group 1
[ 0.222102] iommu: Adding device ff8f0000.vop to group 2
[ 0.222664] iommu: Adding device ff900000.vop to group 3
[ 0.223217] iommu: Adding device ff910000.rkisp1 to group 4
[ 0.223804] iommu: Adding device ff920000.rkisp1 to group 5
[ 0.224799] rk_iommu ff650800.iommu: can't get sclk
[ 0.225507] rk_iommu ff660480.iommu: can't get sclk
[ 0.226158] rk_iommu ff8f3f00.iommu: can't get sclk
[ 0.226753] rk_iommu ff903f00.iommu: can't get sclk
[ 0.227363] rk_iommu ff914000.iommu: can't get sclk
[ 0.227961] rk_iommu ff924000.iommu: can't get sclk
[ 0.228767] SCSI subsystem initialized
[ 0.229293] libata version 3.00 loaded.
[ 0.229508] usbcore: registered new interface driver usbfs
[ 0.230039] usbcore: registered new interface driver hub
[ 0.230609] usbcore: registered new device driver usb
[ 0.231114] media: Linux media interface: v0.10
[ 0.231553] Linux video capture interface: v2.00
[ 0.232033] pps_core: LinuxPPS API ver. 1 registered
[ 0.232477] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.233302] PTP clock support registered
[ 0.234883] Advanced Linux Sound Architecture Driver Initialized.
[ 0.235914] Bluetooth: Core ver 2.21
[ 0.236254] NET: Registered protocol family 31
[ 0.236661] Bluetooth: HCI device and connection manager initialized
[ 0.237227] Bluetooth: HCI socket layer initialized
[ 0.237669] Bluetooth: L2CAP socket layer initialized
[ 0.238132] Bluetooth: SCO socket layer initialized
[ 0.239202] rockchip-cpuinfo cpuinfo: Serial : db88e99c900a6478
[ 0.240310] clocksource: Switched to clocksource arch_sys_counter
[ 0.290037] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.290956] NET: Registered protocol family 2
[ 0.291794] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.292697] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[ 0.294246] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.294954] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.295678] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.296650] NET: Registered protocol family 1
[ 0.297348] RPC: Registered named UNIX socket transport module.
[ 0.297875] RPC: Registered udp transport module.
[ 0.298295] RPC: Registered tcp transport module.
[ 0.298726] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.299320] PCI: CLS 0 bytes, default 64
[ 0.300427] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.301229] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.305079] Initialise system trusted keyring
[ 0.313470] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.314734] NFS: Registering the id_resolver key type
[ 0.315196] Key type id_resolver registered
[ 0.315586] Key type id_legacy registered
[ 0.316160] fuse init (API version 7.23)
[ 0.316855] SGI XFS with security attributes, no debug enabled
[ 0.322265] NET: Registered protocol family 38
[ 0.322707] Key type asymmetric registered
[ 0.323078] Asymmetric key parser 'x509' registered
[ 0.323679] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.324352] io scheduler noop registered
[ 0.324710] io scheduler deadline registered
[ 0.325205] io scheduler cfq registered (default)
[ 0.327953] rockchip-mipi-dphy-rx ff770000.syscon:mipi-dphy-rx0: invalid resource
[ 0.329392] phy phy-ff770000.syscon:phy@f780.0: Looking up phy-supply from device tree
[ 0.329404] phy phy-ff770000.syscon:phy@f780.0: Looking up phy-supply property in node /syscon@ff770000/phy@f780 failed
[ 0.330406] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc0-supply from device tree
[ 0.330421] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc0-supply property in node /power-management@ff310000/power-controller failed
[ 0.330869] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc1-supply from device tree
[ 0.330883] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc1-supply property in node /power-management@ff310000/power-controller failed
[ 0.331237] phy phy-pcie-phy.1: Looking up phy-supply from device tree
[ 0.331247] phy phy-pcie-phy.1: Looking up phy-supply property in node /pcie-phy failed
[ 0.333342] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[ 0.333353] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[ 0.333383] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[ 0.333630] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[ 0.333642] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply property in node /pcie@f8000000 failed
[ 0.333661] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.334224] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree
[ 0.334234] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed
[ 0.334248] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.334821] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree
[ 0.334831] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed
[ 0.334846] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.335416] rockchip-pcie f8000000.pcie: missing "memory-region" property
[ 0.336019] PCI host bridge /pcie@f8000000 ranges:
[ 0.336461] MEM 0xfa000000..0xfbdfffff -> 0xfa000000
[ 0.336920] IO 0xfbe00000..0xfbefffff -> 0xfbe00000
[ 0.381151] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[ 0.381753] pci_bus 0000:00: root bus resource [bus 00-1f]
[ 0.382247] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
[ 0.382867] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
[ 0.383742] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
[ 0.383845] pci 0000:00:00.0: supports D1
[ 0.383854] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 0.384097] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.384929] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-1f] (conflicts with (null) [bus 00-1f])
[ 0.384971] pci 0000:01:00.0: [1cd7:0052] type 00 class 0x040000
[ 0.385025] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x0003ffff]
[ 0.385158] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot
[ 0.387349] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.387383] pci 0000:00:00.0: BAR 8: assigned [mem 0xfa000000-0xfa0fffff]
[ 0.387984] pci 0000:01:00.0: BAR 0: assigned [mem 0xfa000000-0xfa03ffff]
[ 0.388598] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.389048] pci 0000:00:00.0: bridge window [mem 0xfa000000-0xfa0fffff]
[ 0.389706] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 0.390474] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.391093] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 0.391684] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
[ 0.391790] aer 0000:00:00.0:pcie02: service driver aer loaded
[ 0.392340] pwm-backlight backlight: GPIO lookup for consumer enable
[ 0.392349] pwm-backlight backlight: using device tree for GPIO lookup
[ 0.392359] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
[ 0.392368] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
[ 0.392376] pwm-backlight backlight: using lookup tables for GPIO lookup
[ 0.392385] pwm-backlight backlight: lookup for GPIO enable failed
[ 0.392396] pwm-backlight backlight: Looking up power-supply from device tree
[ 0.392405] pwm-backlight backlight: Looking up power-supply property in node /backlight failed
[ 0.392419] backlight supply power not found, using dummy regulator
[ 0.393487] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply from device tree
[ 0.393499] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply property in node /vpu_service@ff650000 failed
[ 0.393515] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.394381] rk-vcodec ff650000.vpu_service: probe device
[ 0.395059] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 0.396265] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.396902] rk-vcodec ff650000.vpu_service: init success
[ 0.397602] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply from device tree
[ 0.397613] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply property in node /rkvdec@ff660000 failed
[ 0.397630] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.398628] rk-vcodec ff660000.rkvdec: probe device
[ 0.399244] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 0.400217] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.400806] rk-vcodec ff660000.rkvdec: init success
[ 0.402768] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.403449] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.405709] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.406390] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.408448] pwm-regulator vdd-log: GPIO lookup for consumer enable
[ 0.408457] pwm-regulator vdd-log: using device tree for GPIO lookup
[ 0.408468] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log[0]'
[ 0.408477] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log[0]'
[ 0.408485] pwm-regulator vdd-log: using lookup tables for GPIO lookup
[ 0.408493] pwm-regulator vdd-log: lookup for GPIO enable failed
[ 0.408534] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.408544] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.408569] vdd_log: 800 <--> 1100 mV at 1007 mV
[ 0.408731] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.408741] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.408796] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.408806] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.409248] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.410473] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[ 0.411627] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-debugger; cannot claim for ff1a0000.serial
[ 0.412580] rockchip-pinctrl pinctrl: pin-147 (ff1a0000.serial) status -22
[ 0.413190] rockchip-pinctrl pinctrl: could not request pin 147 (gpio4-19) from group uart2c-xfer on device rockchip-pinctrl
[ 0.414190] dw-apb-uart ff1a0000.serial: Error applying setting, reverse things back
[ 0.415030] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud = 1500000) is a 16550A
[ 0.417025] [drm] Initialized drm 1.1.0 20060810
[ 0.421605] [drm] Rockchip DRM driver version: v1.0.1
[ 0.424363] mali ff9a0000.gpu: Looking up mali-supply from device tree
[ 0.424388] mali ff9a0000.gpu: Failed to get regulator
[ 0.424846] mali ff9a0000.gpu: Power control initialization failed
[ 0.425443] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_gpu-supply from device tree
[ 0.425455] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_gpu-supply property in node /power-management@ff310000/power-controller failed
[ 0.425774] Unable to detect cache hierarchy for CPU 0
[ 0.427018] brd: module loaded
[ 0.432430] loop: module loaded
[ 0.433232] zram: Added device: zram0
[ 0.433914] lkdtm: No crash points registered, enable through debugfs
[ 0.436101] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 0.436707] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 0.437292] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[ 0.438713] register spi return v = :0
[ 0.439899] rk_gmac-dwmac fe300000.ethernet: Looking up phy-supply from device tree
[ 0.439992] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 0.440628] rk_gmac-dwmac fe300000.ethernet: TX delay(0x2e).
[ 0.441133] rk_gmac-dwmac fe300000.ethernet: RX delay(0x13).
[ 0.441660] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 0.442394] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 0.443013] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 0.448565] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 0.449174] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.449628] Ring mode enabled
[ 0.449899] DMA HW capability register supported
[ 0.450296] Normal descriptors
[ 0.450610] RX Checksum Offload Engine supported (type 2)
[ 0.451098] TX Checksum insertion supported
[ 0.451480] Wake-Up On Lan supported
[ 0.451839] Enable RX Mitigation via HW Watchdog Timer
[ 0.452417] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@fe300000[0]' - status (0)
[ 0.517752] libphy: stmmac: probed
[ 0.518070] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 0.518663] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 0.521480] usbcore: registered new interface driver rndis_wlan
[ 0.522168] Rockchip WiFi SYS interface (V1.00) ...
[ 0.522719] usbcore: registered new interface driver rtl8150
[ 0.523263] usbcore: registered new interface driver r8152
[ 0.523820] usbcore: registered new interface driver asix
[ 0.524360] usbcore: registered new interface driver ax88179_178a
[ 0.524941] usbcore: registered new interface driver cdc_ether
[ 0.525511] usbcore: registered new interface driver rndis_host
[ 0.526113] usbcore: registered new interface driver cdc_ncm
[ 0.526670] usbcore: registered new interface driver qmi_wwan
[ 0.527229] usbcore: registered new interface driver cdc_mbim
[ 0.529728] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 0.530354] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_usb3-supply from device tree
[ 0.530370] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_usb3-supply property in node /power-management@ff310000/power-controller failed
[ 0.531603] rockchip-dwc3 usb1: failed to get drvdata dwc3
[ 0.533598] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.534195] ehci-pci: EHCI PCI platform driver
[ 0.534700] ehci-platform: EHCI generic platform driver
[ 0.536118] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.536700] ohci-platform: OHCI generic platform driver
[ 0.538573] usbcore: registered new interface driver cdc_acm
[ 0.539074] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.539843] usbcore: registered new interface driver cdc_wdm
[ 0.540407] usbcore: registered new interface driver uas
[ 0.540937] usbcore: registered new interface driver usb-storage
[ 0.541581] usbcore: registered new interface driver usbserial
[ 0.542132] usbcore: registered new interface driver usbserial_generic
[ 0.542758] usbserial: USB Serial support registered for generic
[ 0.543348] usbcore: registered new interface driver ch341
[ 0.543865] usbserial: USB Serial support registered for ch341-uart
[ 0.544477] usbcore: registered new interface driver cp210x
[ 0.544995] usbserial: USB Serial support registered for cp210x
[ 0.545573] usbcore: registered new interface driver ftdi_sio
[ 0.546114] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 0.546823] usbcore: registered new interface driver keyspan
[ 0.547368] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 0.548090] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 0.548781] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 0.549471] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 0.550160] usbcore: registered new interface driver option
[ 0.550694] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.551368] usbcore: registered new interface driver oti6858
[ 0.551900] usbserial: USB Serial support registered for oti6858
[ 0.552491] usbcore: registered new interface driver pl2303
[ 0.553009] usbserial: USB Serial support registered for pl2303
[ 0.553588] usbcore: registered new interface driver qcserial
[ 0.554128] usbserial: USB Serial support registered for Qualcomm USB modem
[ 0.554799] usbcore: registered new interface driver sierra
[ 0.555337] usbserial: USB Serial support registered for Sierra USB modem
[ 0.557340] usbcore: registered new interface driver usbtouchscreen
[ 0.558129] .. rk pwm remotectl v1.1 init
[ 0.558743] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 0.559838] sensor_register_slave:mma8452,id=17
[ 0.560244] sensor_register_slave:lis3dh,id=7
[ 0.560653] sensor_register_slave:mma7660,id=18
[ 0.561057] sensor_register_slave:lsm303d,id=22
[ 0.561468] sensor_register_slave:gs_mc3230,id=23
[ 0.561888] [Gsensor] gsensor_init
[ 0.562210] sensor_register_slave:mpu6880_acc,id=24
[ 0.562656] sensor_register_slave:mpu6500_acc,id=25
[ 0.563094] sensor_register_slave:lsm330_acc,id=26
[ 0.563527] sensor_register_slave:akm8975,id=30
[ 0.563930] sensor_register_slave:akm8963,id=31
[ 0.564341] sensor_register_slave:l3g4200d,id=45
[ 0.564754] sensor_register_slave:l3g20d,id=46
[ 0.565157] sensor_register_slave:ewtsa,id=47
[ 0.565556] sensor_register_slave:lsm330_gyro,id=51
[ 0.565993] sensor_register_slave:cm3217,id=53
[ 0.566403] sensor_register_slave:cm3218,id=54
[ 0.567340] i2c /dev entries driver
[ 0.568525] fan53555-regulator 0-0040: GPIO lookup for consumer vsel
[ 0.568535] fan53555-regulator 0-0040: using device tree for GPIO lookup
[ 0.568566] of_get_named_gpiod_flags: parsed 'vsel-gpios' property of node '/i2c@ff3c0000/syr827@40[0]' - status (0)
[ 0.568957] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 0.569592] fan53555-regulator 0-0040: Looking up vin-supply from device tree
[ 0.569654] fan53555-reg: supplied by vcc5v0_sys
[ 0.570068] vcc5v0_sys: could not add device link regulator.14 err -2
[ 0.571207] vdd_cpu_b: 712 <--> 1500 mV at 800 mV
[ 0.571587] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.571600] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.571835] fan53555-regulator 0-0041: GPIO lookup for consumer vsel
[ 0.571844] fan53555-regulator 0-0041: using device tree for GPIO lookup
[ 0.571874] of_get_named_gpiod_flags: parsed 'vsel-gpios' property of node '/i2c@ff3c0000/syr828@41[0]' - status (0)
[ 0.572219] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 0.572853] fan53555-regulator 0-0041: Looking up vin-supply from device tree
[ 0.572897] fan53555-reg: supplied by vcc5v0_sys
[ 0.573321] vcc5v0_sys: could not add device link regulator.15 err -2
[ 0.574466] vdd_gpu: 712 <--> 1500 mV at 800 mV
[ 0.574824] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.574835] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.575518] rk808 0-001b: Pmic Chip id: 0x0
[ 0.578581] rk808 0-001b: GPIO lookup for consumer dvs
[ 0.578590] rk808 0-001b: using device tree for GPIO lookup
[ 0.578601] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3c0000/pmic@1b[0]'
[ 0.578611] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3c0000/pmic@1b[0]'
[ 0.578618] rk808 0-001b: using lookup tables for GPIO lookup
[ 0.578627] rk808 0-001b: lookup for GPIO dvs failed
[ 0.578635] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.579184] rk808 0-001b: GPIO lookup for consumer dvs
[ 0.579191] rk808 0-001b: using device tree for GPIO lookup
[ 0.579199] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3c0000/pmic@1b[1]'
[ 0.579208] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3c0000/pmic@1b[1]'
[ 0.579215] rk808 0-001b: using lookup tables for GPIO lookup
[ 0.579222] rk808 0-001b: lookup for GPIO dvs failed
[ 0.579229] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.579833] rk808 0-001b: Looking up vcc1-supply from device tree
[ 0.579894] DCDC_REG1: supplied by vcc3v3_sys
[ 0.580284] vcc3v3_sys: could not add device link regulator.16 err -2
[ 0.580745] vdd_center: 750 <--> 1350 mV at 900 mV
[ 0.580968] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.580979] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.581030] rk808 0-001b: Looking up vcc2-supply from device tree
[ 0.581070] DCDC_REG2: supplied by vcc3v3_sys
[ 0.581476] vcc3v3_sys: could not add device link regulator.17 err -2
[ 0.581772] vdd_cpu_l: 750 <--> 1350 mV at 800 mV
[ 0.581981] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.581992] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.582039] rk808 0-001b: Looking up vcc3-supply from device tree
[ 0.582079] DCDC_REG3: supplied by vcc3v3_sys
[ 0.582484] vcc3v3_sys: could not add device link regulator.18 err -2
[ 0.582514] vcc_ddr: at 3300 mV
[ 0.582691] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.582702] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.582753] rk808 0-001b: Looking up vcc4-supply from device tree
[ 0.582792] DCDC_REG4: supplied by vcc3v3_sys
[ 0.583181] vcc3v3_sys: could not add device link regulator.19 err -2
[ 0.583375] vcc_1v8: 1800 mV
[ 0.583578] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.583589] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.583641] rk808 0-001b: Looking up vcc6-supply from device tree
[ 0.583680] LDO_REG1: supplied by vcc3v3_sys
[ 0.584058] vcc3v3_sys: could not add device link regulator.20 err -2
[ 0.584895] vcca1v8_codec: 1800 mV
[ 0.585106] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.585117] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.585171] rk808 0-001b: Looking up vcc6-supply from device tree
[ 0.585209] LDO_REG2: supplied by vcc3v3_sys
[ 0.585605] vcc3v3_sys: could not add device link regulator.21 err -2
[ 0.586314] vcc1v8_hdmi: 1800 mV
[ 0.586523] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.586533] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.586589] rk808 0-001b: Looking up vcc7-supply from device tree
[ 0.586628] LDO_REG3: supplied by vcc3v3_sys
[ 0.587006] vcc3v3_sys: could not add device link regulator.22 err -2
[ 0.587705] vcc1v8_pmu: 1800 mV
[ 0.587915] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.587925] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.587985] rk808 0-001b: Looking up vcc9-supply from device tree
[ 0.588022] LDO_REG4: supplied by vcc3v3_sys
[ 0.588416] vcc3v3_sys: could not add device link regulator.23 err -2
[ 0.589119] vccio_sd: 1800 <--> 3000 mV at 3000 mV
[ 0.589345] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.589355] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.589416] rk808 0-001b: Looking up vcc9-supply from device tree
[ 0.589457] LDO_REG5: supplied by vcc3v3_sys
[ 0.589838] vcc3v3_sys: could not add device link regulator.24 err -2
[ 0.590533] vcca3v0_codec: 3000 mV
[ 0.590733] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.590744] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.590810] rk808 0-001b: Looking up vcc10-supply from device tree
[ 0.590850] LDO_REG6: supplied by vcc3v3_sys
[ 0.591228] vcc3v3_sys: could not add device link regulator.25 err -2
[ 0.591939] vcc_1v5: 1500 mV
[ 0.592142] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.592153] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.592219] rk808 0-001b: Looking up vcc7-supply from device tree
[ 0.592258] LDO_REG7: supplied by vcc3v3_sys
[ 0.592654] vcc3v3_sys: could not add device link regulator.26 err -2
[ 0.593351] vcca0v9_hdmi: 900 mV
[ 0.593563] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.593573] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.593640] rk808 0-001b: Looking up vcc11-supply from device tree
[ 0.593680] LDO_REG8: supplied by vcc3v3_sys
[ 0.594058] vcc3v3_sys: could not add device link regulator.27 err -2
[ 0.594754] vcc_3v0: 3000 mV
[ 0.594971] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.594981] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.595048] rk808 0-001b: Looking up vcc8-supply from device tree
[ 0.595086] SWITCH_REG1: supplied by vcc3v3_sys
[ 0.595502] vcc3v3_sys: could not add device link regulator.28 err -2
[ 0.595531] vcc3v3_s3: at 3300 mV
[ 0.595719] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.595729] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.595800] rk808 0-001b: Looking up vcc12-supply from device tree
[ 0.595838] SWITCH_REG2: supplied by vcc3v3_sys
[ 0.596239] vcc3v3_sys: could not add device link regulator.29 err -2
[ 0.596267] vcc3v3_s0: at 3300 mV
[ 0.596456] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.596466] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.599657] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 0.600677] of_get_named_gpiod_flags: parsed 'pmic,hold-gpio' property of node '/i2c@ff3c0000/pmic@1b[0]' - status (0)
[ 0.600715] of_get_named_gpiod_flags: can't parse 'pmic,stby-gpio' property of node '/i2c@ff3c0000/pmic@1b[0]'
[ 0.600725] rk808 0-001b: Can not read property pmic,stby-gpio
[ 0.601267] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80093f6000
[ 0.602673] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80093f8000
[ 0.603901] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff80093fa000
[ 0.605268] fusb302 7-0022: GPIO lookup for consumer int-n
[ 0.605278] fusb302 7-0022: using device tree for GPIO lookup
[ 0.605325] of_get_named_gpiod_flags: parsed 'int-n-gpios' property of node '/i2c@ff160000/fusb30x@22[0]' - status (0)
[ 0.605351] fusb302 7-0022: GPIO lookup for consumer vbus-5v
[ 0.605358] fusb302 7-0022: using device tree for GPIO lookup
[ 0.605367] of_get_named_gpiod_flags: can't parse 'vbus-5v-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
[ 0.605376] of_get_named_gpiod_flags: can't parse 'vbus-5v-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
[ 0.605383] fusb302 7-0022: using lookup tables for GPIO lookup
[ 0.605392] fusb302 7-0022: lookup for GPIO vbus-5v failed
[ 0.605400] fusb302 7-0022: GPIO lookup for consumer vbus-other
[ 0.605407] fusb302 7-0022: using device tree for GPIO lookup
[ 0.605415] of_get_named_gpiod_flags: can't parse 'vbus-other-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
[ 0.605424] of_get_named_gpiod_flags: can't parse 'vbus-other-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
[ 0.605431] fusb302 7-0022: using lookup tables for GPIO lookup
[ 0.605438] fusb302 7-0022: lookup for GPIO vbus-other failed
[ 0.605446] fusb302 7-0022: GPIO lookup for consumer discharge
[ 0.605454] fusb302 7-0022: using device tree for GPIO lookup
[ 0.605462] of_get_named_gpiod_flags: can't parse 'discharge-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
[ 0.605470] of_get_named_gpiod_flags: can't parse 'discharge-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
[ 0.605477] fusb302 7-0022: using lookup tables for GPIO lookup
[ 0.605484] fusb302 7-0022: lookup for GPIO discharge failed
[ 0.605493] fusb302 7-0022: GPIO lookup for consumer charge-en
[ 0.605499] fusb302 7-0022: using device tree for GPIO lookup
[ 0.605507] of_get_named_gpiod_flags: can't parse 'charge-en-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
[ 0.605516] of_get_named_gpiod_flags: can't parse 'charge-en-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
[ 0.605522] fusb302 7-0022: using lookup tables for GPIO lookup
[ 0.605529] fusb302 7-0022: lookup for GPIO charge-en failed
[ 0.605697] fusb302 7-0022: Can't get property of role, set role to default DRP
[ 0.606513] fusb302 7-0022: fusb302 send extcon to disable vbus 5v
[ 0.609785] fusb302 7-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 0.610710] mp8859 7-0066: GPIO lookup for consumer charge-en
[ 0.610719] mp8859 7-0066: using device tree for GPIO lookup
[ 0.610727] of_get_named_gpiod_flags: can't parse 'charge-en-gpios' property of node '/i2c@ff160000/mp8859@66[0]'
[ 0.610736] of_get_named_gpiod_flags: can't parse 'charge-en-gpio' property of node '/i2c@ff160000/mp8859@66[0]'
[ 0.610743] mp8859 7-0066: using lookup tables for GPIO lookup
[ 0.610751] mp8859 7-0066: lookup for GPIO charge-en failed
[ 0.611462] mp8859 7-0066: set mp8859 out 12v ok
[ 0.611873] mp8859 7-0066: register ext0 dev0
[ 0.612407] mp8859 7-0066: mp8859 probe successful
[ 0.612852] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff80093fc000
[ 0.614318] rockchip-pinctrl pinctrl: pin gpio1-1 already requested by vcc_mipi; cannot claim for 4-0022
[ 0.615150] rockchip-pinctrl pinctrl: pin-33 (4-0022) status -22
[ 0.615701] rockchip-pinctrl pinctrl: could not request pin 33 (gpio1-1) from group fusb1-int on device rockchip-pinctrl
[ 0.616669] fusb302 4-0022: Error applying setting, reverse things back
[ 0.617336] fusb302 4-0022: GPIO lookup for consumer int-n
[ 0.617344] fusb302 4-0022: using device tree for GPIO lookup
[ 0.617374] of_get_named_gpiod_flags: parsed 'int-n-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]' - status (0)
[ 0.617398] fusb302 4-0022: GPIO lookup for consumer vbus-5v
[ 0.617406] fusb302 4-0022: using device tree for GPIO lookup
[ 0.617432] of_get_named_gpiod_flags: parsed 'vbus-5v-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]' - status (0)
[ 0.617458] fusb302 4-0022: GPIO lookup for consumer vbus-other
[ 0.617465] fusb302 4-0022: using device tree for GPIO lookup
[ 0.617475] of_get_named_gpiod_flags: can't parse 'vbus-other-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[ 0.617483] of_get_named_gpiod_flags: can't parse 'vbus-other-gpio' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[ 0.617491] fusb302 4-0022: using lookup tables for GPIO lookup
[ 0.617498] fusb302 4-0022: lookup for GPIO vbus-other failed
[ 0.617506] fusb302 4-0022: GPIO lookup for consumer discharge
[ 0.617513] fusb302 4-0022: using device tree for GPIO lookup
[ 0.617521] of_get_named_gpiod_flags: can't parse 'discharge-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[ 0.617529] of_get_named_gpiod_flags: can't parse 'discharge-gpio' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[ 0.617536] fusb302 4-0022: using lookup tables for GPIO lookup
[ 0.617543] fusb302 4-0022: lookup for GPIO discharge failed
[ 0.617551] fusb302 4-0022: GPIO lookup for consumer charge-en
[ 0.617558] fusb302 4-0022: using device tree for GPIO lookup
[ 0.617566] of_get_named_gpiod_flags: can't parse 'charge-en-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[ 0.617574] of_get_named_gpiod_flags: can't parse 'charge-en-gpio' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[ 0.617581] fusb302 4-0022: using lookup tables for GPIO lookup
[ 0.617588] fusb302 4-0022: lookup for GPIO charge-en failed
[ 0.617731] fusb302 4-0022: Can't get property of role, set role to default DRP
[ 0.626662] fusb302 4-0022: port 1 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 0.627482] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80093fe000
[ 0.629282] IR NEC protocol handler initialized
[ 0.630534] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.00
[ 0.631115] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 0.632852] rkisp1 ff910000.rkisp1: GPIO lookup for consumer vsirq
[ 0.632862] rkisp1 ff910000.rkisp1: using device tree for GPIO lookup
[ 0.632872] of_get_named_gpiod_flags: can't parse 'vsirq-gpios' property of node '/rkisp1@ff910000[0]'
[ 0.632880] of_get_named_gpiod_flags: can't parse 'vsirq-gpio' property of node '/rkisp1@ff910000[0]'
[ 0.632888] rkisp1 ff910000.rkisp1: using lookup tables for GPIO lookup
[ 0.632896] rkisp1 ff910000.rkisp1: lookup for GPIO vsirq failed
[ 0.633214] rkisp1 ff920000.rkisp1: rkisp1 driver version: v00.01.00
[ 0.633812] rkisp1 ff920000.rkisp1: Missing rockchip,grf property
[ 0.635542] rkisp1 ff920000.rkisp1: GPIO lookup for consumer vsirq
[ 0.635552] rkisp1 ff920000.rkisp1: using device tree for GPIO lookup
[ 0.635563] of_get_named_gpiod_flags: can't parse 'vsirq-gpios' property of node '/rkisp1@ff920000[0]'
[ 0.635572] of_get_named_gpiod_flags: can't parse 'vsirq-gpio' property of node '/rkisp1@ff920000[0]'
[ 0.635579] rkisp1 ff920000.rkisp1: using lookup tables for GPIO lookup
[ 0.635588] rkisp1 ff920000.rkisp1: lookup for GPIO vsirq failed
[ 0.635848] usbcore: registered new interface driver uvcvideo
[ 0.636377] USB Video Class driver (1.1.1)
[ 0.636813] cw201x 2-0062: design_capacity missing!
[ 0.669270] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 0.670241] cw201x 2-0062: cw2015/cw2013 driver v1.2 probe sucess
[ 0.671493] rockchip-iodomain ff320000.syscon:io-domains: Looking up pmu1830-supply from device tree
[ 0.671714] rockchip-iodomain ff770000.syscon:io-domains: Looking up bt656-supply from device tree
[ 0.671773] rockchip-iodomain ff770000.syscon:io-domains: Looking up audio-supply from device tree
[ 0.671831] rockchip-iodomain ff770000.syscon:io-domains: Looking up sdmmc-supply from device tree
[ 0.671886] rockchip-iodomain ff770000.syscon:io-domains: Looking up gpio1830-supply from device tree
[ 0.673872] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 0.674821] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[ 0.676335] Bluetooth: Virtual HCI driver ver 1.5
[ 0.676884] Bluetooth: HCI UART driver ver 2.3
[ 0.677283] Bluetooth: HCI UART protocol H4 registered
[ 0.677751] Bluetooth: HCI UART protocol LL registered
[ 0.678207] Bluetooth: HCI UART protocol ATH3K registered
[ 0.678752] usbcore: registered new interface driver bfusb
[ 0.679286] usbcore: registered new interface driver btusb
[ 0.680381] cpu cpu0: bin=1
[ 0.680683] cpu cpu0: leakage=21
[ 0.681024] cpu cpu0: Looking up cpu-supply from device tree
[ 0.693716] cpu cpu0: temp=63125, pvtm=148332 (146880 + 1452)
[ 0.694458] cpu cpu0: pvtm-volt-sel=1
[ 0.694841] cpu cpu0: bin-scale=34
[ 0.695479] cpu cpu4: bin=1
[ 0.695778] cpu cpu4: leakage=37
[ 0.696089] cpu cpu4: Looking up cpu-supply from device tree
[ 0.708930] cpu cpu4: temp=63125, pvtm=155285 (154515 + 770)
[ 0.710578] cpu cpu4: pvtm-volt-sel=2
[ 0.710952] cpu cpu4: bin-scale=17
[ 0.711555] cpu cpu0: Looking up cpu-supply from device tree
[ 0.711830] cpu cpu0: Looking up cpu-supply from device tree
[ 0.712432] cpu cpu0: avs=0, target-scale=34
[ 0.712882] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 0.714136] cpu cpu4: Looking up cpu-supply from device tree
[ 0.714797] cpu cpu4: avs=0, target-scale=17
[ 0.715246] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 0.717283] sdhci: Secure Digital Host Controller Interface driver
[ 0.717848] sdhci: Copyright(c) Pierre Ossman
[ 0.718239] Synopsys Designware Multimedia Card Interface Driver
[ 0.719721] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.720406] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 0.721012] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 0.721566] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 0.722452] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[ 0.722463] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed
[ 0.722496] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[ 0.722506] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed
[ 0.722529] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 0.723078] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 0.723646] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
[ 0.723653] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
[ 0.723664] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe310000[0]'
[ 0.723673] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe310000[0]'
[ 0.723681] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
[ 0.723689] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[ 0.723915] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_sdioaudio-supply from device tree
[ 0.723927] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_sdioaudio-supply property in node /power-management@ff310000/power-controller failed
[ 0.724610] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.725271] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 0.725889] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 0.726445] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 0.727321] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 0.728035] dwmmc_rockchip fe320000.dwmmc: Looking up vmmc-supply from device tree
[ 0.728132] dwmmc_rockchip fe320000.dwmmc: Looking up vqmmc-supply from device tree
[ 0.728203] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer cd
[ 0.728211] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[ 0.728221] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/dwmmc@fe320000[0]'
[ 0.728230] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/dwmmc@fe320000[0]'
[ 0.728238] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[ 0.728246] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO cd failed
[ 0.728255] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer wp
[ 0.728263] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[ 0.728271] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe320000[0]'
[ 0.728280] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe320000[0]'
[ 0.728288] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[ 0.728295] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO wp failed
[ 0.728476] vccio_sd: unsupportable voltage range: 3300000-3000000uV
[ 0.729050] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 0.729719] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 0.741372] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.747567] fusb302 7-0022: CC connected in CC1 as UFP
[ 0.752452] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 0.753729] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.755319] sdhci-arasan fe330000.sdhci: GPIO lookup for consumer wp
[ 0.755331] sdhci-arasan fe330000.sdhci: using device tree for GPIO lookup
[ 0.755346] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/sdhci@fe330000[0]'
[ 0.755358] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/sdhci@fe330000[0]'
[ 0.755369] sdhci-arasan fe330000.sdhci: using lookup tables for GPIO lookup
[ 0.755380] sdhci-arasan fe330000.sdhci: lookup for GPIO wp failed
[ 0.756525] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply from device tree
[ 0.756540] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply property in node /sdhci@fe330000 failed
[ 0.756608] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply from device tree
[ 0.756628] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe330000 failed
[ 0.756653] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 0.757196] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 0.784345] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 0.786355] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/power[0]' - status (0)
[ 0.786613] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/user[0]' - status (0)
[ 0.786994] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.788136] usbcore: registered new interface driver usbhid
[ 0.788664] usbhid: USB HID core driver
[ 0.789231] inv_mpu_iio: inv_mpu_init:746
[ 0.792225] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 0.797738] rockchip-saradc ff100000.saradc: Looking up vref-supply from device tree
[ 0.799899] usbcore: registered new interface driver snd-usb-audio
[ 0.806251] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
[ 0.806949] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
[ 0.807842] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 0.809058] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 0.809686] Initializing XFRM netlink socket
[ 0.810725] NET: Registered protocol family 10
[ 0.812686] NET: Registered protocol family 17
[ 0.813109] NET: Registered protocol family 15
[ 0.814118] Bluetooth: RFCOMM socket layer initialized
[ 0.814630] Bluetooth: RFCOMM ver 1.11
[ 0.814993] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 0.815536] Bluetooth: HIDP socket layer initialized
[ 0.816037] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 0.816808] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 0.817270] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354
[ 0.817887] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 0.818524] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 0.819182] of_get_named_gpiod_flags: can't parse 'WIFI,poweren_gpio' property of node '/wireless-wlan[0]'
[ 0.819190] of_get_named_gpiod_flags: can't parse 'WIFI,vbat_gpio' property of node '/wireless-wlan[0]'
[ 0.819198] of_get_named_gpiod_flags: can't parse 'WIFI,reset_gpio' property of node '/wireless-wlan[0]'
[ 0.819238] of_get_named_gpiod_flags: parsed 'WIFI,host_wake_irq' property of node '/wireless-wlan[0]' - status (0)
[ 0.819245] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 0.820050] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 0.820823] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 0.821312] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 0.821822] [BT_RFKILL]: Enter rfkill_rk_init
[ 0.822685] of_get_named_gpiod_flags: parsed 'uart_rts_gpios' property of node '/wireless-bluetooth[0]' - status (0)
[ 0.822693] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 0.823551] of_get_named_gpiod_flags: can't parse 'BT,power_gpio' property of node '/wireless-bluetooth[0]'
[ 0.823573] of_get_named_gpiod_flags: parsed 'BT,reset_gpio' property of node '/wireless-bluetooth[0]' - status (0)
[ 0.823578] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 0.824287] of_get_named_gpiod_flags: parsed 'BT,wake_gpio' property of node '/wireless-bluetooth[0]' - status (0)
[ 0.824292] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 0.825009] of_get_named_gpiod_flags: parsed 'BT,wake_host_irq' property of node '/wireless-bluetooth[0]' - status (0)
[ 0.825014] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 0.825739] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 0.826382] [BT_RFKILL]: Request irq for bt wakeup host
[ 0.826888] [BT_RFKILL]: ** disable irq
[ 0.827352] [BT_RFKILL]: bt_default device registered.
[ 0.827869] Key type dns_resolver registered
[ 0.828464] sensor_register_slave:mpu6880_gyro,id=50
[ 0.829700] ov13850 1-0036: GPIO lookup for consumer reset
[ 0.829713] ov13850 1-0036: using device tree for GPIO lookup
[ 0.829752] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/i2c@ff110000/ov13850@36[0]' - status (0)
[ 0.829810] ov13850 1-0036: Looking up avdd-supply from device tree
[ 0.830018] ov13850 1-0036: Looking up dovdd-supply from device tree
[ 0.830118] ov13850 1-0036: Looking up dvdd-supply from device tree
[ 0.830545] ov13850 1-0036: GPIO lookup for consumer pwdn
[ 0.830556] ov13850 1-0036: using device tree for GPIO lookup
[ 0.830595] of_get_named_gpiod_flags: parsed 'pwdn-gpios' property of node '/i2c@ff110000/ov13850@36[0]' - status (0)
[ 0.832866] ov13850 1-0036: write SCCB_ID failed
[ 0.833519] ov13850: probe of 1-0036 failed with error -5
[ 0.834450] ov13850 1-0046: GPIO lookup for consumer reset
[ 0.834461] ov13850 1-0046: using device tree for GPIO lookup
[ 0.834498] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/i2c@ff110000/ov13850@46[0]' - status (0)
[ 0.834538] ov13850 1-0046: Looking up avdd-supply from device tree
[ 0.834677] ov13850 1-0046: Looking up dovdd-supply from device tree
[ 0.834806] ov13850 1-0046: Looking up dvdd-supply from device tree
[ 0.835200] ov13850 1-0046: GPIO lookup for consumer pwdn
[ 0.835211] ov13850 1-0046: using device tree for GPIO lookup
[ 0.835250] of_get_named_gpiod_flags: parsed 'pwdn-gpios' property of node '/i2c@ff110000/ov13850@46[0]' - status (0)
[ 0.837199] ov13850 1-0046: write SCCB_ID failed
[ 0.837889] ov13850: probe of 1-0046 failed with error -5
[ 0.839203] Registered cp15_barrier emulation handler
[ 0.839791] Registered setend emulation handler
[ 0.841768] Loading compiled-in X.509 certificates
[ 0.843078] rga2: Module initialized.
[ 0.844031] phy phy-ff770000.syscon:usb2-phy@e450.2: Looking up phy-supply from device tree
[ 0.844121] vcc5v0_host: could not add device link phy-ff770000.syscon:usb2-phy@e450.2 err -2
[ 0.844550] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up phy-supply from device tree
[ 0.844562] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
[ 0.844925] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up vbus-supply from device tree
[ 0.844936] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
[ 0.844957] phy phy-ff770000.syscon:usb2-phy@e450.3: Failed to get VBUS supply regulator
[ 0.846342] phy phy-ff770000.syscon:usb2-phy@e460.4: Looking up phy-supply from device tree
[ 0.846404] vcc5v0_host: could not add device link phy-ff770000.syscon:usb2-phy@e460.4 err -2
[ 0.846742] phy phy-ff770000.syscon:usb2-phy@e460.5: Looking up phy-supply from device tree
[ 0.846753] phy phy-ff770000.syscon:usb2-phy@e460.5: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed
[ 0.847030] phy phy-ff770000.syscon:usb2-phy@e460.5: Looking up vbus-supply from device tree
[ 0.847039] phy phy-ff770000.syscon:usb2-phy@e460.5: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed
[ 0.847059] phy phy-ff770000.syscon:usb2-phy@e460.5: Failed to get VBUS supply regulator
[ 0.848392] phy phy-ff7c0000.phy.6: Looking up phy-supply from device tree
[ 0.848402] phy phy-ff7c0000.phy.6: Looking up phy-supply property in node /phy@ff7c0000/dp-port failed
[ 0.848461] mp8859 7-0066: mp8859 get notify
[ 0.848518] phy phy-ff7c0000.phy.7: Looking up phy-supply from device tree
[ 0.848523] phy phy-ff7c0000.phy.7: Looking up phy-supply property in node /phy@ff7c0000/usb3-port failed
[ 0.848862] mp8859 7-0066: mp8859 get ufp 1 dp 0
[ 0.848922] phy phy-ff800000.phy.8: Looking up phy-supply from device tree
[ 0.848927] phy phy-ff800000.phy.8: Looking up phy-supply property in node /phy@ff800000/dp-port failed
[ 0.849010] phy phy-ff800000.phy.9: Looking up phy-supply from device tree
[ 0.849015] phy phy-ff800000.phy.9: Looking up phy-supply property in node /phy@ff800000/usb3-port failed
[ 0.849550] rockchip-drm display-subsystem: defer getting devfreq
[ 0.850365] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 0.850375] mp8859 7-0066: set mp8859 out 12v ok
[ 0.851582] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008b251e8)
[ 0.852337] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 0.853048] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008b251e8)
[ 0.854119] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 0.854734] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.855517] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.858139] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008b19fd8)
[ 0.859325] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 0.860184] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 0.860994] rockchip-drm display-subsystem: bound fec00000.dp (ops 0xffffff8008b1aff8)
[ 0.861700] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.862279] [drm] No driver support for vblank timestamp query.
[ 0.918437] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 0.919349] vccio_sd: ramp_delay not set
[ 0.919378] rockchip-iodomain ff770000.syscon:io-domains: Setting to 1800000 done
[ 0.945830] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.154948] dwmmc_rockchip fe320000.dwmmc: Successfully tuned phase to 116
[ 1.154983] mmc0: new ultra high speed SDR50 SDXC card at address aaaa
[ 1.156534] mmcblk0: mmc0:aaaa SL128 119 GiB
[ 1.187805] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1280x720p50, type: 11
[ 1.190291] mmcblk0: p1 p2 p3 p4 p5
[ 1.221833] Freeing drm_logo memory: 616K
[ 1.298125] Console: switching to colour frame buffer device 160x45
[ 1.344925] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.352139] mali ff9a0000.gpu: Looking up mali-supply from device tree
[ 1.352448] mali ff9a0000.gpu: leakage=28
[ 1.352827] mali ff9a0000.gpu: Looking up mali-supply from device tree
[ 1.352850] vdd_gpu: could not add device link ff9a0000.gpu err -17
[ 1.352861] vdd_gpu: Failed to create debugfs directory
[ 1.366031] mali ff9a0000.gpu: temp=62500, pvtm=126167 (125915 + 252)
[ 1.370158] mali ff9a0000.gpu: pvtm-volt-sel=2
[ 1.371478] fusb302 7-0022: 0000 max vol cur 0 0
[ 1.371911] fusb302 7-0022: max vol cur 15000 3000
[ 1.372991] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 1.374146] mali ff9a0000.gpu: Protected mode not available
[ 1.376001] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.376743] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 1.377946] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 414; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 1.380826] mali ff9a0000.gpu: Probed as mali0
[ 1.387066] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 1.388055] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 1
[ 1.388890] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 1.389711] xhci-hcd xhci-hcd.10.auto: irq 232, io mem 0xfe800000
[ 1.390458] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.391060] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.391701] usb usb1: Product: xHCI Host Controller
[ 1.392131] usb usb1: Manufacturer: Linux 4.4.167 xhci-hcd
[ 1.392638] usb usb1: SerialNumber: xhci-hcd.10.auto
[ 1.393815] hub 1-0:1.0: USB hub found
[ 1.394173] hub 1-0:1.0: 1 port detected
[ 1.394784] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 1.395521] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 2
[ 1.396250] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.397049] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.397659] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.398293] usb usb2: Product: xHCI Host Controller
[ 1.398729] usb usb2: Manufacturer: Linux 4.4.167 xhci-hcd
[ 1.399215] usb usb2: SerialNumber: xhci-hcd.10.auto
[ 1.400342] hub 2-0:1.0: USB hub found
[ 1.400697] hub 2-0:1.0: 1 port detected
[ 1.402295] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 1.402801] usb usb2: USB disconnect, device number 1
[ 1.427577] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
[ 1.428241] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
[ 1.428961] xhci-hcd xhci-hcd.10.auto: USB bus 2 deregistered
[ 1.429838] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 1.430370] usb usb1: USB disconnect, device number 1
[ 1.431577] xhci-hcd xhci-hcd.10.auto: USB bus 1 deregistered
[ 1.489235] fusb302 7-0022: PD connected as UFP, fetching 5V
[ 1.570806] random: nonblocking pool is initialized
[ 1.590676] mp8859 7-0066: mp8859 get notify
[ 1.591081] mp8859 7-0066: mp8859 get ufp 1 dp 1
[ 1.594291] mp8859 7-0066: set mp8859 out 12v ok
[ 1.612701] phy phy-ff770000.syscon:usb2-phy@e450.3: charger = USB_DCP_CHARGER
[ 1.618631] rockchip-dwc3 usb0: USB peripheral connected
[ 1.621100] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.621978] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 1
[ 1.622923] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 1.623800] xhci-hcd xhci-hcd.11.auto: irq 233, io mem 0xfe900000
[ 1.624741] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.625382] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.626025] usb usb1: Product: xHCI Host Controller
[ 1.626488] usb usb1: Manufacturer: Linux 4.4.167 xhci-hcd
[ 1.626984] usb usb1: SerialNumber: xhci-hcd.11.auto
[ 1.628402] hub 1-0:1.0: USB hub found
[ 1.628789] hub 1-0:1.0: 1 port detected
[ 1.629715] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.630498] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 2
[ 1.631289] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.632203] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.632833] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.633489] usb usb2: Product: xHCI Host Controller
[ 1.633936] usb usb2: Manufacturer: Linux 4.4.167 xhci-hcd
[ 1.634446] usb usb2: SerialNumber: xhci-hcd.11.auto
[ 1.635803] hub 2-0:1.0: USB hub found
[ 1.636185] hub 2-0:1.0: 1 port detected
[ 1.637391] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 1.637875] usb usb2: USB disconnect, device number 1
[ 1.639216] xhci-hcd xhci-hcd.11.auto: USB bus 2 deregistered
[ 1.639979] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 1.640512] usb usb1: USB disconnect, device number 1
[ 1.641508] xhci-hcd xhci-hcd.11.auto: USB bus 1 deregistered
[ 1.644474] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.645544] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 1.646524] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 1.652383] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.653436] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.654055] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.654735] usb usb1: Product: EHCI Host Controller
[ 1.655186] usb usb1: Manufacturer: Linux 4.4.167 ehci_hcd
[ 1.655709] usb usb1: SerialNumber: fe380000.usb
[ 1.657643] hub 1-0:1.0: USB hub found
[ 1.658047] hub 1-0:1.0: 1 port detected
[ 1.664127] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.665640] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 1.666737] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.673404] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.674532] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.675153] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.675833] usb usb2: Product: EHCI Host Controller
[ 1.676284] usb usb2: Manufacturer: Linux 4.4.167 ehci_hcd
[ 1.676812] usb usb2: SerialNumber: fe3c0000.usb
[ 1.678534] hub 2-0:1.0: USB hub found
[ 1.678989] hub 2-0:1.0: 1 port detected
[ 1.681640] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.683223] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 1.684386] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 1.739842] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.740494] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.741144] usb usb3: Product: Generic Platform OHCI controller
[ 1.741709] usb usb3: Manufacturer: Linux 4.4.167 ohci_hcd
[ 1.742206] usb usb3: SerialNumber: fe3a0000.usb
[ 1.744296] hub 3-0:1.0: USB hub found
[ 1.744785] hub 3-0:1.0: 1 port detected
[ 1.747394] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.748779] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 1.749771] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.805808] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.806448] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.807103] usb usb4: Product: Generic Platform OHCI controller
[ 1.807653] usb usb4: Manufacturer: Linux 4.4.167 ohci_hcd
[ 1.808150] usb usb4: SerialNumber: fe3e0000.usb
[ 1.809975] hub 4-0:1.0: USB hub found
[ 1.810456] hub 4-0:1.0: 1 port detected
[ 1.812776] input: adc-keys as /devices/platform/adc-keys/input/input1
[ 1.816375] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.817112] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.817802] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.818399] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.819360] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[ 1.819389] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed
[ 1.819479] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.819507] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed
[ 1.819555] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.820145] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.820767] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
[ 1.820789] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
[ 1.820815] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe310000[0]'
[ 1.820838] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe310000[0]'
[ 1.820859] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
[ 1.820882] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[ 1.821478] platform sdio-pwrseq: GPIO lookup for consumer reset
[ 1.821500] platform sdio-pwrseq: using device tree for GPIO lookup
[ 1.821570] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0)
[ 1.821672] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.833516] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.845786] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 1.847530] rockchip-dmc dmc: Looking up center-supply from device tree
[ 1.848158] rockchip-dmc dmc: Failed to get leakage
[ 1.848749] rockchip-dmc dmc: Looking up center-supply from device tree
[ 1.848821] vdd_center: could not add device link dmc err -17
[ 1.848850] vdd_center: Failed to create debugfs directory
[ 1.848876] rockchip-dmc dmc: Failed to get pvtm
[ 1.850054] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 1.850703] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 1.851777] rockchip-dmc dmc: could not find power_model node
[ 1.853636] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]'
[ 1.853661] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]'
[ 1.854967] asoc-simple-card hdmi-sound: i2s-hifi <-> ff8a0000.i2s mapping ok
[ 1.860122] rockchip-cdndp-sound dp-sound: spdif-hifi <-> ff870000.spdif mapping ok
[ 1.861162] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to create Playback debugfs file
[ 1.861578] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 1.864629] input: rockchip-cdndp-sound DP Jack as /devices/platform/dp-sound/sound/card1/input2
[ 1.867774] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-keys/button@0[0]' - status (0)
[ 1.867875] gpio-5 (GPIO Key Power): gpiod_set_debounce: missing set() or set_debounce() operations
[ 1.868415] input: gpio-keys as /devices/platform/gpio-keys/input/input3
[ 1.869707] ==gsl_ts_init==
[ 1.870102] ret=0
[ 1.870892] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_edp-supply from device tree
[ 1.870925] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_edp-supply property in node /power-management@ff310000/power-controller failed
[ 1.871052] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_rga-supply from device tree
[ 1.871081] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_rga-supply property in node /power-management@ff310000/power-controller failed
[ 1.871184] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_iep-supply from device tree
[ 1.871213] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_iep-supply property in node /power-management@ff310000/power-controller failed
[ 1.872132] rk808-rtc rk808-rtc: setting system clock to 2019-08-20 05:04:41 UTC (1566277481)
[ 1.873473] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 1.911142] vcc_mipi: disabling
[ 1.911473] dvdd_1v2: disabling
[ 1.911801] ret 1024
[ 1.912404] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 1.912585] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp1-supply from device tree
[ 1.912605] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp1-supply property in node /power-management@ff310000/power-controller failed
[ 1.912750] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp0-supply from device tree
[ 1.912765] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp0-supply property in node /power-management@ff310000/power-controller failed
[ 1.912878] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopl-supply from device tree
[ 1.912892] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopl-supply property in node /power-management@ff310000/power-controller failed
[ 1.912995] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vdu-supply from device tree
[ 1.913008] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vdu-supply property in node /power-management@ff310000/power-controller failed
[ 1.913098] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vcodec-supply from device tree
[ 1.913111] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vcodec-supply property in node /power-management@ff310000/power-controller failed
[ 1.913224] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '14:46:49', on 'Jun 24 2019'.
[ 1.913956] Mali: Mali device driver loaded
[ 1.915333] rockchip-pinctrl pinctrl: unsupported driver strength 20
[ 1.915343] rockchip-pinctrl pinctrl: pin_config_set op failed for pin 122
[ 1.915352] usb-ext-charge usb-charge: Error applying setting, reverse things back
[ 1.915447] usb-ext-charge usb-charge: GPIO lookup for consumer charge-en
[ 1.915457] usb-ext-charge usb-charge: using device tree for GPIO lookup
[ 1.915505] of_get_named_gpiod_flags: parsed 'charge-en-gpios' property of node '/usb-charge[0]' - status (0)
[ 1.915546] usb-ext-charge usb-charge: GPIO lookup for consumer cur-ctl
[ 1.915554] usb-ext-charge usb-charge: using device tree for GPIO lookup
[ 1.915600] of_get_named_gpiod_flags: parsed 'cur-ctl-gpios' property of node '/usb-charge[0]' - status (0)
[ 1.915638] usb-ext-charge usb-charge: GPIO lookup for consumer poe-state
[ 1.915646] usb-ext-charge usb-charge: using device tree for GPIO lookup
[ 1.915689] of_get_named_gpiod_flags: parsed 'poe-state-gpios' property of node '/usb-charge[0]' - status (0)
[ 1.915717] usb-ext-charge usb-charge: GPIO lookup for consumer cap-led
[ 1.915725] usb-ext-charge usb-charge: using device tree for GPIO lookup
[ 1.915737] of_get_named_gpiod_flags: can't parse 'cap-led-gpios' property of node '/usb-charge[0]'
[ 1.915747] of_get_named_gpiod_flags: can't parse 'cap-led-gpio' property of node '/usb-charge[0]'
[ 1.915755] usb-ext-charge usb-charge: using lookup tables for GPIO lookup
[ 1.915765] usb-ext-charge usb-charge: lookup for GPIO cap-led failed
[ 1.915808] of_get_named_gpiod_flags: parsed 'bat-int' property of node '/usb-charge[0]' - status (0)
[ 1.916365] usb-ext-charge usb-charge: register ext0 dev0
[ 1.916378] usb-ext-charge usb-charge: uec get notify
[ 1.916390] usb-ext-charge usb-charge: uec get ufp 1 pd 1
[ 1.916402] usb-ext-charge usb-charge: usb status 2 battery_online 0 poe_online 0
[ 1.916424] usb-ext-charge usb-charge: probe success
[ 1.917233] ALSA device list:
[ 1.917239] #0: rockchip,hdmi
[ 1.917244] #1: rockchip-cdndp-sound
[ 1.961516] mmc_host mmc2: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[ 1.981410] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 2.096450] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101
[ 2.097136] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.097850] usb 2-1: Product: USB 2.0 Hub [MTT]
[ 2.100001] hub 2-1:1.0: USB hub found
[ 2.100625] hub 2-1:1.0: 4 ports detected
[ 2.180416] usb 3-1: new low-speed USB device number 2 using ohci-platform
[ 2.368424] usb 3-1: New USB device found, idVendor=03f0, idProduct=1198
[ 2.369030] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.369694] usb 3-1: Product: HP USB 1000dpi Laser Mouse
[ 2.370175] usb 3-1: Manufacturer: HP
[ 2.378583] usb 2-1.4: new low-speed USB device number 3 using ehci-platform
[ 2.380464] input: HP HP USB 1000dpi Laser Mouse as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.0/0003:03F0:1198.0001/input/input4
[ 2.432761] hid-generic 0003:03F0:1198.0001: input,hidraw0: USB HID v2.00 Mouse [HP HP USB 1000dpi Laser Mouse] on usb-fe3a0000.usb-1/input0
[ 2.433622] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 2.433676] VFS: Mounted root (ext4 filesystem) on device 179:5.
[ 2.441495] hid-generic 0003:03F0:1198.0002: hiddev0,hidraw1: USB HID v2.00 Device [HP HP USB 1000dpi Laser Mouse] on usb-fe3a0000.usb-1/input1
[ 2.443006] devtmpfs: mounted
[ 2.443742] Freeing unused kernel memory: 1088K
[ 2.473186] usb 2-1.4: New USB device found, idVendor=413c, idProduct=2003
[ 2.473853] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.474528] usb 2-1.4: Product: Dell USB Keyboard
[ 2.474955] usb 2-1.4: Manufacturer: Dell
[ 2.483595] input: Dell Dell USB Keyboard as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.4/2-1.4:1.0/0003:413C:2003.0003/input/input5
[ 2.536817] hid-generic 0003:413C:2003.0003: input,hidraw2: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-fe3c0000.usb-1.4/input0
[ 3.173508] cgroup: cgroup2: unknown option "nsdelegate"
[ 3.212676] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.216108] systemd[1]: Detected architecture arm64.
[ 3.242147] systemd[1]: Set hostname to <firefly>.
[ 3.793529] systemd[1]: File /lib/systemd/system/systemd-udevd.service:34 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.795101] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.835397] vendor storage:20160801 ret = -1
[ 3.885539] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 3.886273] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 4.460912] systemd[1]: Created slice User and Session Slice.
[ 4.462438] systemd[1]: Reached target Swap.
[ 4.463758] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.464992] systemd[1]: Reached target User and Group Name Lookups.
[ 4.466445] systemd[1]: Reached target Remote File Systems.
[ 4.468608] systemd[1]: Created slice System Slice.
[ 4.470922] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 4.529365] systemd[1]: Listening on udev Control Socket.
[ 4.530459] systemd[1]: Reached target Slices.
[ 4.531693] systemd[1]: Listening on udev Kernel Socket.
[ 4.533461] systemd[1]: Listening on Journal Socket.
[ 4.541024] systemd[1]: Starting Set the console keyboard layout...
[ 4.548672] systemd[1]: Mounting Kernel Debug File System...
[ 4.557857] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.584038] systemd[1]: Starting Load Kernel Modules...
[ 4.587185] systemd[1]: Listening on Syslog Socket.
[ 4.593616] systemd[1]: Starting udev Coldplug all Devices...
[ 4.595495] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.607084] systemd[1]: Starting Journal Service...
[ 4.611475] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 4.657090] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 4.661023] systemd[1]: Started Remount Root and Kernel File Systems.
[ 4.667967] systemd[1]: Started Load Kernel Modules.
[ 4.678653] systemd[1]: Mounting Kernel Configuration File System...
[ 4.686719] systemd[1]: Starting Apply Kernel Variables...
[ 4.691382] systemd[1]: Mounting FUSE Control File System...
[ 4.724005] systemd[1]: Starting Load/Save Random Seed...
[ 4.788360] systemd[1]: Started Load/Save Random Seed.
[ 4.804362] systemd[1]: Mounted Kernel Debug File System.
[ 4.805567] systemd[1]: Mounted Kernel Configuration File System.
[ 4.806872] systemd[1]: Mounted FUSE Control File System.
[ 4.813586] systemd[1]: Started Apply Kernel Variables.
[ 4.871852] systemd[1]: Started Create Static Device Nodes in /dev.
[ 4.874321] systemd[1]: Starting udev Kernel Device Manager...
[ 4.964237] systemd[1]: Started udev Coldplug all Devices.
[ 5.009674] systemd[1]: Started Set the console keyboard layout.
[ 5.010065] systemd[1]: Reached target Local File Systems (Pre).
[ 5.010234] systemd[1]: Reached target Local File Systems.
[ 5.012370] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[ 5.014529] systemd[1]: Starting Set console font and keymap...
[ 5.026214] systemd[1]: Started Journal Service.
[ 5.056693] systemd-journald[193]: Received request to flush runtime journal from PID 1
[ 5.935477] usb-ext-charge usb-charge: adc value = 3
[ 5.935498] usb-ext-charge usb-charge: usb status 2 battery_online 1 poe_online 0
[ 6.096806] MWEcoCapture: loading out-of-tree module taints kernel.
[ 6.098888] Eco Capture 0000:01:00.0: enabling device (0000 -> 0002)
[ 6.646352] Eco Capture: V4L2 device registered as video8
[ 7.011929] cfg80211: World regulatory domain updated:
[ 7.011955] cfg80211: DFS Master region: unset
[ 7.011965] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 7.011981] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.011997] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 7.012011] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.012026] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 7.012041] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 7.012056] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 7.012069] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.012116] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 7.964395] [BT_RFKILL]: ENABLE UART_RTS
[ 8.074112] [BT_RFKILL]: DISABLE UART_RTS
[ 8.074263] [BT_RFKILL]: bt turn on power
[ 8.939360] file system registered
[ 8.950629] ttyS0 - failed to request DMA, use interrupt mode
[ 9.388430] read descriptors
[ 9.388457] read strings
[ 10.087824] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.914217] tty_port_close_start: tty->count = 1 port count = 2.
[ 13.369743] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 13.369777] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 40.007465] usb-ext-charge usb-charge: adc value = 4
[ 40.007497] usb-ext-charge usb-charge: usb status 2 battery_online 0 poe_online 0
