LVDS Issues
Hello,
I have been trying to make LVDS work on AIO-3399J, but am having some issues. I tried two different displays, but they both look basically the same. I have spent many hours tweaking the code, but I can only get one result. See the attached photos. https://drive.google.com/open?id=1j6VzW2AcwWksnySQuTr3bapcqz07em2N
I made sure to correctly set the color formats in the device tree file and I have correctly set the INIT code for the MIPI DSI to LVDS bridge.
Both displays have been tested and are good, the cable has also been tested and verified to be good.
The coloration is very strange. I opened a photo which displays color bars, and it looks ok when looking at the display straight on. When looking at an angle, you can see a bunch of weird spots. But, if you look at the app icons, the coloration is very grainy and messed up.
Any ideas?
You can try to invert
 pixelclk-active = <0>;
in display-timings, or try to change some LVDS related properties, such as dsi,lvds-force-clk.
Thank you for the brilliant share, it really left me in awe! Minimum C_BCBDC_2505 pass score delivers top-quality content, completely free to you.
時には、進める小さなステップは人生の中での大きなステップとするかもしれません。ITILのITIL-4-Transition-JPN試験は小さな試験だけでなく、あなたの職業生涯に重要な影響を及ぼすことができます。これはあなたの能力を認めます。ITILのITIL-4-Transition-JPN試験のほかの認証試験も大切なのです。それに、これらの資料は我々Fast2testのウェブサイトで見つけることができます。
What an outstanding article, I truly appreciate you sharing it. Hope I perform well in the Pass AZ-700 test exam – wish me luck!
