[SOLVED] kernel compilation
Please excuse my English.
Please tell me why the changes made with make menuconfig, I use the file
kernel/arch/arm64/configs/firefly_roc-rk3399-pc_defconfig
are not applied when compiling? I enabled iptables and Bond support to use Docker, but no bond support was added to the system after the image was recreated. What could I have done wrong ?
I receive the following error message:
level=warning msg="Running modprobe bridge br_netfilter failed with message: modprobe: WARNING: Module bridge not found in directory /lib/modules/4.4
level=warning msg="Running modprobe xt_conntrack failed with message: `modprobe: WARNING: Module xt_conntrack not found in directory /lib/modules/4.4
level=warning msg="Could not load necessary modules for Conntrack: Running modprobe nf_conntrack_netlink failed with message: `modprobe: WARNING: Mod
Also it is unclear to me why after self-Assembly of an image there is no directory with modules (/lib/modules)
Pass4Test 의 Splunk인증 SPLK-4001시험에 도전장을 던지셨나요? 현황에 만족하지 않고 열심히 하는 모습에 박수를 보내드립니다. Splunk인증 SPLK-4001시험을 학원등록하지 않고 많은 공부자료 필요없이Pass4Test 에서 제공해드리는 Splunk인증 SPLK-4001덤프만으로도 가능합니다. 수많은 분들이 검증한Splunk인증 SPLK-4001덤프는 시장에서 가장 최신버전입니다.가격도 친근하구요.
