I downloaded the October updates:
Ubuntu fails on apt update. All versions.
Android 8.1 has no network access even with linksys USB wifi dongle.
ROC-RK3399-PC_Industry7.1.2_HDMI_191026 wont boot.
last attempt to update last ubuntu release.
firefly@firefly:~$ sudo apt update
Hit:1 http://wiki.t-firefly.com/firefly-rk3399-repo bionic InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
Hit:3 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease
Hit:4 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease
Hit:5 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease
Hit:6 http://archive.canonical.com/ubuntu bionic InRelease
Reading package lists… Done
Building dependency tree
251 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
firefly@firefly:~$ sudo apt upgrade
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
libgles2 : Depends: libglvnd0 (= 1.0.0-2ubuntu2.2) but 1.0.0-2ubuntu2.3 is installed
libgstreamer-gl1.0-0 : Depends: libgstreamer1.0-0 (>= 1.14.5) but 1.14.4-1firefly1 is installed
libwebkit2gtk-4.0-37 : Depends: libjavascriptcoregtk-4.0-18 (= 2.26.2-0ubuntu0.18.04.1) but 2.22.5-0ubuntu0.18.04.1 is installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
firefly@firefly:~$ sudo apt --fix-broken install
Correcting dependencies… Done
The following additional packages will be installed:
gir1.2-gstreamer-1.0 libgles2 libgstreamer1.0-0 libgstreamer1.0-dev
The following packages will be upgraded:
5 upgraded, 0 newly installed, 0 to remove and 246 not upgraded.
141 not fully installed or removed.
Need to get 0 B/8946 kB of archives.
After this operation, 2132 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database … 102989 files and directories currently installed.)
Preparing to unpack …/libgles2_1.0.0-2ubuntu2.3_arm64.deb …
Unpacking libgles2:arm64 (1.0.0-2ubuntu2.3) over (1.0.0-2ubuntu2.2) …
dpkg: error processing archive /var/cache/apt/archives/libgles2_1.0.0-2ubuntu2.3_arm64.deb (–unpack):
trying to overwrite ‘/usr/lib/aarch64-linux-gnu/libGLESv2.so.2.0.0’, which is also in package rockchip-mali-midgard14 1.6-1
E: Sub-process /usr/bin/dpkg returned an error code (1)
firefly@firefly:~$
We have to lock up the gstreamer version to match the Rockchip upstream modification.
We do not recommend a ‘apt-get upgrade’ here.
I did get the update to work but gpu still very slow.
Gott will, dass ich eine Person mit Fähigkeit, statt eine gute aussehende Puppe zu werden. Wenn ich IT-Branche wähle, habe ich dem Gott meine Fähigkeiten bewiesen. Aber der Gott ist mit nichts zufrieden. Er hat mich gezwungen, nach oben zu gehen. Die Splunk SPLK-5001 Zertifizierungsprüfung ist eine große Herausforderung in meinem Leben. So habe ich sehr hart gelernt. Aber das macht doch nichts, weil ich ZertPruefung die Fragenkataloge zur Splunk SPLK-5001 Zertifizierung gekauft habe. Mit ihr kann ich sicher die die Splunk SPLK-5001 Prüfung bestehen. Der Weg ist unter unseren Füßen, nur Sie können ihre Richtung entscheiden. Mit den Prüfungsmaterialien zur Splunk SPLK-5001 Prüfung von ZertPruefung können Sie sicher eine bessere Zukunft haben.
I appreciate your article, it really gave me a new perspective. Get the free C_THR82_2505 official practice test exam materials now—your key to career advancement and salary increase!
I’m simply in awe of your article, thank you for sharing such brilliance! Valid DevOps-SRE test notes questions shared for free—unlock promotions and salary increases!
This article is so powerful, thank you for the inspiration! Boost your IT skills and enjoy free Test 3V0-21.25 cram pdf. Best of luck to you!
