rkisp1: MIPI mis error
Hi I’m using a custom MIPI Adapter board in Firefly AIO3399J board running Android 8.1 . I’m facing MIPI mis error and its causing issues with the camera streaming.
The following MIPI mis errors are occuring at different instances.
rkisp1: MIPI mis error: 0x00000004
rkisp1: MIPI mis error: 0x00000006
rkisp1: MIPI mis error: 0x00000001
rkisp1: MIPI mis error: 0x00000300
How to diagonise these errors ? Can you help us find what each of this MIPI mis error means ?
Thanks,
Arvind
See kernel/drivers/media/platform/rockchip/isp1/regs.h
and rkisp1_mipi_isr() in kernel/drivers/media/platform/rockchip/isp1/rkisp1.c
Yes, I have seen them but knowing which registers are set , do not offer much information on the exact reasons for the issue. Can you share the RK3399 MIPI CSI2 datasheet so we can find what these registers are and why they are set.
Right now the registers that are set for my issue seems to be
CIF_MIPI_SYNC_FIFO_OVFLW for the MIPI mis error 0x00000006 , 0x00000004 and 0x00000001
CIF_MIPI_ERR_SOT_SYNC for the MIPI mis error 0x00000300
If you can tell me what these registers are and in which cases they are set , it would be really helpful.
Thank you for your time ,
Regards,
Arvind
I haven’t those register datasheet neither. This is a trial and error process.
Please make sure the frame format is correctly set.
penguin Posted at 12/12/2019 17:55
Please make sure the …
hi buddy ,have you resolved? i met the problem same as yours
Was Wir Ihnen bieten sind, die neuesten und die umfassendesten Test-Bank von CompTIA 220-1202, die risikolose Kaufgarantie und die rechtzeitige Aktualisierung der CompTIA 220-1202. Sie werden sich beim Kauf unbesorgt fühlen, indem Sie die Demo unserer Software kostenlos zu probieren. Die einjährige kostenfreie Aktualisierung der CompTIA 220-1202 erleichtern Ihre Sorgen bei der Prüfungsvorbereitung. Was wir am meisten garantieren ist, dass unsere Software vielen Prüfungsteilnehmern bei der Zertifizierung der CompTIA 220-1202 geholfen hat.
No second guesses, this content gets my like. The Exam PEGACPBA24V1 Questions material is outstanding, and it’s free for you to use.
ここで説明したいのはMogiExamにあるコアバリューです。全てのIIBAのCPOA「Certificate in Product Ownership Analysis (IIBA-CPOA)」試験は非常に大切ですが、この情報技術が急速に発展している時代に、MogiExamはただその中の一つだけです。ではなぜほとんどの人々はMogiExamを選んだのですか。それはMogiExamが提供する問題資料は絶対あなたが試験に受かることを助けられるからです。MogiExamが提供する資料は最新のトレーニングツールが常にアップデートして認証試験の目標を変換するの結果です。MogiExam はあなたに最新の試験研究資料を提供しますから、MogiExam IIBAのCPOA問題集を持っていたら、試験に直面する自信に満ちることができ、合格しないなんて全然心配することはなく気楽に試験に受かることができます。
I’m so grateful for your article, it truly grabbed my attention. PDF C-S4CS-2508 Download exam papers are free for everyone! Best of luck on your exams!
I am so grateful for your share, this article is truly impressive! Get the Valid exam CKYCA sample online questions that helped me succeed in my career—for free today!
やってみて購入します。我々Jpshikenはすべてのお客様に責任を持っています。我々はあなたにHuaweiのH20-923_V1.0試験ソフトのデモを無料で提供しています。あなたは体験してから安心で購入できます。われわれはあなたが弊社のHuaweiのH20-923_V1.0試験ソフトを購入して満足することに自信を持っています。利用してからあなたも弊社のHuaweiのH20-923_V1.0試験ソフトに自信を持っています。あなたは自信満々にHuaweiのH20-923_V1.0試験に参加することができます。
