Hi Friends I need your help in choosing the right OS.
Few days back I come to know about the Firefly boards and I’m very excited to use it in all my future IoT related projects. So I have selected RK3288 and RK3399 based board. Right now I’m using RaspberryPI board for my projects and I use Python and Nodejs for our app development.
In next my project I’m going to do the following things:
  1. Collect data from different sensor at remote location and send it to the server via wifi/4g.
  • Here I want to use any Linux OS which would be without GUI(desktop) and boot very fast ?
  1. Collect, process, display data it to the display screen then take some action.
  • Here I want Linux OS with GUI(desktop) ?
  1. Also in some project I need YOCTO and QT.
Friends I need your suggestion for the above three scenario?
Hi:
Do you need to use different hardware platforms in scenarios 1 and 2?
  1. Both RK3288 and RK3399 are ok for this scenario. but you need to care about the interface and number of your sensors.
  2. Both RK3288 and RK3399 are ok , use ubuntu or buildroot+Qt or Yocto+Qt.
  3. OK
@penguin: Thanks you so much for your expert advice and prompt reply. I have gone through some videos and screen shoot there I have seen Firefly is using customized ubuntu and also have Desktop GUI.
Is there any version where Desktop GUI is not available?
And what is the boot time for both the boards using Ubuntu v18?
This article gave me new motivation, thank you for sharing! Ready for the Latest C_THR92_2505 exam simulator exam? Wishing myself all the best!
Thank you for your article, it left an unforgettable impression on me. Here’s the CCAAK exam demo test material for free. Best of luck in your exams!
IT업계에 종사하시는 분은 국제공인 IT인증자격증 취득이 얼마나 힘든지 알고 계실것입니다. 특히 시험이 영어로 되어있어 부담을 느끼시는 분도 계시는데 DumpTOP를 알게 된 이상 이런 고민은 버리셔도 됩니다. DumpTOP의SAP C_TS422_2504덤프는 모두 영어버전으로 되어있어SAP C_TS422_2504시험의 가장 최근 기출문제를 분석하여 정답까지 작성해두었기에 문제와 답만 외우시면 시험합격가능합니다.
Your article is exceptional, thank you for sharing it with us! The free content in C_OCM_2503 valid exam duration is meant to help guide you through your studies.
