Kernel crash on large file operations
Hi all!
I have some weird bug with Firefly-RK3399 board: kernel suddenly crashes on large file operations (starting from 300Mb). I had this with different kernels (both Rockchip and mainline), so it seems to be hardware problem. In some cases starting infinite loop calling sync command together with main operation can delay or even prevent crash (depends on operation and delay between syncs) but i don’t think keeping it running during all session is a good idea. Can it be fixed somehow?
I attach kernel log with modelled operation (1.6Gb was written before crash):
dd if=/dev/zero of=test bs=1G count=3
[  119.555187] SError Interrupt on CPU1, code 0xbf000000 -- SError
[  119.555189] CPU: 1 PID: 20401 Comm: dd Not tainted 5.4.5-1-ARTIX #1
[  119.555191] Hardware name: Firefly-RK3399 Board (DT)
[  119.555192] pstate: 20000005 (nzCv daif -PAN -UAO)
[  119.555193] pc : __arch_copy_from_user+0x1bc/0x240
[  119.555194] lr : copyin+0x90/0xa0
[  119.555196] sp : ffff80001985bb20
[  119.555196] x29: ffff80001985bb20 x28: 0000000000000000
[  119.555199] x27: 0000000000001000 x26: ffff800010f5f350
[  119.555202] x25: 0000000000000000 x24: ffff80001985bd50
[  119.555204] x23: ffff80001985bd40 x22: 0000000000000000
[  119.555207] x21: 0000000000001000 x20: ffff000009c01000
[  119.555209] x19: 0000000000001000 x18: 0000000000000014
[  119.555212] x17: 00000000f9f64b4b x16: 000000004c3a51cb
[  119.555214] x15: 000000007aeec261 x14: 0000000000000000
[  119.555217] x13: 0000000000000000 x12: 0000000000000000
[  119.555219] x11: 0000000000000000 x10: 0000000000000000
[  119.555221] x9 : 0000000000000000 x8 : 0000000000000000
[  119.555224] x7 : 0000000000000000 x6 : ffff000009c00050
[  119.555226] x5 : ffff000009c01000 x4 : 0000000000000000
[  119.555229] x3 : 0000ffff8419d000 x2 : 0000000000000f40
[  119.555231] x1 : 0000ffff8419d090 x0 : ffff000009c00000
[  119.555234] Kernel panic - not syncing: Asynchronous SError Interrupt
[  119.555236] CPU: 1 PID: 20401 Comm: dd Not tainted 5.4.5-1-ARTIX #1
[  119.555237] Hardware name: Firefly-RK3399 Board (DT)
[  119.555238] Call trace:
[  119.555239]  dump_backtrace+0x0/0x170
[  119.555240]  show_stack+0x24/0x30
[  119.555241]  dump_stack+0xac/0xd0
[  119.555242]  panic+0x144/0x31c
[  119.555243]  __stack_chk_fail+0x0/0x28
[  119.555244]  arm64_serror_panic+0x84/0x90
[  119.555245]  do_serror+0x11c/0x120
[  119.555246]  el1_error+0x84/0xf8
[  119.555248]  __arch_copy_from_user+0x1bc/0x240
[  119.555249]  iov_iter_copy_from_user_atomic+0xec/0x370
[  119.555250]  generic_perform_write+0xf0/0x1d0
[  119.555251]  __generic_file_write_iter+0x134/0x1b8
[  119.555252]  ext4_file_write_iter+0xd0/0x338
[  119.555253]  new_sync_write+0xf8/0x190
[  119.555254]  __vfs_write+0x74/0x90
[  119.555255]  vfs_write+0xe4/0x1c8
[  119.555257]  ksys_write+0x78/0x100
[  119.555257]  __arm64_sys_write+0x24/0x30
[  119.555259]  el0_svc_handler+0x84/0x190
[  119.555260]  el0_svc+0x8/0xc
[  119.555280] SMP: stopping secondary CPUs
[  119.555280] Kernel Offset: disabled
[  119.555282] CPU features: 0x0002,20006008
[  119.555283] Memory Limit: none
The problem seems to have gone after i switched u-boot from slarm build to mainline. Looks weird but the same command worked correctly after this change
I’m giving this a like without a second thought. The CMMC-CCA exam simulator fee questions helped me earn a promotion and raise, and today I’m sharing them with you for free!
I’m deeply grateful for your article, it was truly eye-opening. I’m offering the C-BW4H-2505 latest study questions sheet exam that played a role in my career advancement. It’s free for you today
The viewpoints in the article have been very beneficial to my work. The D-PST-DY-23 Printable PDF helped me land a promotion and salary boost. Now it’s free for all. Wishing you success in your career!
