I recently updated my firefly rk3399 board with android 7 industry version , it is stuck at boot logo not booting, but i am able to put the device in loader mode and mask rom mode, and the device can also be flashed after flash the board is not booting can any one please help me
Lewis-H Posted at 2/6/2020 17:54
Test with other usb in pc. In the box you are in blue usb ? Right.
you can test with rockchip batch …
After flashing from rockchip batch tool 1.8, the board will first display firefly image then its gets in to android erasing screen, after that again its stuck at firefly logo,
Industrial version of Android 7.1 has to be flashed using tools from Industrial Android SDK.
I use Linux_Upgrade_Tool_v1.43.zip in Linux and only this version worked for me.
Your article is so inspiring, thank you for sharing! The comprehensive content in CWSP-208 reliable test tips is offered free, hoping it helps your progress.
This article is truly eye-opening, thank you for sharing. The Excellect 401 pass rate material is top-notch, and I hope it assists you, with no cost involved.
만약 아직도 우리를 선택할지에 대하여 망설이고 있다면. 우선은 우리 사이트에서 Itcertkr가 제공하는 무료인 일부 문제와 답을 다운하여 체험해보시고 결정을 내리시길 바랍니다.그러면 우리의 덤프에 믿음이;갈 것이고,우리 또한 우리의 문제와 답들은 무조건 100%통과 율로 아주 고득점으로Salesforce인증Salesforce-Data-Cloud험을 패스하실 수 있습니다,
Your article was truly inspiring, thank you for sharing it with me. Examcode materials are available free of charge. Best of luck to everyone! C-THR94-2505 reliable test dumps questions
I’m giving this a like without even thinking twice. We’re providing Latest AP-215 exam name, filled with valuable content, for free to support you.
Your article was incredibly insightful, and I’m truly thankful for it. Here are the Detailed C_BCBAI_2502 study plan materials, free of charge—best of luck!
