I want to use an 800x480p LCD with the hdmi interface of core-rk3328-jd4.
The LCD is odroid-c2 compatible.
In aio-3288j, the value of /sys/class/display/HDMI/modes is ‘auto’ and the mode value is recognized as ‘1280x720p-60’ but only 800x480 is displayed on the screen.
core-rk3328-jd4 does not recognize it, and nothing appears on the screen.
How can I use this LCD with core-rk3328-jd4?
Added pixel-rate of 800x480 LCD to ‘kernel/driver/phy/rockchip/phy-rockchip-inno-hdmi-phy.c’.
Add ‘{ 29230000, 29230000, 1, 90, 2, 2, 2, 12, 2, 2, 2, 0, 0},’ to the pre_pll_config list, the screen will appear on the 800x400 LCD.
What does each pre_pll_config item (pixclock, tmdsclock, prediv, fbdiv, tmds_div_a, …, pclk_div_a, …) mean?
Is the problem caused by incorrect pre_pll_config item values?
Your article is exceptional, thank you for sharing it with us! The Valid dumps DCPLA ppt exam questions are available for free. Wishing you the best in your exams!
