Can't recognize USB device after build new imag
Hello,
I am using FireFly-RK3399 Board for Android7.1
I made image and updated to board. It can boot and can see on EDP lcd.
But when I connect to my PC, PC doesn’t recognize USB device.
Here is what I have done…
  1. I followed this wiki page (Build Android7.1)
    http://wiki.t-firefly.com/en/Firefly-RK3399/compile_android7.1_firmware.html
    My computer : Ubuntu14. 8G RAM. 300GB disk space
  2. Installed OpenJDK8
    Done Ubunt13.10/14.04 packages install
    Installed ARM cross compiling toolchain
  3. Downloaded Android7.1SDK and Bundle
  4. Unzip and git stuff (git reset --hard, git rebase FETCH_HEAD)
  5. Executed these
    export JAVA_HOME=/usr/lib/jvm/java-8-openjdk-amd64
    export PATH=$JAVA_HOME/bin:$PATH
    export CLASSPATH=.:$JAVA_HOME/lib:$JAVA_HOME/lib/tools.jar
  6. And I have 8GB RAM, Not 16GB RAM. So excuted these too.
    export JACK_SERVER_VM_ARGUMENTS=“.-Dfile.encoding=UTF-8 -XX:+TieredCompilation -Xmx:4096m”
    out/host/linux-x86/bin/jack-admin kill-server
    out/host/linux-x86/bin/jack-admin start-server
  7. I have EDP LCD. So I did… “Compile EDP7.85”
    ./FFTools/make.sh -j8 -d rk3399-firefly-edp -l rk3399_firefly_edp_box-userdebug
    ./FFTools/mkupdate/mkupdate.sh -l rk3399_firefly_edp_box-userdebug
  8. Successfully made image.
  9. And updated image using AndroidTool
    rockdev/Firefly-RK3399_Android7.1.2_EDP785_200402.img
  10. Successfully updated. And can see Android launcher in EDP LCD
  11. And I connected USB to Computer. But Computer(Windows, Ubuntu14) can not recognize device.
    In device manager, just can see “USB Composite Device”
What did I miss ??
NewDumps已經獲得了很多認證行業的聲譽,因為我們有很多的Microsoft的AZ-500考古題,AZ-500學習指南,AZ-500考古題,AZ-500考題答案,目前在網站上作為最專業的IT認證測試供應商,我們提供完善的售後服務,我們給所有的客戶買的跟蹤服務,在你購買的一年,享受免費的升級試題服務,如果在這期間,認證測試中心Microsoft的AZ-500試題顯示修改或者別的,我們會提供免費為客戶保護,顯示Microsoft的AZ-500考試認證是由我們NewDumps的IT產品專家精心打造,有了NewDumps的Microsoft的AZ-500考試資料,相信你的明天會更好。
当社Jpexamは、お客様に信頼できる学習プラットフォームを提供できることを嬉しく思います。 GREMクイズトレントは、急速な発展の世界のさまざまな分野の多くの専門家や教授によって設計されました。同時に、GREM試験問題集に質問がある場合は、プロの個人が短時間であなたの質問に答えることができます。つまり、GREMクイズ準備を購入することを選択した場合、当社が提供する権威ある学習プラットフォームを楽しむことができます。最新のGREM試験トレントが最適な選択になると確信しています。さらに重要なことは、最新のGREM試験トレントのデモを無料で入手できることです。
Great stuff, I’m liking this without question. Free 350-701 trustworthy exam content exam questions to help you prepare. Best wishes for success!
Your article was such a breath of fresh air, thank you! This Valid practice questions CTS-I files helped me get promoted and enjoy a salary raise. Now it’s available to you for free. Hope you all advance soon!
Thank you for sharing this inspiring piece of writing! You can access Reliable XDR-Analyst exam collection materials for free, filled with rich content to assist your learning.
人々は常に、特定の分野で有能で熟練していることを証明したいと考えています。能力を証明する方法はさまざまですが、最も直接的で便利な方法は、NCP-EUC認定試験に参加し、認定証を取得することです。 NCP-EUC認定に合格すると、非常に有能で優秀であることを証明できます。また、NCP-EUCテストに合格することで有用な知識とスキルを習得できます。 NCP-EUCガイドトレントを購入すると、Fast2testのNCP-EUC試験に合格するのに役立ちます。時間と労力はほとんどかかりません。
