[Firefly-RK3399] system is stuck at logo(blur image) not booting up
Hi,
I have flashed Android 7 image on to the Firefly-RK3399 board. System once booted up normally. But after few boot cycles, system is stuck and not booting up.
Please refer the serial console logs attached below.
U-Boot 2017.02-RK3399-06 (Jun 16 2020 - 15:11:29)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 666000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
can’t find dts node for fixed
pmic:rk808
can’t find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=900000,pwm_value=16
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 666000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2020-06-16#1.09
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
failed to find panel driver
no fuel gauge found
can’t find dts node for deviceinfo
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 0x0@0-0
[EDID-EXTEND] It is a CEA 861 Series Extension.
no baseparametr,find best edid mode,vic=16
hdmi_dev->video.vic is 16
rk lcdc - 0 dclk set: dclk = 148500000HZ, pll select = 0, div = 1
rockchip_panel_prepare: failed to find panel prepare funcs
hdmi_dev_config_video vic 16 color_output 3 color_output_depth 8
pixel clk is 148500000 tmds clk is 148500000
hsync_pol 1 vsync_pol 1
[HDMI] sucess output HDMI.
PHY PLL not locked: PCLK_ON=1,TMDSCLK_ON=1
rockchip_panel_enable: failed to find panel prepare funcs
failed to display kernel logo
checkKey
vbus = 1
got recovery cmd from misc.
load fdt from resouce.
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel @ 0x00280000 (0x01238008)
ramdisk @ 0x04bf0000 (0x007b21c4)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000004600000, end 0000000004615675 … OK
Add bank:000000000a200000, 0000000075e00000
[ 0.000000] Linux version 4.4.103 (kannan@kannan) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Tue Jun 16 15:17:36 IST 2020
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eefe000 s45504 r8192 d32320 u86016
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x00010000@0x00010000(kernel),0x00010000@0x00020000(boot),0x00010000@0x00030000(recovery),0x00038000@0x00040000(backup),0x00040000@0x00078000(cache),0x00400000@0x000B8000(system),0x00008000@0x004B8000(metadata),0x00002000@0x004C0000(baseparamer),-@0x004C2000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2020-06-16_15:11:29 hdmi.vic=-1 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0x7eeb5000-0x7eef5000] (0MB) mapped at [ffffffc07eeb5000-ffffffc07eef4fff]
[ 0.000000] Memory: 1981276K/2064384K available (10878K kernel code, 1632K rwdata, 5272K rodata, 832K init, 1075K bss, 66724K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009050000 - 0xffffff8009120000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b20000 ( 10880 KB)
[ 0.000000] .rodata : 0xffffff8008b20000 - 0xffffff8009050000 ( 5312 KB)
[ 0.000000] .data : 0xffffff8009120000 - 0xffffff80092b8008 ( 1633 KB)
[ 0.009976] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.021258] pid_max: default: 32768 minimum: 301
[ 0.026417] Security Framework initialized
[ 0.030922] SELinux: Initializing.
[ 0.034836] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.042203] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.050814] Initializing cgroup subsys freezer
[ 0.055712] Initializing cgroup subsys debug
[ 0.061329] sched-energy: Sched-energy-costs installed from DT
[ 0.067753] CPU0: update cpu_capacity 401
[ 0.072211] ASID allocator initialised with 65536 entries
[ 0.095019] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.105122] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 1.130008] CPU1: failed to come online
[ 1.134234] CPU1: failed in unknown state : 0x0
[ 1.149371] Detected VIPT I-cache on CPU2
[ 1.149404] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 1.149439] CPU2: using LPI pending table @0x000000007c010000
[ 1.149483] CPU2: update cpu_capacity 401
[ 1.149486] CPU2: Booted secondary processor [410fd034]
[ 1.159394] Detected VIPT I-cache on CPU3
[ 1.159413] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 1.159445] CPU3: using LPI pending table @0x000000007c050000
[ 1.159473] CPU3: update cpu_capacity 401
[ 1.159476] CPU3: Booted secondary processor [410fd034]
[ 1.169438] Detected PIPT I-cache on CPU4
[ 1.169465] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 1.169506] CPU4: using LPI pending table @0x000000007c090000
[ 1.169547] CPU4: update cpu_capacity 1024
[ 1.169551] CPU4: Booted secondary processor [410fd082]
[ 1.179459] Detected PIPT I-cache on CPU5
[ 1.179477] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 1.179514] CPU5: using LPI pending table @0x000000007c0d0000
[ 1.179542] CPU5: update cpu_capacity 1024
[ 1.179545] CPU5: Booted secondary processor [410fd082]
[ 1.179629] Brought up 5 CPUs
[ 1.294359] SMP: Total of 5 processors activated.
[ 1.299529] CPU features: detected feature: GIC system register CPU interface
[ 1.307372] CPU: All CPU(s) started at EL2
[ 1.311905] alternatives: patching kernel code
[ 1.319217] devtmpfs: initialized
[ 1.336655] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 1.347397] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 1.354996] pinctrl core: initialized pinctrl subsystem
[ 1.362258] Failed to find legacy iommu devices
[ 1.367623] NET: Registered protocol family 16
[ 1.372870] schedtune: init normalization constants…
[ 1.378530] schedtune: CLUSTER[0,2-3] min_pwr: 56 max_pwr: 222
[ 1.385714] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 1.392896] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 1.400075] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 1.407255] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 1.414436] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 1.421616] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 1.428795] schedtune: SYSTEM min_pwr: 121 max_pwr: 4212
[ 1.435975] schedtune: using normalization constants mul: 5249288 sh1: 1 sh2: 11
[ 1.444107] schedtune: verify normalization constants…
[ 1.449954] schedtune: max_pwr/2^0: 4091 => norm_pwr: 1024
[ 1.456081] schedtune: max_pwr/2^1: 2045 => norm_pwr: 511
[ 1.462211] schedtune: max_pwr/2^2: 1022 => norm_pwr: 255
[ 1.468339] schedtune: max_pwr/2^3: 511 => norm_pwr: 127
[ 1.474467] schedtune: max_pwr/2^4: 255 => norm_pwr: 63
[ 1.480595] schedtune: max_pwr/2^5: 127 => norm_pwr: 31
[ 1.486722] schedtune: configured to support 5 boost groups
[ 1.512891] cpuidle: using governor ladder
[ 1.540773] cpuidle: using governor menu
[ 1.545113] Registered FIQ tty driver
[ 1.549467] vdso: 2 pages (1 code @ ffffff8008b26000, 1 data @ ffffff8009124000)
[ 1.557642] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 1.565819] DMA: preallocated 256 KiB pool for atomic allocations
[ 1.591494] console [pstore0] enabled
[ 1.595697] pstore: Registered ramoops as persistent store backend
[ 1.602503] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[[ 1.610824] console [ttyFIQ0] enabled
[[ 1.618513] bootconsole [uart0] disabled
[ 1.626899] Registered fiq debugger ttyFIQ0
[ 1.664583] Rockchip hdmi driver version 2.0
[ 1.665849] vcc3v3_sys: supplied by vcc_sys
[ 1.666533] iommu: Adding device ff650000.vpu_service to group 0
[ 1.666603] iommu: Adding device ff660000.rkvdec to group 1
[ 1.666669] iommu: Adding device ff670000.iep to group 2
[ 1.666759] iommu: Adding device ff8f0000.vop to group 3
[ 1.666892] iommu: Adding device ff900000.vop to group 4
[ 1.666995] iommu: Adding device ff910000.isp to group 5
[ 1.667069] iommu: Adding device ff920000.isp to group 6
[ 1.667733] rk_iommu ff670800.iommu: can’t get aclk
[ 1.667749] rk_iommu ff670800.iommu: can’t get hclk
[ 1.668581] SCSI subsystem initialized
[ 1.668750] usbcore: registered new interface driver usbfs
[ 1.668795] usbcore: registered new interface driver hub
[ 1.668877] usbcore: registered new device driver usb
[ 1.669216] media: Linux media interface: v0.10
[ 1.669264] Linux video capture interface: v2.00
[ 1.669394] pps_core: LinuxPPS API ver. 1 registered
[ 1.669404] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.669429] PTP clock support registered
[ 1.670871] Advanced Linux Sound Architecture Driver Initialized.
[ 1.671352] Bluetooth: Core ver 2.21
[ 1.671386] NET: Registered protocol family 31
[ 1.671397] Bluetooth: HCI device and connection manager initialized
[ 1.671414] Bluetooth: HCI socket layer initialized
[ 1.671428] Bluetooth: L2CAP socket layer initialized
[ 1.671459] Bluetooth: SCO socket layer initialized
[ 1.672475] rockchip-cpuinfo cpuinfo: Serial : 22f277de3415e9ca
[ 1.672936] clocksource: Switched to clocksource arch_sys_counter
[ 1.715586] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 1.715821] NET: Registered protocol family 2
[ 1.716235] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 1.716356] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 1.716481] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.716560] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 1.716589] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 1.716744] NET: Registered protocol family 1
[ 1.717223] Trying to unpack rootfs image as initramfs…
[ 2.057228] Freeing initrd memory: 7880K
[ 2.057754] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 2.057847] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 2.060540] audit: initializing netlink subsys (disabled)
[ 2.060598] audit: type=2000 audit(1.943:1): initialized
[ 2.065689] VFS: Disk quotas dquot_6.6.0
[ 2.065813] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.066851] Registering sdcardfs 0.1
[ 2.067441] fuse init (API version 7.23)
[ 2.068515]
[ 2.068515] TEE Core Framework initialization (ver 1:0.1)
[ 2.068543] TEE armv7 Driver initialization
[ 2.068879] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 2.068894] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 2.069057] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 2.073197] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 2.073217] io scheduler noop registered
[ 2.073388] io scheduler cfq registered (default)
[ 2.074578] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 2.078583] iep: failed to find iep power down clock source.
[ 2.078930] IEP Power ON
[ 2.079088] IEP Power OFF
[ 2.079156] IEP Driver loaded succesfully
[ 2.079265] Module initialized.
[ 2.079684] rk-vcodec ff650000.vpu_service: probe device
[ 2.079724] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07c2b9810
[ 2.079858] rk-vcodec ff650000.vpu_service: allocator is drm
[ 2.079912] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 2.080327] rk-vcodec ff650000.vpu_service: init success
[ 2.080886] rk-vcodec ff660000.rkvdec: probe device
[ 2.080926] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07c2ba010
[ 2.081055] rk-vcodec ff660000.rkvdec: allocator is drm
[ 2.081111] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 2.081398] rk-vcodec ff660000.rkvdec: init success
[ 2.082750] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.082769] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 2.084121] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.084140] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 2.085728] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 2.087189] console [ttyS0] disabled
[ 2.087235] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 34, base_baud = 1500000) is a 16550A
[ 2.087747] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 35, base_baud = 1500000) is a 16550A
[ 2.088128] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 2.092739] mali ff9a0000.gpu: Failed to get regulator
[ 2.092757] mali ff9a0000.gpu: Power control initialization failed
[ 2.093055] Unable to detect cache hierarchy from DT for CPU 0
[ 2.100675] brd: module loaded
[ 2.105173] loop: module loaded
[ 2.105668] zram: Added device: zram0
[ 2.106208] SCSI Media Changer driver v0.25
[ 2.107002] tun: Universal TUN/TAP device driver, 1.6
[ 2.107014] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.108056] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 2.108075] rk_gmac-dwmac fe300000.ethernet: TX delay(0x27).
[ 2.108089] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1c).
[ 2.108116] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 2.108279] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 2.113298] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 2.113425] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 2.113436] Ring mode enabled
[ 2.113444] DMA HW capability register supported
[ 2.113453] Normal descriptors
[ 2.113464] RX Checksum Offload Engine supported (type 2)
[ 2.113473] TX Checksum insertion supported
[ 2.113481] Wake-Up On Lan supported
[ 2.113524] Enable RX Mitigation via HW Watchdog Timer
[ 2.182369] libphy: stmmac: probed
[ 2.182384] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 2.182396] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 2.183241] PPP generic driver version 2.4.2
[ 2.183399] PPP BSD Compression module registered
[ 2.183414] PPP Deflate Compression module registered
[ 2.183442] PPP MPPE Compression module registered
[ 2.183461] NET: Registered protocol family 24
[ 2.183500] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 2.183513] CSLIP: code copyright 1989 Regents of the University of California.
[ 2.183534] Rockchip WiFi SYS interface (V1.00) …
[ 2.183618] usbcore: registered new interface driver catc
[ 2.183661] usbcore: registered new interface driver kaweth
[ 2.183677] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 2.183715] usbcore: registered new interface driver pegasus
[ 2.183757] usbcore: registered new interface driver rtl8150
[ 2.183798] usbcore: registered new interface driver r8152
[ 2.183813] hso: drivers/net/usb/hso.c: Option Wireless
[ 2.183873] usbcore: registered new interface driver hso
[ 2.183921] usbcore: registered new interface driver asix
[ 2.183963] usbcore: registered new interface driver ax88179_178a
[ 2.184004] usbcore: registered new interface driver cdc_ether
[ 2.184048] usbcore: registered new interface driver cdc_eem
[ 2.184090] usbcore: registered new interface driver dm9601
[ 2.184141] usbcore: registered new interface driver smsc75xx
[ 2.184193] usbcore: registered new interface driver smsc95xx
[ 2.184234] usbcore: registered new interface driver gl620a
[ 2.184278] usbcore: registered new interface driver net1080
[ 2.184319] usbcore: registered new interface driver plusb
[ 2.184361] usbcore: registered new interface driver rndis_host
[ 2.184404] usbcore: registered new interface driver cdc_subset
[ 2.184446] usbcore: registered new interface driver zaurus
[ 2.184489] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 2.184549] usbcore: registered new interface driver int51x1
[ 2.184591] usbcore: registered new interface driver kalmia
[ 2.184633] usbcore: registered new interface driver ipheth
[ 2.184677] usbcore: registered new interface driver sierra_net
[ 2.184719] usbcore: registered new interface driver cx82310_eth
[ 2.184778] usbcore: registered new interface driver cdc_ncm
[ 2.184822] usbcore: registered new interface driver qmi_wwan
[ 2.184866] usbcore: registered new interface driver cdc_mbim
[ 2.186025] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 2.191521] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 2.192391] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.192409] ehci-pci: EHCI PCI platform driver
[ 2.192469] ehci-platform: EHCI generic platform driver
[ 2.196291] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 2.196326] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 2.196459] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 2.206281] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.206412] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.206428] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.206441] usb usb1: Product: EHCI Host Controller
[ 2.206453] usb usb1: Manufacturer: Linux 4.4.103 ehci_hcd
[ 2.206464] usb usb1: SerialNumber: fe3c0000.usb
[ 2.206940] hub 1-0:1.0: USB hub found
[ 2.206973] hub 1-0:1.0: 1 port detected
[ 2.207459] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.207489] ohci-platform: OHCI generic platform driver
[ 2.207929] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 2.207956] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 2.208071] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 2.263754] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.263771] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.263784] usb usb2: Product: Generic Platform OHCI controller
[ 2.263796] usb usb2: Manufacturer: Linux 4.4.103 ohci_hcd
[ 2.263807] usb usb2: SerialNumber: fe3e0000.usb
[ 2.264220] hub 2-0:1.0: USB hub found
[ 2.264253] hub 2-0:1.0: 1 port detected
[ 2.265042] usbcore: registered new interface driver cdc_acm
[ 2.265055] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.265115] usbcore: registered new interface driver usblp
[ 2.265162] usbcore: registered new interface driver cdc_wdm
[ 2.265209] usbcore: registered new interface driver uas
[ 2.265284] usbcore: registered new interface driver usb-storage
[ 2.265327] usbcore: registered new interface driver ums-alauda
[ 2.265369] usbcore: registered new interface driver ums-cypress
[ 2.265411] usbcore: registered new interface driver ums-datafab
[ 2.265453] usbcore: registered new interface driver ums_eneub6250
[ 2.265496] usbcore: registered new interface driver ums-freecom
[ 2.265538] usbcore: registered new interface driver ums-isd200
[ 2.265583] usbcore: registered new interface driver ums-jumpshot
[ 2.265625] usbcore: registered new interface driver ums-karma
[ 2.265667] usbcore: registered new interface driver ums-onetouch
[ 2.265710] usbcore: registered new interface driver ums-sddr09
[ 2.265752] usbcore: registered new interface driver ums-sddr55
[ 2.265794] usbcore: registered new interface driver ums-usbat
[ 2.265875] usbcore: registered new interface driver usbserial
[ 2.265917] usbcore: registered new interface driver usbserial_generic
[ 2.265948] usbserial: USB Serial support registered for generic
[ 2.265992] usbcore: registered new interface driver option
[ 2.266022] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.266125] usbcore: registered new interface driver trancevibrator
[ 2.266141] usb20_otg: version 3.10a 21-DEC-2012
[ 2.266354] usb20_host: version 3.10a 21-DEC-2012
[ 2.266750] usbcore: registered new interface driver xpad
[ 2.266801] usbcore: registered new interface driver usb_acecad
[ 2.266848] usbcore: registered new interface driver aiptek
[ 2.266895] usbcore: registered new interface driver gtco
[ 2.266945] usbcore: registered new interface driver hanwang
[ 2.266992] usbcore: registered new interface driver kbtab
[ 2.267415] .. rk pwm remotectl v1.1 init
[ 2.267655] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 2.268034] sensor_register_slave:mma8452,id=17
[ 2.268054] sensor_register_slave:lis3dh,id=7
[ 2.268071] sensor_register_slave:mma7660,id=18
[ 2.268086] sensor_register_slave:lsm303d,id=22
[ 2.268102] sensor_register_slave:gs_mc3230,id=23
[ 2.268112] [Gsensor] gsensor_init
[ 2.268127] sensor_register_slave:mpu6880_acc,id=24
[ 2.268143] sensor_register_slave:mpu6500_acc,id=25
[ 2.268159] sensor_register_slave:lsm330_acc,id=26
[ 2.268174] sensor_register_slave:bma2xx_acc,id=27
[ 2.268190] sensor_register_slave:akm8975,id=29
[ 2.268206] sensor_register_slave:akm8963,id=30
[ 2.268221] sensor_register_slave:l3g4200d,id=44
[ 2.268237] sensor_register_slave:l3g20d,id=45
[ 2.268253] sensor_register_slave:ewtsa,id=46
[ 2.268268] sensor_register_slave:lsm330_gyro,id=50
[ 2.268284] sensor_register_slave:cm3217,id=52
[ 2.268299] sensor_register_slave:cm3218,id=53
[ 2.268315] sensor_register_slave:ls_stk3410,id=61
[ 2.268331] sensor_register_slave:ps_stk3410,id=66
[ 2.268959] i2c /dev entries driver
[ 2.269618] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80095de000
[ 2.280146] fusb302 4-0022: port 0 probe success
[ 2.280176] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80095fa000
[ 2.281164] fan53555-regulator 8-0040: FAN53555 Option[8] Rev[1] Detected!
[ 2.281228] fan53555-reg: supplied by vcc_sys
[ 2.283509] fan53555-regulator 8-0041: FAN53555 Option[8] Rev[1] Detected!
[ 2.283557] fan53555-reg: supplied by vcc_sys
[ 2.285996] rk808 8-001b: Pmic Chip id: 0x0
[ 2.289129] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 2.289191] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 2.289267] DCDC_REG1: supplied by vcc_sys
[ 2.289941] DCDC_REG2: supplied by vcc_sys
[ 2.290446] DCDC_REG3: supplied by vcc_sys
[ 2.290654] DCDC_REG4: supplied by vcc_sys
[ 2.291026] LDO_REG1: supplied by vcc_sys
[ 2.292072] LDO_REG2: supplied by vcc_sys
[ 2.293003] LDO_REG3: supplied by vcc_sys
[ 2.293894] LDO_REG4: supplied by vcc_sys
[ 2.294800] LDO_REG5: supplied by vcc_sys
[ 2.295692] LDO_REG6: supplied by vcc_sys
[ 2.296586] LDO_REG7: supplied by vcc_sys
[ 2.297491] LDO_REG8: supplied by vcc_sys
[ 2.298386] SWITCH_REG1: supplied by vcc3v3_sys
[ 2.298621] SWITCH_REG2: supplied by vcc3v3_sys
[ 2.301960] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 2.302388] rk3x-i2c ff3e0000.i2c: Initialized RK3xxx I2C bus at ffffff80095fc000
[ 2.303203] IR NEC protocol handler initialized
[ 2.303219] IR RC5(x/sz) protocol handler initialized
[ 2.303234] IR RC6 protocol handler initialized
[ 2.303247] IR JVC protocol handler initialized
[ 2.303261] IR Sony protocol handler initialized
[ 2.303275] IR SANYO protocol handler initialized
[ 2.303289] IR Sharp protocol handler initialized
[ 2.303303] IR MCE Keyboard/mouse protocol handler initialized
[ 2.303317] IR XMP protocol handler initialized
[ 2.303513] usbcore: registered new interface driver uvcvideo
[ 2.303524] USB Video Class driver (1.1.1)
[ 2.303541] CamSys driver version: v0.34.8, CamSys head file version: v0.14.0
[ 2.307533] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 2.307669] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 2.307910] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 2.308008] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 2.310244] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 2.310794] device-mapper: uevent: version 1.0.3
[ 2.311066] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.311206] Bluetooth: HCI UART driver ver 2.3
[ 2.311219] Bluetooth: HCI UART protocol H4 registered
[ 2.311230] Bluetooth: HCI UART protocol LL registered
[ 2.311246] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 2.311257] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 2.311267] rtk_btusb: Register usb char device interface for BT driver
[ 2.311455] usbcore: registered new interface driver rtk_btusb
[ 2.311846] cpu cpu0: leakage=24
[ 2.328180] cpu cpu0: temp=51111, pvtm=147428 (146768 + 660)
[ 2.328404] cpu cpu0: pvtm-sel=1
[ 2.328707] cpu cpu4: leakage=40
[ 2.340602] cpu cpu4: temp=51111, pvtm=155050 (154700 + 350)
[ 2.340743] cpu cpu4: pvtm-sel=2
[ 2.344745] sdhci: Secure Digital Host Controller Interface driver
[ 2.344763] sdhci: Copyright(c) Pierre Ossman
[ 2.344780] Synopsys Designware Multimedia Card Interface Driver
[ 2.345580] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.345659] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.345680] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.345735] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.345768] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.345812] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.345824] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.346627] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.346678] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.346696] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.346736] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.346758] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.346864] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 2.347116] vcc_sd: unsupportable voltage range: 3300000-3000000uV
[ 2.347140] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 2.347155] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 2.359736] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.374109] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 2.374383] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.376076] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 2.376089] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 2.403042] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 2.404413] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.407969] usbcore: registered new interface driver usbhid
[ 2.407983] usbhid: USB HID core driver
[ 2.408145] inv_mpu_iio: inv_mpu_init:746
[ 2.409148] ashmem: initialized
[ 2.415953] rknandbase v1.1 2016-11-08
[ 2.416457] usbcore: registered new interface driver snd-usb-audio
[ 2.417414] es8316 1-0010: Can not read property hp_det_gpio
[ 2.420560] u32 classifier
[ 2.420575] Actions configured
[ 2.420629] Netfilter messages via NETLINK v0.30.
[ 2.420687] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.421045] ctnetlink v0.93: registering with nfnetlink.
[ 2.421641] xt_time: kernel timezone is -0000
[ 29.229594] NMI watchdog: BUG: soft lockup - CPU#4 stuck for 23s! [swapper/0:1]
[ 29.229636] Modules linked in:
[ 29.229648]
[ 29.229662] CPU: 4 PID: 1 Comm: swapper/0 Not tainted 4.4.103 #1
[ 29.229672] Hardware name: Rockchip RK3399 Board rev2 (BOX) (DT)
[ 29.229685] task: ffffffc00a350000 task.stack: ffffffc00a358000
[ 29.229704] PC is at smp_call_function_many+0x258/0x288
[ 29.229717] LR is at smp_call_function_many+0x238/0x288
[ 29.229729] pc : [] lr : [] pstate: 80400045
[ 29.229741] sp : ffffffc00a35bab0
[ 29.229750] x29: ffffffc00a35bab0 x28: ffffff80090feec0
[ 29.229769] x27: ffffff8009128000 x26: ffffff8009127bd0
[ 29.229786] x25: ffffff8009128000 x24: 0000000000000000
[ 29.229802] x23: ffffff8009128000 x22: ffffffc07ef0be60
[ 29.229818] x21: ffffffc07ef5cf08 x20: ffffff8009127bd0
[ 29.229833] x19: ffffffc07ef5cf00 x18: 0000000000001400
[ 29.229850] x17: 0000000000000003 x16: 0000000000000010
[ 29.229865] x15: 2d736f691200031a x14: 0000000000000000
[ 29.229881] x13: ffffff0000000000 x12: 0000000000000000
[ 29.229896] x11: ffffffffffffffff x10: 0000000000000001
[ 29.229912] x9 : 0000000000000003 x8 : 0000000000000002
[ 29.229928] x7 : ffffff8009369da8 x6 : ffffffbffe7feffc
[ 29.229944] x5 : 000000000000002d x4 : 0000000000000000
[ 29.229959] x3 : 0000000000000000 x2 : 0000000000000000
[ 29.229974] x1 : ffffff8009128310 x0 : 0000000000000003
[ 29.229991]
[ 29.229991] PC: 0xffffff800811a060:
[ 29.230002] a060 b9401801 321f0021 b9001801 910c4361 f9000417 f9000818 f90037a4 f863d822
[ 29.230051] a080 aa0003e1 8b020382 940a0302 f94037a4 17ffffdc aa1503e0 97fdd3da 12800002
[ 29.230097] a0a0 340002b6 912f4294 d0008077 11000442 d2800101 aa1503e0 93407c42 940a02c7
[ 29.230143] a0c0 2a0003e2 b9400281 6b01001f 5400014a 910c42e1 f9400276 f860d820 8b0002d6
[ 29.230188] a0e0 910062c0 88dffc00 3607fe20 d503203f 17fffffc a94153f3 a9425bf5 a94363f7
[ 29.230234] a100 a9446bf9 a94573fb a8c77bfd d65f03c0 a9be7bfd aa0003e4 aa0103e3 910003fd
[ 29.230280] a120 f9000bf3 d5384113 b9401a60 11000400 b9001a60 b0005060 6b1f005f aa0403e1
[ 29.230326] a140 aa0303e2 1a9f07e3 f944e400 97ffff4f b9401a60 51000400 b9001a60 35000080
[ 29.230372]
[ 29.230372] LR: 0xffffff800811a040:
[ 29.230383] a040 36000061 d503203f 17fffffc b9401801 32000021 b9001801 d5033abf 34000096
[ 29.230429] a060 b9401801 321f0021 b9001801 910c4361 f9000417 f9000818 f90037a4 f863d822
[ 29.230475] a080 aa0003e1 8b020382 940a0302 f94037a4 17ffffdc aa1503e0 97fdd3da 12800002
[ 29.230520] a0a0 340002b6 912f4294 d0008077 11000442 d2800101 aa1503e0 93407c42 940a02c7
[ 29.230566] a0c0 2a0003e2 b9400281 6b01001f 5400014a 910c42e1 f9400276 f860d820 8b0002d6
[ 29.230611] a0e0 910062c0 88dffc00 3607fe20 d503203f 17fffffc a94153f3 a9425bf5 a94363f7
[ 29.230657] a100 a9446bf9 a94573fb a8c77bfd d65f03c0 a9be7bfd aa0003e4 aa0103e3 910003fd
[ 29.230702] a120 f9000bf3 d5384113 b9401a60 11000400 b9001a60 b0005060 6b1f005f aa0403e1
[ 29.230749]
[ 29.230749] SP: 0xffffffc00a35ba30:
[ 29.230758] ba30 7ef0be60 ffffffc0 09128000 ffffff80 00000000 00000000 09128000 ffffff80
[ 29.230804] ba50 09127bd0 ffffff80 09128000 ffffff80 090feec0 ffffff80 0a35bab0 ffffffc0
[ 29.230849] ba70 0811a0c0 ffffff80 0a35bab0 ffffffc0 0811a0e0 ffffff80 80400045 00000000
[ 29.230895] ba90 7ef5cf08 ffffffc0 00000001 00000000 ffffffff ffffffff 0811a0c0 ffffff80
[ 29.230940] bab0 0a35bb20 ffffffc0 0811a150 ffffff80 0a350000 ffffffc0 0a35bbd0 ffffffc0
[ 29.230985] bad0 0a35bbcc ffffffc0 1400001c 00000000 04e73a80 ffffffc0 00000000 00000000
[ 29.231031] baf0 091318f0 ffffff80 090504a0 ffffff80 090b2e30 ffffff80 092bc000 ffffff80
[ 29.231076] bb10 0a35bbcc ffffffc0 00000005 00000000 0a35bb40 ffffffc0 0811a218 ffffff80
[ 29.231124]
[ 29.231124] X1: 0xffffff8009128290:
[ 29.231134] 8290 00000001 00000000 00000001 00000000 0000012c 00000000 7ef7c0c0 ffffffc0
[ 29.231179] 82b0 00000015 00000000 7ef7c080 ffffffc0 00000001 00000000 00000060 00000000
[ 29.231225] 82d0 00015000 00000000 7ef7c140 ffffffc0 7ef7c100 ffffffc0 00000001 00001000
[ 29.231270] 82f0 00000006 00000000 00000005 00000010 7eefdf00 ffffffc0 7eefe000 ffffffc0
[ 29.231316] 8310 75e0a000 00000040 75e1f000 00000040 75e34000 00000040 75e49000 00000040
[ 29.231361] 8330 75e5e000 00000040 75e73000 00000040 00000000 00000000 00000000 00000000
[ 29.231406] 8350 00000001 00000000 00000001 00000000 000014bb 00000000 00010000 00000000
[ 29.231451] 8370 0007ffff 00000000 0000f2fc 00000000 00002000 00000000 00000000 0000fffa
[ 29.231499]
[ 29.231499] X6: 0xffffffbffe7fef7c:
[ 29.231509] ef7c ******** ******** ******** ******** ******** ******** ******** ********
[ 29.231563] ef9c ******** ******** ******** ******** ******** ******** ******** ********
[ 29.231611] efbc ******** ******** ******** ******** ******** ******** ******** ********
[ 29.231660] efdc ******** ******** ******** ******** ******** ******** ******** ********
[ 29.231708] effc ******** 00000000 00000001 000000c1 00000003 00000000 00000000 00000000
[ 29.231756] f01c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.231804] f03c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.231853] f05c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.231902]
[ 29.231902] X7: 0xffffff8009369d28:
[ 29.231912] 9d28 08000000 ffffff80 bff72000 ffffffbd 00000000 00000000 00000000 00000000
[ 29.231958] 9d48 000002df 00000000 00001000 00000000 00002000 00000000 00080000 00000000
[ 29.232003] 9d68 00080000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232048] 9d88 00000001 00000000 00200000 00000000 08200000 00000000 00000000 00000000
[ 29.232093] 9da8 0a200000 00000000 75e00000 00000000 00000000 00000000 0a200000 00000000
[ 29.232138] 9dc8 75e00000 00000000 00000000 00000000 0a200000 00000000 75e00000 00000000
[ 29.232184] 9de8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232229] 9e08 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232279]
[ 29.232279] X19: 0xffffffc07ef5ce80:
[ 29.232289] ce80 00000000 00000000 00000001 00000000 7ef5ce90 ffffffc0 7ef5ce90 ffffffc0
[ 29.232335] cea0 00000000 00000000 00000000 00000000 00000000 00000004 09144c40 ffffff80
[ 29.232380] cec0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232425] cee0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232470] cf00 09101e60 ffffff80 0000002d 00000000 00000000 00000000 00000000 00000000
[ 29.232516] cf20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232560] cf40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232605] cf60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232651]
[ 29.232651] X20: 0xffffff8009127b50:
[ 29.232661] 7b50 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232706] 7b70 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232751] 7b90 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232796] 7bb0 7c280000 ffffffc0 00000800 00000000 00000001 00000000 00000000 00000000
[ 29.232842] 7bd0 00000006 00000000 00000013 00000000 00000000 00000000 00000000 00000000
[ 29.232887] 7bf0 00000000 00000000 00000000 00000000 00000000 00000000 092ae1c0 ffffff80
[ 29.232932] 7c10 00000000 00000000 00000000 00000000 00000000 00000000 092ae208 ffffff80
[ 29.232978] 7c30 00000000 00000000 00000000 00000000 0000000a 00000000 00400000 0000000a
[ 29.233024]
[ 29.233024] X21: 0xffffffc07ef5ce88:
[ 29.233034] ce88 00000001 00000000 7ef5ce90 ffffffc0 7ef5ce90 ffffffc0 00000000 00000000
[ 29.233080] cea8 00000000 00000000 00000000 00000004 09144c40 ffffff80 00000000 00000000
[ 29.233127] cec8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233172] cee8 00000000 00000000 00000000 00000000 00000000 00000000 09101e60 ffffff80
[ 29.233217] cf08 0000002d 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233262] cf28 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233307] cf48 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233353] cf68 00000000 00000000 00000000 00000000 00000000 00000000 7ef5cf80 ffffffc0
[ 29.233400]
[ 29.233400] X22: 0xffffffc07ef0bde0:
[ 29.233409] bde0 00000000 00000000 00000001 00000000 00000000 00000000 00000000 00000000
[ 29.233455] be00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233500] be20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233545] be40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233590] be60 00000000 00000000 081197e4 ffffff80 00000000 00000000 00000003 00000000
[ 29.233636] be80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233682] bea0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233727] bec0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233773]
[ 29.233773] X23: 0xffffff8009127f80:
[ 29.233782] 7f80 092952c8 ffffff80 09295360 ffffff80 092953f8 ffffff80 09295490 ffffff80
[ 29.233828] 7fa0 09295528 ffffff80 092955c0 ffffff80 09295658 ffffff80 092956f0 ffffff80
[ 29.233874] 7fc0 09295788 ffffff80 09295820 ffffff80 092958b8 ffffff80 09295950 ffffff80
[ 29.233920] 7fe0 092959e8 ffffff80 09295a80 ffffff80 0928e0a8 ffffff80 0928e140 ffffff80
[ 29.233965] 8000 0928e1d8 ffffff80 0928e270 ffffff80 0928e308 ffffff80 0928e3a0 ffffff80
[ 29.234011] 8020 0928e438 ffffff80 0928e4d0 ffffff80 0928e568 ffffff80 0928e600 ffffff80
[ 29.234057] 8040 0928e698 ffffff80 0928e730 ffffff80 0928e7c8 ffffff80 0928e860 ffffff80
[ 29.234102] 8060 0928e8f8 ffffff80 0928e990 ffffff80 09291898 ffffff80 09291930 ffffff80
[ 29.234149]
[ 29.234149] X25: 0xffffff8009127f80:
[ 29.234159] 7f80 092952c8 ffffff80 09295360 ffffff80 092953f8 ffffff80 09295490 ffffff80
[ 29.234205] 7fa0 09295528 ffffff80 092955c0 ffffff80 09295658 ffffff80 092956f0 ffffff80
[ 29.234251] 7fc0 09295788 ffffff80 09295820 ffffff80 092958b8 ffffff80 09295950 ffffff80
[ 29.234296] 7fe0 092959e8 ffffff80 09295a80 ffffff80 0928e0a8 ffffff80 0928e140 ffffff80
[ 29.234342] 8000 0928e1d8 ffffff80 0928e270 ffffff80 0928e308 ffffff80 0928e3a0 ffffff80
[ 29.234388] 8020 0928e438 ffffff80 0928e4d0 ffffff80 0928e568 ffffff80 0928e600 ffffff80
[ 29.234434] 8040 0928e698 ffffff80 0928e730 ffffff80 0928e7c8 ffffff80 0928e860 ffffff80
[ 29.234480] 8060 0928e8f8 ffffff80 0928e990 ffffff80 09291898 ffffff80 09291930 ffffff80
[ 29.234526]
[ 29.234526] X26: 0xffffff8009127b50:
[ 29.234536] 7b50 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.234581] 7b70 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.234627] 7b90 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.234672] 7bb0 7c280000 ffffffc0 00000800 00000000 00000001 00000000 00000000 00000000
[ 29.234717] 7bd0 00000006 00000000 00000013 00000000 00000000 00000000 00000000 00000000
[ 29.234762] 7bf0 00000000 00000000 00000000 00000000 00000000 00000000 092ae1c0 ffffff80
[ 29.234808] 7c10 00000000 00000000 00000000 00000000 00000000 00000000 092ae208 ffffff80
[ 29.234854] 7c30 00000000 00000000 00000000 00000000 0000000a 00000000 00400000 0000000a
[ 29.234900]
[ 29.234900] X27: 0xffffff8009127f80:
[ 29.234910] 7f80 092952c8 ffffff80 09295360 ffffff80 092953f8 ffffff80 09295490 ffffff80
[ 29.234956] 7fa0 09295528 ffffff80 092955c0 ffffff80 09295658 ffffff80 092956f0 ffffff80
[ 29.235001] 7fc0 09295788 ffffff80 09295820 ffffff80 092958b8 ffffff80 09295950 ffffff80
[ 29.235047] 7fe0 092959e8 ffffff80 09295a80 ffffff80 0928e0a8 ffffff80 0928e140 ffffff80
[ 29.235093] 8000 0928e1d8 ffffff80 0928e270 ffffff80 0928e308 ffffff80 0928e3a0 ffffff80
[ 29.235139] 8020 0928e438 ffffff80 0928e4d0 ffffff80 0928e568 ffffff80 0928e600 ffffff80
[ 29.235185] 8040 0928e698 ffffff80 0928e730 ffffff80 0928e7c8 ffffff80 0928e860 ffffff80
[ 29.235231] 8060 0928e8f8 ffffff80 0928e990 ffffff80 09291898 ffffff80 09291930 ffffff80
[ 29.235278]
[ 29.235278] X28: 0xffffff80090fee40:
[ 29.235287] ee40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.235333] ee60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.235377] ee80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.235423] eea0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.235468] eec0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.235513] eee0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.235558] ef00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.235603] ef20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.235650]
[ 29.235650] X29: 0xffffffc00a35ba30:
[ 29.235659] ba30 7ef0be60 ffffffc0 09128000 ffffff80 00000000 00000000 09128000 ffffff80
[ 29.235705] ba50 09127bd0 ffffff80 09128000 ffffff80 090feec0 ffffff80 0a35bab0 ffffffc0
[ 29.235750] ba70 0811a0c0 ffffff80 0a35bab0 ffffffc0 0811a0e0 ffffff80 80400045 00000000
[ 29.235796] ba90 7ef5cf08 ffffffc0 00000001 00000000 ffffffff ffffffff 0811a0c0 ffffff80
[ 29.235841] bab0 0a35bb20 ffffffc0 0811a150 ffffff80 0a350000 ffffffc0 0a35bbd0 ffffffc0
[ 29.235887] bad0 0a35bbcc ffffffc0 1400001c 00000000 04e73a80 ffffffc0 00000000 00000000
[ 29.235932] baf0 091318f0 ffffff80 090504a0 ffffff80 090b2e30 ffffff80 092bc000 ffffff80
[ 29.235978] bb10 0a35bbcc ffffffc0 00000005 00000000 0a35bb40 ffffffc0 0811a218 ffffff80
[ 29.236024]
Tried flashing some other factory images as well, but still system is not booting. Please let me know, if you people know any solution to resolve this issue.
I had some similar crash using custom image with kernel and u-boot from slarm64 when i tried to perform a large disk operation. In my case building mainline u-boot was a solution
phkr Posted at 6/19/2020 15:38
I had some similar crash using custom image with kernel and u-boot from slarm64 when i tried to perf …
Thanks for your reply.
In my case, I have new board, earlier it had one factory image then I flashed locally built clean image then I was facing the above mentioned issue. After that tried flashing factory image(which was working earlier) also, still same issue is coming. Any idea how to deal with this situation?
That article had a huge impact on me. The NCP-DB-6.10 Online Test material is superb, and it’s available for free.
It was such a valuable learning experience. Taking the Latest 350-501 exam experience exam soon, hope I’ll do well!
I’m completely in awe of your article, thank you for sharing! I advanced with the Valid study guide 1Z0-1081-24 ppt, earning a promotion and salary increase. Now, it’s free for everyone. Best of luck with your own promotions!
I’m in awe of your article, thank you so much for sharing! Free Detailed D-PSC-DY-23 answers to boost your IT knowledge. Best wishes for your journey!
I don’t even need to think—this content deserves a like. Get the Pdf AD0-E605 exam dump exam materials for free—the key to promotions and higher pay!
I’m really thankful for your article, it was a real eye-opener. Sharing free Exam L5M10 pass4sure study materials. Wishing you the best of luck!
