DDR Version 1.14 20180803
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
CPUId = 0x0
ChipType = 0x10, 214
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67727
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
GPT part: 2, name: boot, start:0xa000, size:0x10000
GPT part: 3, name: backup, start:0x2a000, size:0x10000
GPT part: 4, name: rootfs, start:0x5a000, size:0x1cc4fdf
find partition:uboot OK. first_lba:0x4000.
find partition:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xad068
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):56eea3d
NOTICE: BL31: Built : 15:27:37, Aug 8 2018
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1151): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-170-gc4654a6 #16 Wed May 30 08:54:30 UTC 2018 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2017.09-gd80ac02-dirty (Dec 24 2018 - 14:52:31 +0800)
Model: Firefly-RK3399 Board
DRAM: 2 GiB
Relocation Offset is: 7fd12000
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
pwm-regulator(vdd-log): init 950000 uV
vdd_log 950000 uV
regulator(vdd-log) init 950000 uV
MMC: dwmmc@fe320000: 1, sdhci@fe330000: 0
In: serial@ff1a0000
Out: serial@ff1a0000
Err: serial@ff1a0000
mmc_init: -95, time 9
switch to partitions #0, OK
get part misc fail -1
Net: eth0: ethernet@fe300000
android_bootloader_boot_flow Could not find misc partition
Error: Bad gzipped data
FDT load addr 0x10f00000 size 222 KiB
Booting kernel at 0x207f800 with fdt at 33b1600…
## Booting Android Image at 0x0207f800 …
Kernel load addr 0x02080000 size 19651 KiB
## Flattened Device Tree blob at 033b1600
Booting using the fdt blob at 0x33b1600
XIP Kernel Image … OK
Loading Device Tree to 00000000081e5000, end 00000000081ffc03 … OK
Adding bank: start=0x00200000, size=0x08200000
Adding bank: start=0x0a200000, size=0x75e00000
[ 0.000000] Linux version 4.4.154 (zhangxf@tchip14) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #36 SMP Thu Dec 27 15:24:42 CST 2018
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07feea000 s45800 r8192 d32024 u86016
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.mode=emmc androidboot.slot_suffix= androidboot.serialno=450edaa987e407e3 rw rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4
[ 0.000000] software IO TLB [mem 0x7fea2000-0x7fee2000] (0MB) mapped at [ffffffc07fea2000-ffffffc07fee1fff]
[ 0.000000] Memory: 2006564K/2064384K available (12030K kernel code, 1730K rwdata, 4672K rodata, 1152K init, 767K bss, 57820K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff80090e0000 - 0xffffff8009200000 ( 1152 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008c40000 ( 12032 KB)
[ 0.000000] .rodata : 0xffffff8008c40000 - 0xffffff80090e0000 ( 4736 KB)
[ 0.000000] .data : 0xffffff8009200000 - 0xffffff80093b0808 ( 1731 KB)
[ 0.000000] ITS: allocated 65536 Devices @a300000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000000a290000
[ 0.000000] CPU0: using LPI pending table @0x000000000a2a0000
[ 0.002154] Console: colour dummy device 80x25
[ 0.002595] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003585] pid_max: default: 32768 minimum: 301
[ 0.004110] Security Framework initialized
[ 0.004576] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.005216] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006610] Initializing cgroup subsys devices
[ 0.007057] Initializing cgroup subsys freezer
[ 0.007501] ftrace: allocating 43570 entries in 171 pages
[ 0.115772] sched-energy: Sched-energy-costs installed from DT
[ 0.116339] CPU0: update cpu_capacity 401
[ 0.116788] ASID allocator initialised with 32768 entries
[ 0.120561] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.121904] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.124135] Detected VIPT I-cache on CPU1
[ 0.124166] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.124196] CPU1: using LPI pending table @0x0000000000320000
[ 0.124238] CPU1: update cpu_capacity 401
[ 0.124242] CPU1: Booted secondary processor [410fd034]
[ 0.124781] Detected VIPT I-cache on CPU2
[ 0.124801] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.124830] CPU2: using LPI pending table @0x0000000000350000
[ 0.124856] CPU2: update cpu_capacity 401
[ 0.124859] CPU2: Booted secondary processor [410fd034]
[ 0.125375] Detected VIPT I-cache on CPU3
[ 0.125395] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.125423] CPU3: using LPI pending table @0x00000000003a0000
[ 0.125448] CPU3: update cpu_capacity 401
[ 0.125451] CPU3: Booted secondary processor [410fd034]
[ 0.125996] Detected PIPT I-cache on CPU4
[ 0.126021] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.126060] CPU4: using LPI pending table @0x00000000003d0000
[ 0.126097] CPU4: update cpu_capacity 1024
[ 0.126100] CPU4: Booted secondary processor [410fd082]
[ 0.126643] Detected PIPT I-cache on CPU5
[ 0.126661] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.126699] CPU5: using LPI pending table @0x000000007d000000
[ 0.126726] CPU5: update cpu_capacity 1024
[ 0.126729] CPU5: Booted secondary processor [410fd082]
[ 0.126814] Brought up 6 CPUs
[ 0.139180] SMP: Total of 6 processors activated.
[ 0.139632] CPU features: detected feature: GIC system register CPU interface
[ 0.140324] CPU: All CPU(s) started at EL2
[ 0.140755] alternatives: patching kernel code
[ 0.142576] devtmpfs: initialized
[ 0.159536] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.160467] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.161537] pinctrl core: initialized pinctrl subsystem
[ 0.162769] NET: Registered protocol family 16
[ 0.168526] cpuidle: using governor ladder
[ 0.172534] cpuidle: using governor menu
[ 0.172922] Registered FIQ tty driver
[ 0.173604] vdso: 2 pages (1 code @ ffffff8008c46000, 1 data @ ffffff8009204000)
[ 0.174320] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.175123] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.199545] console [ttyFIQ0] enabled
[ 0.200228] bootconsole [uart0] disabled
[ 0.201114] Registered fiq debugger ttyFIQ0
[ 0.232435] iommu: Adding device ff650000.vpu_service to group 0
[ 0.233048] iommu: Adding device ff660000.rkvdec to group 1
[ 0.233627] iommu: Adding device ff8f0000.vop to group 2
[ 0.234175] iommu: Adding device ff900000.vop to group 3
[ 0.235970] SCSI subsystem initialized
[ 0.236663] usbcore: registered new interface driver usbfs
[ 0.237189] usbcore: registered new interface driver hub
[ 0.237743] usbcore: registered new device driver usb
[ 0.238251] media: Linux media interface: v0.10
[ 0.238692] Linux video capture interface: v2.00
[ 0.239147] pps_core: LinuxPPS API ver. 1 registered
[ 0.239591] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.240416] PTP clock support registered
[ 0.241817] Advanced Linux Sound Architecture Driver Initialized.
[ 0.242831] Bluetooth: Core ver 2.21
[ 0.243170] NET: Registered protocol family 31
[ 0.243577] Bluetooth: HCI device and connection manager initialized
[ 0.244143] Bluetooth: HCI socket layer initialized
[ 0.244587] Bluetooth: L2CAP socket layer initialized
[ 0.245049] Bluetooth: SCO socket layer initialized
[ 0.246134] rockchip-cpuinfo cpuinfo: Serial : 450edaa987e407e3
[ 0.247243] clocksource: Switched to clocksource arch_sys_counter
[ 0.295755] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.296677] NET: Registered protocol family 2
[ 0.297498] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.298283] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.299332] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.299979] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.300603] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.301445] NET: Registered protocol family 1
[ 0.302128] RPC: Registered named UNIX socket transport module.
[ 0.302671] RPC: Registered udp transport module.
[ 0.303092] RPC: Registered tcp transport module.
[ 0.303520] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.305157] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.305984] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.309705] Initialise system trusted keyring
[ 0.318162] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.319481] NFS: Registering the id_resolver key type
[ 0.319946] Key type id_resolver registered
[ 0.320333] Key type id_legacy registered
[ 0.320750] fuse init (API version 7.23)
[ 0.321488] SGI XFS with security attributes, no debug enabled
[ 0.326906] NET: Registered protocol family 38
[ 0.327331] Key type asymmetric registered
[ 0.327699] Asymmetric key parser ‘x509’ registered
[ 0.328294] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.328953] io scheduler noop registered
[ 0.329319] io scheduler deadline registered
[ 0.329823] io scheduler cfq registered (default)
[ 0.331895] phy phy-ff770000.syscon:usb2-phy@e460.1: Failed to get VBUS supply regulator
[ 0.337615] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.338199] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.338793] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.393427] PCI host bridge /pcie@f8000000 ranges:
[ 0.393864] MEM 0xfa000000..0xfbdfffff → 0xfa000000
[ 0.394336] IO 0xfbe00000..0xfbefffff → 0xfbe00000
[ 0.395080] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[ 0.395680] pci_bus 0000:00: root bus resource [bus 00-1f]
[ 0.396173] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
[ 0.396792] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
[ 0.398014] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.398926] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 0.399577] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
[ 0.400214] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
[ 0.400859] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
[ 0.401504] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
[ 0.404315] pci 0000:00:00.0: BAR 8: assigned [mem 0xfa000000-0xfa0fffff]
[ 0.404917] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref]
[ 0.405573] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa0101ff]
[ 0.406174] pci 0000:01:00.0: BAR 4: no space for [io size 0x0010]
[ 0.406734] pci 0000:01:00.0: BAR 4: failed to assign [io size 0x0010]
[ 0.407327] pci 0000:01:00.0: BAR 0: no space for [io size 0x0008]
[ 0.407877] pci 0000:01:00.0: BAR 0: failed to assign [io size 0x0008]
[ 0.408471] pci 0000:01:00.0: BAR 2: no space for [io size 0x0008]
[ 0.409021] pci 0000:01:00.0: BAR 2: failed to assign [io size 0x0008]
[ 0.409613] pci 0000:01:00.0: BAR 1: no space for [io size 0x0004]
[ 0.410162] pci 0000:01:00.0: BAR 1: failed to assign [io size 0x0004]
[ 0.410756] pci 0000:01:00.0: BAR 3: no space for [io size 0x0004]
[ 0.411314] pci 0000:01:00.0: BAR 3: failed to assign [io size 0x0004]
[ 0.411899] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.412357] pci 0000:00:00.0: bridge window [mem 0xfa000000-0xfa0fffff]
[ 0.413006] pcieport 0000:00:00.0: enabling device (0000 → 0002)
[ 0.413771] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.414403] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 0.415825] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.416658] rk-vcodec ff650000.vpu_service: probe device
[ 0.417339] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 0.418560] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.419180] rk-vcodec ff650000.vpu_service: init success
[ 0.419889] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.420852] rk-vcodec ff660000.rkvdec: probe device
[ 0.421477] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 0.422441] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.423014] rk-vcodec ff660000.rkvdec: init success
[ 0.424888] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.425569] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.427818] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.428499] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.430443] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.432741] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 0.433868] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-debugger; cannot claim for ff1a0000.serial
[ 0.434821] rockchip-pinctrl pinctrl: pin-147 (ff1a0000.serial) status -22
[ 0.435438] rockchip-pinctrl pinctrl: could not request pin 147 (gpio4-19) from group uart2c-xfer on device rockchip-pinctrl
[ 0.436437] dw-apb-uart ff1a0000.serial: Error applying setting, reverse things back
[ 0.437442] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.438869] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 39, base_baud = 1500000) is a 16550A
[ 0.440725] [drm] Initialized drm 1.1.0 20060810
[ 0.444428] [drm] Rockchip DRM driver version: v1.0.1
[ 0.446789] mali ff9a0000.gpu: Failed to get regulator
[ 0.447264] mali ff9a0000.gpu: Power control initialization failed
[ 0.448116] Unable to detect cache hierarchy for CPU 0
[ 0.449391] brd: module loaded
[ 0.454766] loop: module loaded
[ 0.455624] zram: Added device: zram0
[ 0.456256] lkdtm: No crash points registered, enable through debugfs
[ 0.457317] ahci 0000:01:00.0: enabling device (0000 → 0002)
[ 0.458513] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled
[ 0.459372] ahci 0000:01:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl IDE mode
[ 0.460078] ahci 0000:01:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc sxs
[ 24.129238] Watchdog detected hard LOCKUP on cpu 5
[ 24.129657] ------------[ cut here ]------------
[ 24.130092] WARNING: at kernel/watchdog.c:352
[ 24.130478] Modules linked in:
[ 24.130762]
[ 24.130911] CPU: 4 PID: 0 Comm: swapper/4 Not tainted 4.4.154 #36
[ 24.131447] Hardware name: Firefly-RK3399 Board (Linux Opensource) (DT)
[ 24.132030] task: ffffffc0002cb600 task.stack: ffffffc0002e4000
[ 24.132566] PC is at watchdog_timer_fn+0x170/0x2e0
[ 24.132990] LR is at watchdog_timer_fn+0x170/0x2e0
[ 24.133412] pc : [] lr : [] pstate: 600001c5
[ 24.134063] sp : ffffffc07ff41df0
[ 24.134357] x29: ffffffc07ff41df0 x28: 0000000000000005
[ 24.134851] x27: ffffff8009207710 x26: ffffff80091da238
[ 24.135344] x25: ffffffc07ff44250 x24: ffffffc0002e7e00
[ 24.135837] x23: 0000000000000000 x22: 0000000000000000
[ 24.136329] x21: ffffff8009206000 x20: ffffff80091da2b0
[ 24.136822] x19: ffffff80091da000 x18: ffffff80893b7817
[ 24.137314] x17: 0000000000000050 x16: 00000000899bdca5
[ 24.137807] x15: 0000000000000000 x14: 000000000001f8d6
[ 24.138299] x13: 000000000000000a x12: 0000000000000030
[ 24.138791] x11: 00000000fffffffe x10: ffffff80093b781f
[ 24.139283] x9 : 0000000005f5e0ff x8 : 4c20647261682064
[ 24.139775] x7 : 6574636574656420 x6 : ffffff80093b784d
[ 24.140267] x5 : 00000000ffffffff x4 : ffffff8009205588
[ 24.140759] x3 : 0000004076d6a000 x2 : 0000004076d6a000
[ 24.141251] x
