Native build of Armbian and the kernel on Station P1 and M1
Now for Station P1 users, you can build new Armbian images yourself (you can build different versions of distributions, your own version of the kernel with the addition of your kernel options, etc.) and Libreelec directly on P1 devices. Please note that to build your versions, you no longer need a PC, all operations can be performed completely on P1. Depending on the media used to run Armbian (this is the base system that runs the entire Armbian and LE build), the build time can take from a few minutes to several hours. For example, the maximum build time with downloading all components and fully building the entire system for the Armbian desktop image, when starting the system from an SD card, is ~230 minutes. If you want to try to build your own Armbian image, I will write a step-by-step guide. :slight_smile:
Good news. Now you can build your own version of Armbian with any DE (XFCE KDE Mate LXDE etc) and with your own set of pre-installed programs for the user’s choice. All operations are performed entirely on P1\M1. :slight_smile:
This video guide shows you how to build your own version of Armbian directly on your P1 M1 (or other ARM device). You don’t need a PC or other device to build it, everything is done only on the ARM P1\M1 device itself. :slight_smile:
Thank you NocoD for creating various video instructions. :slight_smile:
https://forum.armbian.com/topic/16582-video-new-at-armbian-build-your-own-armbian-image-on-your-arm-sbc/
balbes150 Posted at 12/25/2020 14:41
This video guide shows you how to build your own version of Armbian directly on your P1 M1 (or other …
You already shared my video :slight_smile:
Thank you.
The article provided me with so much to ponder. The DY0-001 valid exam questions pdf exam helped me climb the career ladder and increase my salary, and today, I’m offering it to you for free!
This article gave me new perspectives, thank you for sharing! I used the Valid study PostgreSQL-Essentials questions pdf to get promoted and get a pay raise. Now it’s free to all. I hope you all get promoted soon!
IBM인증C1000-166시험을 패스하여 자격증을 취득한다면 여러분의 미래에 많은 도움이 될 것입니다.IBM인증C1000-166시험자격증은 it업계에서도 아주 인지도가 높고 또한 알아주는 시험이며 자격증 하나로도 취직은 문제없다고 볼만큼 가치가 있는 자격증이죠.IBM인증C1000-166시험은 여러분이 it지식테스트시험입니다.
