Hello
How to install Google App for rk3399?
android 7.12
Install Google Play Store on Android 8.1.0
After trying all sorts of methods to get google play store on ROC-RK3399-PC, I finally found a method that works!
Required: Working ADB
Download playstore files for Android 8.1.0 and Device_ID.apk from here: https://mega.nz/#F!AQFWHQRb!CtZaS3cU0PCzTELrHZRrUg
Tested on this image: sd_ROC-RK3399-PC_Android8.1.0_DEFAULT_181025.img
On ROC-RK3399-PC, launch Settings → System → About tablet
Tab on Build number 7 times to activate Developer mode
Settings → System → Developer options
Turn on Root access for ADB
Turn on USB debugging
Turn on ADB over network (Note the IP)
On your PC with working ADB, extract the contents of the playstore_files.zip into a directory
Save Device_ID.apk into the same directory
Open a shell with root/admin privileges
adb connect
adb root
adb connect
adb remount
adb push playstore.apk /system/priv-app/
adb push playservices.apk /system/priv-app/
adb push gsf.apk /system/priv-app/
adb install -r gsf.apk
adb install -r playservices.apk
adb install -r playstore.apk
adb install Device_ID.apk
adb push libAppDataSearch.so /system/lib/
adb push libconscrypt_gmscore_jni.so /system/lib/
adb push libgcastv2_base.so /system/lib/
adb push libgcastv2_support.so /system/lib/
adb push libgmscore.so /system/lib/
adb push libgoogle-ocrclient-v3.so /system/lib/
adb push libjgcastservice.so /system/lib/
adb push libjingle_peerconnection_so.so /system/lib/
adb push libleveldbjni.so /system/lib/
adb push libnative.so /system/lib/
adb push libsslwrapper_jni.so /system/lib/
adb push libvcdiffjni.so /system/lib/
adb push libwearable-selector.so /system/lib/
adb push libWhisper.so /system/lib/
Reboot ROC-RK3399-PC
Launch Settings → Apps and give all the permissions to the 3 apks we installed
Reconnect via ADB again and enter the commands below to prevent occasional Google Play Services errors:
adb shell
pm grant com.google.android.gms android.permission.ACCESS_COARSE_LOCATION
pm grant com.google.android.gms android.permission.ACCESS_FINE_LOCATION
Reboot ROC-RK3399-PC again
Launch Device ID and note the GSF ID
Log into https://www.google.com/android/uncertified/ and register the GSF ID to your account
Turn off Root access for ADB
Turn off ADB over network
Turn off USB debugging
It is not perfect… some apps will launch sideways and I still get pesky uncertified warnings even after I registered the GSF ID. Also GSF ID changes every time you flash and reinstall again so be sure to register every time. At least I could log into Play Store and download purchased apps. Hope this helps!
Checked on Firefly-RK3399 and ROC-RK3399-PC.
You could also consider the alternative : microg.org
AI chatbots and virtual assistants can provide students with help anytime, anywhere. These tools can answer common questions, explain difficult concepts, and even guide students through assignments. learn more at coinfoundation.com
The [b]CRT-251 Questions and Answers[/b] encompasses a broad range of technical domains, from system configuration and management to advanced troubleshooting and security implementation. Navigating this extensive curriculum requires a focused study methodology. TestsFile addresses this need with precision-crafted practice tests that are meticulously aligned with official exam objectives. This targeted approach ensures your preparation efforts remain concentrated on the most critical and high-yield topics, enabling an efficient study process that maximizes both conceptual understanding and practical application skills.
Your article was so impactful, thank you for sharing it. D-VXR-DY-23 new study guide free download content is exceptional, and you can enjoy it for free.
This article is truly an outstanding work, and I’ve benefited greatly from it. Sharing AD0-E137 reliable test forum materials for free—good luck on your exams!
Your article was truly eye-catching and impressive, thank you! Thanks to the Llatest exam collection HPE6-A86 sheet, I got promoted and received a salary raise. Now, I’m offering it for free. Wishing you all success in your careers!
Your article was truly enlightening and refreshing, thank you! Free access to 350-901 valid test sims materials—good luck!
Thank you for sharing this article, it’s incredibly motivating! Best of luck with your exam preparations! Valid L5M9 test voucher questions available for free!
Such a remarkable article, thank you for your generosity in sharing! The Latest ISO-45001-Lead-Auditor test labs content is highly informative, and it’s offered at no cost.
