OpenWrt on ROC-RK3328-CC (aka Renegade)
Hi everyone.
With the help from the OpenWrt community members I have managed to build a working OpenWrt image for this board.
You may get the code from https://github.com/AbraxasDMG/openwrt-roc-cc 4. You may find initial bootable image as well.
There are some things to fine tune but there is also one immediately visible problem. Ethernet adapter reaches only around 200Mbps speed. Could someone confirm if this was a known problem that got solved in some Linux distribution? I’d like to try and learn from other’s experience how to overcome it on OpenWrt.
Thanks in advance.
Cheers!
That article was nothing less than inspiring. Reliable C_ARCIG_2508 exam cost provides valuable content at no cost to you.
I appreciate this thought-provoking article, thank you for sharing! CCAS valid test topics helped me secure a promotion and salary boost, and today, I’m making it available for free!
1z0-809スタディガイドは無料のトライアルサービスを提供するため、スタディの内容、トピック、購入前にソフトウェアを最大限に活用する方法についての情報を入手できます。どのような1z0-809テスト準備が適切であるかを選択し、不必要な無駄を避けるために適切な選択をするのにOracle良い方法です。また、1z0-809練習用トレントまたはトレイルプロセスの購入で問題が発生した場合は、すぐにご連絡いただければ、専門家がオンラインでお手伝いいたします。
The content is incredible, I don’t even have to think before liking it. I’m offering free New Professional-Data-Engineer practice test fee exam materials. Good luck to everyone!
Such a brilliant article, thank you for sharing this gem with us. Free C-THR70-2505 test lab questions exam questions to help you prepare. Best wishes for success!
EMC인증 D-AV-DY-23시험을 패스하여 자격증을 취득하여 승진이나 이직을 꿈구고 있는 분이신가요? 이 글을 읽게 된다면EMC인증 D-AV-DY-23시험패스를 위해 공부자료를 마련하고 싶은 마음이 크다는것을 알고 있어 시장에서 가장 저렴하고 가장 최신버전의 EMC인증 D-AV-DY-23덤프자료를 강추해드립니다. 높은 시험패스율을 자랑하고 있는EMC인증 D-AV-DY-23덤프는 여러분이 승진으로 향해 달리는 길에 날개를 펼쳐드립니다.자격증을 하루 빨리 취득하여 승진꿈을 이루세요.
The article is full of inspiration, thank you for sharing it! The New APP MCE-Con-201 simulations exam questions are your pathway to career advancement—now available for free!
