Hi,
We are using Face-RK3399 board with linux. We want to integrate SV-TAYSH-TQ binocular camera module with Face-RK3399. The linux-SDK is having drivers for it in built. When we try to test the camera modue we are getting error. below is the output from the device
root@firefly:/home/firefly/rkisp-v4l2# sudo media-ctl -d /dev/media0 -p
Media controller API version 0.1.0
Media device information
driver rkisp1
model rkisp1
serial
bus info
hw revision 0x0
driver version 0.0.0
Device topology
entity 1: rkisp1-isp-subdev (4 pads, 6 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
[fmt:SBGGR10_1X10/800x600 field:none
crop.bounds:(0,0)/800x600
crop:(0,0)/800x600]
← “rkisp1_dmapath”:0
← “rockchip-mipi-dphy-rx”:1 [ENABLED]
pad1: Sink
← “rkisp1-input-params”:0 [ENABLED]
pad2: Source
[fmt:YUYV8_2X8/800x600 field:none
crop:(0,0)/800x600]
→ “rkisp1_selfpath”:0 [ENABLED]
→ “rkisp1_mainpath”:0 [ENABLED]
pad3: Source
→ “rkisp1-statistics”:0 [ENABLED] -
entity 2: rkisp1_mainpath (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
← “rkisp1-isp-subdev”:2 [ENABLED] -
entity 3: rkisp1_selfpath (1 pad, 1 link)
device node name /dev/video1
pad0: Sink
entity 4: rkisp1_dmapath (1 pad, 1 link)
device node name /dev/video2
pad0: Source
→ “rkisp1-isp-subdev”:0 -
entity 5: rkisp1-statistics (1 pad, 1 link)
device node name /dev/video3
pad0: Sink
← “rkisp1-isp-subdev”:3 [ENABLED] -
entity 6: rkisp1-input-params (1 pad, 1 link)
device node name /dev/video4
pad0: Source
→ “rkisp1-isp-subdev”:1 [ENABLED] -
entity 7: rockchip-mipi-dphy-rx (2 pads, 1 link)
device node name /dev/v4l-subdev1
pad0: Sink
pad1: Source
→ “rkisp1-isp-subdev”:0 [ENABLED]
root@firefly:/home/firefly/rkisp-v4l2# sudo media-ctl -d /dev/media1 -p
driver rkisp1
model rkisp1
serial
bus info
hw revision 0x0
Device topology
device node name /dev/v4l-subdev2
pad0: Sink
crop:(0,0)/800x600]
pad1: Sink
pad2: Source
crop:(0,0)/800x600]
pad3: Source
device node name /dev/video5
pad0: Sink
device node name /dev/video6
pad0: Sink
device node name /dev/video7
pad0: Source
device node name /dev/video8
pad0: Sink
device node name /dev/video9
pad0: Source
device node name /dev/v4l-subdev3
pad0: Sink
pad1: Source
