Recover (update) whole emmc
Hello and merry festives to all,
Unfortunately I have done a mistake by using the command given at the end of this other tutorial :
sudo dd if=/storage/SDCARD/update.img of=/dev/block/mmblck0 bs=16384 conv=sync,fsync
Using the GMS-Firefly-RK3399_Android7.1.2_MP_181016.7z img provided somewhere else on the forum.
It seems that if I would have simply used mmblck0p10 this would have worked correctly…
http://opensource.rock-chips.com/wiki_Partitions#Default_storage_map
http://wiki.t-firefly.com/en/Firefly-RK3399/compile_android7.1_firmware.html#flash-partition-image
http://wiki.t-firefly.com/en/Firefly-RK3399/customize_android_firmware.html#unpack
http://wiki.t-firefly.com/en/Firefly-RK3399/buildroot_compile.html#directory-structure
http://wiki.t-firefly.com/en/Firefly-RK3399/03-upgrade_firmware.html#id3
I figure out one of these links must explain the correct procedure to correctly update the whole emmc from maskrom mode, but WHICH ONE ??? That’s where I need help…
Also, I got this error when trying to upgrade with the USB-c cable :
Creating Comm Object failed!
This is a udev error ? I hope it will disappear by installing the correct libraries/packages.
Currently I have installed Xubuntu 20.04.2 LTS in order to follow the indications more easily.
OK, I think this is the link I need to follow to recover the default emmc :
http://wiki.t-firefly.com/en/Fir … ustry_firmware.html
Download this (zip folder) :
https://drive.google.com/drive/f … wrwoEplQqWc5pap_YzC
And either of these :
https://gitlab.com/TeeFirefly/rk3399-nougat-bundle
https://gitlab.com/TeeFirefly/rk3399-industry-nougat-bundle
Perhaps use this repository for standard tools :
https://gitlab.com/TeeFirefly/FireNow-Nougat
I’ll update this message/thread as I progress further.
Oh, and this is to get Ubuntu on the board :
http://wiki.t-firefly.com/en/Firefly-RK3399/ubuntu_manual.html
Although I would like to try other, less common systems too…
OK, I managed to recover from the situation using bUBUNTU 20.04 LTS[/b].
I followed the explanation on how to install Firefly’s maintenance industry version of Android and used the update.img dated with 2018-10-16 I think.
First, add this as an udev rule in /etc/udev/rules/51-android.rules :
SUBSYSTEM=="usb", ATTR{idVendor}=="2207", MODE="0666"
Then using the Linux_Upgrade_Tool v 1.2 (not 1.24) worked fine with :
sudo upgrade_tool update.img
Your update.img file needs to be in the same folder.
I don’t think it was actually a requirement, but here are the two apt install sequences I did for a list up-to-date with 20.04 as in “compile the environment to build” :
#1 as per http://wiki.t-firefly.com/en/Fir … ompile_android.html
sudo apt install git-core gnupg flex bison gperf libsdl1.2-dev libwxgtk3.0-gtk3-dev squashfs-tools build-essential zip curl libncurses5-dev zlib1g-dev pngcrush schedtool libxml2 libxml2-utils xsltproc lzop libc6-dev schedtool g++-multilib lib32z1-dev lib32ncurses5-dev lib32readline-dev gcc-multilib libswitch-perl libssl1.1 libssl-dev
You will also need https://packages.debian.org/stable-backports/source/repo (doesn’t exist in 20.04, back in 20.10)
#2 as per http://wiki.t-firefly.com/en/Fir … ilation-environment
sudo apt install expect-dev git-core gitk git-gui gcc-arm-linux-gnueabihf u-boot-tools device-tree-compiler gcc-aarch64-linux-gnu mtools parted libudev-dev libusb-1.0-0-dev linaro-boot-utils autoconf autotools-dev libsigsegv2 m4 intltool libdrm-dev curl sed make binutils build-essential gcc g++ bash patch gzip bzip2 perl tar cpio python unzip rsync file bc wget libncurses5 qtbase5-dev libglib2.0-dev libgtk2.0-dev libglade2-dev cvs git mercurial rsync openssh-client subversion asciidoc w3m dblatex graphviz python3-matplotlib libc6:i386 libssl-dev texinfo liblz4-tool genext2fs lib32stdc++6 expect
If any packages were still missing I retrieved them from : https://packages.ubuntu.com/
Now I have an Android system that works (and with Google Play) except that I can’t access the “settings” menu of many apps (the three vertical-aligned little dots don’t appear …)
Anyway, on to try more exotic configurations, starting with Ubuntu.
Find your signature scent with ECS’s captivating perfume for men. Explore bold to refined fragrances to match your style. Shop now!
Elevate your NetSuite experience with Cloud Nexus Lab’s expert customer support. Our dedicated team ensures seamless integration and personalized assistance, empowering businesses to maximize efficiency. Trust us to handle your NetSuite needs, providing solutions tailored to your unique requirements. Discover unparalleled support today with Cloud Nexus Lab!
Experience the fusion of tradition and luxury with Mushq Official’s velvet dresses Pakistani. Explore intricate embroideries and cultural motifs in plush velvet fabrics.
Discover the latest trends in ready to wear wedding dresses UK from Qamaash. Shop Pakistani ready-to-wear fashion in the UK and elevate your style effortlessly.
Perfect for a variety of occasions, our chiffon suits at Afrozeh boast timeless elegance and versatility. Whether adorned with intricate embroidery or featuring minimalist designs, each suit is a testament to the craftsmanship that defines our collection.
Shop Roheenaz’s winter unstitched fabrics to create your perfect winter outfit. Pick your favorite fabrics and designs to express your personal style this season while staying warm!
Elevate your wardrobe with Mushq Official’s exquisite chiffon dress design. Each piece is crafted to perfection, offering a blend of femininity and sophistication.
Explore the latest dress design for women in Pakistan from Mushq Official. Check out our handpicked selection of stylish and trendy outfits, including both traditional and modern styles. Find the perfect outfit to upgrade your wardrobe.
Are you looking for best pumps shoes in pakistan Online? Essence Offer their costumer best pump shoes for women that are best in quality and Comfort. Shop Now!
Your article really caught my attention, thank you for sharing it. About to face the PR2F Latest version exam. Wish me all the best!
This article is absolutely marvelous, thank you for sharing it with us. Free Latest study guide Digital-Forensics-in-Cybersecurity ppt resources are available here—good luck!
This article is simply breathtaking, thank you for sharing it with us! New Media-Cloud-Consultant dumps sheet offers a broad range of material free of charge, hoping it supports you.
This article is truly a valuable source of knowledge, and I’ve benefited a lot. Wishing you all the best of luck! Here’s the free Exam C-BCWME-2504 sims material.
